Visitor Agreement.
AT
AT
Are the two small bolts on the rear hatch (inside) handle the ones that hold the panels on? I tried to loosen one of the plastic "screws" on the panel around the window, and it just spins...
Thanks in advance!
AT
My biggest problem however, is the resale value for it... Why so low?... It has to be the worst of any car in its class?
Does anyone on the board know how to fix it ?
My last commuter was a 1982 Olds Omega It finally retired at about 270000 miles. Drove it to the junkyard on its own steam.
Taurus even gets 30 mpg on the highway.....
Oh What A Feeling....
I could be driving a civic or corolla for more money
Started up my 2000 Sable LS to get the paper this morning and felt a loss of power half way to the store. This was followed by a flashing check engine light. I ended up putting in some fuel injector cleaner and the loss of power problem seems to have gone away ( clogged injector ?)
Anyhow, with 94,500 miles I'm guessing it's time for a tune up. Anyone have an idea how much my dealer will soak...er, charge me for the 100,000
job and what's involved. Any info will be greatly appreciated.
My 2000 Taurus is still rattle and squeek free, just past 40K miles a few weeks ago. The only rattles I have had so far are when the front sway bar links went under warranty and the front end clunked occasionally, but only could be heard at low speed over rough bumps.
Spark Plugs and DPFE sensor are less likely to cause flashing CEL. They bring solid CEL. I replaced my DPFE sensor after P0402 code (excessive EGR) and light was solid in my case.
However, he should get his computer read by Autozone to determine what is going on.
Unfortunately, the cylinder three misfire was the result of a slightly cracked coil on top of the plug according to the diagnostic. Replacement cost including labor $116.00.
My mechanic said the plugs were toast, but how does that happen to one of the plug coils ?. Bad gas, or maybe should have tuned it up sooner ? Any thoughts from anyone.
I wouldn't be surprised if Northern Virginia is not in the recall area, though the extended warranty on spring failure is probably nationwide, just only the northern states are getting the shields. And I can confirm the shields won't be available until the end of the year, when we will get another notice in the mail.
Your mileage is awful, I get 21.4 in 100% city traffic, 27-28 on highway (70 mph average). But I think your car is too new to measure the gas milage yet.
Good luck!
The stereo is very loud but I would like to get a more quality sound. My listening has found that there is very boomy bass, no mids, and shrill trebles. Good speakers would hopefully smooth all this out. I have tried several stereo stores and they all seem clueless. One even said that the only way to upgrade the speakers was to buy a new head unit, amp, speaker wires, and probably a new jacuzzi tub for the installer.
I have looked at Crutchfield and they tell me the info on speaker sizes but that is all.
Note for 2005 model year they are dropping down to two versions of Taurus, the SE and SEL. Just simplifying the model offering, as Taurus/Sable is tapering off production levels (down to one plant vs two as the Chicago plant is now building Five Hundreds and Freestyles) and will probably disappear altogether when the Fusion comes out in a couple of years.
Did it have a cassette player in the dash? I have been having a heck of a time finding out any information about the specs on the Mach stereo system in my Taurus. Nobody seems to have a clue. Even the specialty car audio places in town are totally clueless about it.
Ford lets its dealers play all kinds of dirty trick on buyers, not just through the sales process but also during servicing vehicles.
Back to subject-I have a brand new '05 SE Ford Taurus furnished by my company. It's an OK vehicle, except for the fact the seats are hard as a rock! What are they thinking? When you spend all day in a vehicle you want the seats to be comfortable!! The quality seems to good thus far, but it has only 1,600 miles on the odometer. All these problems on my Explorer did not manifest themselves until after two years.
I wouldn't get the Sony changer.....especially with the latest iPod and other mini-hard drive players on the market. Six CDs isn't enough!
Jon
However, they are pre-wired to install one and the head unit has the controls already there in case a CD changer is installed in the future. Installing a compatible CD changer later is trivially simple other than mounting it.
high beams on my '01 SEL seem dim in comparison to many other cars on the road. TIA!
The only way your car might not have it is if you bought it used and the previous owner had it deploy on them and did not replace it, but then your airbag warning light would be on continuously, as I doubt if someone would go to the effort of disabling the test check electronics and software. Does your airbag light go on for a short period of time when you first turn the key and start the engine? It should, and then go out shortly after that as the system performs a self check when you start the car.
Just turned 103,000 on my 2000 Sable LS Premium with no major problems at all!!. Local dealer in MA just over the border from me in NH was advertising new 2004 Taurus SEL with all discounts at $16,999.00. How does that stack up?.
Or...should I try to take the Sable out to 150K and wait. Any idea on the finance rates out there?
Shank6
It is nearly always cheaper to keep what you've got, pay for any repairs needed and drive it into the ground. Also, if you are contemplating buying another Taurus/Sable, you are replacing your current car with one that is essentially the same car, so if that floats your boat fine. Otherwise, keeping what you have gives you nearly the same driving experience as the 2004 model.
If you wait a couple years, the Ford Fusion will be out, and also the Five Hundred will be three years on the market, so prices of it will likely be discounted on it some by then, so your choices for replacement will be more wide ranging by then, assuming you are going to stick with Ford.
The price sounds good on the 2004 SEL. Is it fully loaded, and what was the MSRP? That price is $1k less than I paid new for my 2000 Taurus SES Duratech!
