Older Honda Accords
1145146148150151389
  • anonymouspostsanonymousposts Member Posts: 3,802
    From our experience with GM they make "temporary" fixes and most of your problems usually result in multiple trips to the dealer.
  • tblazer503tblazer503 Member Posts: 620
    lemme see if I can answer some of your questions to the best of my ability.
    1> Suspension. As far as I can tell, it is the same double wishbone suspension that Honda is famous for. It still has the infamous forks and socket. Now the Civic... that has the cheaper stuff on it. BTW, my Accord handles very well, so I don't see much of a difference.=o)
    2>The new spare is a full size. Don't understand the question well enough to answer it completely.
    ie. fit a full size alloy, or just a full size tire?.
    3>Nope, not the same engine block as before. The '03 has the K24 engine while the '02 had the 2.3L I4. The K24 is also an iVTEC and not a VTEC engine. There is a long story behind this, essentially, there is a rumor that they went to this type of engine design to sell engines to other manufacturers. They couldn't do it with the old ones because they turned the opposite direction, etc. This is why the engine has moved from the drivers side to the passenger side. The engine does require a valve adjustment somewhere near 100k mi. The engine also has a timing chain instead of belt now. I believe it is a solid lifter off the double over head cams... definitely not hydraulic I don't think Honda ever had hydraulic lifters/valves.
    4>temp controls... are interesting. Not too difficult to navigate though.. If you are changing from defroster to foot and front vents etc, it does require a look-see for a sec. The far left control is for the fan, and the far right is for the temp. The center is the audio volume control. Overall, not too bad, the big plus is that at night all the gauges are very easy to see... nice white backlights, not green or orange or yellow. Very clear and crisp.
    Wish you luck... love mine.
    Keep us posted on what you do.
  • zigzag7239zigzag7239 Member Posts: 40
    I was skeptical at first - I've always had dials for heat/AC modes - but when I test-drove the Accord I really liked the feel of the mode buttons - light and responsive but with a sure action. Dials on other cars (including my own) feel much more clunky and awkward after using the Accord. And I find that mode dials usually require a quick look to see where they're positioned anyway, so buttons work as well or better.
    As for the fan and temp dials, they're also smooth as silk - I love them.
    Unlike the LX, the EX has buttons for fan speed (both of the dials are temp dials because of the dual climate control feature). I'm still not crazy about using buttons for fan speed but at least they're high-quality.
  • pluto5pluto5 Member Posts: 618
    Let's wait for the NHTSA crash tests before we conclude this is the best sedan. Camry was a disappointment.
  • robertsmxrobertsmx Member Posts: 5,525
    But since the Accord's trunk is smaller than the competition, then "that's all the average family really needs". Right?
    Just like "horsepower". Before the Accord didn't have it so nobody needed it.....
    Accord had 200 HP before any Japanese competition, but most people don't buy Accords for HP anyway.
    As for trunk, I think a lot of Honda fans will take objection to use of cheaper but space efficient MacPherson struts (like in Camry and Impala at all corners, and Altima upfront) just like they did when Honda redesigned Civic. For them, trunk space is not as important. And without compromising rear suspension geometry, it would not be easy to increase rear seat legroom and/or trunk size. And Accord uses Watt-link double wishbones in that regard (5-links, also used by E-class and up Mercedes). A way to improve the size would be to make the car as bulky as Altima (which is about 3" longer than Accord) or Impala (about 8" longer than Accord).
    Now, that is something a Honda fan would look for in the Accord before how 14.0 cu. feet translates to useful trunk space. And from my experience (98 Accord, 14.1 cu. ft), that is good enough to swallow enough luggage.
    bburton
    I believe your questions have been answered, but I will add something. The four cylinder is now a DOHC engine and uses timing chain. I don't think valve adjustment is needed before 105K (or 110K) miles.
    And the suspension is the same. No changes in the layout, but they are apparently using stiffer springs and may have been tweaked slightly in terms of their geometry for a flatter dynamics.
