Any Questions for a Car Dealer?
1228229231233234315
    Wow...scary!
    I can't blame you for feeling uneasy but this was a freak thing that could happen on any new car.
    Hard to guess what happened but I would bet on a defective master cylinder from the factory. I'm sure Toyota will be all over this one!
  • graphicguygraphicguy Member Posts: 14,242
    Thanks, isell.....
    Maybe I'm feeling too skittish. My dealer actually was all over it. When they towed it, they had a "loaner" brought to my house, too. It certainly could have been a lot worse scenario.
    Now, the "fear factor" (rightfully or wrongfully) is setting in....I don't know how I'm going to address this when they come back with the repairs and try to soothe my frazzled mind.
    I know you're "a Honda guy" but from a dealer perspective, what do you think would happen if I told them I didn't want the "fixed" Tacoma but another one? I'll stick with the dealership, but because I'm skittish, what would be the dealer stance if I requested another vehicle? I don't want to keep a $27K vehicle that I'm afraid to drive.
    Any good options here?
  • imidazol97imidazol97 Member Posts: 27,784
    Did you think about the emergency brake? At parking lot speeds that would have stopped you quickly using the two rear wheels.
    To be honest, it happened so fast the only thing I could think of was to keep pumping away at the brake pedal to see if I could get any pressure. Didn't even think of the emergency brake. I was just looking for an "out". Looked around quickly to survey my options. Thought the best was to look for a stationary obstacle that wasn't a car or building that could/would stop me. Plus, being a weekend, there were plenty of people in the parking lot. I certainly didn't want to head in their direction. In addition to that, there were cars moving in and out of parking spaces that had no clue I couldn't stop the truck.
    Fortunately, I saw 3 open parking spaces and I headed for those and aimed for the concrete barriers in front of them.
    You don't realize how much of a hit 10 MPH is. It feels like you're crawling when you're driving. When the wheels hit the concrete, it was quite a jolt, however.
    In hindsight (being 20-20), that was probably what I should have done, though....step on the emergency brake.
  • kyfdxkyfdx Moderator Posts: 272,372
    I doubt I would have thought quickly enough to use the parking brake, either...
    It sounds like you did a great job!!
    Not a dealer, but I doubt the new truck thing will fly.. Unless, of course, they tell you they can't find anything wrong.. :surprise:
    regards,
    kyfdx
    After they repair it, ask that the service manager take you for a spin while you ride in the passenger seat. If it passes a 1/2 hour of stop and go driving in the city test, then agree to take it home. If he bawlks, tell him you want another vehicle. ;)
    You will only get a new truck if Toyota itself is involved in the situation. It is not the dealer's call unless you make a big fuss about it, then the dealer would be speaking with toyota itself and getting them involved. Even then, a manufacturer will give you a new replacement car if they fail to find or fix the problem after many tries.
    If they find the problem and fix it, then you shouldn't have anything to worry about although I understand how you might be nervous each time you get behind the wheel of your truck.
  • jlawrence01jlawrence01 Member Posts: 1,757
    Having lost my master cylinders a couple of times, it is really hard to say what you could do when it happens. You generally pump the brakes, find nothing and start to panic.
    But let me assure you, I was not panicking as much as the Midas shop owner whose window I nearly went through ...
  • carol23mcarol23m Member Posts: 4
    Just this Friday (6/10), I bought a USED 1997 Mitsubishi 3000GT. I signed the papers, left a check for the downpayment, and took the car home.
    As soon as I got home, the car started overheating and the Check ENGINE light came one. I was furious.
    The next day (sat.), I went back and tried to take the car back. They wouldn't take it back and said they could put me in another car. They beat around the bush and tried putting me in old, high milage cars that were not close the the value of the 3000GT.
    I went back again yesterday (MOnday), and told them I wanted my down payment back and I wanted to LEAVE THEIR CAR. They said I could not do that. I STOPPED PAYMENT on the check that they had not cashed, and left the car there.
    Is there anything I can do to legally undo the contract? Can they do anything to me at this point? PLEASE HELP??? The car price was only $7,900.
