But since you decided to give me a nasty response, why exactly do you feel you really need a V-6?
I'm just curious, that's all.
Towing a bass boat. How much does the boat and trailer weigh? I don't think the V6 is rated to tow more than the I4 if I recall correctly (both can tow 1,000 pounds). The limit isn't the power, it's the suspension, frame, transmission, braking, or any combination of the others...
Technically, the throttle is electronically controlled, so I would think closing the throttle would be a pretty viable method for VSA.
And I suppose if I had to pass a lot of trucks on two lane roads, that could make a difference also.
Faux humility aside, I have several questions for the site Honda Accord V6 experts:
1) Are the 2-4-6 bank of sparkplugs (those nearest the firewall - leastways that's how they're numbered on my Hyundai V6) removable without removing the intake manifold? I'm already aware that sparkplug servicing isn't due on Honda Accords until the drop side of 100,000 mile yonder.
2) Does the Accord V6 use a timing chain or a belt?
3) Does the Accord's V6 engine use hydraulic lifters or are periodic valve adjustments necessary?
Unrelated to my questions above, one argument in favor of the I4 edition Accord is the reduced weight over the front wheels. Less weight at the front equates to closer to neutral handling characteristics. Having said that, a hypothetical 2.6L I4 with low restriction exhaust and intake plumbing might be a really interesting proposition.
2. V-6 uses a timing belt that should be changed at 105,000 miles of seven years. 4 cyl uses a chain.
3. Hmmm I should know this one...I'll ask one of the techs.
The 4 cyls don't require a valve adjustment unless they get noisy. That's no big deal anyway.
Another reason I happen to perfer the 4 cyls relates to your last paragraph. They do feel more nimble than the V-6's are.
One of our guys got an older Accord up to 138 MPH before he chickened out. The newer ones have even more power.
That is WAY beyond anything I would be doing!
To continue with your analogy, who really needs leather seats, or a moonroof, or a 6 cd changer, or satellite radio, or an auto dimming mirror, or fill in the blank?
Auto dimming mirrors drive me nuts as they constantly adjust.
Still, if a person can afford those extras and they add to the pleasure of owning a long term car, why not?
I guess nobody needs a NEW car. They can buy used.
And, I suppose people could get by with no car at all. take the bus, walk or depend on others but to me havina A car is a definate need at least where I live.
These never need an adjustment but the CAN go bad.
Same with timing chains vs. timing belts. Chains do not have scheduled replacement intervals but they can wear too and tensioners can wear out.
This won't happen often but given enough miles, anything can wear out. Even on a Honda.
And, yes, the V-6's use a belt.
So I asked a tech. He said V-6 Accords do not require valve adjustments. Hopefully this will answer the poster's question.
I don't sell Hondas, I'm just making an assumption.
That is a pretty strong limb grad.
The camshaft does not operate the rocker or valve directly. Otherwise, there's no means of clearance adjustment over time.
There is a screw (tappet) and locknut to adjust valve clearance, just like my old Honda motorcycle did.
Unless you drive like your grandmother.
All your "fart can" does is make you even more annoying, if that's possible.
i went to the grocery store to pick up a few things today.
when i got home i left the receipt on the kitchen counter.
my wife picked it started laughing and said 'you should start going to the store every tuesday'. clueless, i say why? she says 'they gave you the senior discount', you saved 40 cents. ouch. :sick:
actually, maybe i will go on tuesdays from now on. :P
The Accord can't be tricked like the Civic. Plus the Accord's too heavy. What? 3600 lbs. That's a blob.
Doesn't take away from the fact that I love the car.
Since you mention it though, I'll bite...
** Takes free shot at explorerx4
I'm surprised you do the shopping - is there room for your walker AND all the groceries in the trunk?
Have a good night, sir.
Seriously - have a good one.
Yep, that 50 pounds is a real deal-breaker. I could just about empty out my trunk (tools and spare tire) and lose that 50 pounds
When have I EVER talked about being a hot-rodder concerned with "blowing past people?"
Answer: Never. Blow by me all you want. I promise, I'll be ok.
