Ford Aerostar
Steve
I have a '91 Aero sport with 90k miles. Its run well and is practically a new van.
But it has this steering wheel shimmy from 50 mph up and intensifies through 75+. The only thing not replaced so far is the ball joints and tie rod ends.
Have any one out there had a similiar problem? My dealer says everything is OK. Yea, right. Let him put his kids in there.
Any input appreciated.
I started with the rubber and made sure it was balanced, eventually had to replace the rotors, bearings, balance, alignment. I had the dealer check the ball joints and arms to "OK" but i still suspect its either them or the rack itself.
Only problem is they just had to put in the 4th alternator after it caught fire. ther is a 12/12 warrrantee on Ford parts but with 10 months/14K on this alternator they refused right up to Dearborn to assist with replacement despite a TSB and a dozen NHTSA reports of exactly this fire hazard.
POINT: Nice van, but it's discontinued, out of warrantee, and Ford won't back you up. I love my Aerostar depsite all the other work. But like like a family dog, once it bites your little girls face, better get rid of it. And this possible van is beginning to growl.
I'm looking for a 2000+ Odyssea replacement.
Have a nice day!
http://www.hwysafety.org/vehicle_ratings/ce/html/96023.htm
Drew
I experienced a steady water leak at the top of my window located behind the driver's seat.
After inspection from the outside of the vehicle, I noticed the plastic window frame of the side, sliding window had lifted away at the top from the metal leaving a space.
I filled this space all along the top of the window from the outside with clear windshield sealer. (clear silicone sealer can be used also, available at your hardware store). This stopped the leak.
If leaking still persists, I would check your roof rack where it is attached to the roof.
- Since 1992 this vehicle has had these problems:
- All engine gaskets were changed under warranty.
- Chronic brake problems, rear calipers, emergency brake not releasing.
- Leaks at windows.
- Outside door handles and inside window power controls constantly breaking.
- Heater/defroster/airconditioning needs constant repair.
- Balanced driveshaft goes out of balance, needs replacement.
- The Aerostar has no weight at the back of the vehicle and can be very dangerous to drive in slippery and snowy conditions.
- Trade-in value of Aerostar is pathetic so you are forced to keep driving the vehicle.
- Engine lights, brake lights flash on & off, gas guage swings back & forth. It's like having an Arcade Game built in your dash.
- Yes, the 3.0 litre engine has been dependable (after changing all gaskets} and the bucket seats are comfortable.
- If you want to be on the 1st name basis with your mechanic buy an Aerostar.
I'm looking at about $400. Any reccomendations for service? I live in Atlanta.
TIA (Thanks in Advance).
I'm not sure how many miles she has racked up, but it must be well over 60,000 - its her daily driver - and she has not had one problem. Zero. Zilch. Original brakes, belts, hoses, exhaust - everything. It has been a perfect vehicle. And despite its dated styling, it still looks like a new vehicle. She must have found a real peach.
I gave the guy $20.
Needless to say I won't be going back to the location that misdiagnosed the problem, if they don't know the difference between Power Steering fluid and oil.
Watch 'em my friend. They''l keep you sharp.
I had the gasket changed. I got tired of putting in a quart every 2 - 3 days.
This guy at work seems to think that the place I got my oil changed at messed around with the gasket to make it appear there was a problem (pulled it out to make it leak). I can't prove anything but it is a bit suspicious that it started leaking after I got my oil changed.
Any thoughts, since I had it fixed?
thank you
Joe
One BIG problem happened a while ago when the driver side front axle fell off at the inboard CV joint. The axle flange is held to the CVJ by 5 special bolts with lock nuts. Not one nut was left, the bolts were intact and still on. Were they even bolted when I got it? I don't know. Either way, it was a snap to repair.
We just had the van serviced w/ new serp belt and front brakes, oil change, etc. We then drove 800 miles over the Colorado mountains with no problems. I can't say enough about the 4.0L engine for powering through the passes. We averaged 20 mis to the gallon.
I can see most everybody on this discussion board is bummed w/ AC. Mine is shot too. I think the brakes are a little weak also.
My questions: A short time after I got the van I wanted to deal with the surging problem at idle. I ended up replacing the oxygen sensor, intake manifold gasket, and got new plugs and wires. Amazingly I got 29mpg shortly after this tune up (no my calculations were not off, I have a science degree). Anybody else record this kind of mileage? I was informed by Ford about 20,000 miles later that my intake manifold gasket was leaking again. Are there any Ford service write ups about the intake manifold that they are not telling us about? Anyway my rpm surging at idle has returned and the check engine light comes on at strange times (only high speed on the highway).
Anyway I bought the van for about $7,500.00 when they were selling locally between $10-11K. Now the resale value on the TMV page is down to about $1800.00. That's hardly justice to this vehicle.
I am seriously considering keeping it now. Maybe like VW's bug they will be forced to bring this one back.
24+ MPH with CC on long freeway trip. Use severe maint. schedule. Tires will go to 60K?. Have done nothing to it other then the book maint. instructions. Being tall, older, and with arthritis, I can drive on CC all day and not have any discomfort. Love the room to haul anything I have ever wanted to haul on a trip or a new washer, 4x8 sheet of plywood, etc. Wife hates to drive it. Will probably keep it and fixed it and paint if necessary until the end of my driving days. Happy owner.
Wish they still made them. definitely a veheicle for tall people. Only vehicle that long trips didn't tire me out.
This is a former RCMP vehicle, well maintained with 150,000 km on it.
