Older Acura TLs
17980828485175
  • ruskiruski Member Posts: 1,566
    same gas, but... have you considered how often a given station changes their filters?
  • vinceb81vinceb81 Member Posts: 39
    Is controlling the radio functions more difficult with NAVI? I want to be able to control the radio directly from the dials. This could impact my decision concerning getting NAVI. Thanks for the help.
  • uncledaviduncledavid Member Posts: 548
    You really need to go play with it yourself. But, the answer basically is that the TL sound system controls are pretty easy to work, even when you have Nav.
    First of all, in the TL, you have volume and mode controls on the steering wheel and on the dash. You also have controls for the presets, seek and scan on the dash. I'm not sure if there are other controls on the dash (because I have the TSX, not the TL). All of the radio controls respond to verbal commands as well.
    I get in the car in the morning and I turn on the radio with the dial on the dash. Usually, I switch channels primarily with the wheel control and a I also adjust the volume with the steering wheel controls (although both can be done on the dash). If I decide to listen to the cd player, I usually press the mode button on the wheel, or I give a verbal command.
    Thanks for the information. I think I will stay with my original decision: Anthracite/Quartz/NAVI
    Dealer told me some cars with my color combination went into production today and will be available in a month.
  • gregory28gregory28 Member Posts: 174
  • philipnowphilipnow Member Posts: 24
    Thanks gbrozen, vinceb81, and gregory28! I'm really enjoying my TL. The DVD-A adds a lot of depth to music. I've found myself turning to look in the back seat to look for where a sound was coming from!
    Anyone have any mileage stats yet? I never got very great mileage with my 2001 TL, usually around 20-22 mpg, when some were reporting close to 30 mpg. Maybe I have too much of a lead foot!
    I don't think this subject has been addressed in this forum. I find the car to have larger blind spots than others I've owned. I received a link to an article that eliminates them for us if you follow the directions:
    Step 1
    Place yourself in your seat in a normal driving position.
    Step 2
    Set your rear view mirror the way you normally would.
    Step 3
    Lean your head all the way to the left so it touches the driver's window. From that position, set your left side-view mirror so you can see the back corner of your car.
    Step 4
    Lean the same distance the other way, and set your right side-view mirror the same way.
    This method works quite well in eliminating the large blind spots.
  • dulnevdulnev Member Posts: 652
    Yes, it does work very well. I've been setting my mirrors like that for about a year now and I have not had any incidents of starting to make a lane change movement before realizing that there is a car in the blind spot.
  • 1hopeck1hopeck Member Posts: 41
    How much does a DVD-A cost and how many recordings are available?
    Since this sound system only enhancements the play quality of DVD-As and not CDs or Radio seems one would have to have many DVD-A to take advantage.
  • mhewittmhewitt Member Posts: 14
    DVD-As are discounted reasonably well by Amazon but title availability is extremely limited. Take any chance you get to tell manufacturers that you'll buy all they make.
    Blind spots: before manuvering NOTHING beats turning your head both ways and making sure there isn't a suprise waiting for you.
    Hope everybody is enjoying their TLs.
    Only you can decide if the NAV makes sense for you, factoring in the cost and your driving style. For me, I'd never buy another car without it. I love it, and Acura's system is the best I've ever seen.
    Anyway, I wish you luck with your purchase. Either way, you are getting a great car.
  • kfhmailkfhmail Member Posts: 199
    I test drove the 04 TL the other day and am concerned about visibility from the rear view mirror. The side mirrors worked fine.
    But, on the rearview mirror the area shown appears to be small and oval shaped. The area viewed appears alot smaller than what I am used to in my Diamante and with the oval shape the sides/ends viewing area is reduced since the mirror is oval shaped (tapered at each end - smaller area to view). The rear headrests can also get in the way. I lowered the rear headsets all the way to make it better.
    Anyone else have a problem or concern with seeing/visibility with the rear view mirrow?
    Thanks for your help. I have decided to buy the NAVI. We are going to keep the car for years so might of well enjoy all of its features. Just have to wait for right color combination.