    I will be surprised if the new Accord didn't get 5-star all around in NHTSA tests and a Good rating from IIHS. 98-02 was very close (only one 4-star and rest were 5, already). Heck, now even Civic has obtained 5-stars all around. The light truck family of CRV, Pilot and Odyssey have all have quadruple five star rating.
    Honda now has one of the most advanced vehicle safety test and research facility where they not only test cars to meet NHTSA and IIHS requirements, but also Euro and Japanese standards, as well as real world scenario of two vehicles colliding on the road. I remember reading this in one of the magazines, I believe it was either R&T or C&D. They had a picture of a 2600 lb. Civic sedan running into a 3900 lb. Legend.
    IMO 14 cu ft. trunk space is inadequate for a family of four. This is probably a good commuter car but not one for a vacation trip. BTW NYT report rated the Mazda6 as the best sedan, so you need to respect others' opinions. As far as safety tests I would wait for the results before putting my money down.
  • glideslopesglideslopes Member Posts: 431
    Uh oh! You mentioned a Mazda in here! They are going to get you now!!!!
    Mark. :)
    Well, the state police here surely aren't driving Hondas!!
    You're right, some of these cars have a cult following. I'm going to clean my S&W. Guess we should leave the topic of Japanese cars alone on Pearl Harbor Day, anyway.
  • accord7accord7 Member Posts: 96
    Anybody know if the radio volume controls for the steering wheel would be an option for the LX? I think the plastic piece they have in it's place looks poor.
  • diploiddiploid Member Posts: 2,286
    The 'cult following' in here is just the same as the cult following in the Mazda6 forum.
    It's like the kettle calling the pot black.
    Besides, per the editors, Edmunds will do a comparison test in the future ("We'll be doing a comparison test on this class of vehicles in the future, so look for those numbers to more accurately measure interior sound levels. — Ed.)
    . From the first drives of the Accord and Mazda6 done by Edmunds, there's a good chance that they'll favor the Accord over the Mazda6.
  • qguqgu Member Posts: 93
    03 Accord scored so so on IIHS low speed test. Of course, this test only means repair bills not safty issues. Hopefully it will score better at high speed test.
    The Mini suffered minor frame damage.The Accord was only rated acceptable because of the cost of repairs not the significance.
    IIHS's low speed test is not about safety of passengers, rather safety of the car. 2003 Accord is rated Acceptable. It is still an improvement over 98 Accord ($379) which was an improvement over the 94 Accord ($469). Here are some (latest) numbers to put this 'so-so' in perspective...
    Audi A4: $216
    VW Passat: $315
    Honda Accord: $339 (subjected to offset testing)
    Toyota Avalon: $501
    Toyota Camry: $528 (subjected to offset testing)
    Nissan Maxima: $648
    Nissan Altima: $805
    Hyundai XG350: $830
    Here are some numbers compiled for minivans...
    Honda Odyssey: $274
    Nissan Quest: $348
    Ford Windstar: $509
    Toyota Sienna: $583
    Dodge Grand Caravan: $1,110
    Mazda MPV: $1,284
    These are average cost of repairing damage. Audi A4 was praised for its excellent bumper design but it actually suffered more damage than Accord's bumper under different circumstances. The Audi performed exceptionally well with flat barrier. However, it sustained more damage with 'angled' barrier compared to the Honda.
    Oh, and the terrible ones from the latest test...
    Mini: $800
    Aerio: $1,131
    Look at the Aerio! Kind of defeats the purpose of buying the cheap little thing.
    IIHS mentions that they subjected Accord to an offset test (for the rear bumper), not the standard test, and it 'still managed only $332 in damage'.
    I don't understand why would IIHS change testing standards if they thought a car's rear bumper was reinforced in the middle to sustain less damage? Why not do it all for all cars? I believe they did the same with Camry.
    They did it for the Accord, Camry and Corolla.
    I think it was a pretty good call on IIHS's part. The 3 cars reinforced the middle of the rear bumper primarily to ace the IIHS test.
    It wouldn't make any sense for them to do the same with other cars whose bumpers weren't reinforced in the middle - most likely because the results would've been the same, regardless of which part of the bumper was crashed.
    But that does not make it equal. Why not evaluate both ways for all cars? Or is it that other cars will not have an offset bump into a barrier?
