My biggest problem with the transmission is the huge deadband lag between engaging the shifter into drive from reverse, or vice-versa, and the transmission actually getting into that gear. There is a monsterous delay; I've never driven a car with that kind of lazy behaviour. Normally it takes just a fraction of a second for a transmission to realize what gear it's supposed to be in, but my CV can take a couple of seconds to figure it out
Still, though, it's a defficiency I can live with, just 'cause Panthers are so cool :P
What can I use without running into clearance issues? What IS the stock wheel measurements (width, offset, etc)?
Looking to stay within the wheelwells and a 16 in rim as I want to keep the tires on it now (Michelin Energy - but turn the whitewall INSIDE!).
Deke
Did I get short-changed (or the original owner) or did someone swap out one from a Sable or smaller car?
Deke
Or if anybody can tell me what else they think it could be I can test that as well. I have looked over the engine and don't see any vacuum hoses broke or disconnected. I will post a picture of the engine and the sensor I mentioned.
Thank for the help
Not an uncommon problem in a 14 year old car, but not a difficult fix either.
Any help would be appreciated
Thanks for all the help guys.
Oh by the way it was the PCV valve. Installed a new one and idles great.
I have a little hope because the car so far has never failed to get me where I'm going, but I'm sure it's just a matter of time before the car won't get into gear or gets stuck in some gear.
What kinds of things can cause the problem I'm experiencing? Should I believe a mechanic who tells me that I have to get a new or rebuilt transmission because of this?
Thanks all!
Dave
The car expells a very loud air whistel and increases upon acceleration. Is not present in drive. At a certian point above 35 mph the noise is defening and the car stalls and shakes violently until speed falls below 30 and removel of acellerator foot pressure. Getting worse and now has the same problems at 20 mph and very difficult to start. Reverse kills the engine.
Have replace the catalyic convertors and no improvement. Engine still loses power sometimes and cannot get past 1st gear. Disconnected both vacume lines to air control valves and it still whistels and stalls.
Have done major repairs to start system. New battery, new starter, new ERG valve, all new hoses, new EGR vacume control solinoid two ports, tune up, new plugs Bosh 2 prong, new muffler, new 'Y' pipe, oil change and all new filters, new distrubeter cap and put cables back to original car specs (last Ford dealer had the firing order wrong for a larger police car) which completly solved all vibration. Car still sucks air at idell (weasing or starvation) and tries to stall. Have to put in neutral then rev up and shift to drive to proceed without stalling.
HELP!!!! No parts available to repair thermoactor system.
I have run out of ideas. Thank you very much, Gene.
I have a serious concern about the high engine speed on cold start up and shifting into gear at these high speeds. I was always taught that an engine was supposed to be run at low throttle at first, until it warms up. Shifting into gear at high RPM was not recommended. I wonder whether the car will suffer premature engine wear and/or damage to the transmission, because of this.
Anyone have any thoughts on this?
" . . . I assume you put a tach in? . . "
I have a 2005 GM, not a 2006. I love the car, but I really wish my car had one of the factory-installed tachs found in the 2006 cars. The 2006 GMs are little different than in 2005; but this particular improvement, the tach, is a big one to me.
And no add-on tach is ever going to be the equivalent of having a factory-installed tach, matching the other instruments and built into the instrument cluster.
Oh well. (sigh)
While it is possible, I hesitate to think that I could have 2 sets of defects...
Other than that, it is a good quote, in my opinion.
However, I did locate a site here that allows you to input your own data and get an estimate of what both engines you cited would cost you to drive. Scroll down that page for the Ford Crown Vic's picture and info, then click "COST ANALYSIS" and go from there.
Good luck!
CV and GM are basically the same car, except GM comes with more features standard and a little more trim. A buddy recently retired from FoMoCo buys whatever (CV or GM) gets him the best trade for his old car. There are some differences between GM's GS and LS lines (and, I assume, between CV's base and LX lines). Here's a link to a comparison of 1998 GS and LS lines.
My question: do I need to find an *exact* match in vehicle (ie: 99 GM GS), or would it work to go as broad as to find any of the 98-2002 models of Grand Marquis in either GS or LS?
Brock
Regardless it is a joy to know Ford will be keeping our factory open, at least for now. Here are all the happy details:
http://quote.bloomberg.com/apps/news?pid=20601109&sid=aYj7p.UTdyi4&refer=home
Driving an auto orphan is not an outcome I relish. Let's hope St. Thomas remains afloat and continues turning out those great cars. Also it is not so bad being associated with the LTC; why I'm feeling a little snootier already!!
But it is rated better than every OTHER car out there (see last paragraph):
http://www.usatoday.com/money/autos/2006-08-09-dependability-survey_x.htm
Not too bad IMHO.
Anyway, the question remains, he wants to reprogram the FOB. Perhaps that answer, too, is in the owner's manual?
The reason for an extra semester is I changed from a Minor in Economics to Music as at the time most of the Econ profs were of socialistic, pro labor, & not respecting captains of industry and/or the self employed.
As I graduated from 'Silo Tech' the sheepskin was forsaken for common old paper signed by the President of the college.
They didn't want to upset the animals in the Vet Med department.
Euphonium, Moo U Class of '55
