185/65TR14 85T SL 420 A B
185/70TR14 87T 420 A B
195/60TR14 85T SL 420 A B
195/65TR14 88T SL 420 A B
http://www.tirerack.com/tires/Spec.jsp?make=Yokohama&model=Avid+T4
This info above came from Tirerack. The 185/65 14 has the same # at 85 than the 195/60 14, but if you look at the webpage, the 185/65 14 falls between the 195/60 14 and the 195/65 14.
I experience minor rubbing on dips in the road but I like the tire increase. It has not affected my speedometer. The 195/60 shouldn't affect the speedometer either and it will have no rubbing because of its lower diameter. I purchased the 195/65 because thats what they had in stock that particular day when I needed them.
1. If it's not too steep, simply slipping your foot from the brake to the accelerator is fine -- just be sure to give it enough gas so as not to stall (this will come to you very quickly, with practice).
2. If the hill is relatively steep, you can keep the brake depressed with your heel while depressing the accelerator with your toe. This is known as "heel and toeing", and is used in double-clutching for high-speed driving in corners.
3. If the hill is REALLY steep (say, San Francisco), using the handbrake is not a bad idea, although technique #2 will work well with a little practice.
I've also read a post replying to this woman's comment, and said that it was due to improper warm-up of her car. Ok, what's a proper warm-up for the car? To me that means to not start the car and drive it immediately when it's -30 Celsius outside, but some of you might have different meanings of this.
Thanks in advance!
If you follow the maintenance schedule in your owner's manual, ANYTHING that goes wrong would be fixed under warranty anyway -- don't worry about it. To warm up your car, start it, let it run for about 10-15 seconds, then drive it gently until the temp gauage indicates the engine is up to normal operating temperature. This procedure should be followed for ANY car (be sure to tell that to your wife -- women are notorious for getting in a car and immediately revving the crap out the engine).
Re the Corolla's ride: silky. I added the TRD suspension bits, so mine is definitely no longer silky -- but it handles a lot better, so I'm happy with the trade-off. Dunno about the Civic, haven't driven one.
Dennis:
could u define what you said by gently? My commute to/from work is only 2-3 miles via the highway, so the engine temperature usually only been at the normal temp for a short time when I got there. I know a lot of "cold" start isn't good for the engine, so in this case will 3000miles oil change interval help lessen the impact?
With this winter weather, I now start my car and let it sit for 1-2 minutes in the morning before driving. Make the car warmer for my frozen body.
Canc:
The 2000 Civic does has harsher suspension (translation:rougher ride) and lot more engine and wind noise compare to the 2000 Corolla.
But the 2001 Civic does ride better and less noise. I say the ride and noise is pretty much comparable now, maybe Corolla has a slightly better ride. The difference i noticed the most is in the passenger space & the flat rear floor of the civic.
Will be ready to trade my 2000 CE when it gets here. Charlie
http://motortrend.com/autoshows/la01/
By the way, after 2002, the Chevy prizm will be discontinued and the GM will live on as the Pontiac Vibe Hybrid/Sportswagon.
http://www.epa.gov/OMSWWW/rfgecon.htm
It shows how how much reformulated gas, cold temperature, and poor road condition, ect will affect your gas milage on average. Good to know.
I don't understand why Toyota is letting GM get their hands on the Corolla design. Prizm ate into Corolla's sales, and Vibe will be competing with Toyota's RAV4. Why not just pay GM the money and buy the GM's share of the NUMMI plant from them?
Also wenyue, I dont think GM will be stupid enough to sell their shares in the NUMMI plant. It gives them ways to learn Toyota's secret like you said.
The Vibe does looks intriguing. Why on earth did GM release the Aztek if they have something such as the Vibe in their pocket??
When you change the transmission oil, did the transmission oil still look red-pink? And do you often carry heavy load or drive on hills? Driving with extra load, or in low gear puts greater stress on the transmission, and heat the fluid up too much so that the oil starts to degrade by the heat.
If you do any of those, keep an eye on your transmission fluid (check it when you are checking the engine oil). If the red-pink color is becoming brown and dark, you know it's time to change it.
Other wise, driving in normal condition, I would change my transmission fluid after 2 year anyway.