  • kelvinwookelvinwoo Member Posts: 6
    Do 2003 HONDA ACCORD V-6's Wheels and tires can put on a 2003 HONDA ACCORD I4 LX?
  • ickes_mobileickes_mobile Member Posts: 675
    For the 17th time in 21 years, the Accord is named as a Car and Driver Ten Best. A couple quotes:
    "The Accord's secret has been a combination of solid construction, agile handling, optimal use of interior space, flawless ergonomics, and outstanding powertrailns."
    "...the new Accord maintains these traditions."
    "In the competitive world of midsize sedans,, it just doesn't get any better than this."
  • mrchrismrchris Member Posts: 3
    How fast have you gotten your 03 EX V6 to go? I top out at about 142mph on a flat road. Amazingly, it rides VERY nice @ it's top speed. Had mine since Oct 4 and I am still shocked at how easily I end up at 80mph without realizing it. On, I use mid-grade (Chevron) fuel in mine too. I suppose prem. might give me an extra mile or two on the top end...
  • jvkalrajvkalra Member Posts: 98
    In the same C & D issue which names the Accord one of the 10 best, there are 6 letters (about the Accord) to the Editor from C & D readers. What is interesting is that 5 out of the 6 letters are down on the Accord's styling, one reader saying the Accord looks "Buicky". I'm assuming that Honda tested consumer reaction in clinics before freezing the design and perhaps C & D readers don't represent the reaction of the Honda buying public.
    I can't wait to get our Accord Coupe. We didn't get NAV but didn't think we really needed it especially since dealers would probably be gouging the prices of the NAV system.
    The Voice Command feature comes with NAV. I don't think you can get it as a separate option (i.e. without the NAV).
    Switching from 15" to 16" in LX is a dealer installed option. You could as well get EX (I-4) which comes with 16" alloy.
    C&D's 10 Best ranking is not based on styling, rather the overall package.
    Accord's styling may not be appealing to you, I find it refreshing and in some ways, an improvement over the previous generation. If people are calling it 'Buicky', they must be the same ones who called 98 accord 'Buicky' as well. I remember those comments from five years ago when the Accord was redesigned and I bought my first Honda.
    All I can say about them is, they have no sense of style, and that C&D (or anybody) could care less about what some people think of "style". This new Accord is far more detail oriented than any Accord in the past, my only disappointment is the higher cowl, thats it.
  • npkbnpkb Member Posts: 25
    Honda's canadian website shows a DX with Air, but a local dealer in the midwest denies its existence...
    http://he.honda.ca/models/accord_sedan.asp
    LX add Air, Power locks, Keyless, Speakers to DX. I think I can settle for DX if it had Air.
    Any expert opinion?
    The cowl is higher in the new Accord but supposedly Honda also raised the seat height. I still think it feels higher than the 98-02 Accords even if they did raise the seat height. Still overall a low cowl compared to some other cars though.
    You can have AC installed by the dealer but I don't think you can get factory AC. It is listed as an option on Honda's website but there is not a cost for it. I would think it would run several hundred dollars at least.
  • IT's exactly the same thing as "factory air". It's around 1300.00 to install.
    DX Accords are VERY slow sellers. Most people want AC and by the time it's installed the price is close to an LX.
    isn't it really "dealer air" if it's not installed at the factory? :)
    would you mind telling me if you think this is a fair deal?
    03 Accord EX-L Coupe 5-speed with spoiler, fog lights, splash guards, and paint protectant on a 36/15 lease with $637 out of pocket for $325 p/month.
    I did not say that the Car and Driver rankings were based on style. It's well known that most people buy Accord for the overall package rather than styling, one reads that in every article about the Accord in every magazine. And of course every day on this board.
    What I did say is: 5 letters out of 6 from readers to the C&D Editor were down on Accord styling and one called it "Buicky". Maybe 5/6 is significant, maybe not. In my post above I also said that "perhaps C & D readers don't represent the reaction of the Honda buying public".
  • dinu01dinu01 Member Posts: 2,586
    They're not the same
    The DX in Canada has A/C, pwr windows/locks, 15" steel wheels w/wheelcovers.
