Golf: 164.9'
Jetta: 172.3'
Corolla: 174.1'
Courtesy of Edmund, they also said that Jetta is the sedan's version of Golf.
Pricewise, the Golf is around$1.5-2K more than a Corolla, while the Jetta is around $3K more.
VW has some of things going for them, great styling, sporty performance, good fit & finish. For some people this is more than enough to overcome VW shaky reliability factor and justify paying the premium (are these things sell for MSRP??), just as many people still buy Chrysler product despite their transmission woes.
my Corolla CE needs to be tune up and it needs expensive, special spark plugs (NOT Platium or Resistor), cost $75.00.
Another local dealer told me that it needs only
Resistor spark plugs and costs $50.00 for the
tune up. (Southern California)
Please, let me know which one is correct?
Should I do the tune up or wait until 60K?
I did go to part dept. of that dealer to check
the price of the spark plug and the sale clerk
told me it around $14 for ONE SPARK PLUG.
Sorry, I do not want to mention the name of that dealer. Thanks for all your help.
BTW... www.toyotaparts4u.com sells genuine Toyota parts at 25% discount. this is an actual toyota parts dept/dealership in North Carolina.
The local Toyota dealer here charges an outrageous $199 for the 36K miles service. This is a rip off, of course.
Read the owners manual, I think most Toyotas recommend maintaince check up every 36K miles. If this is the first 36K miles, your car should pass the check up with flying colors.
Spark plugs should probably be changed every 36K miles. That sounds right. And the ones currently in your corolla are the platinum kind (at least that's what the dealer told me). So $14 per plug sound right.
Oil change, most places charges $20. Air filter, if you buy it yourself, probaly $6-$8.
$30 for the spark plugs, $25-$30 for the oil/airfilter change, plus little diagnostic/check up/topping off, then $75 sounds reasonable.
However, none of these things are hard to do. So you can probably do it all yourself for $30-$40 in less than an afternoon (if you don't mind getting dirty)
The 2000 corolla uses iridium spark plugs which are good for 120,000 miles. It says in the manual to use only iridium spark plugs. At 30k miles I believe you need to change oil, air filter and coolant and check other stuff.
sv1104
Corrola 2000 Tune up is required at 120,000 miles interval, using Iridium spark plugs.
To Wenyue, FYI:
30K service (Included tune up with resistor spark plugs only, others plugs additional cost)
from $259 (Sale) to $395 (Regular).
Toyota Air filter EFI sale with coupon $12.
They are lowest cost which I can find in Orange
county, Southern California.
To all you people saying the new 2001 Corolla
is slower that the 99, 20. You are dead wrong.
There is absolutely no differnce!!
heres a pic. (i forgot how to imbed so the link shall do. http://global.toyota.com/countries/images/corolla.jpg
I just traded in my Toyota Camry for a different brand of car. I happened to get electric seat heaters on the new car. This brings up my wife's Toyota Corolla. She is quite envious of the seat heaters and I was wondering if there is an aftermarket add-0n with which someone might be familiar. Peace in the family rests in the balance, so I'm looking forward to some good info. Thanks in advance.
Michael
Geomatree@aol.com
I recently bought a used 99 corolla ve and found the car to have abyssmal low gas mileage (~25 mpg). I filled up the car with 87 grade gasoline from Acro here in Portland, OR. I used the car mainly for commune back to work on weekdays (~3 miles one way), and some freeway driving on weekends (~30 miles).
My guess for low mileage are listed below but they are not satisfactory answers.
1. The car mainly run with the engine 'cold' on weekdays.
2. The gas from Acro is subpar and may account for low gas mileage (I do not know if the gasoline is causing knocking).
My bet is to fill up the car with gasoline from a more reputable gas station (e.g. Chevon) and see if the mileage improves. Any suggestions out there? Thanks.
Cold engines aren't as efficient, and your short trips really just kills the gas milage.
I have the similiar experience here in Michigan winter. I drive short commutes just like you (5 miles each way). It's even colder in Michigan, so the drop is even more dramatic. It goes from 28 mpg when it's 50's outside (100% city driving), down to 22-23 mpg when it's near freezing or below.
But at least for the last 2 years of my ownership, as soon as the weather warms, it's back to 28 mpg for city driving once again, just as the paper says it should.
The last long trip (mainly highway driving for over 500 miles), got me 39mpg. Pretty good, I would say.
