Mazda MPV: Problems & Solutions
Get an LX and several spray cans of 3M ScotchGuard. I have twins due any day now (hence why I bought the MPV in the first place) and I have no concerns regarding stains. I'm enjoying the $2500 I saved (bought a big screen TV with $1000 of it).
Well, ES trim does not just give you a power seat and dead cow hide on seats and steering wheel :-) I think traction control and 17" alloys, rear heating and a/c and front side airbags are standard in ES trim. Also, vehicle anti-theft system is NOT available in LX trim.
anyone have the same overheating probs and if so, what did you do to fix it? thanks.
I changed the coolant, hoses, radiator cap and thermostat and double checked operation of the fan (did that have two fans?). I never noticed any real water/coolant lose during this time, although.
At any rate, the gauge registered the same - of course, the gauge came under suspect but the engine did seem hotter than normal.
Someone mentioned either here or on Mars...(?) that the aluminum heads had some problems back then. But if that was the (my) case I should have seen some coolant drop. I sold the van about 10K miles later - it still ran fine.
mileage on his van is only 100,000+kms.
he's got only one big white fan. the fan is a "counter spin" type or something like that, can't remember the exact term. it's always turning when the engine is on and not electrically powered/controlled. i personally think the design of the fan system is the problem. it's not electrically powered or hooked up to the thermostat so it's not cooling down the radiator when it's supposed to. when the van is stuck in traffic, engine rpm is low so the fan turns slowly while the temp. goes up and engine overheats.
i think it's a poor design by mazda. just my two cents.
Anyone?
the van doesn't have a/c.
Also, a response about the loaner car comment made earlier. I have a loaner car while my van is in the shop but have to pay $12.00 a day for Loss of Use insurance. (I tried to get this coverage through my insurance company but they don't offer it.) I'm in a fight with the dealer manager to have this insurance charge waived since the repair will take so long - as yet it is unresolved.
LIFE!!!
If so, isn't the PCV line simply a piece of hose?
I don't mean to make light of your troubles or frustration, just looking to offer constructive help.
If the hose to the PCV valve (positive crankcase ventilation valve) has collapsed, buy yourself a piece of standard hose at your local autoparts store, and replace it.
I don't see how a collapsed hose could mean a 2 week wait, but perhaps I've misunderstood your problem.
Hope this helps,
-brianV
jolly2, I wouldn't generalize that MPV is a bad car because it is not. You are not lucky with your van and as they say if you are not lucky then even in a wooden church a brick will hit you on the head.
MB
Mark. : )
Thanks for correcting me. I transposed.
Don't mean to be argumentative, just want to point out other options. A piece of PCV hose is a piece of PCV hose. This is not a high-tech part of the car. Unless it's routed near a heat source or something, it ought to be a simple fix.
Hope this helps,
-brianV
If you have any questions/concerns, please direct them to me in email.
KarenS
Senior Host
Owners Clubs
Such an oais!
I had a pop-up problem, and haven't tracked down where my laptop picked it up. I suspected Edmunds, but can't say. It'd surprise me if that were the case. I got some crazy Xupiter junk. Now, that stuff just drives me nutz (not in the mpv... content), b/c you'll just get random pop-ups. But, I don't think I picked that up at Edmunds, but from some shopping my dw was doing. <rolls eyes>
On the other hand if I had to drive to the nearest dealer 60 miles then I would probably cut off a piece of a hose from my cloth dryer and installed it as modified PCV hose :-)
mazda_guy
'nuff said.
-brianV
Ok, content (transpose from other topic) - Mazda never came back with my red, eh? I guess I still have a classic.
-brianV
Content: '02 LX runs perfect at 13,000 miles, but it has been 100+ for 3 weeks here in Central Cal, I think I will look at the PVC hose and see what the big deal is.
John
(content) Actually, here's some real content. The dw keeps complaining about this. Let's see if any other 2000-2001 owners can relate. You're going up a hill, slow to an intersection and then turn right, but after turning right, the road is level. The tranny kicks down 1...2 gears in the process. I always chock this to the fuzzy-logic, but anyone else experience this?
John
Otherwise, my next best guess would be that it's under the engine cover plate (looks nice, but gets in the way, frankly, it's hard enough to get around in a van's engine bay...). I haven't pulled that to look yet.
I don't get the heat issue, since the exhaust manifolds are on the bottom of the engine, well-removed from where you'd expect a PCV line to run...
There's also all kinds of stuff running underneath and around the battery, although that's not a likely place for a PCV line, IMHO...
-brianV (pondering the layout of his engine bay)
John
They applied the TSB fix and the mirror is right on the mark for accuracy.
As for tires; has anyone tried a different size tire? I noticed that MPVCLUB had a listing of tires and the effect they have on the speedo, but is there any other effect a size change would have?
I also noticed that Michelin is now making two tires in the 215/60-17 size, but the snow rating wasn't that much better than the Dunlops. I didn't think the Dunlops did very well last winter.
It's not hard to d-i-y on the Quest; maybe that stuff is accessible on your MPV?
A few weeks ago, i noticed some rough idling. A few days later the check engine light came on. The dealer said it was the pcv tube that everyone here talks about. It was backordered for a week. the dealer put me into a rental car and somehow got the part much sooner and put me back onto the road, but the same day, i noticed the engine was still idling slightly rough. 2 days after getting the car back from the shop, the check engine light is back on.
ideas anyone? the car goes back for service first thing tomorrow, but this is getting old fast.
<BR
this is our 3rd unreliable minivan. are there no reliable vans out there ????? just last year we lost over 8,000$ on a bum silhouette.
What's the most reliable minivan on the market?
I recently purchased a 2003 MPV ES.
I now have 1,000 miles on the vehicle.
The auto door on the passenger side is now malfunctioning. When we attempt to close it using the auto function (either the remote or the buttons on the vehicle) it closes 3/4's of the way - then abruptly reverses direction and opens again. It does this repeatedly now.
Looking through the manual, I see that they recommend you don't try to "force" the door when it is opening or closing. I may have done this once. Is this enough to screw it up like that?
The door on the other side works fine.
Has anyone else experienced this?
What solutions can anyone suggest?
-Brian
Thanks for the tip, anyway.
I found the right fuse and did what you said. Didn't help. The right power door is still closing only 3/4's of the way, before it then reverses and stays open.
Looks like I will now take it to the dealer.
-Brian
Yes.
"Could check the lower track for debris or something that would prevent it from closing."
OK. Thanks Brian. I will do a thorough inspection there.
-Brian
