Visitor Agreement.
Interesting, helpful and positive dialogue that's been evidenced here is nice to see. Did our "identity changing" detractor get bored? My 2000 Steel Blue ES continues to soldier on--recently completing a round trip of about 1500 miles for a grand total of 56,500.. Unlike some I have had all brake pads changed--with Bendix lifetime replacement pads. Changed my tires at just shy of 40K to Goodyear Allegra's. Many of your know have read the potential transmission "horror story" that I averted when they put the incorrect fluid in despite my warning.
Has anyone else with 50K or more decided to have the timing belt (and other accessory belt) replaced? It falls at 50K in the cycle and the dealer mentioned it--although my private shop did not. It is looking a bit glazed and pitted, squeals near redline, but still holds together.. Probably better to have it replaced now. With regard to oil changes--because of the large number of highway miles--and the fact that I use full synthetic in my 3.2--I go at least 5000 now before changes.. Hope all is well any feedback on car-truck.com welcome.. Be well and peace to us all..
My 2.7 has a timing chain, whereas the 3.2/3.5 have a timing belt, so I'm not too concerned about the chain. I think the timing belt interval is 105K miles, though. The 3.2 is an interference engine, but the 3.5 is not. Interesting.
As for the accessory belts, mine is at around 77K miles now, and when it was in the shop recently, I had them check it out. Belts, hoses, and coolant all still look fine. I just had new tires put on this past Friday...some Yokohama Avids. I'm due for another tranny service around 90K, so I'll probably have them do the belts/hoses/coolant then, just to be safe...even if they say it still looks good. Depending on how quick I rack up the miles, I might have it done sooner, as I'm not driving nearly as much as I used to. I'm only putting around 1000 miles a month on the car now, and expect that to drop as nicer weather nears, as I tend to get out the convertible. I also have an '85 Chevy pickup and a '79 New Yorker that I'm trying to drive every once in awhile so they don't sit too long, so the 'Trep's mileage may be even lower. Maybe I'll just end up getting the belts/hoses/coolant done on the 'Trep's 4th anniversary, in November, regardless of how many miles are on it!
If your accessory belts are actually looking worn and pitted though, it might be a good idea to have them changed. I've heard that the flat belts they use nowadays tend *not* to show visual damage as readily as the older V-style belts, so if yours is actually showing damage and wear, it might be close to snapping.
the old iron block 3.5l was not an "interference" engine, but the newer aluminum block 3.2l and 3.5l are intereference engines. interference means that if the timing belt breaks the pistons could collide with the valves.
did you say your timing belt was squealing?? if so definitely replace that. same with accessory drive belt. like andre said the timing belt replacement schedule is 105k, but i don't think i'd wait that long if it were me...
Gates could be wrong, though!
I can never remember...is the 3.2 destroked or debored from the 3.5, or are both dimensions smaller?
i'm not entirely sure...but thought i'd read somewhere that the newer v6s (3.2l and 3.5l) where indeed interference. it would seem strange to me that the 3.2l would be and the 3.5l which is basically the same engine wouldn't be. i'll do some checking around as time permits.
according to allpar.com the 3.2l is a debored version of the 3.5l, but the stroke is the same. i'm still not 100% positive about valve clearance on the 3.5l...
Brain fart eh? The kids still say that? ;-)
Hmmm... I thought brain fart was relatively new...
Thanks for telling me that the 3.2 is an interference engine. Although I have only 63,000 miles and the interval for timing belt chain isn't until 105,000 I think I will get that done about 90,000 or so. I don't want to take a chance. I have had timing belts break on 2.2 liter engines (non-interference), a Reliant, and an Omni GLH Turbo, with no big deal. The engine just stops running. With the GLH, I coasted into a service garage that I use, got out and told the guy that I needed a timing belt. He looked at me like I didn't know what I was talking about. Called me later that day and said "You were right about the timing belt and that will be $138.00". I suspect the tab for the 3.2 will be considerably higher.
Time to wash the 'Trep.
ES
If you have the time and the money though, I guess anything is possible! I've seen PT Cruisers with the 426 Hemi in them, and once I saw an old 70's Dodge Colt with a 440 in it!
I haven't gotten a good look up close at the new Hemi, but I don't think it's nearly as big as the old ones. First off, the old one was based on a big-block V-8. The new one, while it's all new, has the same bore spacing as the 360 it replaces. I think it has the same stroke too, but I'm not sure. I think the new Hemi is even lighter than the 360. The two rocker arms in the head are spaced closer together too, so the heads aren't nearly as wide as they were back in the day.
Hey Mike, is your 4.9 a turbo or the regular model? Oh yeah, I forgot...what'd I say about the Impala? I tried to go back and look but couldn't find it. Hope it wasn't anything *too* naughty ;-)
Oh yeah, my first car was a Chevy too, a 1980 Malibu coupe. It just had a 229 V-6, but it was a good little car.
The guys that ran this shop (they finally retired about a year ago...they were transitioning when I had the car in for its last tranny service) had been around forever...before they opened up their own business they worked at a place up the street that had sold DeSotos!
