Visitor Agreement.
It states there that Taurus will disappear sometime before 2008. Primarily being sold to Fleet/rental car companies between now and when Ford eventually stops production.
I suppose they could elect to stop production sooner, but with no other announced product in the pipeline right now for the Atlanta plant, my guess it will be around for a year or two.
Actually, Ford Taurus is being replaced by both Five Hundred-a bigger car, and Fusion-a smaller car, though I would assume at this point that Fusion will have nearly the same interior room and trunk space of current Taurus.
There seems to be conflicting information. Everything I have read states that the Taurus will end by the end of the 2006 model year. AND, that the Fusion is the DIRECT REPLACEMENT for the Taurus. It is all really a mute point I would think. Since the only way to get a 2005 Taurus is if you work for a company that has a fleet deal with Ford. My company is one. I would think when demand softens with the fleets that will be the ultimate test as to when they will stop making these things. I have had an '05 SE since October of last year. My neighbor has a 2000 model. I would not recommend this car new or used, since they started making them for fleets, They have stripped down this car, and the seats are horrible. My neighbor's 2000 is a much better car. Even when these things show up used, I would stay away. I currently have 14,000 miles on mine. I can say there have been no problems to date. My company keeps them for two years then you turn them in.
This tells me Ford is still allowing their dealers to get them for sale to the general public.
I would bet Ford will still allow sales to dealers at least up until the Fusion comes along.
I cannot comment on the seats in the 2005 models, but I would really be surprised that Ford would change them much from 2000 on as the tooling for those seat designs has long been paid for and it does not make much economic sense to retool to make cheaper seats for a model that is going to be discontinued.
Danielj6: Taurus/Sable have been a roaring bargain all along, so I doubt it will get much better than it has been.
Well, I spend 6 to 7 hours a day in mine, and I can tell you the seats are very bad. Also, when a product nears "end of life" many car makers look for ways to cut corners and make more money on the last of the models. Look at the current Explorer, they changed the door handles from "body color" to flat "black plastic". If you want "body color" you now pay for them in an "appearance or "sport package". Again, I read where the '05 models were "fleet only". Per your post that information I read is not correct. As I mentioned- five months and 14,000 miles later, I can't recommend this car based on the seats alone, and the standard motor is underpowered!
My 2000 Taurus seats are quite firm in a good way and very comfortable, long trips included and the 3.0 Duratech has all the power I require with very good fuel effiency.
On the upside, Ford did add a driver information center and switched to a low profile LED high mounted brake light, so not all the changes were decontenting. Additionally in those four years, the out the door price I could have paid actually was flat or went down for the comparably equipped Taurus.
In my job (outside sales) I have driven for business 32 automobiles. The miles add up real quick when you cover a lot of territory. This Taurus has the worst seats of all of the cars I have used in business. If you sit on the "hard seats" and they do not conform to your "bottom half" in any way, I do not see how that can be "good". When you spend 6 to 7 hours a day "on them" you notice it real quick. I have the "Vulcan Motor" in my Taurus. I think it puts out a 160 horsepower, someone can correct me if I am wrong. You now have 4 cyl. motors that put out close to 150 in much lighter cars. The Taurus was a good car 5 or 6 years ago. Time and technology has passed it by. I would think that you would pay less for a car that is almost 6 model years old that has been decontented, and not updated. Why would you pay more?
Seriously though - This sounds like a bad ground problem to me. First clean the battery connections. Then clean the ground cables that run from the engine to the frame. They must have excellent conduction or you'll see problems like you mention.
Every repair I have to do on this car has to be balanced by the current cost of the car ($500)
Somehow the a/c cools marginal on the hottest day.
So if I just let it go for now what happens?
How long till it freezes? or will it just make a racket and a lot of noise and thats it?
2.
I presume I need the hose removal tool to remove the a/c compressor. I intend to have it evacuated and filled with gas professionally as I dont have the equipment. Any ideas?
3.
In 1998, a colleague of mine drove the car with no power steering (PS) fluid. Now everytime the car turns the PS pump makes a loud whine (10 times the normal). How do you remove the fanbelt that drives the PS and the AC? I did not see an idler pulley or anyway to even adjust the tension of this belt.
4.
Also the book tells me that I need a special tool to remove the PS pulley first before the PS pump can be removed. Is that right? Why cant I remove the whole thing at the mounting?
I have the opportunity to buy a used Sable through my company's fleet-return program. The prices seems pretty good, but it's difficult to figure out how the cars are equipped. The 2003 Sable LS I'm considering now has Preferred Equipment Package 905A. Does anyone know what that package includes are (even better) where one can look such packages up online? Thanks!
It doesn't really bother me that they did deploy, but it seems like too "soft" a hit.
I have a 1996 Mercury Sable Wagon and last night i just noticed my door lights won't were on all night long and they won't go out. :confuse: Now i get the signal that one of the doors is not properly closed, but they all are, i checked several times and they are all properly closed. Any ideas of what i could do?