    Well, I guess you could demand another truck and see what they say. They really did no wrong. It was a defective part that caused the failure. Very surprising the more I think of it. You have a dual master cylinder so you shouldn't have had a total failure. And...it gave no prior warning like a soft pedel.
    Very VERY strange....be sure to let us know what they found. They also need to carefully inspect the truck for any damage from hitting that curb.
  • 1racefan1racefan Member Posts: 932
    Well, IF the car was purchased "as-is", it sounds like it is your car and your problem. IF there was any warranty offered by the dealer, then they need to fix the car. I am not a lawyer, but either way I think ultimately the car is yours. You are talking about a 9 year old car, and when you buy a 9 year old car used, you cannot assume it will perform and be up to the standards of a brand new car.
    Well, I assume you didn't have the car inspected by a good shop before you bought it?
    Normally cars aren't returnable. Once you drive it off the lot it's yours. No "cooling off" period on cars.
    What kind of a lot was it? a dealer or an independent.?
    How many miles on the car?
    And, it's possible it just blew a hose or something monir happened that the dealer who sold you the car knew nothing about. Maybe it's not a big deal.
    I was going to bring up the pre-purchase mechanical inspection too, but I didn't want to "pile on". Seems like if nothing else, this is a good "learning experience".
  • mirthmirth Member Posts: 1,212
    First - go back and get the car. Unfortunately for you, it is yours. You paid the money and signed the papers. By giving them back the car and not paying, it essentially becomes a repossession. Your credit rating could take a hit, and the dealer could just turn around and sell it again, so you're not hurting them.
    Sounds like you got a bad dealer, but did you have a mechanic check out this 9 year-old car before you bought it? Buyer beware. I feel for you, but I doubt that a court would do anything for you. Maybe you could get your deposit back and get the dealer to take the car back, but it's iffy. Talk to a lawyer first.
    They don't have any of your money.. Have you signed any loan papers?
    I have no idea of the legal aspects... but, the fact that you've left the car at the dealership, and they don't have your money is a positive for your situation..
    It is almost impossible for someone to make you fulfill a contract... that is, to sue for specific performance... However, they can sue you for monetary damages..
    But, they have kind of a tough argument.. they can only sue for actual damages.. So, to say they took a bath on the deal, they'll have to admit the car is a piece of crap... Otherwise, how much damage can their be?
    If you want to go down this road, just be sure that if any bank calls, you tell them that you are NOT purchasing the car, and will not be responsible for any monies that they forward to the dealer..
    I'm not saying you have a legal leg to stand on, but if you already know the car is a POS, then you are better off stonewalling, than taking the car..
    regards,
    kyfdx
    I guess you can tell we aren't lawyers.... ;)
    No, but I used to watch LA Law as a kid.
    thanks for your responses.
    I DID have the car inspected by my mechanic. Look it thourougly and said there was nothing wrong with it except the brake pads, and roters.
    So THEN....the dealership a big JOE MYERS Toyota, "fixed" these minor details. So I took it home.
    When I argued with them that the car is malfunctioning, even the Regional Mgr. said..."maybe when we worked on it, and washed the motor, something happened". So essentially, AFTER they worked on it, is when the car started acting up.
    I did not sign loaner papers. But now the car is at their dealership, I left the keys, and stopped payment on the check.
    They don't have your money, or loan application.. and, you don't have their car..
    Doesn't sound like the deal was ever consumated...
    Of course, they could file a criminal charge of fraud for you stopping payment on the check, but that seems unlikely...
    Sounds like a sticky situation..
    By the way....this 1997 Mitsubishi only had about 66K miles. Not very much.
    I am afriad that my credit will take the hit for all this.
    This is a nightmare.
  • jasmith52jasmith52 Member Posts: 462
    Has anyone assessed what actually is wrong with the car ?
    It could be as simple as a thermostat or even low coolant or a broken hose. Don't assume the worst and immediately jump to the conclusion that the head gasket needs to be replaced or the block is cracked. My guess, without knowing more, is that you are leaking coolant water somewhere and once you fix the leak then your problems will go away.
