Visitor Agreement.
Subaru has a very loyal following. Audi enthusiasts in number probably don't compare. Just look at the message boards here at Edmunds ...it's almost cult like over there in the Subaru section. There's no reason not to compare the two cars. Yeah, I know that there those who wouldn't put the two in the same category. But nevertheless, the two are cross-shopped quite frequently ...both being AWD sedans that are quite sporty in nature.
Still, I'd urge you not to to make a decision merely on price. I know I had to convince myself when I was shopping for a sedan that an Audi was worth the slight extra money. I too was looking in the 25k range or lower. But for 30k, I just couldn't find a better VALUE.
Another quick note: remember the safety factors. The A4 has such standard features as side curtain air bags and stability control. Also the A4 scored excellently in the IIHS and the NHTSA crash protection tests.
--'rocco
Meade
About those awesome looking underbody panels, yes they are actually authorized Audi products!!! Finally someone's thinking straight. There was one on a red B6 A4 on show at a dealer hosted party with Audi Car Club Chicagoland and here's the pic of the COMPLETE body, from the front, side and rear.....incredible.
http://www.audichicago.org/main/Events/2002/Picnic/PC_02_Pics/SP_- - 02.htm
Billy
I am also curious what owners think about owning the warranty. Basically, does the warranty get honored or do the owners just get hosed?
Here is an interesting article from automobilemagazine.com describing the problem:
click here for the automobilemag.com article
You can also find the offical press release on the AoA web site which states their intentions:
click here for official VW/Audi press release
But, to answer your question on "owning" the warranty if I understand what you're asking; I believe that Audi does try to be honorable in accepting claims from owners. Yes, you'll read stories from those that think they got hosed in one situation or another but for the most part Audi tries to honor most claims if legitimate. Personally, so far, they've done everything I've asked them to do under the Audi Advantage coverage. Any little rattle or adjustment is gladly looked into. Things such as wiper blades have been replaced several times. I've haven't yet had any major claims I've asked to be covered but I have the feeling that my dealer wouldn't hesitate to take care of it. Now, if you are asking about an extended warranty, I'll let somebody else answer that.
re: painted lowers-- oooooooooh, ok, it's a body kit! I thought we were just talking about painting the lowers to match the body color. I did hear talk about a kit but didn't know it was already available and an actual Audi accessory. The kit really looks sharp. I really appreciate the relatively understated look without the gaudy appearance of the typically overstated designs we see so often. Thanks for setting me straight. It's not the first time I've looked like a dummy.
--'rocco
What is the cutoff for when the new non-defective coils were being put in these things?
ptrekker-- The ignition coil problem shouldn't apply to the new '03 models now on the dealer's lots or those currently scheduled to come into their inventory. It only affected the very early '03 units. According to what I remember from the extensive research done by a guy from New Mexico on an AudiWorld thread, the '03 units which had a build date after 06/02 should have arrived from the factory with the new and impoved coils. This means that only the very first '03 units off the assembly line should have had the defective coils. My dealer said that all the cars in his inventory are okay and even if if there was a stray one that happened to be an early production '03, that they had instructions from the factory to change them out before delivering the car. So, you shouldn't have to worry at all.
When it gets down close to finalizing the deal on a specific car, I'd suggest that you check the build date on that car to see if in fact it was built after 06/02. If it's anywhere near that date, have the dealer show you documentation to prove the coils have been changed. You can also check them yourself; which is probably a better idea. I have somewhere the part number of the defective ones. Let me know if and when you need it and I'll look it up for you.
--'rocco
Billy
At 1K miles though, I would suspect that either she has a leak or her car wasn't filled to specs from the start. Another possibility is if she drives the car very hard and then shuts it down immediately - it's possible that the turbo would cook off a little oil everytime she did that, which would lead to turbo problems down the road.
The 1.8T is known to consume a little oil. My salesman pointed this out and that I should be sure to check the oil level at least once a month. In the 8 months and 7500 miles I've had my A4, I've put in about 1/3 of a quart of oil. My oil light has never been on though. I don't consider this to be any sort of inconvenience - it's a good idea to pop the hood once a month and check all your fluid levels anyway, and spending $5 for a quart of oil to keep in the trunk just in case is something everyone should do.
Most people, including the service folks at the dealership, recommend changing the oil more frequently than 10k as stated in the manual.
I plan to keep the car for atleast 10yrs, 120k miles so I was thinking every 5k atleast. The dealership uses Castrol GTX, and not the synthetic stuff - every 10k makes me nervous.
Thanks in advance.
I bring my own synthetic Mobil1 0W30 in every time. They won't credit me for the 3.7qt of oil they don't use during the scheduled services they cover. However, for the in between service oil changes, they charge me only $10 for the filter and don't charge me anything on labor. So I figure they should even out. Ask them if they are running anything special for 2001's. That's what they enter in the computer to free up the labor charge.
Billy
click here to go to Mobil 1's web page explaning 0W-40.
--'rocco
--'rocco
--'rocco
This caused the timing to go out and several valves were damaged.
