Pontiac Grand Am
1212224262751
  • photodoctorphotodoctor Member Posts: 17
    tonychrys......
    When I first started driving my new 2001 GA/GT I noticed my mileage was in the low 20's, around 21mpg. This was a real surprise as I expected something in the mid 20's. I drive 40 miles a day to work and back, about half of that is at non stop highway speeds of 60-65 mph. I called the service manager at the Pontiac dealer and questioned the lower than expected gas mileage. He assured me that the mileage would improve the more I drove it. Somewhere around 5000k you'll be in the mid 20's, he told me.
    Well, he was right. I'm now averaging 25mpg without a/c and about 23 with the air on. I'm approaching 9000 miles on the odometer.
    ALSO.....for a while I tried using 89 octane instead of 87 and had no better performance and no greater gas mileage. My car seems to like Gulf regular which goes for around 1.38/gallon here in central NJ
    tonychris
    I didn't realize that mileage would vary between the SE's without RamAir and the GT's with that feature. It seems from reading the other responses that the GT's get slightly lower mileage.
  • tonychrystonychrys Member Posts: 1,310
    Actually, the GTs should get better mileage because of the ramair. The more air the better the combustion.
    At about 12k I noticed we hit the mid 20's, just like you said. But when folks here start mentioning low 30's, I just start thinking something is wrong. Again, I'm a lead foot, I do about 70 -75 MPH when I'm on the GSP. Then it's heavy stop-and-go when I hit the Belt.
    I have several mods lined up (thanks to folks here and over at the GA club web site) for my GA that should help with handling and performance/MPG:
    1. Strut tower braces. I'll start with the fronts and then do the backs if I notice the difference.
    2. Plugs and wires as outlined by the_art_guy.
    3. I might go for the RamAir retrofit. A lot of folks don't realize that you can do the RamAir to your SE to get the few extra HP equivalent to the GT model.
    4. If I do #3, then I might have to do a cat-back in order to exhaust out the extra HP and see the difference.
    Let's not talk about the new stereo system I'm designing... (which will actually utilize the steering wheel controls).
  • jdexter23jdexter23 Member Posts: 94
    Well, I got my GA back from the shop yesterday, man is it good to be back in that car! I think dealers give out crappy loaner cars (Oldsmobile Eighty-Eight Royal) just so you are happy to have your car back, no matter the condition is:) BTW, my loaner broke down on the 4th day I had it...
    I had a list of things fixed under warranty this week.
    #1. Drivers seat back spring - replaced
    #2. Squeaky rear windows - they told me they were just dirty!
    #3. Passenger doors were hard to unlatch - needed adjustments
    #4. The clunk in the front suspension - This was a loose nut somewhere on the lower support, I can give the specifics at a later date if requested.
    I have 33K miles now and am about out of warranty. Hope everything holds up now. Someone mentioned this before an I have found this to be true as well...all my problems with this car are small inconviences, never anything with the drivetrain. Thats a big plus for the GA.
    My 00 SE V6 gets on average 28 MPG with 90% highway driving at 65-70mph. The best MPG I have calculated was 31, but that was an all day drive on the highway.
    Happy Motoring! Have a good holiday.
    jdexter23
    Let me know, when you get a chance, about the front suspension clunk. I don't think that's my problem, but, anything is possible. I'm hoping to take mine in within the next few weeks to have mine "de-clunked" !
    Thanks !
  • lrymallrymal Member Posts: 105
    I have a '99 SE, rather then the more desired GT, so am slowing tightening up the handling of the car. I purchased front and back strut braces and the difference I noticed was subtle. Admittedly, I got rid of the AWFUL factory BG Goodrich tires that were as loose as a south Texan driving in a Montana ice storm and replaced them with Michelins, which immediatedly helped the cornering.
    My impressions with the braces are that they don't make a major difference, but they do give a more solid feel that is noticeable. I would think the braces are designed to work with other performance additions, such as a more competive rear sway bar. I intend to get that. I think with the braces, Michelins, and improved sway bar, that my SE will handle nearly as good as the GT.