  • kahunahkahunah Member Posts: 448
    Yes, rearview mirror visibility is less than in my '00 TL and the rear headrests don't help either but I find the visibility adequate.
    Hold on a second...you mean to tell me that the rear headrests move up and down? I've had my '04 TL for three weeks and did not realize this. Nor did the salesperson point this out to me. I'm just checking out the specs on line and there it is "Adjustable rear seat headrests"...cool.
    Sam Goody, Best Buy and Borders all have good DVD-A selections. On-line there's quite a few places.
    I disagree with some about the CD sound. I think it's fantastic in the '04 TL. The DCD-A's do sound better and when one does a direct comparison one notice's the shortcomings of the CD more dramatically. The best way to hear for yourself is to bring some of your favorite CDs to the dealer and listen. XM doesn't sound as good as CDs, but it sounds better than FM. It's all a matter of degrees.
    I do find that the rear headrests partially block the view of the rear window. My previous car had headrests that were movable downward by remote switch on the dashboard. At least one should be able to move them downwards manually enough to totally unblock the view of the rear window . Let's face it, most people are alone when driving and I agree that this is a minor design flaw. I sent a letter to Acura about this and the lack of storage space in the cabin. Anybody notice how few DVD-A jewel cases fit in the center arm rest? Because of their oversize very few fit.
    They are adjustable, but they still partially block the rear window when fully lowered. Did you know the center arm rest and shoulder belts are adjustable too? These are nice features.
  • bmwdriver02bmwdriver02 Member Posts: 46
    On Saturday, got my first glimpse of two TLs on the road. I saw a silver/ebony and a blue/camel. The silver one was parked so I got a better view. The blue one was moving on the highway but the driver was only doing about 45 mph behind a school bus. The silver looked better mainly because the blue one was dirty with a beige/tan pinstripe.
    I like the look of them. My wife and I are considering purchasing an anthracite one whenever we sell our 99 Accord.
  • msf2msf2 Member Posts: 88
    Haven't seen the Camel interior yet.....any comments from owners on how you like it and what exterior color you have it with. Thanks in advance.
    Yes, I know about the rest (I have an '00 TL remember). Previous TL rear headrests did not adjust, so I just assumed the same for the 04.
    The shoulder belt max. height adjustment on the 04 is too low (lower than previous TLs). I think this may be due to the deployment path of the side curtain air bags.
  • bodble2bodble2 Member Posts: 4,514
    My personal view is that it is a little too yellow and doesn't blend with the faux wood as attractively as the parchment does.
    I'm with my pal, bodble2. I really don't think it goes well with the faux wood. The parchment is a much better combination with the faux wood, IMO. To my eyes the camel is an orangish color and I believe it's a love or hate interior. Some people have compared it to the color of some very exotic car's interiors. Definitely look at it in person prior to ordering. Colors have been discussed at length in earlier messages in this forum. You might want to "back message" and see what other's opinions have been.
  • s852s852 Member Posts: 1,051
    I have head people say it is very firm, and similar to the ride in the "Type S" 2003 TL.
    If that is true, people looking for a compliant ride like the base TL from last generartion need to look elsewhere.
    Also, just because someone wants a comfortable ride, doesn't mean they want a Buick or Lincoln.
    BMW and even last years TL manage good handling with good ride comfort at the same time.
    I can see how someone who has had cars with very soft rides will think that the '04 TL has too firm of a ride. Someone who trades their little sports car in may think the ride's too soft. This is a tough one to comment on. I think it's important for the possible buyer to spend some time test driving it and make their mind up.
    Some guy commented that he bought the '04 TL for his wife and she was used to her Lexus's ride. She was very dissapointed and he was considering selling it.
    My neighbor has a 911, talk about a firm ride! One person's fun to ride, great handling, feeling the road joy, is another's "harsh ride".
    I like the Camel interior the best and will be getting Anthracite+Camel TL. My take on different interior colors:
    * Black (ebony). Best looking, in my opinion, with most colors that I like (Anthracite, Silver and Blue), BUT gets impossibly hot in the summer and requires a LOT of cleaning and maintenance. Every little mark or scratch or spec of dust stands out! That's the interior I have on my 2003 TL-S and I don't want to live with it any more.
