Older Honda Accords
1366367369371372389
  • dairyshickdairyshick Member Posts: 129
    So, the consensus sounds as though taking my car 1200 miles next week shouldn't be an issue?....or am I wrong?
    I have already registered about 300 miles on it b/c the first 175 were from the ride home from the dealer! I imagine I'll have it close to 500 miles by the time I leave next week...and the first 150 miles or so are on a small back road.
    Also, is it reasonable that I'm keeping the engine under about 4,000 RPM's so far?...should I be racing it up to the 6,000 RPM range every now and then to help break the engine in, or would that just cause potential problems?
    ...Up until now, I've always bought used, so pardon my lack of knowledge in this area!...a new car was recently uncharted territory for me.
    Finally, does anyone have any experience, good or bad, with the 3M clear film bras for the front of the car? I'm not a fan of the typical black bra, and am looking for an alternative.
  • tamu2002tamu2002 Member Posts: 758
    Oops, my memory failed me. On my way home I checked again and my manual 4-cy engine revs at about 2800 RPM at 70 mph. Not as high as I remembered but still much higher than the numbers you posted for the auto tranny. :confuse:
  • thinscthinsc Member Posts: 2
    Does anyone know where I can find one of these. My dealer is all out. I've found a Canadian one online, but would locate a U.S. one since I recently purchased v6 Accord in NC.
  • blaneblane Member Posts: 2,017
    The 2006 and 2007 Accord vehicles are virtually identical. The brochures may have a few different words or pictures, but it wouldn't matter. The specifications are the same.
  • elroy5elroy5 Member Posts: 3,735
    I would not say you have to go full throttle (6,000 rpm), but I would get it up to 5,000 rpm, at least a couple times briefly.
    I've heard conflicting theories on that. Can you elaborate on the reasoning for doing it? Thanks.
    Just filled up my first tank. Averaged 32 mpg (80% highway). Not too bad for a 4-cy engine with 166 hp. The car has over 400 miles now and I can't wait for it to be broken in. I've been very careful not to exceed 65-70 mph for the past 300 miles.
    Just noticed that the passenger airbag off light doesn't come on when no one in the seat! Should I wait and give it a few more chances before taking it in? Is it gonna correct itself? My car also has intermittent small rattles from the dash.
  • scottmtscottmt Member Posts: 21
    I contacted Honda directly. They only made two recommendations: Aviod hard-braking for the first 600 miles and avoid excessive "hihg-range" RPM revving for the same time peiod. When I asked about avoiding constant highway speeds or staying below 65mph I was told that these practices do not apply to today's cars.
  • tallman1tallman1 Member Posts: 1,874
    If I'm reading your post correctly, the light shouldn't come on when no one is there. It is supposed to come on when something light is on the seat, like a child, so that the airbag won't deploy. Sometimes a grocery bag or box might cause it to light up but I've never noticed it coming on with anything I've put there. I'm sure it is because a briefcase or whatever isn't heavy enough.
    Thanks. My fault. I went back and read the manual again. The light is NOT supposed to come on when no on is riding in the front passenger seat.
  • mgmtechmgmtech Member Posts: 7
    I recently bought a new 2006 Accord EX-L. If I remember correctly, the sales person told me not to get my first oil change until 10,000. Is that accurate? I'm at 8,000 now and the reminder flashes every time I start the car.
  • qbrozenqbrozen Member Posts: 33,772
    if the reminder is telling you to change it, then change it.
  • ray_h1ray_h1 Member Posts: 1,134
    Honda recommended leaving the factory-fill engine oil in until the 10,000 mile mark back in 2004 or 2005 (forget which). Whatever was the first year of the oil reminder light marked a much needed change in the company's thinking. (Apparently the company finally started listening to its engineers instead of its marketing "gurus". ;)) If the light's coming on now, you're past due. ALWAYS treat with suspicion anything of a technical nature a salesperson tells you - it's inevitably second hand and could just as well be from their idiot second cousin twice removed as from someone knowledgeable in the service department.
    I haven't gotten my service history booklet yet so I don't know what the recommened oil change intervals are. For our last 2 new cars I changed the oil very early ~2000 miles, following the theory that you want to remove the fine metal particles from break-in from the engine ASAP. Is this a good practice for the Accord engine? The theory really sounds sensible and should be universally applicable, no?