    As far as the check engine light going on. I suspect that gets set by the onboard ECM computer when the car overheats.
    Maybe the car is still in pretty good condition but needs some minor work.
    So - My advice is to find out what is wrong before you take some of the (questionable) advice given previously and ruin a good credit rating.
    If you are going to buy and drive 8-9 year old cars then you'll either have to work on em yourself or find a mechanic to do the work for you. After all it's not a new car and stuff will break and have to be worked on.
    No one has assessed what is wrong with the car.
    They wouldn't even take a look at it. They were very difficult about the whole thing from the beginning.
    I do see what you are saying. Maybe it's something minor. But what if it's not?? If that Check Engine light is coming on already. I don't think anyone would want to buy the car.
  • qbrozenqbrozen Member Posts: 33,845
    it would take the dealership a few minutes to pull the code and see what the CEL is all about. I'm not sure why they wouldn't at least do that much.
    jlawrence.....that's exactly what happened...pumped the brakes a couple of times. Pedal went to the floor and I wasn't slowing down. Pedal was totally devoid of feel. Panic, did indeed, set in....even at a slow speed. No one around me had any idea what was happening until I jumped the concrete "curb" (actually a small island with plants in it). Of course, when the flat bed came and blocked about 1/3 row of parking, everyone noticed.
    isellhondas....while I'm at best, a shade tree mechanic, I was surprised that the Tacoma, with back-up braking systems and anti-lock (didn't feel any pulse in the brake pedal) seemed to totally fail. After I stopped, I immediately checked to see if the master cylinder had fluid. But, not even a "brake warning light" came on (or if it did, I didn't notice it in my panic).
    Based on that, I'm sure the brakes are controlled somewhat by the computer. Computer failure of some sort? I had noticed that the brake pedal seemed to travel pretty far down when I took delivery. But, since I checked under the hood before I bought it, and saw the master cyl was full, I thought little of it, figuring the brakes were self adjusting. Brand new unit, so the disks and pads had to be new, too.
    If I had to guess, two things happened simultaneously. First there was some sort of contamination, kink or air in the brake lines, coupled with a computer failure.
    One of those very rare circumstances where Murphy's Law prevailed.
    Maybe needlessly, but if I end up picking the truck up after they fix it, I'll always be worried about another similar break (brake?) down. If it was something minor, I would just let Toyota take care of it and be done with it. But brake failure? Scary!
    This wasn't a rattle or an oil leak. It was a major failure of your brakes. Very lucky nobody was standing there unloading a grocery cart.
    Yeah...I would tell them you have NO CONFIDENCE in that particular truck and that you would like another to replace it.
    Of course, the chances of a repeat performance would probably be no greater on the truck you have than another, it sounds like you would always have a nagging feeling it could happen again.
    That is one scary feeling ....
    By the way, for those who ever find themselves in the situation that Graphic (and I) have been in, get the car stopped and call the tow truck. Do **NOT** drive it to the brake shop even if it is less than a mile. (g)
    I put that in my "LESSONS LEARNED" folder.
  • jaserbjaserb Member Posts: 820
    "I'm not saying you have a legal leg to stand on, but if you already know the car is a POS, then you are better off stonewalling, than taking the car.. "
    That depends on how much you value your credit rating. Sure, you could fight tooth and nail to not have to pay for the car and finally win, but in the meantime you have creditors calling, black marks on your credit, late fees, maybe your insurance gets raised, etc. I paid a bogus (but very expensive) traffic ticket just because I knew it had been referred to a collections agency and they couldn't care less if you're in the right or not. They just want money, and will use any means at their disposal to get it. I finally decided to just eat the cost to avoid all the headaches later.
    -Jason
    Aren't those Toyotas supposed to be bulletproof ?
    Since nobody got hurt in this story, I take a little somewhat sadistic pleasure in seeing that Toyotas have problems too. I get so tired of all of the Big-3 car bashing that goes on in the media.
    A lot of components in today's complicated cars that can fail.
    Some people do get a bit of pleasure, I know, when it happens to Honda or Toyota.