Also, I should mention that I noticed a nasty pull to the left when I took the car in and asked them to check alignment. Sure enough it was out. The kicker was that they told me that the right rear tire was scuffed and caused the misalighnement. I said that that was a pretty good stretch at best and refused to pay a cent! they caved in! The car now runs with a noticeable improvement in power and gas milage.
We have had 5 Audis over the past years and I must confess that although I own the top 2002 A4 model I'm getting a bit bored with the lack of horse power. Even though it was taken up to 220 hp I feel the car really needs to be pushing around the 260-280hp range.
I had a 2001 S4 that was Ok . But it sucked the gas when you gave it the pedal and the ride was very hard. I know you are supposed to "feel" the road but not every crack!
The seating really needed to be vastly improved as in comfortable. The 2002 a4 was big step up in better seating but the car is in my view rather lackluster in performance in the city. On the highway it shows it's true colors.
The new upcoming S4 has something like 344hp pouring out of a V8. I understand that the V8 is not overly heavy but a V8?
I know Audi has V6 motors that turn out over 300 hp. So why does north America get stuck with a V8?
From what I have been told the car is going to be selling for around $70,000 Canadian and it still looks like an A4!
I gotta be honest and tell you folks the new Maxima is starting to look pretty good at two thirds the price.
I for one am going to have to give these newer Japanese cars a closer look.
I just feel that Audi is not giving its coustmers anything really all that new! While Benz is very pricey it gets very pricey for performance.
Nissian might be on to something and I'm going to give it a real close look!
Just to finish off I have been putting Royal purple 5-30 in both cars for over a year. There was a noticeable "difference in motor performance in both cars and gas milage did improve a bit. I have tried the over priced Mobile synthetic and you can keep it. Not even close!
Those that like to tune and chip and fool around technically with the tunable turbos may have things to carp about -- but after reading the review of the S4, as noted above, I would welcome the V8. It doesn't weigh more than the 2.7T, it has "bottomless wells of torque" and it sounds sweet.
There appears to be many improvements over the last generation S4 and the price seems to be, in relative terms, a bargain when compared with the M3 Bimmer.
The other points about the car, however, do have great merit. Now, that doesn't mean I'm going to jump the Audi ship and go to a Japanese car, but I do understand the point.
If so, when the orig. warantee does expire, is there any problem buying an extended warantee if you're not the original owner?
Part C: any comments on the high output 225HP 1.8 turbo engine? Thanks!
The dealer should probably get a clerical fee for the trouble ($50), in addition.
And, yes the original factory warranty and Audi advantage carry from owner A to owner B.
The 1.8T engine 225HP is a great engine -- remember there have been coil problems, but the recalls should have taken care of your concern.
She's waffling between an A-4 quattro sedan and the TT, with that 225 engine pulling her toward the TT. Man, I just hate the possibility of spending that kinda dough for a potential headache though! Is it reasonable to hope that since the model's several years old now, most of the glitches have been worked out?
They were all great cars -- power window problems on the second one, once, fixed under warranty.
The current one seems to eat key fob batteries, but other than that, no problems.
The factory phone in the 03 is pricey but nice.
We miss the in dash tape deck but love the in dash CD.
Wish ON star and power drivers seat were options.
My wife's favorite car ever.
I am not big, but the one I think will be a hit and would be with me is the new S4! The TT is just a wee bit, uh, wee.
I currently have an 03 allroad 2.7T with 6spd manual. I love it!
Welcome to the Audi family!
So I decided to drive an A4 with smaller wheels and Front-Trak with the CVT trans. Loved it. Smooth solid ride, all that power when you want it, just a great car.
I decided that Cleveland is too flat, too well snowplowed (even this year), and too heavily salted to bother with Quattro. Plus I've never seen a front drive car stranded on the side of the road.
This car was great. It weighs 190lbs less than the automatic Quattro and the CVT accelerates so smoothly it makes the most of the turbo.
I got 1.8T, silver with ebony leather. I'm supposed to be sharing it with my wife but I really think its too small for her to putting the kids into so I'll just make the sacrifice and drive it.
almost like new. I Lexol it 3/4 times per year.
The leather in our new A4 is really nice.
While strolling around Audi dealerships I looked in the window of used Audi's and their interiors all looked good. Lighter colored leather will show dirt more than black and be a litle older looking because of that.
that did look like the had a little wear @37k. The seats were excellent as far as shape but looked "low-rent" compared to the leatherette or the leather.
The 1.8T CAN be chipped and blown and piped, etc. so that it will actually exceed the 3.0's horsepower and torque.
A "stage one" chip from one of the biggie names, APR, MTM, etc. has a torque curve goal -- find out what the claims are, ask the vendor and determine if the new torque of the chipped 1.8T appears to "blow away" the torque of the 3.0 V6. If it does NOT, you are "probably" safe.
Anyone else having windnoise problems from the doors and having a hard time getting it corrected from the dealerships?
I have called the main office in Auburn Hill,Mi and filed several complaints to no avail so far.
Billy
