Visitor Agreement.
I read in a reply to the original post that a person bought a new switch and replaced it for a window that got stuck. Hopefully someone can suggest a resolution for my driver side window getting stuck half way on its way up.
Thanks in advance!
Thanks in advance for your suggestions and or solution to this problem.
I have owned an 87 Firebird (had to be repainted when new), 92 Cougar (brakes kept glazing over...3 sets in 40k miles), an 03 Venture (rear brake cylinders were leaking and both replaced this week...36,571 miles), and 04 Ram (6,000 miles on it and the ECM had to be reset, rear discs replaced due to warping).....
Contrast that to my 89 Accord (flawless, I actually traded this in on a patriotic move when I bought my 92 Cougar...go figure) 92 Camry (112,500 flawless miles on it)....99 Camry....flawless, (69,000 miles on it and the front brakes, tires and routine maintenance have been performed....I will keep this thing until it croaks or the kids wreck it...)
So its American Cars: 0-2-2 vs. [non-permissible content removed] 3-0.......next time I need a passenger vehicle or hear an American autoworker is going to lose his/her job, I am going to RUN to the nearest Toyota or Honda dealership and buy one or two more to make absolutely, positively sure one or two more workers get knocked out at the "plant"....
1. Check your light ALL of your tail lights or turn signal bulbs. They will cause fast blinks and slow blinks and dimming on the side where the bulb is burnt out. Make sure the bulb isn’t partly burnt out. The tail lights have a high and low setting, if one or the other is burnt out this can cause the problem as well. You might even check for corrosion at the base of the light bulb where it plugs into the light bulb mount. If that doesn’t work or if you have corrosion in the bulb mount follow the rest of the instructions. this will solve that issue as well.
2. Remove the tail light and detach the wire harness assembly from the actual tail light lens.
3. Detach the positive battery cable. (this is a pain on the Venture)
4. About 6 inches from the male wire connection use a wire cuter and snip the connection. (I think it was a total of 5 or 6 wires)
5. I previously went to a junk yard and found a wire harness assembly with no corrosion or burning, on the bulb plug ins, male side, female side of the wire harness and the actual light bulb plug in mount. Make sure that you have NO corrosion on either side of the plug in. This ran me only about 10 bucks and being that the Venture was common in my neck of the woods I have plenty to pick from.
6. It’s best if you get corresponding wire harness to your problem. i.e. right side if it is right side This is not necessary but it is recommended. The wire coloring is one wire off.
7. Strip all wires one quarter of an inch on the cut sides.
8. Use a standard wire connector or crimping tube to attach the wires to the corresponding wire on the vehicle. Green to green yellow to yellow you know the drill.
9. Wrap the new connections in electrical tape or shrink tube. This will help to prevent a reoccurrence or similar issues from happening.
10. Reinstall the wire harness, bulb assembly and tail light.
11. Check your fuses. I found that the venture has an odd tendency to pop fuses when any electrical issues happen.
12. Reattach your battery cable.
13. You may have to drive long enough for the ABS computer to reset or run a few cycles. I drove mine for about 15 minutes before the computer reset.
Let me know if that works for you. I took this to several places that said in no way shape or form should the ABS light come on because a tail light short. They where wrong! I did this last month and I have had no issues since.
Within a week all the dials start repeating their last performance and I go directly to the battery, it's fine. I continue driving it for two months and the dings occur occasionally. Finally it is dead outside the post office. I go and shake the battery but not even a hum or click. Dealer says it was a loose starter connection.
Wow, glad we figured that one out! Now less than two weeks from the last trip to the dealer and the same bell dings and all guages dropping off! Yellow security light stays lit up as long as I run it. When I restart it the yellow security light goes off..... any comments or similar problems out there?
Hope this helps.
I am glad to see other folks have the same problem. My husband thought that it was because I spilled something on the switch. Thanks for your help!
:mad:
:mad:
It's long legged gearing was ideal and registered 29mpg on the read out which is really about 27mpg even with the air condioner going. Nevertheless we traveled in comfort and this van eats up the miles. Next week it will get its first set of spark plugs.
With so many criticisms posted on this site, this van is not all bad.
If it is like mine and the engine starts and idles fine, it is not likely going to be electrical or timing. It is possible that it is in the the fuel system. Apparently GM used some hoses that were inadequate and sometimes collapse. Could also be the computer that controls the transmission. I will let you know when out for sure.
Please respond
Here is the website: http://www-odi.nhtsa.dot.gov/?CFID=1372897&CFTOKEN=38236678
Copy and paste the address and file your own complaint. Maybe there is a light at the end of the tunnel!
It took 2 hours to change, not bad for never doing it before. A few hints disconnect all the wiring & dont forget speaker wire and tie out of the way, also disconnect the door inner open handle (just clipped in) and tie handle and rods up out of the way. The whole black frame comes out as a unit. Window is heavy a second person might help. Mark the gear on the motor and watch your fingers when you disconnect the motor.
GM now sells the sensor and float separate from the fuel pump now, significantly cutting down costs. The Venture has one of the easiest tanks to free and lower, incidentally.
The Venture is so $%%^@& hard to change, do yourself a favor!
I went a few rounds with the dealer and GM and right now they aint payin' for squat. I need to write a few letters and such but I don't think I'm going to get too far. Sad part is we really liked the van and it was pretty much trouble free until it hit the three year mark - now it's falling apart. So for the first time in my life I visited the Japanese car maker sights and... I liked what I saw! Sionara GM! I'm willing to bet that even if the vehicles are no better I'll at least get treated better!
You'd think that after buying 12 GM vehicles in about 15 years they'd throw me a bone or something - nope!
(please forgive me if this has been discussed elsewhere. I am a new member today - I signed up after I found out about myspeed control board being the prolem with my A/C level 1 and 2).
Also, I am trying to locate a cylinder head for the same model. I refuse to have the gaskets replaced prior to locating heads in the event one is cracked. Any help would be appreciated.
I own a 2000 Venture, almost 6 years old now, with aprox 57K.
I have had many of the common problems: especially the coolant leak- gaskets. This has happened twice, most recently in the Spring, when GM completely covered the cost, thanks to info I found here.
Lately, the transmission has been shifting very roughly only when the AC is on. I have read many others have had this problem, but no one has linked it to the AC. I guess from reading that it is the solenoid?
If GM had not recently done a free major repair, I would look to them.
I just spent $600 on van, and hope to get about 6 more months out of it before I sell.
Any help?
Believer - Did you ever determine what was causing the ABS to act up? I have a 2002 AWD Venture that's doing the same thing.
I posted a few days ago about my transmission problem.
My van shifts roughly on occasion.
From what I read here, I suspect the solenoid.
If I keep driving it, am I risking ruining the whole transmission?