    Truth told.....it is such a rare occasion that this type of scenario would happen to any new car/truck that I'll chalk it up as an anomalie, at worst. Given Toyota's (and Honda's) reputation and ratings year after year for reliability, I'd probably be more likely to win the lottery than I would to have the type of failure as I experienced.
    jlawrence.....very good advice. First, I think it just reinforces your idea to follow smart maintenance procedures for your entire car/truck.....including brakes. So often, people fill up with gas and wheel their cars in for oil changes at the local quick lube and think they're done. Or, they notice their tires are bald and buy new ones. In the case of a new vehicle, people make certain that there aren't any "dings" or paint flaws and totally ignore checking for things like fluid levels before they drive off the dealer's lot. I know....the PDI is supposed to find things like this. But, looking back, I should have said something during the test drive when I noticed the brakes felt unusually "spongy". Instead, I was fiddling with the A/C, radio, looking around the cabin, etc. But, at the time, the brakes stopped the truck, so they must have been OK, right (rhetorical question)?
    It bears repeating.........DO NOT DRIVE YOUR VEHICLE ANYWHERE WITH FAULTY BRAKES! I was lucky. If I had been on the interstate, or even in town, this scenario could have been disasterous....for me and probably others around me. Hell, it could have been a disaster just being pokey in a parking lot.
    Isell....dealer has had the Tacoma going on two days now. My salesperson did call me today after she saw my truck in their service bay. She said they didn't know what went wrong as of yet, but they had the wheels off and it has been on a lift since yesterday. I told her of my "skittishness", particularly given the safety implications of what happened. She said she understood, but they wanted to find out what failed. I floated the idea that I'm entertaining the thought that I may not be satisfied with it, even if it's supposedly fixed. She said she'd talk to her GM about swapping vehicles. Nothing guaranteed, though.
    As a side note, the Toyota store also owns a Honda store right next door. The "loaner vehicle" they gave me to use is a Pilot LX. Very nice vehicle, BTW. Why they didn't put me in another Toyota is something of a mystery.
    If interested, I'll let you know how the whole thing ends up.
    They are pretty good guys over there at Performance.. I leased three Accords from the Honda dealership...
    ky....really, I've got no complaints with the people at Performance. For those of you not local to kyfdx and I, Performance Auto Group is a big Toyota, Honda, Lexus, Mitsu dealer in southern OH and I believe FL.
    They've treated me great. The saleslady I dealt with was knowledgeable. She even sent me a package of Mrs Fields cookies with a note thanking me for my business. Negotiations were fair and smooth. The deal was good. The Sales Mgr made certain to tell me how much they appreciated my business. All-in-all, a very pleasant experience up until now. Even the service mgr didn't hesitate to get me a tow truck once I called them about my situation....in less than 20 minutes. They had someone pick me up when the tow truck arrived to take me to the dealership for a loaner vehicle. I live close, so that only took about 15 minutes.
    Aside from the actual vehicle problems, I rate Performance one of the best dealership experiences I've ever had. If this is what they do for their Toyota/Honda customers, I can't begin to imagine what they do for their Lexus customers.
    From what I understand, Mike Dever still owns the dealerships, but he now lives in FL. I guess he's got his daughter (Shelby) running the OH operations. Must be the woman's touch. She just left a message on my cell phone telling me she was aware of my situation and that she was personally overseeing the progress. Now, she didn't promise anything, but the thought is good.
    Since we don't allow profanity, abbreviations for profanity such as POS aren't allowed either. Let's try to find other ways of expressing dissatisfaction. Thanks!
    MODERATOR /ADMINISTRATOR
    Review your vehicle
    Oops.. mea culpa..
  • alfoxalfox Member Posts: 708
    you said POS too!... 8-0
    What's wrong with the abbreviation for Point Of Sale?
  • dobygirl301dobygirl301 Member Posts: 5
    I just wanted to thank everyone for your advice. I finally have a resolution that I am happy about.
    I contacted GM customer care and they got a hold of the general manager of the dealership. He said he would look into it and that I might need to bring the car in for his body shop to look at it and make a determination. He said he would look into a repurchase.
    Well, I got a call today and the dealership is going to do a repurchase and is going to give me my down payment back.
