May have found your problem on the NHTSA website under Service Bulletins Database...Bulletin #010002 (NHTSA Item #SB612525) covers Automatic Transmission/Power Train component: "CONCERNS WITH THE VEHICLE IN A LIMP MODE, TRANSMISSION WILL NOT SHIFT GEARS, DIAGNOSTIC TROUBLE CODE 17114 STORED IN DIAGNOSTIC TROUBLE CODE MEMORY ON VEHICLES FROM VIN 4B_YN019790 TO VIN 4B_YN078064."
Check this out with your dealer, and good luck.
The bulletin listed is not the problem because I have the problem on my A6 2.7T, and I have checked my car before and it has no DTCs stored.
If you get this clunk fixed, please report to this list, and it is beginning to bug me. I have learned to drive in such a way to keep it from happening, but that shouldn't be necessary.
If you would like to show the problem to a technician, find a place where you are going downhill (even slightly), apply the brakes lightly for a second or two, then get off them to the gas at a normal pace when you are going about 10 mpg. It will clunk nearly every time.
iheiman, go to www.clairparts.com to get the CD changer. Use my FAQ on www.audiworld.com to install it. Save yourself a bundle.
Don Moore and Fernando are the salespeople I worked with at Metro. They are low pressure and very helpful.
Good Luck.
Your thoughts and comments are always appreciated
2. Quattro is a marvelously transparent system and if you live in a climate with snow, it well worth adding on the 2.8 (std on 2.7T and 4.2).
3. Turbos are now just as dependable as any other engine component. I've seen a few reports of failures, but if they make thru the first 10K, they'll probably last as long as the any other engine part. (My son's M/B turbo has 320K miles on it).
4. The 2.8 is absolutely NOT underpowered compared to other luxury sedans. When I first drove one, I felt it had pretty good performance. After I drove the 2.7T, though, there was no going back! Its dependent on how you like to drive and what you want to pay for.
5. There's nothing really to "solve", the 2.8 performance is adequate for most people; the 2.7T performance is equal or better than the 4.2. I have no idea why anyone spends the extra $8K ($12K over the 2.8) for the 4.2. Its a lot of $$ to pay for for a few more accessories and bigger wheels.
6. Don't know of any A6s with over 50K yet, but theres no reason to expect maintenance to cost any more than for any DOHC V6 engine; most all of them are stinkers to work on and have similar maintenance needs like timing belt replacement.
7. I've only had my 2.7T for a month, but I'm totally satisfied.
8. Except for the S Class, I don't think M/B is building cars of the same quality of say, 10 years ago. I shopped M/B and was quite disappointed. The new C Class is tiny and gimmicky; the E's are dowdy and way overpriced.
A few additional thoughts...
1. Regarding quattro, it doesn't sap power; the only way it "slows a car down" is by adding weight to the car.
2. I live in a moderate climate (northern CA) and have not yet driven my car on wet or slippery pavement, so I haven't yet experienced the benefits of quattro. Depending upon who you ask, quattro may or may not affect "handling"; I can tell you that the car feels incredibly stable. (I've heard it described as being "on rails" and can't disagree.) Where quattro really shines, of course, is on wet pavement; there, its benefits are undeniable.
3. Turbos in themselves have no specific additional maintenance. The big thing with turbochargers is that prompt oil changes are much more critical than with non-turbocharged cars. In addition to my A6, I own a Volvo 940 Turbo with 255,000 miles on it; it has never had a turbo problem. Keep in mind that on a 2001 Audi, scheduled maintenance is paid for by Audi for the first 4 yrs./50,000 miles. Of course, if you have to replace one or both turbos out of warranty (unlikely but certainly possible), you're looking at major money.