  • pgagt101pgagt101 Member Posts: 7
    Well, he was right. <<
    This was recently discussed at grandamgt.com and others had the same experience.
    >> I tried using 89 octane instead of 87 and had no better performance and no greater gas mileage. <<
    The 3400 in the GAGT is a low-compression engine. Unless you experience knocking (which you shouldn't) there's no reason to use higher-octane gas in this engine. As you've seen, you don't get more power or better mileage. Some people do feel a difference, but that's a psychological effect (I paid for "better" gas so my car must run better, etc.)
  • rose_budrose_bud Member Posts: 15
    Hi! I finally did it! I purchased the GA GT1 Sedan in Silver and I LOVE MY CAR!
    Thanks to those of you who took the time to write out your opinions and experiences. It was extremely helpful to get both the pros and the cons.
    I have a question - the sales person said that there was no 'broken in' period that I needed to worry about. Is this correct?
    Rose
  • bill211bill211 Member Posts: 21
    Well from info I gathered from multiple sources is this, GM runs the engines on a rack for a while before installing into vehicles. So in essence the engine has already been run-in. However there is a bit in the manual about "not driving too fast or too slow for the first 500 miles". What this means I have no idea
  • yurakmyurakm Member Posts: 1,345
    As well I remember the manuals for my cars (different, but also made by GM), they suggest not driving with constant speed for the first 500 miles. This is different than "not too fast, nor too slow".
    Practically, during the break-in period, I did not use cruise control, and drove in different environments: city traffic to work, on the rural roads, and highways. 0-40 mph, 30-50, and 60-75.
    The winding rural roads in hilly CT automatically provides for variable speed, as well as the traffic lights in city; only on highway I had to think about changing speed. Just changed lanes time to time: the left is fast, right is slow.
    There is a lot of part to break-up, other than engine and transmission. What about axles...
  • joe3891joe3891 Member Posts: 759
    With the engine factories building 8000 engines a day its very doubtful that they pre run them.They do pressure checks on the oil system to detect excessive leakage.The 500 mi run in seems to standard.
  • moeharrimoeharri Member Posts: 108
    I tried looking around in stores near my house for a set of Bosch +4 Platinum spark plugs for my 2000 GT, but no store around here has them. I was wondering if anyone knows of a site on the internet that has them for sale. I would probably also like to buy a K&N air filter from the same site if possible. Thanks for any info!
    I sorta kinda differ on this. Attended a consumer engine factory tour about five years ago and there was a giant narrow hallway with rack-mounted motors, on robot (???) type racks that were said to run for 48 hours.
    This was for a Mazda tour. Didn't see a single human in the hall.
    Beyond this statement, I know nutzing....
    However, the days of not driving past 45 MPH for the first 100 miles, not over 60 for the next 500, and not over 70 for the first 1000 are gone.
    And, I can remember back in the good old days, when I had my brand new Dodge Challenger with its 383 Magnum with 440 heads (those were wonderful days), that the manual said extended breakins were not necessary, however, do not drive at a steady speed for the first 2000 miles, and FULL THROTTLE ACCLERATION WAS BENEFICIAL.
    Well, "somebody has gotta do it...". I sure didn't argue with the manual.
    Rose, congrats on the silver GAGT1 sedan! Of course I'm biased (I have the same thing) but I think you made the best choice color-wise. I love the way it reflects light on a sunny day, and love the way it looks on a cloudy day. It's just a great-looking car. Consider getting a California Car Duster for the exterior and a California Dash (or Mini?) Duster for the interior. These things really work well.
    Regarding the break-in period, your sales person was wrong. The manual says that for the first 500 miles you shouldn't drive for long periods at the same speed. If you're on the freeway, drive at faster speeds for a little bit and then move over and drive in a slower lane for a few minutes. I don't think the manual says this, but most people also will tell you to not go above 4000 RPM during the break-in period. In other words, don't punch it. I took it really easy until I got to 800 or 900 miles, then started to drive a bit more aggressively and I really didn't floor it until I got up to about 1200 miles.