Is there anything anyone can offer here about a 93 Aerostar? Thanks
These vans are tough, I have my 94 Aerostar with the standard 3.0 Liter V6, automatic transmission. She has 133,000 miles with all original parts. I have changed all the filters on a regular basis and plan on driving it til she drops. Too bad they don't make these girls anymore! Not bad fuel economy either for a baby V6 - plus, I have heard horror stories about Dodge and Plymouth Caravans where they self-destruct at 100,000 miles - transmission/engine issues.
Lovin the beast in NH!
I am a newbie to this message board.
I own a 1993 Ford Aerostar 4.0L V6 AWD.
It runs fine except when going up hills if the
outside temp is above about 65F. Depending on
the steepness and length of the hill the engine
temp will get steadily hotter eventually to the point when it will overheat (I have not allowed this to happen so far).
I have changed all of the fluids, and flushed out the cooling system and installed new coolant.
It is strange as the engine temp is fine on the flat, even on really hot days. So I am assuming that it is the extra load the engine is under going uphill. Surely this should not happen unless the van is fully loaded and the external temp is really hot?
Any help would be most appreciated as I really like the van and it is otherwise mechanically sound.
Mark.
Oh yes, and like the other posts; my A/C had been history for the past 4 yrs. It didn't bother me tho' - I don't find much of a need for it unless it's like near 90-degrees and it's terribly humid.
Good luck to all of those who still have theirs. Let's face it, though - every make of automobile will have its lemons.
Shortly after we took it home I had to return it because it was missing, leaking radiator and pinion seal was blown. All that was covered under warrantee. Except now the pinion seal is blown again so that will need to be fixed at my cost.
All in all it hasn't been a bad vehicle but it is difficult to work on - no space in the engine compartment! Mine has the 3.0L V6 so it has a little more room than the ones with the 4.0L but it is still tight quarters. We took a vacation to New Orleans and back through Georgia to Virginia (home) and then on to western Pa. without major problems. I was disappointed with my gas mileage. Carrying family of six with the a/c on, luggage on roof and averaging 70 mph I averaged just over 17 mpg hwy. I thought I'd at least get 21-22 mpg. Any thoughts? I've sinced changed plugs (using platinum Autolites), and changed sparkplug wires. Before and after the trip my wife averages about 19-20 mpg combined city/hwy. It now has over 159k miles. I like it because it hauls all 6 of us with no problems - however the quality has been less than I expected. Simply been in the shop a bit more than I like.
I am wondering, is it possible to swap out the middle 2seater bench and replace it with the high back captains chairs? Would be much nicer on an upcoming long summer trip.
Any info would be much appreciated.
You may try a container of Techron fuel injector cleaner, to help clean up your valves...
And about the oxygenated fuels - they only use it in the winter correct? So that shouldn't have been an issue. I remember getting fuel at Texaco (a truck stop in Alabama) and other convenience store type places. In fact at the Texaco I remember getting mid-grade fuel (91 octane) and not the regular 87 octane. Didn't seem to make a difference.
I just changed the oil/filter at 162k miles. Everything is good to go for another 5k miles.
Also the sliding door latch needs replacing. The spring that holds the top "hook" up when the door is open has broken and to close the door one has to make sure the hook is "up" before sliding the door closed. I haven't checked with our local mechanic as to cost. Any thoughts? TIA.
Other than this we love the van, the size, power, comfort and pretty good handling for a truck.
repaired at a Midas Muffler shop that advertised Air work in the news paper.
The 93 used the old type of refrigerant that's been outlawed. So when the diagnosis
said the compressor was bad they replaced compressor,accumulator,and coil to
accommodate the new refrigerant. We think they did their job right.
However it cools great sitting still or going 30 mph but when you accelerate
or clime a hill or drive over 55 mph the air shuts off till the engine is no longer
in a strain then it comes back on. does anyone have any suggestions as to
what the problem might be?
Calvin
If your car does this whenever you open the throttle even briefly, then something is wrong with the vacuum accumulator system: either an air leak somewhere (bad vacuum hose), or perhaps a bad one-way valve. Our Aerostar does it on long climbs, where long means maybe a minute or longer; anything under that time it does not happen. Any sustained load makes it happen, so for example a long pull in D4 with a heavy trailer will do it.
Almost every car we've ever owned would do it on long mountain stretches, though the more powerful the car, the less it happened, since the engine wasn't pulling as hard on a given stretch. BTW, a downshift to D3 or even to second on really hard pulls would often spin the engine up just enough to restore vacuum, and the a/c would cool again.
Hope this helps!
There is one thing however, I have been noticing the last couple of months. When I drive over rough road sections, such as railway crossings, I get a loud rattling and thumping noise. I have had the front end checked out by two reputable service centers and they claim everything is fine. There is nothing to indicate that the shocks may be bad as they seem to work fine, no front end diving or bouncing. The steering also appears to be tight, as there is no excessive steering wheel movement or wandering on the road. Any thoughts by anyone would be appreciated. I would like to fix this annoying noise as we plan to keep the van on the road for some time yet.
BTW, Consumer Reports pans Aerostars for reliability, but ours has been excellent. The only repairs (other than normal maintenance) have been two sets of front brake rotors and pads, shocks, and a thermostat. And an annoying switch in the tailgate that kept telling us the tailgate was open when it wasn't. I finally cut the wire rather than spend money on an annoyance.
All else is original: a/c, steering, auto trans, engine, etc., etc. Paint is still excellent. And NO rust anywhere. The van has done yeoman's service, pulling a 2800-lb boat trailer and occasionally a very large U-Haul trailer (4500 lbs?). And I once carried 1700 lbs of building materials inside for a project at home....
I was just driving our '94 Aerostar and while passing over a set of railway tracks the front wheel centers rattled very loudly.
Just a thought.