4. I find the power of the 2.8 to be fine. I have the Tiptronic and really enjoy the power train. Of course, it isn't the neck snapper that the 2.7T and 4.2 are, but not everyone requires that level of acceleration to be happy. When I bought, a comparably-equipped 2.7T would have cost me about $4000-5000 more than a 2.8; had $$$ not been an object, I'd have probably gone for the 2.7T. For me, however, $$$ WAS an object; I could swing a pretty-well-loaded 2.8Q, but not a comparably-equipped 2.7T. I decided that I'd rather own a lesser-powered A6 than no A6. Today, I have absolutely no regrets, and I NEVER find myself disappointed in the performance of my car.
5. As for the 4.2, as Dennis has pointed out it comes with a hefty price increase over both the 2.8 and 2.7T. If you're willing and able to spend the $$$, you'll absolutely love the 4.2. I've always thought that there's nothing quite like a V8! You also get slightly more aggressive styling with wider wheel well flares, a unique front end, unique wheel choices (16 and 17"), a couple of 4.2-only colors (Nemo Blue and Andorra Red), power operated tilt-telescope steering column with memory, aluminum front fenders, special "contoured" rear seat, the inclusion of a heated steering wheel in the optional Premium Package (none of which are available on the 2.8 or 2.7T). The 4.2 includes other features as standard that are available as options on the 2.8 and 2.7T, e.g. auto-dimming mirrors, ESP (also standard on 2.7T), multi-function steering wheel, leather seating, power moonroof, HomeLink, memory front seats and outside mirrors, rear sunshade, ski sack, and Bose audio system.
6. My guess is that owner-paid maintenance will be moderately but not hugely expensive. The only other European cars I've had experience with are Volvos, and their maintenance costs weren't bad at all.
7. I would absolutely buy another Audi, and an A6 to be sure. This car has eye-catching style, tons of class, and is (in my opinion) the perfect blend of luxury and sport. I have never felt as good driving any other car as I do when I drive my A6.
8. I'm with Dennis all the way. The MB E Class is a very nice car but it's over-priced and boring. I see it as loaded with luxury but completely lacking in sport unless you go for the mega-buck E55. I just looked at the new C Class and, while it's a nice car (and they'll sell zillions of them), it's very small compared to an A6. (Its real Audi counterpart is the A4, and I'd take the A4 over the C Class.)
If you haven't yet done so, I encourage you to drive the A6 and see what you think. Definitely drive a 2.8Q; if you can afford the 2.7T but aren't sure whether or not it's worth the extra cost to you, then drive it and decide (same with the 4.2); if those two versions are out of reach, then I suggest not going near them!
When you drive the cars, notice the incredible comfort, the beautiful interior styling, the high-quality feel of every control and switch; don't miss seeing the interior lighting after dark - there isn't another car out there that does it better.
If you decide to get an A6, I have two strong recommendations:
1. Get the Premium Package (Steering wheel stereo controls, memory front seats & mirrors (2.8), auto-dimming mirrors, and xenon headlights). The auto-dimming mirrors are very nice (the only way I know of to eliminate annoying glare from the outside mirrors) and the xenons are fabulous; I wouldn't own a car without them.
2. Don't assume that the Bose audio system will sound better to you than the standard system; to many, it doesn't. Listen to both and decide for yourself.
3. Go to the A6 forum at http://www.audiworld.com and browse the threads; there is a ton of valuable information there.
Good luck!
- Mike
stay at for any length of time even in 3rd or 4th.
Thanks, I'll have to try it out.
As far as the clutch being out of balance, wouldn't I have symptoms all over the place if that were the case?
The cold makes the compound of summer tires close up and they lose grip, even without coming into contact with snow.
where did you see the information about the 17 inch wheel being part of part of the 2.7t sport package. I have search audiworld without success.
CalTrans (not CHP) will check for chains at designated checkpoints. They move up and down the road depending on the snow level. You will probably be allowed past anyway because you have Quattro. They don't know your tires are no good (on snow) and don't take the time to check them for the M+S designation.
You really should use your own careful judgement. As to when it isn't safe to proceed.