    )) "I contacted Honda directly. ... When I asked about avoiding constant highway speeds or staying below 65mph I was told that these practices do not apply to today's cars." ((
    I have no idea to whom you spoke at Honda, but I suspect he/she doesn't hold a degree in mechanical engineering. (I don't either - but I've rebuilt several engines during restoration projects, myself, over the past 44 years.) You're, of course, free to drive your car in any manner you choose short of recklessly that may cause harm to others. But the simple fact is that brand new piston rings take time to "square" into proper alignment with their cylinder bores. New rings are intentionaly ground and lapped with a very slight convex ("bowed" outward) surface to allow this process to happen - and happen from the center of the ring's bore contact surface for best alignment and longest life. Regardless what you were told, the smart money is on varying engine speed frequently over the first 600 miles to aid precise and quickest ring seating. Ask any mechanic who makes his living rebuilding engines instead of some call center person who may or may not be ten thousand miles away in Karachi, Pakistan or Calcutta, India. (They don't all speak with noticeable accents - the ones who've mastered neutral American dialect command premium compensation for some inexplicable reason...)
  • gunjan151gunjan151 Member Posts: 3
    check the oil life..dealers reccomend oil change when oil life is around 10%.I have 2006 Accord V6 and my dealer reccomended oil change after 7500 miles or 6 months.
    )) "... For our last 2 new cars I changed the oil very early ~2000 miles, following the theory that you want to remove the fine metal particles from break-in from the engine ASAP. Is this a good practice for the Accord engine?..." ((
    YES, Sir! (You're your engine's newest best friend. ;)) Short of factory run-in engines such as Porsche, Ferarri, Maybach, etc., I know of no other automaker who takes more care than Honda in how they build their engines - certainly none in Honda's respective sales classes. Still, that doesn't preclude an astute owner's adding significantly to his motor's ultimate life with careful initial operation. With your technique you'll more likely lose your cars to rust than worn-out motors. Break-in is accelerated, but controlled, initial wear to intentionally grind down the largest remaining asperities present on precision machined surfaces. In other words, the final sliding parts' lapping takes place during break-in by the parts machining against themselves. In addition to the above, break-in also dislodges the inevitable factory leftovers - factory machining debris and core sand remnants in hidden crannies that eluded the automaker's best efforts at flushing. The oil filter goes a LONG way in trapping this crap, but some will just be too fine to be caught. You did absolutely no harm with your early oil change. For the price of just ONE additional oil change over that engine's life you added to the life expectancy of that engine. Salute!
    Except that everything I've read here and in my owners manual says to NOT change oil in a new Accord until 5000 miles so that the special factory oil has a chance to get all those fine metal particles out.
    In light of these different theories and practices, Honda should've addressed these in a crystal clear fasion in their manual, using stronger language and being more specific and emphatic.
    What Ray said certainly makes alot of sense to me, but again you'd think Honda knows what they're talking about when they warn NOT to change the oil untill 5000 miles :confuse:
    Could you show me where I can find this recommendation? I can't find it in my manual. Thansk.
    Exactly right. Keep the factory oil in for a minimum 5,000 miles. I did it with my 06 Accord (to 4,983mi to be precise!) and I'm getting better gas mileage than I would expect to have gotten from this car (30 MPG is normal in mixed, 36-39.2MPG on trips).
  • wsmorenowsmoreno Member Posts: 2
    do you guys think its worth putting a short ram intake to my 94' accord with a 98 engine. would i notice a difference on power or speed? or should i get a different year and fix it?... :confuse:
    OK, When your engine is turning at let's say 2,000 rpm the pistons will be exerting more force on one side of the cylinder wall than the other (the piston is never being pushed perfectly straight up). At 4,000 rpm more force could be applied to the opposite side of the cylinder wall. By varying your speeds, at a wide range of rpms, you are making sure the piston rings and bearings wear as evenly as possible.
  • idluvanew1idluvanew1 Member Posts: 2
    I found mine in the maintenence book that came with the car
    my new accord 4cyl. 5sp got 28mpg on first tank of gas should that go up after break in time and also honda service told me the honda oil filter has a sprcial seal that you can only get from honda but that my choice of oil bran was fine for doing my own oil changes.
    The service dept at my dealership told me other brands of filters would work. But they recommended changing the washer on the drain plug everytime the oil is changed. I bought 10 of them for $5 from them.
    I'm still waiting for mine to arrive in the mail. They were out of the maintenance booklet when we bought the car.
    "honda service told me the honda oil filter has a sprcial seal that you can only get from honda "
    BullsH*f
    If they said this, then they have to provide the oil filter for free. Federal law dictates that if an auto manufactor requires only their maintenance item be used, they must provide it for free.
    This law was passed just to stop the kind of nonsense you were told.
    Go back and tell them about this. See how fast they will back-peddle about only Honda filters working.
    Well, they weren't 'out of the maintenance booklet when we bought the car". Every new car is shipped with one, along with the owner's manual/manuals.