    Also, the manual says for the first 200 miles not to step on the brakes very hard. Break earlier and more gently than you normally would. I took it pretty easy for the first 400 or 500 miles.
    I have to agree with pgagt101, you basically shouldn't listen to anyone (including me) except the manual. All folks have to do is read the manual from front to back and over half the questions on Edmunds would dissappear. I mean after all, it's a $20,000 product we're talking here, it's worth the hour it takes to read the manual. I went back to my manual the other day and I discovered a feature on my GA I completely forgot about! And it's a feature I needed/wanted, boy did I feel silly.
    With regards to breakin, it's not a speed issue, but a RPM issue. The manual will tell you to vary the rpm's, which means don't use cruise control on the highway. My own personal rule is not exceed 50 - 60% of the engine's RPM range, which means no hard accelaration. And the part about no hard braking is an ABSOLUTE MUST on GAs because of GM's bad choice in brakes. I'm not saying you will have a problem, but you'll increase your chances of not warping (over-heating) them if you take it easy.
    I followed the above guidelines on my engine, after the first major service (7500 miles) I let loose, the MPG went up at about this time and the accelaration was smooth. One thing that is overkill but I recommend is changing the oil between 500 - 1000 miles, you wouldn't believe all the metal that accumulates from wearing in a new engine. Most folks will argue that the oil filter will trap this stuff. I beg to differ, I've seen the drain pan from some new cars, it's amazing at the amount of silvery stuff you'll see.
    I didn't take it easy on the brakes and noticed the warpage and bad braking at about 12k miles and had them replaced under warranty at about 15k. Then again, GM has acknowledged that this is a design flaw of under-sized brakes. I don't know whether they've improved since the '99 models.
    Enjoy the miles!
  • the_art_guythe_art_guy Member Posts: 61
    I have to agree with tonychrys about reading your owners manual. Next to your house, a car is probably the most expensive thing you will buy, it is to your benefit to read the owners manual. Most people think they know all about their car without having to read a "manual" explaining it to them.
    It only takes about an hour or so, and most likely, you will learn a few things about your car that you didn't know. For example, I found out that you can cancel the cruise control by pressing both the 'coast' and 'accel' buttons at the same time. This way you don't have to step on the brakes or turn off and on the cruise control if you just want to disengage the cruise control. I love this feature and didn't even know about it until I read it in the manual. I'm one of those people who coast up to a light if I see that it is red, so I use this cruise control cancel feature all the time. After all, there's no need to keep accelerating up to a red light that you are going to have to stop at anyway. I have a 2000 Grand Am SE V6, so this will work on the 99+ Grand Am's.
    Hope this feature helps those of you that use your cruise control regularly. Drive safe and read those manuals!!
    BTW, anyone else found out any 'features' from reading your owners manual that you didn't know about?
  • midlifecrisismidlifecrisis Member Posts: 391
    I didn't know about the cruise control cancellation. I read my manual from cover to cover and don't remember this feature. Guess that explains why I didn't do great in college. I'll have to try this feature on the way home!
    I did not have any control over my break in period. My car had 330 miles on it when I bought it. It had been paraded around the track in Dover, Delaware at a NASCAR race and then driven up to my dealer up here in NJ. Who knows how it was driven during those 300+ miles!
    When I first brought her home I took a bunch of pictures and then took the manual inside and read the whole thing. There was a lot of stuff that I didn't know about. I had no idea about the automatic lights, although I would have figured that out the first time I drove at night. But, it was good to read how this works.
    There were a lot of radio features I would not have figured out without the manual. Like, I was going to set the clock to the correct time, and I found out that if you set the radio to an RDS station (one where the station's call-letters appear in the display) and then press the hours and minutes buttons at the same time, the radio gets the correct time from the radio signal. This is pretty neat. I also had no idea you could specify different EQ settings for each of the presets.
