I have had my computer tell me I'm getting 17-19 in the city. From 20-36 on the highway. What I really want to know is what I get on average for that whole tank of gas. I have only been able to do that once on a tank of gas with about 90% highway driving. It was over 25mpg. Almost 26. I think I could have gotten 26 if I hadn't had about 25 miles of it city driving.
My '05 Sienna, which is up to over 2,500 miles now, is rated 36% better city and 37% better highway than my '02 Mountaineer, but it only achieves 12% better mileage when driven the same way on the same roads with the same passenger and cargo loads.
I tried premium fuel, and it adds 0.1 to 0.2 MPG, hardly worth the extra cost.
The CE should produce a little better mileage, as it weighs the least of all Siennas.
I just filled mine up today. Set my tripometer to zero.I'll see by next week what it will get with mostly city driving as I no longer have to pick my grand kids up from school.
Considering the weight you were pulling and the mountain you were climbing and what you got going back without the trailer, I'd say you did very well.
I have had mixed results trying to figure out whether the AC is more efficient than running with the windows down. Minivans have rear windows that allows air to flow through the vehicle, but it makes sense that opening the windows produces drag.
I do know that I can drastically reduce my engine temp running AC while in doing stop and go traffic since the second fan kicks on automatically.
I also know that crosswinds and speed also factor into the equation.
The Discovery Channel show "Mythbusters" did a test with identical vehicles on a test track and had no difference in mileage.
Anyone have any thoughts?
Another consideration though is the noise level and the cumulative damage that can have on your hearing. I can attest to this since I have suffered hearing loss in my left ear at the wind-roar frequencies from the years driving highway speeds with the driver's side window down (in Spring, Summer, and Fall good weather, of course). This corresponds neatly to the frequency of the alarm on my clock. So, this morning for example, since I was sleeping on my right (better ear) side, my wife had to punch me to make me aware of the insistent trilling of my alarm clock. Without her then, I'm either going to be habitually late abed or a left-side-only sleeper!
All things considered then, I think that the advantages of air conditioning far outweigh any slim possibility of a gain in leaving it off. So, IMHO, you can enjoy your comfort guilt-free!
He also won't turn on the a/c until everyone is in and the doors are closed. I told him he works the a/c more by doing that. I said if you turn on the a/c while people are getting in, you'll blow a lot of that hot air out while the doors are open. He still doesn't believe it.
He is certainly wrong about getting the hot air out. Just leave the windows down for a minute while driving, then close them and turn the A/C on.
But only after the greenhouse-effect-super-heated air in the vehicle is allowed to escape. If the vehicle is sitting in the sun and you recirculate without letting out the hotter-than-the-ambient-temperature interior air first, then you are working on the very greatest possible temperature difference to overcome. A combination of all these suggestions folks have given above (open the windows for a minute and then recirculate) will cool off the vehicle the fastest way possible IMHO. Where are the Mythbusters to confirm or deny?
I thought that was only true with automatic climate control.?
With the temp on max cold you can still keep from freezing by turning down the fan, which in turn keeps the compressor from running as often (there is less volume of air being cooled)
This is what I have always thought. Once turned on, the A/C has but one setting, fully cold. You can cut down on the cold air blowing in by turning down the fan, or turning on the dial to allow a small amount of heated air to mix with A/C air.But as long as compressor is ingaged, A/C would be running at full force. If you increase the fan speed, you increase the force of A/C coming into the van. But as long as compressor is running, you'll use same amount of fuel no matter if fan is on high or low.
Max cold, cuts any warm air coming from outside the van from mixing with cold A/C .Allowing only the cold air to keep recirculating through the van.
Am I wrong on all this?
I get the same mileage with it on high or low - and my Venture has two AC units, one front and one rear. I messed with it quite often in my travels over the week, about 2500 miles or so. Today reached about 94 outside, so it was pumping all day. Once the vehicle is moving, electricity is free and abundant - use it or lose it. I always keep my back windows open for a few minutes to draw out the hot air, which make a huge difference. I always thought that the AC clutch was either engaged or not, but it could be variable. I do know that AC is much more efficient at highway speeds as opposed to having the windows down. Or you could ask a good dealership - they should be able to tell you - get it in writing and you can do an "I-told-you-so" that will burn for a good long time! (what's family for?)
I live in a rural area, with a lot of hills. Much of my driving is 14 to 15 miles per trip.
I have tried preminum, and mid-grade. The best mileage seems to occur using regular.
Higher octane will not give you better gas mileage unless your vehicle calls for it, or unless your vehicle suffers from ignition problems. You also need to take into consideration whether or not your fuel has alcohol in it or not. Here in Southern Illinois, our 89 octane is cheaper than the 87. The alcohol added to the fuel to raise the octane is cheaper than gas, so lower price and higher octane.
