Mazda MPV: Problems & Solutions
After driving on the highway for around 5 minutes I start to hear a strange buzzing or humming noise up front. You can only hear it when you are accelerating. If you stop at a stop light and then start up again the noise is at its most obvious. If you get off the highway and drive around the city for a while the noise goes away. At one point I took it on to a quiet part of highway and went 140 km/h for about 10 minutes. The sound was fairly loud at this point. I stopped, got out and looked under the hood. I gave the engine a bit of gas and could hear the noise well, (normally you can't hear the noise under the hood), it really seemed like an exhaust noise. When this noise happens there seems to be no affect on the performance and the vehicle runs perfectly otherwise. I haven't taken it to a dealer yet. I would like to figure out what it could be first. Anyone have any ideas.
I have a 2001 LX with 30,000+ miles on it. For the past month or so I've been experiencing symtoms that sort of indicate the original struts are being worn out - the ride is not as stable as before (during suspension rebound especially) and there is considerable nose dive during braking. I then realized that all four tires were under inflated at around 33psi (I normally keep them at 35). The unstable ride and nose dive effects seem to have been lessened after I inflated the tires back to 35psi, but I still think the ride is definitely softer (in a way that is not as stable) compare to when I first thought the ride was a little stiff after first bought the van. How long do the stock struts last in general? Have anyone replaced their OEM struts that soon, at 30k miles? I thought struts should last longer than that, and I understand the lifespan of struts depend on driving conditions/habits. I will admit I'm not the most "easy going" driver on the road (thanks to the responsive handling the MPV possess), but I sure do not want to believe the OEM struts are shot already at 30k miles.
Another thing I should mention, I had the front tires replaced (they were Dunlop's before) at around 28,000 miles when I experienced vibration from the front. The ones I'm riding on in the front now are Generals. Could the different brand of tires affect the handling characteristics so much that, it gives you the impressions that you're riding on bad struts?
I've spoke to my nearby dealer and my '01 LX is already out of warranty (technically over the 3-yr period), so none of the parts/components on the car are convered anymore. Anyone has any idea/opinion? Thanks.
tl
Mine came with Yoko's which weren't bad. I changed to Michelin Symmetry at 30K miles. That changed the handling. It took me a month before I found the right tire pressure for these (37psi) and the van handled fine after that. I was disappointed with the tire wear and noise but handling was still good. I just put on two Goodyear Assurance tires on the front and not sure I like them yet. They are smooth, 80K warranty but the handling changed - again. I might have to mess with the tire pressures on these too. I'm not a General Tire fan so I won't comment about yours.... )
I just rolled past 71K miles and haven't seen evidence of shock or strut wear yet. I drive 95% at highway speeds so lack of a lot of cornering, potholes, etc., might play a factor in my case.
Chris
t
Chris
Heater: Anyone else have problems getting heat? I turn the dial up and it seems to take forever to get heat to come out. Is this the thermostat or is it the temp control??
Thanks, TC
Mirek
Mirekski
It is now on its third week of starting, with no problems. However, its done this before. I won't agree that its fixed until it's OK for three more weeks. It does seem to run much better though. My uneducated guess is that some sensor was cleaned and now it might work.
Interested in other experiences, but bought a Ford in the meantime as a backup.
How long ago did THAT bulletin come out? Man, you've got to stay up on all these 'secret' issues on this vehicle!!
Thanks, Tom
Also, how often is the tranny fluid suppose to be changed? The manual does not state anything on this issue and the dealer said around 50000 miles!
PF Flyer
The MAZDA chat is on TONIGHT. Stop in for a holiday visit! Check out the schedule
They only last 30K miles and then go bald. Notorious for this. I replaced with Bridgstone Turanza's and they have GREAT traction in snow and water. Ride nice too!
Heater thing, not sure yet. Need to chat with my 'friendly boys' at the Mazda place.
Still waiting for someone to reply on how to replace that cabin filter thing behind the glove box....?
Open glovebox. Locate and remove numerous screws for glovebox. Remove glovebox. Filter is against the firewall on the right. Locate the tab on the filter door and pry it open. Remove used filter media and replace with the appropriate one (either a 2 piece unit or a 1 piece filter). Reverse process to reassemble.
And yes, the tires are not the greatest. But, FWD and being a minivan does take it's toll on tires.
-Brian
Regards, Terry
-Brian
PF Flyer
-Brian
Any ideas of where I should start to look in the wiring maze.
Thanks for any advice
Bob Upshon
Shediac, NB, Canada
PF Flyer
The MAZDA MANIA chat is on TONIGHT. Stop in for a holiday visit! Check out the schedule
Has anyone else had a problem with a cracked crank case? I've had several cars (actual cars, not minivans) and have never had a cracked crank case.
Flushing the fuel system won't hurt especially if the fuel you are using comes from Fred's Fast Fuel Emporium @ 85 cents a gallon....
I agree with Jipster - see another mechanic about the crankcase and take a look for yourself on that.
Had the same problem and now I pay over $3000 at aamco!
Anyone else wont to sign up?!
Matt-New Jersey
steve_, "Nissan Quest/Mercury Villager problems" #1688, 27 Dec 2004 10:52 pm
It should be easy enough to adapt to the MPV. There may be some Mazda specific posts in here too (try Search This Discussion).
-Brian
-Brian
-Jason
-Jason