    Hi! Thanks for recommending I read the manual! Duh... I should have looked there first for info. I'm pretty clueless about cars so this will help me out a lot.
    I took my GA in for a 30k service today (not the dealer I bought from), and also scheduled another appointment for warranty stuff. One of the things I mentioned is the side plastic mirrors fading/turning white, i.e., "chalking". I said that GM has a TSB out that says they should be painted. He looked me in the eye and said "we're not painting your mirrors." I said "can you look up the TSB?" and he reiterated "we're not painting your mirrors."
    Thoughts?
    " BTW, anyone else found out any 'features' from reading your owners manual that you didn't know about?"
    Well, a glaring misprint. Can't recall the oil filter number, but for the '99, the manual indicates the wrong oil filter, like a PF 44 instead of a PF 47, or maybe the other way around. Can't recall while here at the 'puter. Did cause the parts guys at NAPA and other places to look at me funny since the misprinted number didn't have a corresponding filter.
    Secondly, the instructions for the RESET button for items such as changing the oil filter were confusing in the '99 manual. Seems it conflicted with itself in about three of the instruction sets. It is obvious that that particular manual was written independently by different authors as it developed.
    This manual was probably printed in late Spring of '98.
    Also, don't like the "drivers ed" section at the beginning of the manual, but with the law-suit hungry public, I'm sure Pontiac and other makers don't have a choice.
    Other than those little gotchas.... this manual is "required" reading.
    Cancelling the cruise control works! Now I have one more toy to play with when I drive to work. You've gotta love this car.....
    To my knowledge, there IS a TSB out on fading of the black plastic mirrors used on the Grand Am SE's. However, I don't think that this means a dealer has to fix the problem that is noted in the TSB. These are service bulliten, they don't necessarily fall under the category of warranty fixes.
    Case in point: We all know that the Chevy Malibu is built on the same platform as the Grand Am, thus sharing many parts. Before my Grand Am, I owned a 99 Malibu. My rotors were warped and there was a service bulliten out on them. I took my car to my local Chevy dealer and they said there was no way they were going to fix them under warranty because it is " a wear item". Needless to say, I ended up paying more than I should have and was very disappointed. Fast forward to now...
    I have my 00 Grand Am and there is also a TSB out on the rotors. I took my car to my local Pontiac shop and I asked them to check the brakes, I didn't even know for sure if the rotors were warped. 30 minutes later I get my car back and notice nice new, shiny rotors. I asked them if they replaced the rotors and they said they did because they were warped. I was happy, didn't have to pay a dime and drove off.
    In both instances I was told that the new rotors were in fact made from a different mix of metals and are supposed to be much more durable than the stock rotors.
    Back to the mirrors...I did get my Pontiac shop (the same one that did the rotors) to paint my mirrors, instead of just replacing them. One of the service techs there said that they were aware of the TSB and would replace the mirrors with new black plastic ones. I went to the service manager and asked him if they would paint them silver, to match my car (as they are on the GT models) he said sure and so they just painted right over the faded plack ones.
    I think this kind of stuff varies from dealer to dealer. I have experienced both good ones and bad ones, so I think my statement is valid. If you have a good shop then they should cover the TSB's under warranty, if you don't then they probably won't.
    Good luck and safe driving!
    I do not think the Grand Am and Malibu share the same platform. Anybody else know if this is true or not? I was told that the Grand Am and Alero were built from a new platform for the 99 model. Malibu's appeared in the 97 model year.
  • corvettecorvette Member Posts: 11,414
    I have seen the same thing on a GMC Sonoma, and conveniently ignored it until it was time to sell it. I am not sure if the materials are the same, but I was able to make the mirrors shiny again by using Meguiar's Step 2 Deep Crystal System Polish. If this has happened to anyone out of warranty, you might want to try this.
    Is this stuff for plastic?