Though the alcohol supposedly helps keep the engine and injectors cleaner and lowers emissions, it will also reduce your gas mileage. Your car will run better on pure gas, and raising the octane will only resolve engine ping.
There are too many factors to accuratly gage your mileage. Use your "instant" mileage to tell you what you are getting at that time, and use it to adjust your driving habits to increase your gas mileage. You would be amazed at some of the simple things you can do (or not do) to stop wasting gas and easily exceed the EPA mpg for your car.
The alcohol added has lower energy than gasoline per unit volume, so it's not too surprising the mileage goes down.
My question is what type of gas miliage can we expect to have ?
I have 2005 DGC SXT with 4800 miles on it.
I'm not sure break in, but always thought it was about 10k miles? I'm getting about 19 driving round town, short trips etc.. From day one, I've been getting 24-25mpg on Highway.
I also have a 2005 DGC, 3.8 engine. I have around 4,500 miles on it. My first tank got 16.10. I go from that to around 18mpg city. Throw in a combination of city/highway driving and I can get a little over 19mpg. All highway, I can get a little over 26mpg.
I had also hoped to get better, but these are heavy vans and when I think about it, I didn't do much better in the city with my six cylinder Dodge Dakota and it was a lot lighter. Plus, I was never able to get over 20mpg on the Dakota on the highway.
City driving can kill mileage. Especially if your sitting at long lights or idling waiting for someone. The a/c also drags it down. See if you can time your lights better so your not stopping for a lot of them. Starting up from a dead stop is what really sucks up the gas in these heavy vehicles.
We have now been a proud owners of a KIA SEDONA L, 2901cc Turbo Diesel Powered MPV, for 6 months, we love this vehicle to bits, its a joy to drive and travel in.
We live in the UK, recently we decided to go to Germany by road, total round trip of some 1500 miles, after the journey we decided to do a fuel check. after doing the calculations it worked out that we are getting 47.6mpg from this car. I feel that your mileage seems ever so low compared to ours.
Only had one problem with this car, and that is that the bottom radiator hose split causing it to loose all its cooling liquid, the engine magagment system kicked in and would not allow you to drive the car, as the throttle is what we call drive by wire, meening there is no throttle cable so you can not accelerate, it would only idle.
after replacing the hose we had terrible trouble replacing the lost cooling liquid,
Could not get the system bled, we have now learnt that there are two heater matrixes in the veh. the rear heater system was causing the system to air lock.There is a certain way to refill the cooling system, you must get the front end up higher than the rear to allow the air in the rear matrix to flow up and out otherwise the system will continually to blow all the water back out.
By the way this car is 2001 model with 40.000 miles on the clock.
This is a UK speck vehicle.
It only has 370 miles so some break-in is needed but I never expected mileage this low.
I just checked and tires (17" wheels) are all about 33psi when cold.
Any other owners see mileage this low on their new Sienna? BTW, anyone know how to clear the AVG mileage meter after each tank?
I never heard of any minivan getting mileage like that. How did you get that reading?
He forgot to mention it was with 2 horses pulling him!!! :P
If not, maybe you are right. But I suggest at least FOUR horses, the minivan is heavy heheheh.
It is a bit dispointing since Toyata's claim is 18/24. But what the heck, as long as i do not smell fuel leaking.
It is good to know that mine is not the only one that has lower mpg.
That probably would do it. Better yet, the world could change from metric, instead of us having to change. That only seems fair.
If you really want to be anal about this, get a small spiral notebook to keep in the glove compartment and record the mileage for each tank of gas. This is the most accurate way of keeping track of your gas mileage. I do it for my Quest and my Intrigue. I would not rely on the computer for your gas mileage.
Beats me. We have an 05 Nissan Quest with 9,600 miles on it. Average mpg for the first 6,200 miles was 22.4mpg. We recently got one tank of 25.5 and one of 26.5 (428 mi, 16.1 gal). Mostly highway, as you might imagine, at speeds of 75-80.
My experience is that a lot of SUV owners are in denial. I know two guys who both have Suburbans. One says he averages 16 mpg and gets 20 mog on the highway. The other one says he averages 12 around town, 16 on the highway and has never gotten higher than 18. Go figure.
1. Imperial gallons instead of US gallons?
2. Diesel engine, which is not available in the US.
Either that or they meant that gas mileage was "improved" from the point of view of the oil companies! :P
On our first tank, I got about 18 1/2 mpg in combination city/hwy driving. I usually can get the ave. difference in city/hwy EPA estimates, so I'm hoping the MPV will give me about 21 combined after the engine loosens up a bit.
When the low fuel light came on, I drove the van probably another 30 miles. (Probably not smart not knowing how much reserve I had) When I did fill up, I found I was still about 2.5 gallons from empty.
Congrats on your wise purchase.