    The GM agreed that part of the problem was the finance company gouging me. Anyway, I think I have learned my lesson and will NEVER, EVER buy a car without reading the contract and I will negotiate in the future.
    For anyone else out there, I do want to commend General Motors Customer Care for helping me - they were great and they did what they said they would do which is rare these days. :blush:
  • mark156mark156 Member Posts: 1,915
    Audia8q, I'm surprised as a car dealer, that you have never seen cloth seats in the front and plastic in the rear. The Explorer you saw, I'm sure, didn't have leather in the second row.
    My brother and his wife bought a new 1980 Buick wagon, wood paneling, etc.. and it had cloth split seats in the front and pleather in the back. They bought it that way because it was perfect for small children and their spills, etc.
    I'm not sure if cars will come that way now but is good for some folks.
    Mark
    2010 Land Rover LR4, 2013 Honda CR-V, 2009 Bentley GTC, 1990 MB 500SL, 2001 MB S500, 2007 Lincoln TC, 1964 RR Silver Cloud III, 1995 MB E320 Cab., 2015 Prevost Liberty Coach
    Oh! Kirstie - sorry. Freudian slip I suppose.
    That is the way you see most police cars - cloth in the front seats, vinyl in the back seats ... and no carpeting in the car.
    Now how exactly would you know what the seats on the inside of a police car look like? ;)
    Up here in Chicagoland, I have a reputation ....
    for attending the police auctions.
    Seiously, one of the engineering interns buys and refurbishes Chevy Caprice police cars ... and does a pretty good job at it.
    off-topic posts have been deleted. If you wish to let other registered members communicate with you about off-topic subjects, please make your e-mail address public by editing your preferences.
    Review your vehicle
  • delangedelange Member Posts: 42
    however, if you go in with a pleasant and positive attitude, you will have a great experience - if you do get a salesperson you don't like, just walk away. there are plenty of good ones out there that WILL treat you with respect!
    Thene,
    I'm curious, is it OK to ask for a different salesman at the same dealership? If so, how? Or, would you walk away to another dealership instead?
    Thanks for your thoughful advice - it has certainly helped us out this week!
  • otis1otis1 Member Posts: 142
    I'm also curious about this. Are all the sales people at a specific dealership going to be the same (w/ regard to the price)? Is there an etiquette to switching sales people if the customer is not happy with the treatment and/or price? I asked a similar question once, and someone jumped on me saying that it was unfair to make salesmen work against each other at the same dealership.
    as a 2nd related question, who really sets the selling price? It was my understanding that the salesman got a cut of the profit. so selling at a lower price would mean a smaller commision. Does the sales manager have veto power if the salesman is willing to sell the car so cheap, he only gets a $1 commision on the sale (not that he would- just a hypothetical situation)
  • troispoulstroispouls Member Posts: 1
    Ok, reposted minus the bad word (and apologizes to the host who had originally emailed me about it; your email got caught in my spam filter. Sorry!).
    Just an FYI, I'm not a 'car person' so forgive me if I use some incorrect terms...
    My boyfriend bought a used 2003 Lexus IS300 from a Nissan dealer a few months ago (I guess it was a trade-in). The car worked great and was still under warranty. He bought it and we brought it to a Lexus Service center to be checked out during a "bumper-to-bumper" inspection. It checked out with no problems.
    Fast forward to after the warranty ends and to Spring and Spring rains. We go to the car one morning to find its lights flashing and gages jumping. Apparently there is a small leak into the car's junction block and water is getting in and shorting the circuit. My first question here, is the dealer that sold it to us responsible at all? Can we take any action against them since it was a used car?
    Unfortunately the story doesn't end there. So, we go back to the Lexus Service center to get it looked at. Suddenly they find all these "obvious" things wrong with the cars - holes in the car's body that were under the hood, corroded circuits, etc! So, we pay the $1000 to fix it and go to pick the car up. Well, right before they give it back to us, they take it for a car wash and guess what? Water is still leaking into the junction block! So, we pay another $250 to apparently fix a leak in the windshield and take it home a couple days later. The next time it rains, the junction block still gets wet and we're back at the Lexus Service center (unforutnately the only one in the area). Now, they're telling us we have to pay at least another $600 to entirely replace the windshield! We had a long and painful talk with the center's manager and he agreed to refund us some $$$ since they weren't doing their job in the first place (I asked the manager to bring in one of the mechanics and ask him what specific items in the $1000 work order went toward fixing the leak and the mechanic said "none of it." Unbelievable.)
