1.) you went to the top of a 1 mile long hill with a 30% grade and;
2.) had a 2001 Town Car with each of the 4 foot wells cut out (so that you could put your feet on the highway) and;
3.) had four 300 lb. Wrestlers/bodybuilders sitting - one in each seat and;
4.) Put the car in neutral and
5.) from a dead stop... had the guys start to paddle their feet like the Flintstones....
just how fast would you get going by the bottom of the hill?
Oh yeah, the brakes would have been removed... so stopping would have to be accomplished by the Flintstone method.
(I'm sorry... I couldn't resist!)
Gas filter
Oil filter
H2O filter
How about a warzonectx filter?
I have found a factory cd control unit at a salvage yard for $125 but no factory changer. Could I buy an aftermarket unit and wire (plug) it into the the control? Thanks for any and all assistance.
Saw what I thought was very cool this afternoon while at work, a stretch limo of a triple black '79 Town Car. Wonder if it was made now...or then?
finis !!!!!!
I've looked on the internet for a cd changer for my 94 TC. Nobody seems to have one for the stereos prior to 1995 and newer. My Lincoln dealer quoted me $250.00 installed! Check your dealer... it may be your best hope.
You could also purchase an aftermarket CD changer that will convert the sound into an FM frequency. All you do is tune your radio to a per determined channel not commonly used like 89.1. The changer will play the CD over the radio channel. It doesn't have the dynamic range sound that a regular changer does since it is being broadcasted over an FM station, but I have heard this type of changer play and it sounds really good!!
Personally, I'm going to purchase the original changer thru the dealer for simplicity sake and it also works off the radio controls rather than having to mount a small control box.
Please post your solution since I'm in the same boat as you. Thanks!
Replacement air shocks for $109.00 each. Coil springs ($199.00/pair) if you want to replace the air shocks. Somebody e-mail me with this company. I have not used them ...yet...but I thought everybody would like to know!!
PLEASE let them know you found them here in edmunds town hall message group!
There is no sticker on the compter box or on the trunk hindge.
the vehicle has been scoured front to back and no dice.
any advice would be great!
Adri
Here is our situation: 98 Volvo, 00 Expedition, 01 BMW. Wife would like to swap out the Volvo for a new TC. I say she is crazy, but she loves the quiet, smooth ride, big trunk, doesn't care for the SUV, etc...
I say she is crazy b/c outside of limo drivers, I don't see many people/women in their mid-30's driving around in these things...seems like an "Older persons vehicle"...am I right/wrong? stereotyping? ...do I have the wrong perception? Everyones thoughts are appreciated!
Should we choose to go the TC route, how much can we expect to pay (ballpark)? On Edmunds, I see numerous variations (ie Signature, etc) I there a "base" model TC? Are they difficult to drive / park / maneuver?
I know all of these questions would be answered via a test drive, but I have found these boards to be very informative, and would love y'alls first-hand knowledge / experiences, etc.
Thanks!!!!
If you use your Expedition to pull a mid-size boat or camper you may want to consider getting a Town Car with the handling and towing packages. This vehicle could replace your Expedition and Volvo. Not a bad deal in my book. You may want to put this purchase off for a while because Ford in planning on putting a DOHC version of the 4.6 V8 (300hp) in the Town Car starting next model year. Tons of blue tire smoke should help shed some of the "old foggy" image. :-)
Now comes the hard part - telling your wife that she is right!
We purchased our first TC when we were 47 and 47 is not old unless you're 25. The TC's have never been of speed and sport, but of very high quality, long lasting, quiet, comfortable,and easy to drive for long distances. Do you suppose the wisdom of old people enable them to discern the value of the TC?
Every opinion is really appreciated .
THANK YOU in advance
Thank you again
Question:Are all the TC models the same length?
Expedition. However, it is lighter, by about 700lbs, and the ride is A LOT better.
Wbj: If your air suspension switch was off the "Check Air Suspension" light would be illuminated in your dashboard. Sometimes the air early air suspension systems (1984-92) require replacement parts when the vehicle has over 75,000 miles on it. If your car is not under warrenty I recommend first going to a service garage that you trust rather then a dealer to have it checked out. My Grandfather has a 2000 Town Car and unless you get lucky most dealers try to rob you blind. Hope this helps!
Adri
