you want to re-read your sentence and maybe re-consider the wording???...keep in mind you ARE talking about the American auto industry...assuming they do get 25 mpg highway, that places them in good company considering their size...
If they dropped the 300HP new V6 that gets 31 mpg in the Mustang, ya think it might do 25 or better in the Crown Vic???
Another weird thing is the ODB2 code reader produces "Error" after trying to read any codes.
Any ideas out there?
I would check the owners manual, it may have a simple adjustment for raising/lowering the wipers for ice and snow...I have never moved mine since I bought it in 2004...:):):)
Now I have a new car for $15,000
I gotta get some pictures up on it!
Good luck!
I am new to this site, so am unaware of any chat room "nuances" or protocol when it comes to discussion. I also do not live on the net, just occasionally read things of interest when I can remember them.
I have owned a 2000 Crown Vic [practically beat it to death] and always, despite having to replace the rear air suspension hoses due to driving fast over a bumpy dirt road, regretted getting rid of that car. Bought an 08 Mazda 6 just to see what having a car like that would be like [i.e. snappy sport sedan] and I ended up getting rid of that too. The replacement: an 09 Grand Marquis. Now, I knew there would be a slew of old-man jokes, and I knew that Edmunds and other sites knock this car to pieces, but I will tell you what - get used to one of these babies and unless you are restless, stick with it. I live in Colorado, so of course snow is a consideration. Face it, if it is snowing that bad no one should be out anyway, but my GMLS handles fine. It is heavy, safe, and I don't have to worry about being smacked and getting torn up in an accident because there is a lot of meat on this car. It is also big inside - and I know I am going to catch it from the Sable crowd, but oh well.
Another thing is, I have the Norsea Blue [I think that is what it is called], and being a Navy Vet, it is somehow appropriate. I get a lot of looks in this car - I swear, when you're on the freeway putting around Denver, people act like you're a state trooper and they slow down
And by the way, whomever at Edmunds said this thing handles like the USS Nimitz doesn't realize that is actually a backhanded compliment. I was a reactor electrician on the USS Eisenhower [the Nimitz was our sister ship] and I am flattered that we ended up being referred to in a car review column.
It was tge top bolt that caused most of the problem. What I finally did was to get a open end wrench on it and use a long pry bar and hit it with a hammer to break the bolt loose. Then I was able to get my 1/4" socket set up there to take it the rest of the way off. It took so much time I wished I had it towed it to a shop instead of home when it went out. The problem with the old one was the woven copper wire from the solenoid to the starter had corroded in half.
Good luck. Wish I had better news.
Secondly, I had a diagnostic done on my heater /cooler dash control at a ford dealer. My unit is stuck on AC. The ford dealer said I had a dead blend door activator motor. They have to take out most of the the dash assembly to replace it. I'm in las Vegas NV. They want 900.00. Does that price sound reasonable??? does anyone know of other problems that come from R/I the dash? Rattles?? electrical? etc. Sounds like major surgery. Thanks
Does not sound too bad. I have had things go wrong with my 2004 Crwon Vic that I never thought would go bad. Dash panel for HVAC, fan speed stuck on high, climate control stopped working, air would literally come out of dash, then defrost, then heat ducts all in 1-2 minutes...I have never seen the need to replace the dash switch, but it happened to me.
Than, my intake manifold went bad...who thought to design the manifold with mostly aluminum and 25% PLASTIC???...yeah, plastic, which leaked and cost $1200 to fix...
Then, my tail lights stopped working at night...brake and signal lights (upper filament) worked fine, but the lower filament did not work, and my license plate light stopped working...so, if you approached me at night from the rear, no lights were visible...tried the cheap way and replaced the dash lamp switch for $50...did not work...had to replace some electronic module above the gas pedal for $750.00...that worked...
Here is the worst part...the manifold, the module and the dashboard HVAC control were ALL IN STOCK AT THE FORD DEALER...they stock that stuff???...yeah, if it is known to go bad often enough, they stock it...they EXPECT the intake manifold to go bad???...yeah, they stock that, too...