I spent the last week (vacation) in Panama City and hoped to find an Audi dealer in Destin ($$$$) but no Audi dealer to be found, unless I am blind (which may be the case)
If you really can't deal with turbo lag, you don't have much choice other than the 4.2. Me, I find the lag to be so minimal as to not be a problem.
At first I thought maybe my passengers were doing something wrong but then I tried it and it did the same thing.
My Driver Console works great for all the windows.
I took my car in for its 6-Month service and alerted the service rep.
If fact when I was there, the rep had to roll down the window to put in the anti theft box or whatever that thing is, and it did the same thing.
He said he would check it out.
Upon picking my car up the first thing I did was check the window and it did the same thing.
The rep and My salesman said that all there A6's
Did that.
On the service report they stated that
"The car is operating according to Manufacturing
Specifications at this time"
My Boss has a 1999 A6 2.8 and his Driver Passenger
window works perfect everytime.
Am I Doing something wrong.
Has anyone else experienced this problem.
Steve Bollinger, Do you have any suggestions.
Thank You All.
Tom
At any rate, I just tried the express down on all 4 of my windows. They all work normally from the buttons on their respective doors. That is, a single push and immediate release results in full lowering of the windows. If yours doesn't do that, something's wrong.
I presume you are holding down the switch when it doesn't work? That is, press and hold, release, press and hold to make it work? It really sounds like a problem in the auto-up.
My drivers window required resetting once (as described above). The only other problem I've had is that if you start all 4 windows in motion in quick succession, usually the auto-up will reverse on one or more windows. This is because the auto-up detects motor stalls through voltage drops. When you turn on all 4 windows at once the voltage drops and the falses the sensor. Not great, but not a big problem. I just take a little longer between lifting the front two switches and then lifting the back two.
Thank you for your help.
I Picked up my A6 2.7 Sat and the Passenger side
window switch works fine. My salesman told me they reset the switch.
Steve, I wish you worked at my dealer.
My Question is, Why did I have to Bounce it back to them in the first place ??.
I Also had a Squeak in my back Seat, again they fixed it only after I Complained.
Some of the Excuses my dealer comes up with are so lame that they are Insulting.
Example: They originally they said the Squeak in my back seat was the back brakes engaging ????
Overall all my problems have been minor
and after 3-Days in a 1996 Volvo My 2.7 is a Dream Machine.
Thanks again.
Tom
On to dealer responsiveness:
I do keep hearing problems such as are spoken on here, with dealers being reticent to fix or look at problems. Mine has been quite the opposite, asking if I have any complaints I want looked at each time my car is in. At times, they have been hamstrung by parts availability (still waiting on a radio), but they do mean well.
I wonder what makes a dealer take a particular stance either way? If your repairs are warranty repairs they actually make a profit fixing them, so I don't know why they'd balk at that. For really minor things like resetting your window system, it just seems like it takes less time to fix it than argue about it!
I've never had an Audi as a loaner yet (I get awful little cars), but otherwise the dealer has been as helpful as they could be.
often, in a luxury car environment (Audi, MB, and so on) the people working on the car share some blue-collar resentment of the people who they see can "afford" such machines. They see that their customers are -- like all customers -- a mix of idiocy, arrogance, and irnorance (as well as many of the nicer qualities) and do what they can to exercise a moment of superiority over their custo ... err, victims. It must, for example, be frustrating to a mechanic who likes fine machinery to see it having troubles due to sloppy and inconsiderate maintenance.
I once had an acquaintance, a MB mechanic, confess over a couple of beers that they often "lost" parts orders or inserted additional minor problems (loose bolts, rattles, etc.) just "for fun" when a car was in the shop, especially when they perceived the customer as "asking for it."
I suspect that such attitudes may fester in a difficult working environment and may only disappear if the dealership owner makes a concerted effort to generate respect for the purchaser in his staff. My guess, in other words, is it comes from the top down.
FWIW.
Take care.
Joe W>
Just so we're clear, this is a vibration--a slight one--felt through the pedal and seat at around 65 mph, and which disappears at about 85 mph. Right?
Please provide more details about the arbitration.