Just remember that engine reaches the temperature faster than tranny does. Read the manual before driving your car :-)))
Yes, the car will stay in 3rd longer if the weather is cold. This is discribed in the owner's manual. If that's what you are referring to, then yes, it's completely normal.
Second, I was discussing this with my cousin tonight and I wondered if the Corolla has a full or partial steel frame? I looked on Toyota's website and they say it's a "unitized body", whatever that means. Anyway, if you are familiar with this, please decode it for me.
Wenyue: The study talks about ethanol gasoline; does this study also include regular grade (87 octane) fuel?
teo: No -- we have yet to see the design of the US-spec Corolla.
charlie: I, too, think the new home-market Corolla is nice looking, and the interior is gorgeous -- I just don't care for the tall profile. I hope the US version looks sleeker and sportier.
wenyue: Toyota forms partnerships with anyone willing to share technology and resources -- it's a wise thing to do economically, technically and politically, and it has served them well for 15 years. I don't think they're likely to stop now. Besides, who knows -- one day they may own GM anyway! Lexus now uses GM's OnStar system, by the way -- so the partnership pays off in a lot of different ways.
canc: most cars nowadays are unibodies -- that means there is no separate frame, the way there is on most trucks. It's lighter and cheaper, and it's a lot less likely to develop squeaks and rattles.
If there is no dark smoke, then that's a good sign since it means you are not burning oil. But if you see smoke, then you are probably in for a engine job.
You can click on the picture to enlarge it. Got the now signature Lexus IS300 clear tail lights. Will be available with front or 4WD. Powered by clean ULEV rated 130 hp engine (probably 2003 Corolla's engine).
MOST EXCITING NEWS! There is a SPORT model, with the 180 hp Celica engine, sports tunes suspension and 17"(that's right) wheels. Those of you who envisioned a 180 hp Corolla, well, I guess someone was listening.
It's designed by CALTY, so Celica's looks will probably rub off on this. My friends and I are going to the Detroit Autoshow this weekend, so I will keep you guys posted of my experience in person.
I think this might be the PT-cruiser killer.
Neon R/T 7.8 seconds
Civic EX, Focus ZTS & Sentra SE 8.3 - 8.4 seconds
Corolla S 9.2 seconds
The Corolla looked absolutely horrible in the slalom test compared to the other cars in the test. The Civic's handling was described as "capable but not race ready". They regarded the Sentra's handling as "a step up on the Civic's handling".
The Corolla's ride was described as "clunky". The Civic's ride was said to be much improved and the Sentra's ride was said to be at a mid-sized level.
The Corolla was also said to be the noisiest of the bunch.
Is Motorweek totally biased against Corolla's or are Corollas not keeping up with the pack? I could definitely see the Corolla not keeping up with the pack when it comes to handling, but I thought ride and acceleration were it's strong points.
MotorTrend have test the Corolla, Civic, Sentra sedan. And the Corolla is second only to Sentra in speed, and is undoubtly faster than the Civic.
MotorTrend's Civic EX sedan was clocked at 0-60 at 9.0 seconds (civic gained weight, with no increase in power, it's 0-60 droped by 0.1 seconds from the 8.9 seconds of the previous Civic). Corolla at 8.7 seconds(?). Sentra was the quickest at 8.5 seconds. Curiously, 99 Corolla (before the VVt-i engine) use to do 0-60 in 8.4 seconds. VVt-i increased the hp by 5, but didn't help the 0-60 number, but the gas milage did go up considerably.
Handling. Yes, I would agree that the Corolla will run the slowest at the slalom, since it's got the softest suspension set up. But the soft suspension will also give the most comfortable ride for everyday driving.
Noisiest. Now I know MotorWeek doesn't know what they are doing. It's another point where they totally went against every review there is so far. The Corolla is the quiest, and long been described as being "baby lexus" like. Toyota in general makes the quiestest cars on the market. And if Honda and Nissan (both has long known as making noisy cars) are now quieter than Toyota, the sun would surely rise from the west first.
My wife's friend has a brand new Lexus IS300. I didn't get to drive it, but she did give us a ride for a lunch outing this weekend.
