Chrysler Town and Country EX/LX/LXi/Limited
anyone experienced similar problem? any ideas?
thanks.
Any information would be appreciated.
It is intermittent. Makes it impossible for
rocket scientist at dealership to find. Started
taking vehicle to new dealership.
could this be indicative of a belt tensioner problem, as in post # 1316?
Thanks, for your time and effort.
Rear shocks now, 4743 229AA, need 4743 233AA
Rear Sway Bar now, 5006 128AA, need 5006 121AA
Front Struts now, 5006 333AA, need 5066 334AA
Front Sway Bar, Same as present
Springs I cannot tell. Need a 3 digit code for the spring groups (like ZAF). There are 13 or 14 different part numbers (maybe left and right) listed for both front and rear.
The book says" Spring Group Types; Found on Individual Vehicle Sales Code Listing".
Front spring part numbers range from 5006 705AA thru 5006 780AA. Rear springs 5006 304AA thru 5006 457AA.
You can check prices and descriptions by entering the part numbers in at http://www.magauto.com/chrysler.htm
Prices are discounted 20-25%.
I would guess you are looking at $1000-1300 just for the parts.
Hope this helps!!!!
1. 03 EX (std equipment includes 2 power doors and liftgate) with leather as the only option: $24,952
2. 03 EX (std equipment includes 2 power doors and liftgate) with leather, rear audio and DVD as the only options: $26,947
2. 03 Lxi with leather and heated seats as only options: $26,621
What do people think? Do you think prices will go lower or increase?
Marty
Those look like some pretty nice numbers for T&C. It looks like they have the incentives already subtracted so you can't use the 0% financing. Is this correct? Also is it really a $2k add for the EX to get the DVD w/rear audio? And do you get a lot more with the LXi over the EX w/leather to justify the price increase? Are these vans on the lot or would you be ordering? Thanks for you info, I am looking at these same vans right now ;-)
On the Ex with DVD/rear audio, it also came with the infinity speakers ($500 option)-sorry forgot to add that.
Correct, cannot get 0% financing. These prices are with the incentives. What are your thoughts in terms of the better deal, taking the incentives or th 0%??
The vans are on the lot.
The difference between the Ex and Lxi I that I recall are auto climate control, power passenger seat, side molding, fog lites, passenger lites for all 3 rows and probably a couple of more I can't think of now.
That is the million dollar question, an Ex or Lxi??? Any thoughts from anyone else on why they bought either one? I really like the thought of the auto climate control, set it once. You aren't constantly fiddling it, turning it on, off, etc. However, is that convenience, plus the other perks worth $1,600. Tough call to me.
The other thing getting me is that I am a honda person, 2 accords and 1 civic were last 3 cars. Im my opiniion, the T&C looks so much nicer from the outside and inside and with these incentives, comes out less expensive to boot than the Odyssey. Hopefully, Chrysler got it right with the new generation T&C and I am not rolling the dice.
Just feels more solid to drive even in the rain. Being from CA we had it up in the sierras on I80 during the thanksgiving snowstorm of '00 and it did great. One highlight was we didn't have to pull over to put chains on when they became mandatory up in the mountains. And while others were sliding and fish-tailing on the steep parts, we stayed pretty sure-footed. I had 5 passengers plus luggage with me. So for me it was more of safety of the AWD more than anything else.
So far (@ 43k) the belt tensioner has given way and had to be replaced. One of my load leveling rear shocks (leaking) was replaced about a year or so after I bought the van (warranty). The auto doors and hatch of the new ones would be nice but didn't have it back then. Otherwise, we're pretty happy with it. Soon I'll be due for new tires though. Good luck.
1. Lxi with leather and DVD only: $27,656
2. Lxi with leather and heated seats only: $26,621
3. Lxi with leather, DVD and heated seats only: $27,995
4. Lxi with leather, heated seats, moonroof and DVD only: $27,963
Hope that helps!
You will need to take the calipers off, making sure that you do not stress the flexible hose. While you have the caliper off, lubricating the caliper sliders with high temp brake grease is a good idea too. I would also suggest replacing the pads with the rotors as a set to better mating of the braking surfaces. Use of some anti-squeal coating on the backs of the pads is optional, but recommended. You can buy little packets of the slider grease and the anti-squeal goop from Pep Boys.
Proper break-in of the new rotors is important for long lasting performance. Briefly, no hard stops first 100 miles, no long slow braking from a high speed, then progressive use, then a few hard stops at about 200 miles or so.
Good luck, and if you are unsure about any step, seek advice and help if needed, as one should not take any chances with brakes.
Which state that is in. Boy i am paying almost that price for an employee. you've got really good deals on it.
A good NAV system such as the Pioneer will run you about $2000 I'm guessing, and perhaps no more than a few hundred for a professional install.
Please post back how it goes, and your thoughts about it.
I ran mine down last weekend and had to get a jump. My dash lights would flash, but I doubt that there was enough juice to run the wipers.
Maybe your original battery is worn out and the drain was enough to kill it for good? I don't know if that would explain why a trickle charge wouldn't take.