Where should i go the dealer who replaced my blend door activator for $700.00 or the garage that i do all my normal maintenance with??? PS. The garage was afraid to replace my tranny fluid unless it was necessary to so, citing dripping problems with the tranny after the fluid change. This makes me thing the garage or the the tranny dripping is a problem with this car?? Any help out here? :confuse: ">
And what means "unless it is necessary to so.."? Never wait till it´s necessary with a tranny fluid change, cause that might also be too late -and expensive-. Depending on your driving style, if you are often in stop and go, live in or close by a city and/ or like to drive "sporty", stick to the Police and taxi maintenance schedule (shorter intervals). Anyways, if it has never been changed yet, change it!!
The dealers usually just flush the transmissions these days and I guess, as they do it pretty often, it might be the better place. My Dad had his transmission on his Town Car flushed at a Ford place and it seemed to work good (price was around 120 $ including the oil)! BUT always check the fluid level when you are out the door of the garage and always check for a wet undercarriage when you arrive home and for stains the next morning! Things can happen, anywhere!
Another Question, do you have to have an "official 60000 mls check" because of a warranty or so or do you just want to have it checked according to the specs? If no "official check" is necessary, maybe check what has to be done by the books, then decide on what you wanna do and place your instructions at one or the other or different things on both dealers.
Local Ford/Lincoln "flushed" the tranny in our 95 4.6 T Bird & in so doing blew the O ring seal around the transmission dipstick. They claimed a coincidence and charged me accordinly to fix that.
IMO the flushing is too powerful and the process doesn't involve a change of filter. Believe in dropping the tranny pan, changing the filter, new gasket, attach the pan & fill with oil. If the oil needs changing, so does the filter.
(I did an internet search about new ball joints, and half the people said an alignment is necessary and the other half said it wasn't.)
Can't comment on front tire treadwear because I've only put 8 miles on them with the new ball joints.
1.) The seat belt chime / tone (?) goes off, after the seat belts are engaged, for 5 sets of 5 chimes, with about 5 seconds between sets. It wouldn't be that bad if that was it, but they will randomly start the whole process over again just driving down the road, 30-40 minutes later for instance. The seat belts are generic replacements from autozone or somewhere. The guy I bought it from said there was a chip / sensor in the seat belt that was very expensive to replace and said I could probably get one at a junkyard. IMO, he was bs'ing me.
2.) There is a replacement car stereo installed that sucks. Any suggestions on a replacement? It is a 'Dual' brand with a removable face plate. There is an empty half inch space below it.
3.) A previous owner was a smoker, though the very vast majority of the smoke odor is gone (I have a VERY high sensitivity to this smell, but even I think its barely noticeable....I don't smell like smoke after I get out of the car). Is there any 'go-to' products that I can use / spray on the car ceiling liner and floor carpeting to remove the odor? what about the leather seats? Do they harbor that smell also? I'd tend to think not...
Thanks to all who contribute!
Eric in Indy
I have factory radio/cd/cassette, and it functions...that's about all...part of me wants to replace it, and the other part says that a new audio system would be worth more than the car is now...
I would think a decent leather cleaner (Lexol?) might work...
How many miles on your odo, and, may I ask what you paid for the car?
Thanks for the tip on the Lexol. I hope it works. What about on the ceiling?
I'd be surprised if your 2004 is not worth more, depending on condition. Mine has 137,000 miles on it. I paid a 'friend' $2,700. As I've driven it more and more, I'm pretty sure I got sold a bill of goods....
He told me about the chime/tone problem, as he did about the warped rotors on the back, and the tires needing to be replaced in the next 5-6 months.
What I've discovered he didn't tell me about, that I assumed I guess, is
1.)the missing full size or otherwise spare
2.) No driver's manual of any kind in the glove box.
3.) No code for the outside combination door lock pads (can I find out what that is somehow without spending a fortune?)