Personally, i got 35 mpg in my 2000 LE until I put 16" rims on -- then I got 32. Now that it's turbocharged I get 24-28 depending on how much I tip into the throttle.
I once heard that all the additives in gasoline are pretty much useless and could even be harmful to the car. Is there any truth on this? BTW dennis, how many pony that you have on that car after all the mod you put in it?
I can come up with 4 explanations for the spoty appearance.
1) Wait for the paint to dry longer and the color will blend in better.
2) The car was well waxed 1 week before I put on the paint. Therefore, the spotty appearance will soften after re-waxing the newly painted spot. I plan on doing it on Sat (48 hr after painting)
3) It is just the way it looks. I hope not! There are lots of dots on the hood (and some on the side of the vehicles) that show up like sore thumbs!
4) The paint was not well mixed before use. Unlikely, since the paint was shake for 2 minutes before use, and I kept shaking it every now and then during the touch up process.
Can I get help from other people in the forum? Thanks a lot!
You may have better luck having a local Toyota dealer (or other) body shop mix up a small batch of paint to match your car exactly.
I learned to drive a stick on my dad's old Toyota Supra (yep it was a turbo) so I've driven Toyota sticks before. But on a Corolla--is there anything I should watch out for? Any suggestions for better miles or smoother shifting?
The only times I stall *grin* tend to be going from a stop into first when I don't get the RPM's up high enough....just a matter of practice.
Also, my office has a very steep incline you have to stop at when waiting for the traffic light. Roll-back is a bit of a problem for me still. Is using the handbrake OK? It makes it easier and I keep the button pressed and release it when I feel the car start to move....any suggestions would be appreciated.
Zypher/Jennifer--proud owner of "Periwinkle" a spiffy Misty Plum colored Corolla! (Yes, it's a "girly" color! And I named my car--I think it's a girl thing.)
Thank you,
Zypher/Jennifer
The dealership I bought from was found on the internet off of MSN's car site. We emailed them, got a very nice polite response. I liked that the sales manager also reccommended the cheaper car and didn't try to get me to upgrade to a Camry. I know Corolla is small and most of the toyota dealers I went to tried very persistantly to push a Camry on me and kept saying stuff like "are you sure you can drive a stick shift?" I agree with using e-mail to weed out the dealers.
My car was just under $9,000 and I also got a 7yr/100k mile ext. warrenty that should last for the next four years for less than their original quote for the 6yr warrenty because I brought printouts for a web site advertising warrenties. Saved about $350 because I had competitors prices to compare to. When all is said and done...if I take the full 60 months to pay off the financing I'll pay about $13,000. But if I pay off in 2-3 years I'll cut off a good chunk of that cause of saved financing costs! Also, getting price quotes of interest levels from banks got me a much better interest rate!
I've found the night service manager to be great....their service is open til Midnight and I get off at 10pm....and the night manager is lot less "anal" about charging for little stuff! I think he's so bored that he's glad for anything to do. Every time I've called with a question or wanted a latch adjusted he says "Come right over!" I fix it for you. I tired to pay him and he just said "Ah, I'm sure it's in your warrenty, and if it's not, it should be," winked and gave me my keys.
Zypher/Jennifer -- the happy owner of "Periwinkle" a 98 Corolla (anybody want to buy a 1984 Buick Electra Estate Wagon with 160k miles on it? The car has character *grin*)
Regarding the hand-brake, I think its fine. I have an auto right now, but thats what I did when I was driving a stick-shift & got stuck in really steep incline. Either that or be quick enough to balance the gas pedal and the clutch. With time, roll-back should be less of a problem for you.
As for the alarm system, it will provides you with some peace of mind. But for lowering insurance rates, GEICO only lower my insurance by 4(FOUR) bucks!!! when I called to check. If I remember correctly, wenyue has an alarm system installed on his, so you can check with him on that. I'll say get the alarm system WITH a keyless entry. Thats one thing I won't mind paying for after being drenched in parking lot too many times.
Seems like got a great deal on your Corolla. The Lincoln dealer must be a bit "wacky". For 12K, you might as well get a 2001 Corolla!! Its only 1K more and you get a brand new car instead.
I see combo-packs at tire stores, but I always wonder about the quality and how it would really feel after the change. Maybe I will take the plunge at 36,000 miles.
The Corolla is a small car - so you'll feel the bumps in the road more than with a larger car (but the Corolla is certainly not worst-in-class when it comes to ride - for that, try a Neon for comparison).