    It is taking the dealer an extra day to install the new dashboard pad in my 99 GT. So they got me a rent a car for the day, and it is a Cavalier. I owned a Cavalier before the Grand Am, and was pretty happy with it for the most part. Well, now getting back into a Cavalier, I realize what I was missing with the Grand Am. Granted that it is not fair to compare the two cars because the Cavalier is more of an economy car and is cheaper. But what a difference in every aspect! The Grand Am feels so much more substantial, even the way the doors shut. The dash, seats and appointments are so much better in the Grand Am. And the performance is on another planet. The Cav can move out pretty decently, but you've got to stomp on the gas and rev the engine very loud. The Grand Am just goes with little effort and noise.
    I wonder what the cost comparison would be between a base SE Grand Am 4 cylinder and a loaded Cavalier. The GA probably wouldn't be that much more in price and IMHO you get so much more in value with the GA.
  • vocusvocus Member Posts: 7,777
    According to CarsDirect.com, there is about $1200 difference between a loaded Cavalier LS sedan and a loaded Grand Am SE. Interesting.
    I liked the Grand Am when I got my car a couple months ago, but didn't get one because I was scared of the GM reliability. I got a Mazda Protege instead. I now have 15K in 7 months, and have been back to the shop like 4 times for stupid stuff (alignment, warped rotors, etc), so buying Japanese doesn't necessarily mean you are going to get a better car.
    With the nice rebates now, I might just see what kinda trade-in deal I can wing on the Grand Am vs. the Protege... :)
    Would you get the 4 or 6 cylinder Grand Am? There seems to be mega-incentives on the 2001 model Grand Ams. It could be worth looking into, provided you don't get killed on Protege depreciation.
  • collegepro04collegepro04 Member Posts: 3
    I just pounded a friends 2000 Grand Am Ram Air GT for an 800 mile round trip in three days. I'm used to the understated reliability and unassuming sporting charachter of my Mistubishi Mirage LS Sport Coupe. One thing they should sell with these things is a radar detector because if you don't like cruise (like me) you'll find yourself into triple digits before you know it. Very impressive ride and handleing. I'm 6 foot and I was very at home in the GA. I mashed the accelorater to pass a slow moving BMW 325 with two young men such as myself in it. They gave chase on the interstate and gave up around a hundred and ten or so- I never realized how fast we were going until I passed one of those "Your Speed" trailers my state loves to much. Thank God there was no cop in sight, they were running radar the other direction at the motercycles pouring over the SD/MN border from the end of Sturgis. Over all, this car could convert me back to American made autos.
    There is no other but the Grand Am GT sedan in bright red for me. :) I should have gotten one back in February when I got this Protege, but like I said before I was scared off by the notion of poor reliability. I am not going to be able to make the trade now, as my 7-month old car with 15K on it is worth a whopping $6000 less than I owe on it. That's what happens when you drive alot and have a small car that doesn't hold its value well. Perhaps a year or so down the road. Or maybe I will lease a Grand Am initially, then turn it into a purchase. We shall see.
    I have had both: a '96 4 banger GrandAm and my current '99 V-6. Both are marvelous motors!
    I remember a review by one of the magazines on the 2.4 motor. Several vehicles of the GrandAm size were being measured for 0-60 ratings. Both GrandAms were compared, the V-6, then the 4. The magazine said after the 6 was rated, that the testers in the completed lane heard this loud roar and saw this red streak about 1/2 second later just cross the line. It was the 2.4. "What the heck was that??? Was that that 4 cylinder GrandAm?" They were amazed.
    Obviously, that made me really feel good since it had been YEARS since I had a 4 banger. And this was no mere 4 banger. This 2.4 cycliner motor is a very nice box.
    When I finally traded in the '96 for the '99, I was equally amazed by the V-6. Definitely could feel a better balanced pull in the point-and-shoot department. Lots of wonderful "sweet spots" in the acceleration. It will surprise. And, it yawns at high speeds when the cruise is on. REally hard to push this motor.
    So, which is better? NEITHER. Both are marvelous. Depends on your wants and wallet.