4.) the fact the high beams don't stay on when pushing the turn signal arm forward....they only go on when pulling it back...and then need to be held otherwise it goes back to standard beams.
5.) The headlight dial / switch only turns the headlights on or off...no parking lights only functionality.
6.) Only one ignition key...no door key....thus, I had to spend $69.00 at WalMart last week to get a second ignition key.
The car seems to drive quietly engine wise and is running fine, so I guess the other stuff is fairly minor, but nevertheless I feel he should have informed me of each...he drove the car himself for 2-3 months afterall.
He's a newer friend, but I seriously doubt I will buy a car from him ever again. He was acting like because he has a wholesale license, he was doing me a huge favor to sell it to me at that price....implying he could get $4-4.5k for it retail. Yeah, right.
I haven't run a CarFax on it yet, but will. He told me he had some sort of trade-only app on his phone and that it was clean except for a small front end mishap that somehow ruined the airbag sensor in the front, but didn't pop the airbag. He claims he replaced it. I have a sneaky feeling I'm going to find out quite a bit about this car when I get the CarFax.
Oh, well,....live and learn.
I had my mechanic look it over today and give it a test drive...he said other than the tires needing replacement immediately, he thinks I got a decent, fair, deal, which is all I was looking for. He is a 35 year mechanic and absolutely loves the Crown Vic line.
Also, I id'd the model of the Dual stereo in the unit, and it is the Dual HD250, a basic run of the mill $50 unit sold at WalMart. Fair enough....it has it's limitations, and that's fine, as I'm not an audio-phile, though I used to think I was one...then realized that I really didn't care all that much to have the best stereo in the world.
For your radio, the size in a Crown Vic is a "Din" radio. This is basically double the size (height) from a standard "skinny" radio. If you have a gap, sounds like someone put in a standard radio. I would look at any audio store or Best Buy for "Din" radios, which will fit the space perfectly. Your other option would be to go online or to a junk yard and find a Crown Vic or Grand Marquis and purchase the radio. These are pretty good Ford radios, so the original in your car must have died for the previous owner to replace it with a cheap unit.
Bel Air Car Guy
The high beam problem sounds like a switch problem to me but I did have to change the LCM on my 03. LCMs are a common problem on these.
Spray some Simple Green or better yet Benefact if you can find it to get rid of the smoke smell. You can spray it directly on the headliner parcel shelf visors etc. The Benefect has a thyme smell but it does go away and takes odors with it, it's good.
I'm getting ready to install a Double DIN into mine. DIN is the standard 'skinny' radios we remember, and they also 1-1/2 DIN and Double din. From what I understand it's pretty simple, but you do need to use a utility blade to cut little tabs off the top and bottom of the opening for it to fit. Don't cut the side ones!
Seat belts are simple to remove (the part with the latch anyway) but need a little muscle. You might want to simply find the wire going to the seat belts (that lets the car know if they're clicked) and either open or close the circuit to see if it turns off. If it does, leave it that way
I believe LCM refers to the lighting control module, a "black box" under the dashboard to the right of where the driver's leg would be. It has lots of integrated circuits and relays that control the lights on the car. Sometimes, the relays come unsoldered or burn out. Standard Operating Procedure is to replace the entire LCM for a few hundred dollars, but it is possible to replace just the bad relay if you're good at working with electronics. The lights on my 2004 Grand marquis got where they would not always come on. Whacking the LCM would usually make them come on. It was a sign one of the relays was loose, and needed replacing or re-soldering. But I totaled the car hitting a deer at 75 MPH before I ever got around to fixing it, so the point is moot now.
My CD player in the dash and the multi-CD in the trunk are failing...I hesitate to put a $1000 stereo in a $1000 car...has anyone ever just changed the trunk unit? Is it just a few bolts or do you need a "stereo degree?"...I see refurbished units on the internet for $145, and since the electronic controls work fine (it is the actual players that no longer read the CD's after the 3rd or 4th song), I thought changing the trunk unit would give me a multi CD player that would solve my problem...thoughts on this? Thanks