    With some many 'light-fingered' people browsing thru new cars, most dealers leave no manuals in any cars for sale on their lot. But one was probably stolen out of some car and the one in you car was switched to some other car sold previously. Or maybe the one in your car was stolen.
    )) "Federal law dictates that if an auto manufactor requires only their maintenance item be used, they must provide it for free. This law was passed just to stop the kind of nonsense you were told. Go back and tell them about this. See how fast they will back-peddle about only Honda filters working." ((
    Exactly right on all counts. The federal law involved is the 1975 Magnuson-Moss Act which stopped abuses by all automakers (Particularly Ford and GM) in which the automakers voided buyers' new car warranties unless the buyers used automaker brand replacement parts*, fluids, and dealership servicing for all routine servicing. If a given fluid, say Dexron III automatic transmission fluid, is required for an automatic transmission, it can be purchased anywhere by do-it-yourselfers without endangering the owner's warranty claim rights. (M-M also specifically allows owners to do their own routine maintenance without endangering warranty provisions. Save receipts and keep a handwritten log of what was done and when - it'll hold up in court if the automaker challenges you - and it's always the automaker's legal obligation to prove you screwed up, not yours to prove you didn't.) However there is a serious caveat: Most current cars no longer use the once nearly universal Dexron AT fluid. Honda specifies a proprietary fluid - "Z-1" which the company has not licensed for aftermarket production. Honda, though, allows in writing, the use of Dexron temporarily in their gear-type automatic transmissions with the admonition to change it out as soon as possible. (Only Z-1 is to be used in Honda's CVT transmission, though.) Others, such as Hyundai, will void transmission warranty coverage outright if anything other than a Mitsubishi spec. AT fluid - "SP III" is used. Like Honda's, SP III is not available through the aftermarket channels. There're other examples, but I merely wanted to give an easy to digest example of possible gotchas. Motor oil is another matter. All that's required is that the proper viscosity and API certification (5W-20 and probably "SL" or "SM" for current Hondas) be followed. (The next API certification will be "SN", but isn't due until late 2009. The latest API certifications are always backward compatible with previous certifications, but the inverse isn't true. Don't use "SF" in a new Accord, but it's fine to use "SM" in a '96 Accord.) Brand is irrelevant for warranty coverage. Same goes for brake fluid - DOT 3 or DOT 4 is good to go regardless of brand.
    *Honda does not make oil filters. Most filters mounted to U.S. production Accords are made by Honeywell's Fram division in Canada and labled as Honda. (These are not exactly the same as run-of-the-mill Frams, but do employ the same basic construction techniques.) However, the Honda brand filters employ a "P" profile mounting gasket and a silicone antidrainback valve identifiable by its orange color through the inlet holes. A number of other automakers have adopted the "P" profile mounting gasket, too, but to my knowledge none of the aftermarket brand oil filters use this configuration. Still, even the conventional press-on mounting gaskets have never leaked for me. (Just 'cause a mousetrap's better doesn't mean it kills a mouse deader. ;)) Some Honda dealers order and stock Japanese "Honda" filters (made by Toyo Roki), but they're priced signficantly more than the Fram-made Honda filters. Like to use "Honda" motor oil purchased from the dealerships? Honda doesn't operate oil refineries. The Honda motor oil sold through U.S. dealerships is actually blended and bottled in the U.S. by ExxonMobil. Mobil 5000 and Exxon Superflow are virtually identical - and cheaper at the cash register at WalMart or K-mart.
    Thanks for the expansion on the subject, ray_h1, which I also agree with.
    I've wondered how Honda can get by with not licensing their transmission fluid and antifreeze? I would think the govnmint would get into this and force them to provide the specification for other producers to market this stuff.
    I bought Honda antifreeze, premixed to 50/50, for $10 a gallon. This comes to $20 a gallon for 100% antifreeze. Pretty steep, when other major brand long-life antifreeze is at the most about $8/$10 gallon around here.
    I've never bought tranny fluid, no idea what it costs, never ran enough miles yet to do that service.
    )) "I've wondered how Honda can get by with not licensing their transmission fluid and antifreeze? I would think the govnmint would get into this and force them to provide the specification for other producers to market this stuff." ((
    I, too, wish the latter were true. But, Honda spent considerable time and money researching what combination of base oils, additives, and clutch facing materials would provide smoothest operation and protect their transmissions over the longest possible operational life. (and Honda automatics are a whole 'notha matter compared to everybody else's automatics...) They applied for (and received) international patents to protect their right to recoup their development costs and earn profits on their specialized ATF. The gub'mnt's powerless to force Honda to divulge their secrets while the patents remain in effect. Expect Honda Z-1 ATF to run $4.00-$6.00 per quart at retail - maybe less by the 12 qt. case.