    Did I happen to mention the V6? ;-)
    Make no mistakes folks, this is not a light econo-box car. Get the V6. You'll be happy.
    The 4 versus 6 cylinder debate reminds me of the bias in Consumer Reports. When they reviewed the Grand Am in 1999, they drove the 4 cylinder model and complained about everything and how it doesn't stack up against the Accord and Camry.
    Interestingly, when they reviewed the Accord and Camry, guess what engine they drove? The 6 cylinder of course. I was so mad at their lack of objectivity I cancelled my subscription.
    BTW - I've heard from many people how good the 4 cylinder is. If I had to get a car for my teenage kid I'd definitely consider the 4-cylinder. As for me - just call me the rocketman, and I'm really spoiled with the GT!
    ...I drove nothing but 4-bangers most of my single life. Fuel-effecient, yet sporty cars. If it's someone's first car, then yea, maybe the 4 is cool.
    But once you are an accomplished driver and drive a V6, nothing else compares. You get the combination of the decent fuel economy and the power when needed. After my first V6, I refused to go back to anything less for anything that weighs 3k lbs or more.
    No, it is for painted metal or plastic, but as far as I could tell, the mirrors on that Sonoma were worn or weathered down to the plastic.
    So what you are saying is that it was able to polish the plastic without scratching it up?
    I did it the other way around, Tony. I learned to drive on a 1994 Bonneville SE 3800. And you KNOW that engine has some power in it. I then went to a 4-cylinder Cavalier, then a Protege, and now my current 2.0 Protege 4. I want a V6 again though. I got the 2.0 Protege because I wanted to save on gas. I average about 24.5 mpg with my automatic and 4, which is probably the same or less than I would average with the Grand Am GT V6.
    This is the last year of the 2.4 4cyl, when the supply runs out they are history.
    They are being replaced by the 2.2 motor from the Saturn L Series cars. It's suppose to be a better engine, but less power and more economy. I don't know if that's a change for the good or not.
    Ya see?! You know you want it baby... the power that is. It's nice being able to launch the car with out the engine straining.
    The only thing better is nice V8, but we all know what happens to the MPG :-(
    I just filled up my 2000 SE V6 a few days ago. My trip odometer was at 367 miles and the gas light hadn't even come on yet...I got 30.7 mpg. That was with some A/C, some traffic and some 50mph crusing.
    I'm serious about changing the spark plugs, they really make a difference.
    I love this car!!
    Do you have to set the spark plug gap when installing them?
    I'm speechless... seriously. I must get these plugs!
    I've been away from the board all week and just read that rosebud took the plunge!. Good for you.
    I trust you got a good deal on it. Take good care of it and have loads of fun driving it. You shoulda got the Red - it goes faster, but the Silver looks sharp too !!!
    V6 - 4 cyl. debate....I remember in 95 when I was shopping for a GA - I test drove a 4 cyl GT, then got into a V6. Wow, what a difference!
    No comparison for me. The V6 won hands down. Of course, when it was time to go for a current model
    there was no question which engine to drive. The 3400 is a nice improvement over the 3100.
    PS: My wife drives a 99 Malibu V6 and I'm very impressed with the performance. Having that extra power when you need it is a secure feeling.
    The radio controls on the steering wheel and the power driver seat were well worth the extra money I paid for the GT1.
    I got the car for a little over 20.5K (with taxes and all that other stuff). Is that good? It sure feels good. That price includes a factory rebate.
    I was able to put a nice chunk down so my monthly payments aren't too scary. The insurance is less than I had thought it would be. It's rough insuring a 5.0 mustang convertible!
    I was originally looking for a white GA. Red is very nice and yes, I understand that it DOES go faster. :) But, I have to park the car on the street and I had visions of people walking by and scratching it. The red is such a looker that I was scared that people would hurt it just because it was so pretty. And I was concerned that dings from parking lots would show up more... At any rate, too late now! Silver it is. And the silver looks great with the rims. I didn't get the aluminum rims; I got the regular chrome rims and they almost perfectly match the silver on the car.
