Conversion Vans
You could try price comparison with the '96 Ford Club Wagon. NADA shows whsle 12,800. and retail 14,700.
Jerry
I think $21,000 for a 97 seems a bit high, especially because if there is no extended warranty, you are on your own. We bought the extended warranty with a future sale in mind
Values of other conversion mfg's indicates a wholesale range of 38-41% and retail 51-54% of original msrp.
NADA mileage says 45-50k is average range.
Deduct 1,400. for hi miles.
You can make a comparison with Edmund's on the mileage. Might check your local "auto swapper" for prices on other 97 vans for sale.
Thanks ,
Tim
96 Chevy(new body style)
64K miles
Gladiator hi top - don't remember model designation but it is pretty loaded:
power driver seat and sofa
leather
exterior vista window air foil things
oiled walnut everywhere
TV/VCP/rear Stereo/cassette
nice thick carpeting
NADA has no info since 1990 model year.
Other '96 high-end conversions have wholesale values of about 35% of original msrp and retail is about 45%.
Jerry
Designer II whsle 5,060. retail 6,660.
Saphire whsle 4,500. retail 5,910.
Jerry
I now drive (21/2 years) a '97 Ford/Coachmen. I've been very pleased with this van.
The sofa in this van is manual rather than power and does require a fair amount of strength to operate. It seems quite possible that one could remove the handle that releases the seat from the upright position.
As for conversion packages, there are only three that I've seen (of the 97 conversion houses) that I regard as having a top quality product: Explorer, Tiara (their top end product) and Southern Comfort. I am not familiar with Rocky Ridge.
GO FOR THE DARK INTERIOR - With kids, especially twins, you are going to appreciate leather seating and darker colors; they don't show the inevitable stains like cloth and lighter colors.
As for the power sofa/bed: Yes, you can easily disconnect the power supply on the Explorer and on most (all?) power seats. There are two connections on the Safari/Explorer under the seat; they come out from the floor carpet. One is for fore/aft movement, the other is for raising and lowering the bed.
I have to agree to some extent about the plastic wood veneer. It is a little cheesy, but I recall the screwed-on chunks of millwork the older conversions vans had on the dash and doors. They look like crap after a couple of years in the sun. You refer to Southern cars that have wooden dashes; however, these were designed from the inside out to be used where they are, and many have laminations that include layers of steel to allow them to maintain their complex shapes and to avoid cracks, etc. Haven't investigated other options.
The only downside of these vans with twins is going to be getting them in and out; the convenience of a driver's side rear door on most mini-vans would be helpful.
Good luck in your quest.
Should you find one, I'd like to know.
Jerry
Some conversion mfg's refuse to release msrp or dealer invoice.
Hot sellers? Look about the traffic in your local area. How many conversions do you see relative to other motor vehicles? The van conversion division of Coachmen was just recently acquired by Glaval Corp. Just a guess, but I suspect that sales volume was a factor.
You might check classified ads in your area for asking prices on one and two year old vans. It might help in determining the amount you are willing to pay for a new van. Also, take a look at a new E-150 XLT Wagon and ask yourself, How much more or less should a conversion cost? Keep in mind that a conversion mfg. starts with an unfinished version of a cargo van/wagon.
dfdreamer
The lowest value Sherrod is the Quantum. whsle
2,100. retail 2,700. Add these numbers to the cargo van values found at Edmund's.
I don't know about the V6. I would think a good
test drive would be the best indicator
While I've owned three different GM vans in the past, none of them were of the recently redesigned version. As such, I can't give you any first hand feedback on the Savanna.
There are of course, major differences between a passenger car and a full size conversion van. I find myself frequently hauling stuff (no kids) and would find it difficult to go back to a passenger car. I might consider a mini-van. They drive more like a passenger car but you do give-up some interior space.
At the very least, I'd recommend a good shakedown test drive of the Savanna. Be sure to test drive at expressway speeds. Check for road and windnoise levels and general handling of the van. I don't know how big of an issue fuel efficiency is but, you should expect that full size vans will likely be the least fuel efficient. My 4.6L V8 averages about 15 mpg in warm weather and 14 mpg in cold weather.
Jerry
I was wondering if anyone knows of a resource on the web or a repair shop in New England that could help me with this one.
I would actually preffer to set the sofa/bed on manual and this way I'd be able to unfold it every time and not rely on a stupid electronic gadget.
Further indicate "no longer producing van or truck conversions". Last year listed is 1997.
Jerry
Check your local yellow pages under Van & Truck Conversions and also check to see if there is a separate mfg. label on the sofa. Might be able to contact them.
Jerry
mike
Are you sure the garage door cannot be raised? When the carpenters were building a house for me, I looked at the opening for the garage door and said it looked too low (based only on the appearance that I wanted), and that it needed to be raised by about 1 foot. They said no problem. The next time I went by to look at it, they had raised the opening by about a foot.
dlrouton@hiwaay.net
I'd guess because of age, the value would be similar to the Chevy oem passenger van. You might check Edmund's for value on it and also check local classified ads for similar vans for sale.
Jerry
thanks,
Jerry
Please email me at ohmygosh@worldnet.att.net. I don't mean to rush you all, but would really appreciate a quick response. I plan to drive this in the morning......
You can search for these topics by using the "Topic Search" feature on the left hand column of your screen. Simply type in "Dodge Caravan" and click on "Go".
Best of luck!
Drew/aling
Townhall Community Leader/Vans Conference
I'm looking about myself. I've seen a Sherrod that seems pretty nice and a Discovery as well.
May not be your cup of tea, but I understand the 2000 model year is the last for Jayco. You might find a good price on one of theirs. Sad to say, Coachmen got out of the auto conversion business earlier this year too. I've been very happy with the '97 I drive.
Ford may be getting into the conversion business in the 2001 model year. Don't know for sure.
Jerry