Thanks a lot! :P
ABS was standard on the SES and SEL.
It turns out it will be the first quarter of '06.
I am getting ready to purchase (4) new tires for my 2001 SES with 66,200 miles on it. I am getting H-rated 215/60/16 Fusion HRi performance all-season tires. They will surely be good for all the curves I drive on. I am getting them all mounted and balanced, tax and all for just $201.30!
Meanwhile, I was going to ask if anyone noticed a "car vibration sensation" when going on curves and hills while having the foot on the pedal? I always assumed it was the crappy touring tires I have on there now (they are down to 5/32). Or, is it something else? If you DO NOT have the foot on the pedal (coasting), it will NOT do this.
- Alex
You have to keep pushing the button on the doors until it clicks the lock open. What can be done to fix this?
Last summer a few of you highly suggested that I have it checked out. Of course when I called the dealer, they originally said that they couldn't do anything unless the light was on when I drove in. Right! :P Like I'm going to drive directly to my dealer and expect them to immediately inspect my car with no appointment in front of other cars!!
Luckily for me they were able to find error codes left on the computer which indicated to them that the sensor was, indeed, defective. And here I was driving with confidence that I finally had airbags on my car! Better news - NO COST to me because they came under a safety warrenty that lasts five years or 80,000 miles.
Other than the inconvience of dropping the car off twice because of a wrong part being sent from NY, and the other recall notice visits,
Glad you got it fixed!
So in 2007, you will probably see dozens of used 2006 Fusions at HertzCarSales.com for about $10,988.
Well they have to fix 3.0L Duretec though. On my Sable it sounds harsh and steering wheel vibrates unpleasantly in idle. On my Focus 2.3 Duratec (developed by Mazda) in idle it is as smooth as German engines. You still can hear that engine running, but there are no vibrations on the steering wheel. And it has lot of torque at low rpm!
No problems until about 3 weeks ago.
Car starts fine one day, and then next day, turn key and it is dead. No clicks, no whirring sound, nothing. Battery AOK. I believe it is starter or starter solenoid. Checked it out. No loose or exposed wires. Go back in an hour and car starts fine and does so for next couple of days. Then, same thing happens. No rhyme or reason. Doesn't matter if it is hot or cold engine or outside temperature. Took it to a mechanic I trust. He could not find any problem either. He even ran some water right on starter, but car started fine. Mechanic apologized and said: "Call me if it happens in town. I'll drive right over and try to figure out what is going on." He did not charge me either. All was OK for about a week, and it happened again today, Sunday. After about 30 minutes, I turned the key and it stared up fine, just like there was no problem. These electrical problems can drive you nuts. Anybody have any similar experiences? Is this peculiar to 2002 Taurus? I had a 1993, 1995, and 2000 Taurus. All 3 had the starter die. No warning. In each case it was fine one minute, and completely dead the next. And it never got better. Had to replace starter each time. I half way wish this 2002 Taurus would just die so I know what is causing the problem. Maybe I should just change the starter just for the heck of it because I am going crazy trying to guess what is going on? Any help is appreciated. Thanks.
BTW I saw today two rental Five Hundreds on our parking lot - almost side by side. First sighting of 500 rentals! It supposedly would never go to rental. I had to stare pretty hard before I recognized the brand (in traffic - the same problem). First thought is - Mercedes - if I see it from back, or Avalon - if I see it from front, or -what is it - looks familiar but what hell it may be? Then you search for the badge and then it dawns to you - the new Ford Five Hundred!
Save for the very exotic cars...you will find a few numbers of ALL TYPES in rental fleets; Mercedes, BMW, Volkswagen, etc. The problem is when they go in to fleets in MASSIVE numbers. A few will not affect resale value of the general line.
SEL. I've browsed some of the reviews on Tire Rack's web site and seen
generally positive comments on the following: Goodyear Regatta 2, BF Goodrich
Traction T/A, Bridgestone Turanza LS-T.
What have you folks been replacing the OEMs with? My budget is around
$85 per tire.
TIA!
I think that you can waste an awful lot of money swapping out parts at random. And electrical parts can't be returned.
Maybe you should consider paying a factory certified mechanic to diagnose your problem. They might charge you 1 -hour labor for the diagnosis. Even at $90 an hout that's cheaper than all of the parts you'll buy and not reaqlly need.
I have been having the EXACT same problem with my 02 Taurus SE with 68k miles. Owned since new with no other problems. Intermittent start problem with exact same symptoms as your car. Brought to Ford dealer 3 times and they have kept the car for a few days at a time...even having a service tech take the car home after work to try to replicate problem. Of course as soon as I get car back, I am broken down on the side of the road. Please follow up. I am trying to troubleshoot this problem on my own, as Ford cant seem to service their vehicle. Any help is greatly appreciated.