    * Quartz: too mousy looking for my taste, but it was my second choice. The leather color is Ok, but the carpeting just looks cheap in this color.
    * Parchment: beautiful, but WAY too light. My wife's minivan has this color interior and you simply cannot keep it clean.
    * Camel: camel with black dash looks amazing too me. I've seen it on several cars with different exterior colors and liked it every time. Not too light, not too dark. Just perfect. And I think it looks awesome with the wood.
  • automophileautomophile Member Posts: 780
    I, too have been setting the mirrors as described for the last 2-3 years. It makes a BIG difference in your overall visibility. When mirrors are set conventionally, there is a lot of overlap. When they are set correctly, they barely overlap, so you end up with a much wider field of view.
    I found that the rear headrests do block the view a bit, but also noticed that the side mirrors well cover the area blocked in the rear mirror when they are set correctly. Use them all AND turn your head is the best bet. I am coming from a 2-door car, and I am still getting used to having a big post right next to me when I turn to the left!
    regarding the audio system - it is a very clean and accurate system, it will make any CD sound its best, even if not in full surround sound. There are audio processors that can derive surround from even standard CDs - too bad that Acura didn't include that as well since they set the car up for 5.1.
    I have been out of town this week, it is killing me to know that the TL is sitting in my garage begging to be driven! Can't wait to get home. While travling, I have been reading the Quick Guides that came with the car and I am astounded at the wealth of features that are not apparent. This car needs a full training course to come with it!
    does look good with the black dash. But somehow it doesn't go that well with the wood trim.
    It is possible for a suspension to be really taut and give good handling but also have a complaint ride. Good examples are the BMW and VW Passat. However, my TSX is taut and stiff. Too much of the road makes its way into the cabin. Its not a horrible ride, and I still love the car. But, the ride is stiff.
    Keep that in mind when you drive the TL. If you feel that the ride is taut but complaint, it should be comfortable over the longterm. If it is stiff, that might be another issue. Personally, I'm suspicious. With those low profile tires, the ride can't be great.
    At first I was concerned about the TL ride. But after driving the BMW 330I, I know the TL has a better ride. Sure the BMW handled better, but I was disappointed in the ride and the interior. The TL has more options for $6,000 less.
    I just finished my first time entrance into the 1 hour long chat room about cars here in Edmunds. It's the third Wednesday of every month between 6-7 PST. I thought some of you TL owners would be there. It was enjoyable but it was a real small group- 8 people at peak!
    They have one hour chats for Mazda and Suburu every week. They would have one for Acura if there was enough interest. Maybe a Honda/Acura would have enough attendees to support it- 2 of the 8 tonight were Honda owners.
    I finally got through the entire manual- skipped the navigation and hands-free sections since I don't use these features(yet, on the hands-free). Yep, slightly easier to read than "War and Peace"- not much shorter; LOL. Not quite as enjoyable as a Tom Clancy thriller (understatement of the day).
    I realize this will be rudimentary for many of the car afficionados in these forum, but for all the rest I hope it's helpful.
    Some highlights:
    Auto Select (page 119): "If you are traveling far from home and can no longer receive your preset stations, you can use the Auto Select feature to find stations in the local area." The beauty of this is after you get back close to home, you hit the button again and your original settings are restored.
    Yes I know, many of us are using XM radio and listening to DVD-A and DTS to take full advantage of the great 5.1 surround system. It's still a great feature IMO, and variety is the spice of life. It gives one an opportunity to get a good flavor of one's new destination. I enjoy hearing the local news and other local programming. They play less commercials outside of the NYC area too, so "I've got that going for me" when I travel- any Caddyshack fans here?
    Speaking of the sound system: 6 presets for AM, 12 for FM and 12 for XM. 30 of one's favorites at one's quick convenience. Add 6 discs and one tape and you've customized the sounds for 3 dozen plus 1 sources. BTW, my cassette tapes have never sound so good in a car.