  • jimmy1943jimmy1943 Member Posts: 4
    I use Fram oil filters and change them every 7500 miles with the Mobil 1 5-30 synthetic oil. I've heard that synthetic motor oils will last the full period without deteriation. For anti-freeze, I use the expensive Honda stuff ... figure with an aluminum block and cylinderhead I should follow Honda's recommendation. For the 5 speed manual transmission, I use the again expensive Honda stuff and I noticed a slight increase in gas economy with it over synthetic MTL I put in last time ... it also shifted more smoothly.
    You know the Honda stuff might be more expensive, but the change intervals for anti-freeze and transmission fluid are so long that it doesn't seem worth not doing it.
    I think it is important to change the brake fluid every two - three years.
  • deb19deb19 Member Posts: 2
    Is it a lemon or is my new Accord so poorly made that the dashboard rattles with the least uneven road surface? Is there hope for repair or do I need ear plugs for driving? It is not the CDs, keys or other car junk making the noise.
    Have you emptied out your glove compartment, your ashtray, and the compartment under your audio system before doing a test drive on a rough road? Is there anything rattling around in your door pockets?
    My spanking new Accord also rattles intermittently in the dash and door/window areas, and possibly underneath. It's disappointing since this is my 1st Honda. The car drives butter smooth otherwise though.
    Sorry... I've been out of town. I can't remember all the places I've seen it but on p. 154 of the 06 Owner's Manual under Break-in Period, it says "Do not change the oil until the scheduled maintenance time."
    Many people have had problems with the windows. Mine rattle too and I'll get that fixed on the next visit to the dealer.
    As for the dash, I've had a small rattle on the storage compartment door... only shows up on some roads. Next time you hear it, try opening the door and see if it goes away.
    How do they fix these rattles? It's not like they can tighten a few screws. :confuse: Please let me know if your dealer can make your rattles go away.
    I'm not sure about the compartment door, but the part above the arm rest right below the window glass definitely rattles because it goes away if I press on it.
  • dlangdlang Member Posts: 59
    Ah that's nothin'. I remeber last year being stuck in Boston traffic before a Sox game. My Passat was getting about 6 mpg.
    Sitting in traffic would kill any brand's MPG.
    Someone around here will talk about spraying some silicon around the window seals. I'm not sure when I'll have time to take mine in... I'd like a bit more done to it than that.
  • 1997montez341997montez34 Member Posts: 202
    Dude, you have a V6 Milan and drive in NYC (usually stopped) traffic. What did you expect?
    Should you really post this in the Honda Accord forum anyway?
    This is my 3rd Honda and I have never had this problem. Even now my 2002 Civic does not rattle like the new Accord. The Honda service manager said since the parts are made with plastic, that is what happens. Wish I had known that before I purchased the car, then I would have purchased a cheaper car and known the rattles were included in the purchase price.
    I'm rather disappointed with Honda by the many rattles my car has. It's not a terribly big deal and I can live with the rattles. But I can't say my socks were knocked off by the legendary Honda quality either. Hope this'll be the only problem I'll see on this car for a LONG time.
  • zzzzzz Member Posts: 17
    My son stacked 2 CD together and jammed it into the CD player, now my 2001 Accord EX's CD player now shows 'ERR'. This is a 6-CD changer player. Any directions on how to fix this?
    I called the dealer, and was told that this usually destroy the CD player -- replacement would cost 1000 dollars !!!
    thanks.
    If the CD player IS destroyed, go aftermarket. I got a CD player with MUCH more power (200 watts total compared to 120 watts in the 2006 Accord 6-CD changer), better sound quality too, from Pioneer, for less than $200. I bought it to replace a tape deck in my 1996 Accord (4-speaker stereo). It actually sounds better than the system in my new 06 Accord, and the only thing I replaced was the head unit; no amps, no speakers.
    A CD Changer will cost considerably more, but since you are replacing it on an aging car (not old, but not new), maybe you could step down to a single-disc unit with FANTASTIC sound quality for $200 or so and be ok?
  • piloti_stipiloti_sti Member Posts: 62
    Just looking for some comments on the car overall, looking at a few good deals out there on them...
  • canddmeyercanddmeyer Member Posts: 410
    I test drove the SE two weeks ago, looking to replace my 1999 Accord 4-cyl. I loved it, especially the abundant air bags and stability control. Thankfully I didn't get to test those features. I'll admit, it reminded me of our 1999 LX with just a few changes. I guess the wife thought the same thing as she nixed the lease I was considering.
    I liked the power, standard safety features, the lease offer on a brand new model year, and the quietness. The only things I'd like to have that it doesn't have standard are heated mirrors and auto-dimming mirror. The auto-dimming mirror however can be dealer installed.