    Question: Do any of you take your cars to car washes? The ones where they have folks dry them afterwards?
    Another question: Should I feel guilty about wanting to take it to get washed? Does this make me a 'bad' new car owner?
    Also, do any of you have problems scraping the front when going in and out of driveways? It's not the body of the car that I'm scraping..It's some vertical piece of something. Maybe it's there to protect the car underneath?
  • donnariedonnarie Member Posts: 2
    Any thoughts on a wind deflector for the sunroof of a 2001 GTI (white)?? I had one on my previous car and really noticed how it cut down on wind noise, but I have not seen one on a Grand Am even though our local Ziebart says they can install one for $90 +/- . I don't want to ruin the appearance of the car!!!!!
    Re the front scraping going in and out driveways - mine does that often also. It happens less often if you can enter / exit at an angle
    First, congratulations on the new ride. Silver is beautiful. Red is hot. My '99 is red. So far, never have had it keyed and the car is knocking on the 60k door.
    Regarding finish care... I go to the chamois type slop slop, spinning chamois brush type washes. That's the best description I have it for it. I *avoid* the brush washes that have nylon filaments. Look for any of the franchais type car washes, and main brand gasoline stations, and you'll "probably" be safe.
    I AVOID any carwash place that use humans to wax and dry the car. These guys have caused swirl marks on previous vehicles for me and it just isn't worth getting into an argument with them.
    Also, it is unnecessary to buy a buffer or anything like that. I'm serious. Your car has CLEARCOAT on it, and this stuff is designed to remain shiny waaaaay past the car's life. When you clean or wax the car, you are not even touching the paint, you are touching the clear coat. Think of taking care of polyurethene (sp?) coated tables and you'll be close. Don't fall for waxes that restore OXIDIZED paint, because you don't have any, as long as your car has its clearcoat intact.
    Here are some tips that I have learned, as a result of having one of my former students (I'm a school teacher) showing me some goodies at the car shop he works for. He showed me a clay bar that the detail shops use. It is designed for car clearcoat cleaning and basically, it along with Windex liberally applied, will pull all pine tar and stuff that just sticks to the paint, and any stubborn road film. Although the body shop's clay is far more generic, you can buy this stuff at most auto shops, and also at any place that sells Clay Magic. It honestly works, and keeps my nearkt 60k mileage car body in almost new shape.
    Secondly, don't buy any wax that requires heavy buffing or heavy cloth wiping. This is how you get swirl marks, mostly noticeable in the sun. Remember that the ClearCoat is designed to LOOK shiny forever, even without any type of wax coating. However, after clay cleaning the body, you'll want to complete the final cleaning with a light duty wax that has hardly any abrasives (the clay bar has done the abrasive scrubbing for you).
    Typically, a detail supply truck will come by your dealer once weekly and you can buy any showroom type wax from there. Very easy to apply, no HARD RUBBING required, no swirl or buff marks show up in the ClearCoat.
    You would want to apply this once a month, just to keep the shiny look in "wet" condition. Should take no more than 30 minutes for the whole car.
    The Clay Magic application would be done once every three months or so. You will get some road film that just won't come off and the Clay Magic is honestly the easiest way to get rid of it.
    Anyway, this is my routine and basically, the whole approach I'm following is exactly how the detail shop does their work. There is really not that much work involved and the results are immediate.
    I think in short, don't "love" the car body too much.
    Oh yeah, the front scraping. That air dam is separate from the other wind deflector pieces and can be replaced. It really isn't that expensive. I'm not a fan of the thing, but.... Anyway, I still have the original and it is not torn and has done nearly 60 k of scrapings.
    If you buy the Bosch Platinum+4 plugs for the 1999+ Grand Am model, they will be gapped correctly. I think gap for both the 4 cyl. and V6 is .06".
    lrymal - Thanks! I'll check out the Clay Magic.