    If anyone figures out how the 2nd paragraph on page 131 makes any sense please advise. I just don't think the feature works.
    Some people have had problems with the memory settings for side view mirrors and driver's seat. Some may need to read pages 93-95 and page 86 a bit more carefully. It's a combination of storing the settings on the driver's door and on the remote control.
    Using the heat seat heater even in the low position for a long time when the engine is idling will drain the battery.
    This reminds me that certain devices left on and connected to the accessory power sockets will severely drain the battery; i.e TV/VCR. A friend has gone through a couple of batterys due to leaving a power draining device connected and on while the car's engine was off.
    page 165: "Do not try to 'top off' the tank" when adding fuel. "Leave some room for the fuel to expand with temperature chnages".
    "Screw the fuel fill cap back on until it clicks at least three times. If you do not properly tighten the cap, the Malfunction Indicator Lamp may come on". Page 243: 'If you have recently refueled your vehicle, the indicator coming on could be loose or missing fuel fill cap. Tighten the cap at least three times. Tightening the cap will not turn the indicator turn off immediately; it takes at least three days of normal driving."
    I had a car that had the Malfunction Indicator light on a great deal- it was a total headache. Sometimes the gas attendent made a mistake other times there was a problem with this indicator. In NJ one can't pump one's own gas- so I'm accustomed to watch the guy closely or put the cap back on myself.
    Page 173 has instructions on hooking the cargo nets. This feature is more difficult than some of the audio features. :-)
    Due to the tougher emmission standards the car meets,there may be occasions when the vehicle won't start on the first try. This has only happened to me on one occasion in 3 weeks. This may get worse in colder weather- every car is more difficult to start in colder weather has been my experience.
    Features I haven't had in my previous vehicles that I find very useful:
    Side mirrors that have a defrost feature.
    Ability to open all windows and sun roof with remote.
    Full features of the sound system.
    Hands-free cell phone through sound system.
    Homelink.
    XM Radio.
    5.1 surround (no one has had this from the factory).
    Memory for seats AND side mirrors.
    Fog lights in the headlights- more effective system.
    Multi-Information Display- so many choices with timing features of lights and locks.
    Ability to lock trunk from glove box and then give valet the key.
    First tune-up at 105K miles
    Features I've had on previous vehicles that I'm glad are available:
    Sports Shift.
    Valet key.
    Automatically darkening rear view mirror.
    Trunk pass-through.
    Power everything.
    Sun Roof.
    Controls from steering wheel.
    Thanks for the long and informative post! This car does so much, I think we will all learn a lot from each other.
    Gregory28, I agree with your assessment of paragraph 2, page 131. I can't get these buttons to function as DISC - or DISC + controls either. They will only perform the direct access function to disk 5 or disk 6, respectively.
    I went out and bought 6 DVD-Audio discs today. I bought 2 at Fry's, 2 and Circuit City, and 2 at Best Buy. I bought Faith Hill -- Cry, Frank Sinatra at the Sands, Diana Krall -- When I Look in Your Eyes, B.B. King & Eric Clapton -- Riding with the King, Vivaldi Four Seasons with soloist Anne-Sophie Mutter, and 38 Special -- "Live at Sturgis." They're all good. King/Clapton's Riding with the King and Krall's When I Look in Your Eyes are probably my favorite of those I bought today. They seem to make best use of the 5.1 mixing. The sound in the TL is fabulous! I did run into a little problem trying to store all of the DVD-Audio cases in the center console compartment. That compartment seems to have perhaps been designed with CD cases in mind. CD cases fit great but DVD-Audio cases are a little too big and therefore have to be angled a bit in order to fit 6.
    Can you make the "beep beep" sound for the keyless entry system louder? It was so feeble in the old CL/TL that you could only really hear it if you're parked indoors. Can it "beep" for both lock and unlock?
  • mdhaukemdhauke Member Posts: 202
    I have a question about the trip computer and the gas mileage statistics it gives out. I always thought that these statistics were unreliable because they were only estimates. Are they only estimates or is there actually a sensor that measures actually fuel consumption in the gas tank?