That thing was super quiet. I sat in the back seat. There we were, turning on the car. There is no sound! Not even sound of ignition. My wife joked (or not) that the car must be broken. Well, it's not. We pulled out of the parking spot, and got to where the parking lot meets the street. And this was a major street, with cars flying by at 45 mph (speed limit) just 3 feet in front of us. We sat there, stretching our ears to hear any sound but we can't. It's almost a creepy feeling seeing cars driving by in front of you, and you see them clearly, but you can't hear anything, not your car, not their car, not the wind, or any noise! It's almost like a waking dream.
Then she starts to apply the gas. There was no noise at first, and then you can faintly make out that the engine is indeed running. 30-40 mph, there was very littel road noise, and no wind noise what so ever.
When they say Lexus are quiet, they really really DO mean it. It's spooky just how quiet they get, it makes the Corolla sounds like a Honda.
Wow...I usually stay on top of what's coming down the pike in new models, but these sport wagons have taken me totally by surprise...never heard or read anything about them until the last week or so. They look very, very promising.
My bias at this point would be towards the Pontiac Vibe...the past has shown that Prizm's hold up more or less as well as the bullet-proof Corolla. Since the Vibe/Matrix combo will be rolling out of the same plant, using Toyota mechanicals, I'd expect a high level of reliabilty from the Pontiac product...lower brand equity of Pontiac, GMAC financing and some of those nice, standard GM creature comforts (On Star, Satelite Radio) all should conspire to make the Pontiac a little better value overall.
Either way, the fan of well-packaged, fun-to-drive, compact cars has to be pretty damn happy these days. I know I am.
Any idea whether the Pontia will get the 180 hp sports tune model for their vibe? The 180 hp VVTL-i engine technology and data is probably jealously guarded by Toyota, I have doubts whether Toyota will be willing to share it. Either way, yes, the do look very promising.
The Matrix/Vibe's picture really reminds me of smaller version of the Lexus RX300 (which also recently got the sigature clear tail lights from the IS300). I guess the reviewers know what they are talking about when they called the Corolla models "baby Lexus" in nature.
Tom2002:
No smoke. Good, that's a good sign. Oil level is normal and is clean, you say? So the oil is not being burned, hence no major engine problem. So you are most likely just in for a relatively cheap repair.
It sounds like you have a malfunctioning oil level detector. Maybe the dector is just failing to detecting the right level of oil. And when you rev the engine, oil splashes turning off the light.
If I was in your shoes, I would take the car to the dealership and get an engine diagonistic, it should pull up any warning code/signal that was triggered. Confirm the code and the mechanic (knowing it's not the oil level) can probably tell you the most likely cause, and go from there.
I'm no car mechanic, but that's just want I would do. Either way, listen to what the mechanic has to say, but get a second opinion if the explaination is too far fetched or cost unreasonable amount of money. Good luck.
http://www.vtec.net/pics/02/rsx/rsx-02.jpg
http://a332.g.akamai.net/7/332/936/0001/www.edmunds.com/pictures/42326.jpg
Notice the new Integra is essential a 2001 Civic hood with a Celica grill. The side is 90% identical to the celica.
http://www.vtec.net/pics/02/rsx/rsx-04.jpg
http://a332.g.akamai.net/7/332/936/0001/www.edmunds.com/pictures/42328.jpg
Steering wheel, aluminum peddels, instrument cluster, even the air vents and the little rectangular buttons on the dash left of the steering wheels didn't get away. Geez!
wenyue , this is not an "oil level detector" warning lamp. This is a low oil pressure warning lamp. You use a dipstick to check a level.
That light's purpose is to come on when it dectect that the engine hasn't got enough oil left in it for proper lubrication. Correct me if I'm wrong. The engine should have 4-5 quarts of oil in it, but the if there is a leak, or the engine is burning the oil, there might only be 1-2 quarts left in the engine, and that's when the light should come on, telling you that there isn't enough oil to lubricate the engine parts.
Since he stated that he HAS checked the oil level (with the dip stick) and the oil level is normal. So the problem isn't because there is not enough engine oil, but the computer is dectecing or saying there isn't enough.
Like I said earlier, I recommend an engine diagnoistic, and see what's the problem.
