Haven't seen a post in aaaaaaawhile and just checking on you folks.
The air conditioning lines under the hood are cold and sweating like the A/C is operating, but seems the heater is on (not just outside air).
A/C worked ok last season and heater worked ok in winter.
Any ideas?
Battery went dead in winter. I replaced it and upon hooking up cables to new battery, there was a clicking sound coming from the dash area. It did sound a little like a small door opening and closing. No affect on the heater. Called dealer service and they said sounded like blend door and would be very expensive to fix-up to $700 because of labor.
The clicking stopped and when first turning on A/C this spring, got hot air only. The clicking has not returned. Thought it was a vacuum valve under the glovebox, but that seems to be working ok. It moves one direction when key is on, then opposite direction when car starts. Neither position changed hot air from A/C.
Thanks very much for help.
Thanks again for your help.
1) Simultaneously depress OFF and FLOOR buttons, then press AUTOMATIC button WITHIN two seconds. Display will show a pulse tracer going around the center of the display window for up to 30 seconds while test is running.
2) Self-diagnostics can be initiated at any time with the resulting DTCs being displayed. Normal system operation is stopped when system is in self-diagnostic mode.
DIAGNOSTIC TROUBLE CODES TABLE
code number
24, 25 (1) ELECTRONIC TEMPERATURE BLEND DOOR ACTUATOR
30 IN-VEHICLE TEMP SENSOR SHORT
31 IN-VEHICLE TEMP SENSOR OPEN
40, 42 (1) AMBIENT TEMP SENSOR SHORTED
41, 43 (1)AMBIENT TEMP SENSOR OPEN
50, 52 (1) SUNLOAD SENSOR SHORT4ED
115 (1) ENGINE COOLANT TEMP SENSOR
125 (1) VEHICLE SPEED SENSOR
(1) - INTERMITTENT FAULT
TO EXIT THE SELF-DIAGNOSTICS WHILE RETAINING DTCs IN MEMORY, DEPRESS BLUE BUTTON.
TO EXIT SELF-DIAGNOSTICS CLEARING DTCs, DEPRESS DEFROST BUTTON.
If you can hear a vacuum leak anywhere, start with that.
It pays to shop around. Have quotes from $360 to $650 to replace the actuator. Lowest is an independent garage. Got an estimate of $405 from one Lincoln dealer and $650 from another.
This board is great. Thanks again.
Many thanks to you soaringlincoln for the tip on accessing the diagnostics.
Its a one owner car with all the paper work for maintaince. Is there anything with this car that I should be aware of to worry about. I drive 200 highway miles a day and would like to get another 100,000 miles out of this car if I do buy it. Anyone have any help? Its being offered at $3500.00
R
I think all cars should do away with gears completely and have variable trannies. Now THAT'S smooth!
Hey, remember "ballcoolers"? ... the little A/C vent right under steering column? Boy, those were the days!
I stand by my opinion though, that Lincolns should have the hot engines in them. Whether or not grandpa (and I am one...) cares about it or not.
FoMoCo is likely to make some attempt to increase performance in order to compete with DC's new products. They may make a more powerful engine standard across the board on all Panthers, or they may keep the pedestrian version of the 4.6 for (pauses to think of how to put this diplomatically) buyers uninterested in performance, and offer a more powerful engine as an option.
I think it would make sense to offer a handling package with a more powerful engine. Include stiffer shocks and springs, sportier wheels and tires, deeper gears, a more agressive trans calibration, and maybe a more agressive exhaust.
Come to think of it, I wish they offered that across the whole Panther line.
In case this should ever happen again, note that as long as you are logged in you can delete your own messages. The ability to edit a message expires after 30 minutes, but the ability to delete is always present.
There is something else everyone should realize - if you do a "Refresh" (or Reload or whatever your browser calls it) right after making a post, your message will repost. If you want to redisplay a page after making a post the best thing to do is use the "Recent Msgs" link on the page bar.
Hope this helps.
Regarding a HP boost, if there are performance minded TC buyers out there (how old are Baby-Boomers nowadays, anyway?), the magic number will be 300.
Back to the leather: I went to an auto show a few months ago and took a good look at the Panther offerings. The leather was hard and just didn't seem very luxurious. I don't know what Lincoln leather was like a long time ago, but my father has had a series of Cadillacs from the 1980 through 91 model years. The 80 had MUCH nicer leather than his 89 and 91 models.
For the record, I still prefer cloth.
Back in 2000, they made a Touring Edition, that had twice pipes (with nice exhaust note) and about 25 more hp as a result, special wheels and some trim differences. But it didn't sell well, and I think that gave Lincoln the impression that "Dad" didn't give a flip about performance in the Townie, so why bother. And frankly, they are probably right! I'm no doubt, the exception. But for me the LS is too small. It has all the performance I want, in too small a package.
