Visitor Agreement.
Then there are other items that aren't scheduled but are considered maintenance and not repairs: Tires, brakes, battery, etc. Buy longer-life tires (usually lower speed rated which is fine unless you drive 100+), ceramic or semi-metallic brake pads, long life battery. Use a K&N air filter for cost savings not supposed performance benefits (1 filter for the life of the car).
In terms of repairs, on my '99 LS V6 I've only done a couple and over 9.5 years and 143K miles they totaled well under $1000.
If you drive way, way more than the average 12K miles a year your maintenance could add up but even then I don't see how it would approach averaging $100 a month.
Heck, even if I blew both the engine & trans today and had to replace them I'd still be averaging under that.
Replace the bulbs. That's the cheapest diagnostic. Preferably with a different brand.
Also, water pumps (in general, not Mitsu specifically) frequently only last around 140K miles or so. The labor to replace it is roughly the same as that to do the timing belt. You might consider replacing the water pump & timing belt together as there's no real extra labor (labor cost) involved.
As to the cost, it will vary. Call you local dealer but also call other reputable shops. Timing belts aren't anything super-special that requires dealer server. Meineke and others can replace them. It will be a few hundred dollars, though, as it takes a few hours.
Thanks for any ideas and help!
Can anybody help me turn this off or only have it beep a few times.
Please help ?
Tim
Sorry for bothering you with a stupid question.
Best,
Zach
Frankly, while I like the stereo, it's not current on features (no MP3 capability, etc.) so I'd suggest that if the dealer is going to charge a lot to repair the unit you may want to consider just replacing it with an aftermarket stereo. They aren't very expensive nowadays.
P.S.
I Am The Only Person She
Will Let Do Any Kind Of
Work On HER, Have Had
Problems After Other Persons
Have!!!!!!
Does the vibration smooth out or at least diminish when you drive v. being at idle?
(I'm at 146K on my '99 LS V6)
Good luck. Sorry for the delayed response.
Mike
Thanks for whatever you can tell me.
I disconnected my radio, overhead lights, tail lights, door harnesses, amplifier and also my alarm. I popped a fuse in and it continued to blow. I decides to completely disconnect the battery and the ECU for about 5 minutes and then I put a fuse in and it DID NOT blow. SO i started connecting everything back 1 by 1 and it didnt blow. SO finally everything was good until today, the fuse blew again and continues to blow.
This time when I got home, I disconnected the battery, ecu and plugged in another fuse, reconnected everything and it still blew. Then I disconnected the door harnesses and put in another fuse and it didnt blow. Connected the passenger side, didnt blow, then i connected the drivers side and that when it blew. But i tested again by disconnecting the drivers side harness, put another fuse in and it blew. SO i have no clue where the short is coming from.
Does anybody have any ideas on where the problem can be?
I am in need of help. I am sad to have to say goodbye to my 2008 Mitsubishi Galant Ralliart (fully loaded-nav and all), however I have been diagnosed with an illness and am unable to keep the car due to being out of work. I loved owning this car every minute and love driving it more than any other car I have ever driven, not to mention it's fun to watch heads turn when it is spiffy and shining. I bought the car in Oct 2007 and it has the low low mileage of 18,800. I am simply looking to sell my car for what is left on the loan ($18,900). I have babied my car and hope the person who buys it enjoys and loves it as much as I have. I don't know if anyone can offer me some advice on the best way to do this, but thought I would ask my fellow Mitsu lovers for their help first. Thanks for any advice you can give me. Broken Hearted in NY">
http://www.mawarinternational.com/stock/detailed_stock_report.php?flag=1&lang=En- glish&id=450