The guys that run the shop now are a bit more hi-tech though, so they may have gotten in a machine that can flush out the tranny. I dunno, though.
they recommend dropping the pan and draining the torque converter...then refilling.
i guess a number of people have had tranny failures soon after a flush service. supposely the flush can cause things to come lose that shouldn't be floating around in a tranny??
I've also heard that it was common for a rebuilt tranny to fail because they'd forget to flush out fluid in the cooling lines that go to the base of the radiator. Junk that had accumulated in there would circulate through the new tranny, and cause it to fail prematurely.
atf+4 didn't even come into existence until about 2000...so before that it was atf+3 and atf type 7176. i think what you are referring to was back in the late 80s very early 90s some manuals said that dexron was okay...that was a huge NO NO!! dexron has very different frictional properties vs chrysler spec tranny fluid.
i believe i have this right. aftf+4 is backwards compatible with chrysler trannies that originally required atf+2 (type 7176) and atf+3 except for '99 and earlier minivans. something to do with torque converter shudder on the vans. however, a vehicle that was factory filled with atf+4 should only use atf+4...
there was a chrysler tsb that mentioned this somewhere...
doesn't it make you wish they all (all car makers) used the same damn tranny fluid!!!
The only real problem I had was that the installers didn't put everything back together quite right. The first time I put on the parking brake, it went to the floor and stayed there! They forgot to re-attach a cable or two. Luckilly I was only about a mile or two from the shop, and they sent someone out to fix me on the spot.
Otherwise, I'm happy with it. If you look inside the left-most a/c duct, a red wire is visible, but it's really only obvious at certain times of the day, when the sun hits it just right.
I know that it's not going to keep away anybody who really, *really* wants to get into my car, but if nothing else, it at least gives me some peace of mind, and it'll make a few of the less *professional* thieves think twice.
One thing that came in really handy though, is the remote unlock for the doors. I used to deliver pizzas, and the remote figure made hopping in the car with 3 or 4 hot-bags a lot easier! And now it's gotten to the point that I'm so used to hitting a button instead of fumbling for the keys, it feels weird whenever I drive an older car. I've caught myself on a few occasions, trying to aim the fob at my '79 New Yorker!
Would I do it again? Probably. The main reason I got the Viper in the first place was because someone tried to break into my car, and damaged the passenger-side door handle and sheetmetal in the process. When I bought my car, I had the dealership put in a 10-disk cd changer, which has the controls mounted on the dash, just to the right of the steering column. I think that's what they were probably trying to get to. If the CD system was integrated into the car better, like from the factory, maybe they wouldn't have tried to steal it.
My OEM Eagle GA's lasted a grand total of 30K miles, and that was even pushing it...they were almost down to slicks by that point! I did a lot more driving back then, putting on that 30K in about 11 months, so when I bought my first set of replacement tires, I was looking mainly for low cost and long treadlife.
Back then, I bought some cheap General Tire Continentals, or something like that, from www.tire.com. They were about $255 with shipping, and had a 520 treadwear rating. I got about 47K miles out of them, and they actually did have some life left in them. Only problem was, about 7K miles into these tires, I picked up two nails in one tire, and got it plugged. One of the plugs was close to the sidewall, so it was pushing it a little. About 5 months ago, it started getting a slow leak. Never would go totally flat, but it would go down to about 20 psi. For awhile, I could get by with putting air in it every 3 weeks or so, but in the end it got down to every couple of days.
One of my tires was also worn unevenly, when the car went out of alignment. It wasn't *too* bad though.
Anyway, the Yokohamas make a world of difference. They ride smoother and the car handles better than those Continentals did. I honestly can't remember how they compare to those Eagle GAs though. I've only had them on the car about 2 weeks now, but we've had plenty of wet weather, and no traction/braking problems yet!
They'll insure just about anything from the '60's and earlier, provided it's not a total clunker. They have a minimum value, I think it's $3-4K. The car also has to be garaged though. With the '70's and '80's though, they tend to get much more selective. I'd think that something like a Firebird would stand a good shot at being insured though. It's one of the few cars from that era that would stand a chance of being a collectible.
They also charge more if the car has been modified for performance, expensive paint, customization, etc.
That being said, my 67 Galaxie 500 XL convertible was $192 a year at State Farm, Hagerty quoted me $82 a year.
I do remember awhile back, on one of those wildest police chases videos seeing a first-gen 'Trep that was flying down the interstate and clipped another car, flipped gently onto its roof, and slid upside down for about a half-mile. They said he was doing 125 mph. I don't remember if it was a base or ES, though. Were the first-gen models faster than the current ones? Or maybe the rev limiter on this one was just disabled?
ES
Anyway, I'd imagine the 3.2 is somewhere similar, designed to top it out at around 110. I'd like to know how fast some of these cars really can go, though. I found some test results from the Michigan State Police, and their '03 test Intrepid topped out at 138 mph! And *that* was rev limited! For comparison, I think the fastest stock Mopar police cruiser was the '69 Dodge Polara, and I believe it topped out at around 145 mph.
