Visitor Agreement.
I have not had any leak problems on my 1999 GT that I bought 1 1/2 months ago. But I have seen many posts regarding cars with this problem.
PS By not locking I mean that the upper part of the seat can be pushed forward with your hand (without resorting to pulling the little lever on the side-unlike in every other non GM car I've seen-so is this a GM thing, or is the seat messed up?)
Trying to convince my wife that we have plenty of gas when that thing goes off is my next challenge. I've been rather unsuccessful, although she allows me to keep driving when there is a quarter of a tank left...so I'm making a bit of progress. (She's from a family of chronic re-fillers, I'm from a family of Kramer-style fillers)
I was talking to a mechanic friend of mine and he warned me that it is not very good for your car to get too low on fuel. I guess that this can lead to some dirt or grit in your tank going through your fuel system.
Happy Motoring All,
Stephen
Just wanted to fill y'all up with my experience with my 99 Grand Am GT1. The car has about 2700 miles on it and I have had to take it back to the dealership once to have a couple of things looked at.
1. The brakes were groaning and grinding when the the car was at a downhill incline and I applied the brakes halfway. They were grinding when the car was on the level and I partly applied the brakes. Well, the dealer had a look at them, told me that this is the way the brakes behave. Told me some story about Grand Am brakes being non-asbestos. Anyways, the problem was not solved. Would appreciate if someone would fill me in if they have had similar problems with their brakes and if they were corrected.
2. The steering wheel was slightly offset. They corrected that one by realigning the wheels.
3. The driver side mirror flickers if I try to adjust it after some time of inactivity. Dealer supposedly had a look at it, told me there was nothing wrong with it and the mirror still flickers!!!!
Other than the above, nothing to report. Grand Am is a real fun car to drive. Have not had any problems with water leaking into the passenger compartment or anything else. Gas mileage is still pretty low @ 20-22 mpg (but I use aircon a lot).
One question though, the maual says that the tire pressure should be 30kpa all around. Is that the right pressure or should I be trying something different?
We all have a great car. I love mine!!!!!
When the chime goes off, I set the trip computer to fuel used, then I ignore the gas guage... When necessary I let the computer read 15.5 gallons used before I fill-er up... The pump usually pumps in 15.5 to 15.8 gallons... The gas guage is also like a half inch below the E !!!!
Supposed feature to allow for a gas resevoir... Either that or GM doesn't want to have to deliver too much gas in its Free Roadside Assistance
Otherwise, I LOVE my car. Not the best fuel, but zippy. No problems with water leaking or door panel. Great in rain and snow. Good handling. Good pickup (4 cyc. too!).
The rotor problem may due to the non-ventilated discs. Has anyone heard of an aftermarket replacement with ventilated discs?
The rotor problem keeps recurring in my 95. I found it is almost just as easy to replace the rotors as it is to machine them, since they aren't very expensive (about $20 each, aftermarket) and they seem to last longer than if they are machined, probably because they are thicker and can withstand the heat better.
Your problem, is most likely a crappy rotor... I think GM is pretty famous for sticking the rotors on at the factory from the bargain bin...
I would opt for DuraStop Rotors if you wanna stay GM... Otherwise go with some other brand...
Does anyone know of any major issues with the new 4 cylinder engine ?
Any input would be an assistance
Should I plan on trading this thing in when the warranty is up? Or will it be a car I can keep for awhile? Any feedback would be appreciated.
I havn't had any more rotor problems since going aftermarket, but I do keep my eye on the pads more now. Under some conditions, the pedal will fluctuate, but I attributed this to the anti-lock system.
The standard, and the CrossDrilled/Slotted...
Which are you going to get? (I would opt for the CrossDrilled/Slotted
Anyways, DuraStops, are made my AC/Delco... They are in the AC/Delco Performance Catalog at the dealer...
Best of Lucks on the Brakes. I will be curious to hear what you go with.
Stephen
One problem... The first time I took it on a wet rainy road, I could swear the rear right door was ajar. The sound of the wet road just seemed a bit noisy to me, but perhaps I was just hearing things. It did look to me as if the rubber molding around the door was not placed as well as on the opposite side, so I decided to take it back to the dealer. After their inspection they said the right rear door alignment was off, so they realigned it. There was a visible difference in the way the molding fit now, but alas the sound still persists. Am I going crazy? Anyone else had this problem? I have checked for leaks... (it is POURING here in SE Michigan today), and I see no water anywhere, which I guess is good. When traveling at high speed, it was less noticeable (I'm guessing that other general road noise is blocking it out??) If you had this wet-road noise problem, please respond! BTW, I don't notice any excess noise on a dry road.
On the GREAT side, I just took the car on a long road trip... approx 1200 miles total... and got 31.5 MPG! How is that possible? The rating is 20/28 for this car w/this engine. Needless to say I was thrilled, and trust me I checked my math a half-dozen times (368 miles, 11.661 gallons). Have been getting about 23-24 in town.
Later, all!