  • car_lovercar_lover Member Posts: 2
    For the TL owners! Does it actually play DVD when the gear is on PARK?? I saw a couple of articles on the internet mentioning this, but some people on this board saying that this is not the case.
    "Beep-Beep" can't be adjusted to sound louder.
    Trip computer gives exact mileage in "A" and "B" modes- one can verify this if one look's at the odometer.
    "Mileage to Empty" is an estimate; theres a 3-4 gallon reserve, so at "E" one will get only 14 gallons from the pump even though the tank holds 17.09. Every car I ever owned has been this way, I find it odd that people think this is a "problem". It's never good to drive a car until it almost runs out of gas- "running out of fuel could cause the engine to misfire, damaging the catalytic converter" (per manual).
    "AVG MPG" is an estimate. The way to check one's gas mileage is to divide the miles driven by the amount of gallons put in the tank.
    DVD: I'm sure you're asking if one can play a movie and listen to it on the sound system and watch it on the navigation system while the car is in park. Per navigation owners the answer is "no". I read a review that said the same thing.
    I found the same thing with the DVD-A cases. The center counsole fits CDs nicely, but doesn't fit the DVD-A cases very well. It might be time for us to purchase a DVD-A case, if they make such a thing.
  • sftroysftroy Member Posts: 30
    gregory28 -
    Just wanted to say thanks for your instructions on rear view mirror settings (post #1880). It is a little strange at first to get used to, but the blind spots are gone!! Thanks!!
    sftroy
    No Acura comes from the factory with software to watch movies on the NAV systems - whether the car is in park or otherwise. There is a widely circulated rumor that Acura products can do this, but it is not true.
  • midnightcowboymidnightcowboy Member Posts: 1,978
    Accord Navigation discussion where it was stated as fact for the Acura TL several times.
    ...will feature a road test on the 2004 TL. The PBS broadcast window begins Friday, November 21, 2003. Check your local listings.
  • retalerretaler Member Posts: 4
    There must be some place to buy floor mats for my new TL other then Acura. The camel/black interior is beautiful, but after two days of rain is getting dirty. If anyone has a good after market web site I would appreciate it.
  • jaydolljaydoll Member Posts: 120
    To all with camel or parchment interior with wood trim, the wood shift knob looks great. A bit pricey but worth it.
    A couple of hundred miles and I am finding the Turanza to be fine. Im sure that they won't last long but so far so good.
    For all fellow TL owners in the NE, it's time to think about a coat coat of McGuires Medalion or any other really good quality wax before winter comes.
    J
    Two options:
    Go to hondacuraworld.com, and get the acura all season mats for the TL.
    Or, go to Mats.com and get the weathertech all season mats.
    Thanks for the web sites
  • jeffxpjeffxp Member Posts: 33
    I'm really excited again about Acura...I was thinking about other vehicles but was revived when I reviewed the Acura Website about the 2004 TL. I traded my 97 CL 3.0. for Diamond Pearl and Parchment... beatiful car and I just couldn't resist the wrap around spoiler ground effects. Finally reached 600miles and can start using full throttle, amazing synergy. Immediately switched out the tires to Bridgestones Potenza S-03 Poles Position. looks more sporty and much stickier but a little firmer ride. Already Have the Blue-Tooth phone hooked up... Somebody stop me....lol
    jaydoll:
    How often do you wax your car? Didn't they just wax the car before we picked it up? Normally, I have my cars detailed once a year; the water seems to slide off nicely for an entire year.
    greg
    1violinist in a previous post recommended Zaino products:
    http://www.zainostore.com/Merchant2/merchant.mvc
    Apparently, they make superior cleaning and polishing products. If they ship to Canada, I may try some in the Spring.
  • builttospill1builttospill1 Member Posts: 6
    The Acura factory mats are fantastic. Highly recommend purchasing them.
    Gregory28,
    Rule of thumb for wax is 2X a yr minimum of premium wax such as the McGuires. One time in the fall to protect for winter and once in the spring. That's it. No fancy detailing is needed as this will protect your paint as well as any product they will apply at a fraction of the cost.
