Visitor Agreement.
http://www.infinitipartsusa.com/
I'm having the same problem with my '92. Acts like it's running on 4 cylinders, won't idle (cuts off if you take your foot off the gas) and is spewing black soot out of the exhaust. I checked the fuel filter by dis-connecting the hose coming out of it to the fuel system. Seems to be working. Filled up 1/2 of a quart jar when I turned the ignition on and primed the fuel pump.
Question 2. When I am sitting a red light the engine starts missing and then when I start moving it misses for about the first 100 feet or so.
Any suggestions? Thanks
I am having a reliability problem on my Q with the starting procedure. I read in the manual that the ACC position disarms the security system but most times I have to
twist the key fob several times from off to start to get it to kick in. I have tried leaving the key in ACC position until the screen comes on top of the center stack but no guaranty there either. Anybody else experience this? Other wise every thing else works great have had the car 2 weeks.
I am having a similar problem on my '02. Sometimes as I am sitting inside and the key just clicks, I have to pull it out of the ignition switch punch lock and then unlock
3 times insert key turn to ACC and then start and it fires up. I haven't taken it to dealer yet, have had the car for 2 weeks.
its a 2002 q45