    The LX has Leather and alloys
    Then there is the V6 DX and V6 LX (I think)
    BTW, Honda's logo in Canada is on a red background, unlike on blue like in the US.
    Dinu
    The 98-02 Accord is beautiful IMO, but the 03+ looks like a cheapened Civic from the front and a nasty hunchback (hunchback, not hatchback!) at the rear. Again, styling is subjective, but only the Camry looks worse. The 6 and Altima are better looking.
    Dinu
    I agree that the 6 is the best looking one, but the Accord and Altima are pretty similar IMO. From a certain angle, they both look as if they share the same headlights.
  • stragerstrager Member Posts: 308
    You hit it right with the "hunchback" word. No offense meant to anyone who likes it but I see an 'old man's' car, unlike previous generations of the Accord.
    Even though I'm a Honda owner, I find the Accord/Camry/Altima to be all bloated, but the Mazda 6/Passat/Acura TSX more my style.
    IMO, the Altima is not aging well at all. Honda and Toyota, while having somewhat bland designs as a new car, stand the test of time. The Accord will still look fresh 5 years from now (as the 98 Accord still does) and so will the Camry. I think the 6 will also age well. But not the Altima.
    Well I saw some more pics of the new Maxima....ooooh that back end is nasty. That's not going to age too well, IMO.
    I think the Altima has a very good chance of aging well. With the exception of the rear taillights, its overall look is pretty generic.
    C&D readers don't represent the reaction of the Honda buying public
    I read C&D and I drive a Honda.
    More often than not, you're going to see disappointed people writing letters, very few would send a letter of appreciation. That is how it works.
    Said that, I find comments like 'Buicky' styling quite amusing.
    Well, I would blame your eyes.
    Altima's front end... a mix of 96-00 Civic sedan and Passat.
    Mazda6's rear end... '03 Corolla.
    Accord's front end... a mix of 92-93 Accord (grill) and 96-00 Civic (head lamps) and S2000.
    Accord's rear end... mix of 98-02 Accord and 92-95 Civic sedan.
    2003 Accord looks more upscale (albeit rounded) than 98-02 Accord which was boxier (squarish), in and out. It does not possess, the boy-racer look that comes with, say, a Mazda6 and Corolla.
  • talon95talon95 Member Posts: 1,110
    I didn't know that pictures of the new Maxima were out... so I just saw them for the first time.
    Wowee kazowee... I guess the "ugly styling" threads will move over to the Nissan forums. Man, is that thing homely!
    Sorry for the OT...
    My eyes? I don't know about that, but nice try.
    Dinu
    From what I have seen of the new Maxima, the issue I have is its bulkiness. It would almost look like an SUV next to most midsize sedans.
    dinu01,
    Thanks. You wouldn't know. :-)
    dinu: You need to be more concerned with the way the new Protege is going to look if that Lynx is an indicator of the direction in which it's going.
    The Accord is not the best looking car in the world. Nor is it the worst looking car in the world. It is handsome enough not to disuade someone who appreciates it's other virtues from buying it. The interior more than makes up for any problems I see with the exterior. And to me the coupe is one awesome car .. but then again, I am biased right now.
    That Maxima is just wrong. Will have to see it in person before I call it ugly but that's the way I am leaning. And I don't even know if it's ugly .. it's just borrowed too many cues from the Altima but yet Nissan tried to make it look like it didn't.
    I hear you. I saw pics of that Lynx - what an abomination of styling. It resembles at best a Daewoo from the back, but even that's a compliment.
    I did see pics of the Mazda 3 wagon that will replace the P5 and was pleasantly surprised by those looks.
    So who knows. I have to agree with you that the Accord's interior is nice, but I like the boy-racer look of the 6 (bring on the chrome exhaust tip, spoiler, skirts).
    Dinu
    The 6's exterior isn't going to do me much good while I am behind the wheel though. I agree that based on exterior looks alone the line between the Accord and 6 would be narrow. But since I drive my car from behind the wheel and not outside the interior was the deciding factor.
    a Lynx?
    M-144 A1 = Lynx, complete with machine guns. :-)