Any preference as to Chevron, Shell, AM/PM, ARCO etc ?
Go figure a few cents saved vs. your $26-36k investment. For a dime difference you save $1/10 gals. And what's your comfort zone worth?
http://www.pioneerelectronics.com/Pioneer/CDA/CarProducts/CarProd- uctDetails/0,1429,34228,00.html
The price ranging from $1,500 (ebay) to $2,000 (store)....I guess nobody knows where that "speed sensor" wire is in the 01 T&C.
Someone here was raving about the quality of the TC. I will say I am impressed with the overall quality and the materials. I do think however that the fit and finish was rough - at least on my vehicle. On my test drive I noticed the wire way on the power door was unsnapped, the center wood console was not pushed into place, and some wires are sticking out the back of my steering wheel. Its not DCX's fault though - its the UAW workers.
Also, our van experienced its new dent as well when our 2 yr old pressed the garage door button and the door closed on the open rear hatch. Needless to say the button has been relocated to a higher point on the wall.
Lastly, just read an article on the Toyota Sienna. I'm not in the least bit disappointed that I did not wait for that MV. Take a look at the legroom - or should I say kneeroom - in the front. Its not there.
Bun Warmer on driver side seat was shorted out and had to be replaced under warranty.
That was the first trip to the dealer for anything.
Too bad I will never buy another Chrysler product after a Chrysler VP called Conservatives "myopic" and I found out they give hundreds of thousands to Jesse Jackson and Rainbow/Push. They won't get any more $ from me.
My wife and I are in the middle of closing a deal with our local Chrysler dealer for a new '03 T&C LXi. I've signed the papers, but my wife hasn't (which is a good thing). Both of our names are on the contract. So legally, it's not ours yet! Van is still at the dealer. They did put the temporary registration on the window, but I ended up leaving the van at the dealer (please read on).
The pertinent information is that this unit comes with 6-disc CD changer/player (factory in-dash with casette/radio/controls also), sunroof, and tri-zone climate control with rear-AC controls attached to ceiling.
We require a rear DVD entertainment system, so the dealer agreed to include that as part of the "due bill" (i.e. to be added after purchase with cost bundled into the purchase price). They said the factory DVD rear entertainment system could be added.
But, as I was preparing to drive off (and go get my wife so she could sign the papers that same night), I talked with the folks in service to find out how it would work (salesman had assured me it was already worked out). Turns out that the *only* way they could add the factory DVD would be to bolt it to the floor, at a location under one of the rear seats. Well, that doesn't work, since we often remove the seats to put all kinds of stuff in our minivan (currently have Windstar). Originally the salesman was told they could install it under one of the front seats, but that's not possible since they're both power seats, so there's no room for the DVD with all the seat-motor equipment under both front seats.
So, then one of the service guys (actually a very nice/bright guy), suggests I consider an after-market DVD/entertainment system. Turns out they have one from Rosen (ClearVUE Ultra all-in-one), that has the DVD player, drop-down 6.8" LCD, controls, wireless headphones, etc. But this unit is a fairly good size unit, and I don't see how this can fit attached to the ceiling, and still have the rear-ac controls. I could live without the rear-ac controls on the ceiling if I could control *everything* for rear-ac from the front, but from what I can tell, I can't control the rear-ac fans speed from the front (temp in auto mode yes, but I don't think I can control fan speed from the front).
This is killing me. I've been working on this deal for almost 2 weeks. If anyone out there has an idea as to how to add a 3rd party DVD entertainment system to the ceiling (all self-contained), and still have room for the rear-ac controls, and also keeping in mind that we have the sunroof, PLEASE LET ME KNOW!
Otherwise, if I can't get a 3rd party DVD entertainment system added that can also co-exist with the rear-ac controls on the ceiling, I'll have to either:
a) Walk away from the deal (it's an awesome deal)
or
b) Ask them to rip out the entire existing audio system (radio, casette, and 6-disc changer), and replace with the factory system that normally comes with the factory DVD entertainment system, which is single CD player, radio, cassette, and DVD (all in dash)!
I think option 'b' would be quite costly for them, so they would probably resist, plus then we don't get the ultimate audio/video experience.
Again, any advice from people in the know about this sort of thing (expecially anyone that's experienced it before), would be GREATLY APPRECIATED!!!
In fact, if you could cut and paste your response here and also send it to my email address at "mike949@cox.net", that would be great!
Mike
Anyway, I was stopped at the stop sign coming out of our local train station and a bolt of lightning came down struck the stop sign RIGHT next to the passenger window, which shattered our window unexpectedly.
I don't know if that applies to you, but I know how you feel.
We purchased the van yesterday without having the factory DVD entertainment system added (which saved us quite a bit of money).
I've been researching various 3rd party DVD systems, and it looks like there are several possibilities, however they get a little limited due to the power moonroof. In the end, if we don't go with a portable solution (e.g. Audiovox DVD in-a-box), we'll probably end up going with a split solution (factory LCD on headliner, and 3rd party smaller DVD that fits in console).
Mike
thanks for you imput.