JS
I haven't got more than 23-24 mpg no matter what kind of driving I do. 30 mpg does not seem possible. Mine never varies more than 3 mpg from tank to tank.
Also, for those questions about the gas mileage. I use my car for business. I live in No. California in the Bay Area and travel the freeways here. My gas mileage averages about 31 MPG when not in commuter traffic and about 25 when in commuter traffic.
Also, there IS a slight rushing wind noise that is pretty standard in the Grand Am but my experience is that it is coming from the front and not the back. I have driven many other Grand Ams when my car was in for repair at the Dealer and I found this problem to exist in all the other ones that I have driven. As I mentioned earlier, Pontiac bought back my original 1999 Grand AM SEI and I opted to purchase another one. I just can't help it, I love the Grand AM even with its assorted problems. The repair department at the Dealer and I are on first name basis! On my brand new SEI I had the dash replaced after four days!!! The service department had a devil of a time installing that!!! When I picked up my car after they had it for two whole days, the steering wheel was goofed up so back to the Dealer tomorrow! Nonetheless, there is just something about that Grand AM that has charisma. And to think that I almost bought a Buick Regal instead!
I'm considering a Buick Century now, because a Century Custom comes loaded for about the same price as a well optioned Grand Am.
I guess overall I'm happy with the Pontiac, but I doubt if I will buy another Grand Am.
You won't hear any complaints from me, when the "higher performance", CrossDrilled n' Slotted Rotors are approved for warranty replacement. Even if you just pay for the diff, I think its pretty cool...
Now only if you can convince the dealer to install the 12" rotors.....
Some will... One of my friend had the dealer install 12" rotors from the intrigue, (autobahn package), onto his GP...
Just note, that if you install 12" rotors on the front, your temp spare wont fit anymore, because the brakes won't fit in the 15" wheel. Some say if you go flat on the front, you wouldn't want a donut on the front, so the recommend puting the donut on the back, and move a goodtire forward... If its too tedious, you can prob check the price for a donut from an intrigue with the autobahn package...
If going for 12" rotors tho, I would just get 12" CrossDrilled Slotted DuraStops, (or your fav brand), instead of plane jane rotors from an intrigue...
Peace!
JS
My GrandAm is configured like yours. Mine if just coming on 4 months old. I know exactly what you are talking about with the noise that you can only hear when it is raining. I first experienced that and I thought that the window was down. I thought sure with that noise there was a bad seal or something. Yet the car is as quiet can be on no rain days at ANY highway speed. I have had this already is some absolutly terrible rain storm and not a drop of water leaks into the car anywhere. I just chalked it up to oddity with the design. As long as it keeps me dry I am happy.
I have not taken mine on quite that long of a trip but on one occasion I have gotten as high as 29 mpg so your 31 deffinetly sounds possible. I think if I take mine on a long trip it should be able to get the same numbers. Mine too is the SE with the V6.
It really seems to be a great car. My only concern right now with it the long run it sqeaks and rattles with the interior trim. The interior trim just does not feel that solid in some places.
Happy Driving,
Stephen
AV007...I can't wait to have my rotors replaced!!Ha! Ha! I figure around 10 to 12K is when the rotors will begin to have a problem. I only have 1100 miles on my replacement Grand AM. The Dealer will want to machine them, of course. But, they are really sick of seeing me and I think they'd give me whatever I want to get rid of me!!!! When I ask the Dealer to use the DuraStop they are going to wonder where I got my information to even ask for such an item!!! How do you know about those DuraStops?
Boy, you must not travel alot with 50K on a 5 year old car!!!
You are right about the Century. The Dealer did not have one on the lot for me to drive. But they are a step lower than the Regal (I was told by the Dealer)
The steering is the worst part as I drove through the country a lot and it seems I have no control over where the tires want to go.
Back to the dealer tomorrow....again.
We originally bought the car for my wife, but now my daughter uses it when she's home from college.
If I was buying today, I would lean toward the Buick Century, because I still feel it's a better deal at this point.
You must be used to the japanese cars, where ACC is in between lock and run.... GM puts ACC counterclockwise of Lock, and run clockwise of Lock.
off, ACC, on , Start.
and yes when the ignition is set to ACC, in addition to radio power, etc., three or four of the warning lights on the dash come on.
And me used to Japanese cars? Are you kidding? I drive a Silverado Z71!
Mine does that too with the dash lights when the key is in the ACC position. I thought that was a little weird too with the lights. I wish that it did not do that.
The ignition in the 99 GrandAm's are Japanese style in respect to how the key turns. My Buick was not like that, it was the more traditional for GM turn in reverse. It probably has something do with the fact that it is dash instead of column mounted.
Mine is a 99 SE with the variable effort. I am not 100% sure on the tires but I think that they are the 15"s. I will take a look this evening. Steering seems to work fine other then that wonderful torque steer.
Have a good one,
Stephen
Anybody out there with a Grand Am with 20K + miles who can say how these 1999 cars GA's have been holding up?
