Visitor Agreement.
I have a 2002 T&C with AWD. To my mind, power is not what counts, but the ability to deliver the power to the ground. The AWD provides that traction. WHile my 300M was more powerful, it was meaningless on slippery roads. The AWD works and works well. It is a great feeling to know you can step on the gas and go even if the road surface is slippery.
On the T&C, 90% of the power normally goes to the front wheels, if they slip more power goes to the rear.
As to mpg, this is my first van so I have nothing to compare it to. I am getting in the range of 18.5 mpg in suburban driving.
Also, I love the auto load leveling that comes with the AWD. I had nine people in the van and it road like a dream.
Hope this helps.
Ed
I also have a 1995 Subaru LSi AWD with 90K miles. While not trouble free it has been a good car... Hope this helps..
How are you managing that?
Bo
Mike--according to Edmund's the 0-60 time for the 215 hp 3.8 is 9.5 sec. While I find the performance perfectly adequate for my needs, the T&C is certainly not a sports car.
Took to shop, replaced plugs, plug wires, fuel filter, PCV valve, air filter. OBD said "trouble code 300-multiple mis-fires".
$300.00 paid and van ran fine, until I went back to get my kids...Exact same problem on different hill in same high elevation area...
Please help, I'm about to get fleeced but I gotta do the drive once a month due to child visitation reasons...
I have tried to do it myself and actually located the "speed pulse" wire for the Navigation system but I got a major problem with the factory Infinity system. I got everything hooked up and the video looked great but no audio. Talked to the pro and they told me the only way to get the sound out of the original speakers is to go around the build-in amp of each speakers. That involved taking out all panels and reroute all wires. That just too much work for me and decided to let them do it for $500. It took them two days to finish the job so $500 wasn't that bad afterall. I think the cost of the whole system with labor would still be cheaper than the system from Chrysler. Last time I check the roof mounted DVD from Chrysler cost $2000 with labor and I've never checked the price for the new in-dash Navigation system they have (small screen). Now I (the driver) get to watch DVD on a 7 inch screen while driving (no, I don't do that ;-))
I drive lots of miles (45,000) so I am not under warranty. Hate problems with new cars.
The voltage output from the power module is compared to the blower motor feedback voltage in a comparaotr circuit.
The Microprocessor-based ATC calculates the speed that the Power Module applies. It could be bad.
You will need to have the system scanned with a DRBIII scan tool, there should be stored and active codes for diagnosis.
Oh well.
It's so nice having a car that doesn't have any rattles that have to be fixed at the dealer after owning it for three months. Did my Chrysler's have any mechanical problems? Not really, but the rattles were always there.
Try nosing around the Maintenance and Repair Board. There are some discussions about overheating in there that may shed some light.
front bumper passenger side. anyone else?
But still, we're talking $37,000 vans with sun roof etc. etc. for $27,000.
I bet you could do better.
Go to Build a Chrysler, then under the Make it Your Own menu, choose Build Your Chrysler. After you finish the build procedure, I think you select Get a Quote or Search Dealer Inventory, and occasionally a coupon will pop up. They're kind of sporadic, usually offered on various vehicles for 3 days at a time, but it's worth checking before you shop anyway.
kirstie_h
MODERATOR /ADMINISTRATOR
Review your vehicle
I am about to let our '96 DGC go and we are trying to decide between a new T&C or a Ody or Sienna. The worst thing about the T&C is the split rear seat design - the have all but eliminated the large available cargo room unless you give up seats. I wonder what engineering phenom came up with that design??
1. Headlights on with wipers - page 125 of manual - When programmed "y" in EVIC with headlights on Auto and wipers on for 10 seconds, the healights should automatically come on. Mine does not.
2. If you try to adjust the adjustable pedals with cruise control engaged or with the transmission in reverse, you shold get a beep and messages in the EVIC stating that this will not work. Under these conditions, the pedals do not adjust, but I do not get the messages.
3. If you leave the turn signals on too long driving down the highway, you should get a beep and a warning message in the EVIC that the turn signal is on, I do not get this message either.
I know that none of the above are major issues, but on a car of this price, I expect everything to work as described in the manual.
Just one more question about the Load Leveling/Height Control suspension. My T&C has this option as part of the trailer towing package. I recently went on a road trip on I-10 and was surprised and how stiff this suspension was and how hard it took some of the I-10 bumps. Can anyone offer input as to how the ride with this suspension system compares to the regular T&C suspension? Can this suspension be adjusted "softer"? Thanks in advance.
I used the following procedure for the rest, which you may or may not use at your own risk. The only tools I used were a 3/8 ratchet drive, plug socket, a universal joint and two extensions, 3" and 6", for the plugs, and 12, 14 and 15 mm box end spanners for the belt and brackets as you will see.
For #3 and #5, I raised the vehicle on drive-up ramps, and approached from underneath. If you follow the exhaust up to the rear bank, you can see the plugs after the wires have been removed. Believe it or not, there is indeed enough space to put the socket on, attach the universal joint and use the ratchet head with the appropriate extension to remove these two plugs.
#1 is the worst. I removed the serpentine belt, then loosening the alternator and moved to as far back towards the firewall. Then I removed the triangular bracket attaching the alternator braket to the intake plenum. Then there was just enough space to remove the plug.
I used antiseize on all the new plugs, and did not change the wires.
Hints:
Do this with the engine cold. I would suggest parking it on the ramps overnight and work the next morning. Wear good work gloves, and long sleeves since it will be awkward getting your arms into position, and there are a lot of unfinished edges to scratch your knuckles and forearms.
The usual disclaimers apply. You must consider all the above as the ravings of a lunatic not to be followed except at your own risk.
Having said that, if there is anything else I can describe, please let me know.
