Visitor Agreement.
Alland
I have been watching it also in my WRX, and it is also slowly going down also.
There is really not much coolant between the min and max marks.
Mike
Alland
Well, it seems to me that how likely you are to "skid off the road" would be at least partly dependent on what traction you have and hence dependent on how good your tires are.Obviously the system will need to account for reduced traction as tires wear too, so I would think the system may be set for a worst case scenario ie tires are close to wear limit etc. So would say a VDC with non stock high performance summer tires find the VDC system kicking in more often than it really needs to compared to a crummy stock all season tire?
However, all these actions occur split seconds after the tire maxes out on lateral grip. VDC then just keeps working until it achieves it's intended result. Naturally, better tires will allow VDC to work more effectively.
Ken
Ambient air temp/engine temp will affect level.
http://210.101.116.115/fisita/pdf/G347.pdf
I don't think it takes the tire into account, though it does try to estimate the road friction coefficient.
-juice
I was interested if any of the VDC owners compared this vehicle.
Based on base MSRP, they are in the same range, but I have not researched the IS300 enough to know if the base $31K includes the engine and such or if your just paying for Lexus status, then you have to buy the actual car as an option.
In some sense the VDC is a performance wagon - different than the SportX, but still performance oriented. I have seen some Lexus snobs bagging on the VDC as having less power, but I'm not sure there is really much difference between the H6 and whatever Lexus offers - I think they are confusing with the base outback.
whatdo you Subie people think
To be safe, I pump the brakes a few times before pulling out and this takes care of the problem.
Has anyone else had this problem?
The SportCross is probably a little smaller than a WRX wagon, though, and costs several grand more, while not being nearly as quick. And being RWD it wouldn't touch any Subie on snow or even in rain, especially when some models come with summer tires standard.
The interior is gimmicky, I hate the dials. Besides being a bit cramped, though, there's not much else to complain about. I'd compare it to an RSX-S and a WRX wagon, though.
Try the G35 if you want a near-luxury RWD import from Asia, those are much roomier.
-juice
But its quite clear, what I need is a Legacy GT with a 2.5T and VTD!
-juice
I love the comfort and my friends have been surprised at the room, but the handling has been disappointing even though I dumped the cheesy RWL Bridgestones (sloppy) for Dunlop SPs as soon as I got the car. And if they'd only turbo this engine....
Second, consider a sway bar upgrade. Maybe a whiteline adjustable sway bar would be the ticket, better yet a matching set front and rear. You get less sway at not cost in ride, so it's like a free lunch. Well, $120 or so, maybe.
You could get GT springs but you'd probably need different tires for those to fit properly, and you'd lose clearance.
You may be happier making do with the current car and then getting a Legacy turbo next year when those come out, in fact they might even arrive in the fall.
-juice
I have heard from ABS check, to steering, to other "nature of the car" solutions. Any advice is appreciated. Would like to get it to the dealer as early as possible if this is the necessary step. Thanks.
-Brian
Any idea whether this security upgrade kit option is worth getting? Thanks.
the dimming mirror is really useful, no blinding glare at nights from the headlights of the car behind you
I'm planning to get my '02 VDC wagon in for both recalls that I saw here in Edmunds. Minor question. In the long run, is it better to keep it getting serviced at the dealer from which I purchased the car? There is another Soob dealer that is much closer to me that I would rather take to, for time and such, if there is no big benefit of hauling my car the extra 40 minutes.
On a side note, here in South Jersey there has been one snow storm and am looking forward for the projected 2 for this weekend.
-juice
My girlfriend accidentally spill about 1/2 gallon of water in the rear seat floor.
Unfortunately, she was on the freeway and could not immediately stop and fix the spill.
Anyway, to my dismay, I noticed that the seat floor she spilled the water is behind the power amplifier (which is underneath the front passenger seat).
My question is:
Is the amplifier sealed off adequately to deter water damage?
There is sound coming out of the speakers...is it safe to say that water has not caused any short circuits?
What's the best, most complete way of cleaning this up?
For the wet carpet, do you have one of those wet vacs? If so first thing I'd do is vaccum out the excess water.
Then, if it's dry were you are, let it air out. I'd even consider hooking up a dehumidifier if you have one.
If it smells, you can later sprinkle in some baking soda and vacuum it out. Good luck.
-juice
I second Juice's suggestion of hooking up a dehumidifier.
-Dave
-mike
Ralph
Is this true? Words of wisdom/advise from Subaru owners are welcome here.
I once owned three of them...
But my Subaru, now with 24,000 miles, is wonderfully dry without any signs of oil leaks. I expect it to continue this way.
Others here will also venture their opinions and experiences.
Steve
-juice
I just wanted to stop by and say hi........I'm looking forward to chatting with you all.
Hugs,
Julie
Congrats on being part of the quarter million mile club. iSR Subaru has one, with plenty of pics to prove it.
-juice
Revka
Hatchbacks & Wagons Boards
Also, I have not been notified of any recalls, via mail or MySubaru.com. Is there a place on Edmunds for recalls?
Thanks, Dan
Brought my 02 VDC wagon for an oil change and the recalls seen here to another dealership (name it Dealer 2 cause not where I purchased the car in Jan 03). This Dealer 2 says that the recall has already been done. And that it was done by the selling dealer. Surprised me because it has been indicated that it has not been done via mysubaru.com. Called the selling dealer, and they said that in fact, no, it has not been done, and that I should bring it in to get it done.
What?
Possible that selling dealer forgot to put it in the database after they have done it?
How then did the info that it has been done there already? Maybe another dealer prior to selling dealer?
Are they looking at different databases?
Is there any way to eyeball this and figured if it was done or not?
Of course ask them to document it this time. And I'd consider starting to use that other dealer!
-juice
Greg
Mike
-juice
I think they're ironing out the details now and will have a decision in about a month, in time for the NY Auto Show.
Having said that, if we get a new one only in MY2005, then I expect the 2004 will be largely a carryover, with perhaps a couple of very minor items added as standard. Maybe a new color or two.
-juice
So it's a definite possibility, it's just a matter of can they build it in time for the fall, and get it ready to show in late April at New York.
-juice
Note: This all-new Legacy reportedly will be introduced in Japan this May.
Bob
But... I would really like to add the ability to play MP3's, either by CD-RW data discs or with a hard drive/memory system.
My question is has anybody done or tried to do anything like this on the VDC (which obviously came with the McIntosh system)? Are there any suggestions as to how to do this? Can anybody tell me what the back of the McIntosh unit looks like and are there any inputs if I were able to output say from a laptop that had MP3's on it (i.e. AUX input)?
How does one remove the unit from the car properly to look into this? (pictures and detailed instructions welcome encouraged)
Would it be possible to piggyback onto the amp and simply install a second radio that played MP3's and use that output from that as input to the amp along with the McIntosh and simply use one at a time?
Obviously one solution is to FM Modulate the signal and listen to them via the McIntosh radio, but the quality of that would not be accecptable.
Any and all suggestions, etc. are welcomed and encouraged. BTW, is it possible to add on a multi-disk remotely mounted CD player? If so, maybe this unit would be able to play MP3 discs. Any thoughts or progress on this?
I have phones both Subaru and McIntosh Labs and both point to the other and I get no help, even on removing the stereo to inspect.
Thanks - Caleb