    My boyfriend now cannot stand the car and wants to sell it once we get it fixed. My question is, if we get it fixed by the Lexus Service center and sell it but the car still has problems, would we be liable? Or can we just give the new owner all the receipts for the work we had done to the car and tell them their beef is with the
    Lexus Service center who we already paid to fix the problem? Any advice to try to resolve this nightmare would be greatly appreciated.
  • thenebeanthenebean Member Posts: 1,124
    yes - it is ok to ask for a different salesperson, or even the manager, if you do not think you will get anywhere with the one you are with. whether it gets you a better price or not depends - but at least you can feel comfortable and LIKE the person you are working with, rather than feel uncomfortable. If you are uncomfortable with the salesperson you have, ask to see the sales manager and let him know that you would like to try to do business there, but you are not comfortable with your current salesperson. believe me, the manager won't tell you to get lost - they wanna sell a car!
    with regards to how salespeople get paid, and who sets the prices...every dealer is different. some places work strictly commission (meaning they only get $$$ if they sell cars, and profit is considered anything OVER invoice, not holdback and dealer incentives or doc fees or anything else). some get salary plus commission (percentages range on the commission - mine is 20% of the amount over invoice for example) and some dealers will give "minis" meaning regardless of what they sell the car for, they will at LEAST get $50 (or whatever is set by the dealer)
    to be honest, the salesperson really doesn't make the same kind of crazy money that the dealer would make - and when they tell you they arent making money on a deal thats $200 below invoice - its because they don't get paid on holdback, etc.
    hopefully that answers your questions - let me know if you have any others!
    -thene :)
    if you are out of the warranty that the dealer who sold you the car put on the vehicle, you are out of luck. sometimes issues happen after the fact that maybe would have happened even if you bought the car new. the dealer can't be held liable forever - but if this happened within the first couple of weeks, you'd have a very strong argument for them to take care of the issues.
    with regards to you selling the vehicle on your own - every state has different laws. here in CT, if you sell a car, you can be held liable if things fail within the first 30 days or so. if you sell the car as-is, you may be ok, but you have to be careful. i would also get on this lexus service place's case and let them know you are REALLY unhappy that they charged you $1k for work that didnt pertain to the leak! talk about real ripoff!
    good luck with everything!
    -thene :)
  • toyotakentoyotaken Member Posts: 897
    The best way to go about working with a different sales consultant is to ask to speak with the manager and explain that you would feel more comfortable working with someone different. If you prefer a particular type of person to work with tell them as well and they would more than be willing to find the right person for you to work with. They are more interested in making sure that you become a customer than ruffling a few feathers. And that should go for you as well. If you like the dealer, but not the sales consultant, say so and work with someone that you are comfortable with.
    As for your second question, the sales manager is almost always the one that determines if the car is going to be sold at a particular price. That being said, how the sales consultant presents the offer to the sales manager makes a difference as well. Coming from someone who's worked both sides of the desk and is back on the sales floor after being a desk manager, trust me, the sales consultants often work the sales managers much harder than or as hard as they work their customers, especially the sales consultants who have a good customer following. The reason I say this is that although I make a commission based on what we sell the car for, I would much rather take a lower commission and keep a customer happy and keep that customer for referrals and repeat business than make more on a commission at the risk of losing that customer and any referrals they may make. That is not necessarily the long-term mentality that all dealers and/or sales consultants share though.
    Hope this helps
    Ken
    OK....just got a call from the dealer. They can't find anything wrong with the brakes after extensive test driving. I would rather have them say they found something and fixed it.
    What's my next step with a week old Tacoma (that I've only actually driven for 4 days) with the dealer. My confidence is shaken in this truck.
