I need some help on figuring out few problems on my 92 Diamante. First the key is stuck in the ignition and it wont come out, it starts the car so I am using a spare to open/lock the door, any idea what the problem might be.
Second the car failed emmision and has recently been blowing a thick white smoke, this problem happened right after an oil change. can somebody please help me figure out the problems, because I am tired of my mechanic ripping me off, and also if its a major or minor problem.
As to the tire vibration, the tires must be balanced using a force variance machine like the Hunter GSP9700. Read all about it at http://gsp9700.com This machine places a roller against the tire with 700 pounds of force while the tire is being rotated for balancing. This measures the variance of the sidewall stiffness around the circumference of the tire and takes that into account when selecting the proper balancing weights. The resulting measurement is expressed in pounds of variance. You want each tire to have less than 15 pounds of variance after balancing.
Mr. Vivona
You will see that every year of Diamante gets the full five green marks for tops in reliability. Clicking on the green bar for each year will take you to the details for the reliability rating. You can also click "Get More Information" and read all the reviews and owner comments. You can also check out what a fair purchase price would be.
I think you will love a Diamante and have a good ownership experience. I have two (1999 and 2002) and both are real gems!
Mr. Vivona
MITSUBISHI DIAMANTE 1997
Service Bulletin Num : 97110123014
Date of Bulletin: NOV 01, 1997
Component: POWER TRAIN:DRIVELINE:UNIVERSAL JOINT
Summary: SOME CUSTOMERS MAY REPORT HARSH SHIFTING DURING 2-3 UPSHIFT.
Your dealer's service department should be able to show you the full text of the service bulletin.
The Mitsubishi Factory Service Manual is by far the best manual for do-it-yourself repairs. But, it will cost you over $100 from the dealer's parts department. You can get the best price by buying it though one of the many Mitsubishi dealers that sell at wholesale through www.parts.com, One such dealer is http://www.mitsubishiparts.com/default.php though you will have to contact them at 1-800-357-1892 to get a price on a service manual because it is not listed in their online store. Make sure you get a quote for a service manual, not an owner's manual.
As to aftermarket, the only one I know of is the Chiltons at http://www.amazon.com/exec/obidos/tg/detail/-/0801993156/qid=1069- 699831/sr=8-1/ref=sr_8_1/103-0008596-4117434?v=glance&n=50784- 6 It is nowhere as comprehensive as the Mitsubishi manual, but it is under $20 and will give you a lot of what you need for doing your own service.
Probably the most accurate review of the 1997 Diamante can be found at http://www.nctd.com/review-intro.cfm?ReviewID=338
Mr. Vivona
sales dude informed me of new additional incentive for current mitsu owners....another 3000 off on Diamantes.
WOW, that's more incentives than GM even, hehe.
showed me an ad for a 29k list Diamante for like 19,000.
get it now......
I wanted to test drive the Lancer Ralliart, but they didn't have one. Took out an OZ rally and really liked the car.....very nice small car. Excellent steering.
Also I have put on about 33K miles in less than 2 years and the 30K miles maintainence package costs $599 at the Mitsubishi dealerships. I don't want to spend that kind of money. What is the recommended service for 30K miles? So far I only had oil changes. I got a K&N air filter when the car had 15K miles and don't think it will need replacement.
the dealer here had the 30k maintenance pkg. advertised for some absurdly high number like that.
WASTE OF CASH.
here was the primary bits i caught the most of it
oil change
tranny flush
coolant flush
chaeck belts hoses and brakes
lube some hinges and driveline parts
check driveline components
change plugs and air filter
and probably some other stuff
thing is, it didn't appear to me to be anything worth 5-600 bucks.
I'd think a non-dealer service center could do this much cheaper.
as far as the gas goes, an extra dollar per fill won't equate to much more than 50 bucks a year. a drop in the pan compared to your car payment.
better to keep the engine clean.
Thanks for the info. I think that anything over $150 for the services is too much. I could have done that myself but coolant and transmission fluild flush needs equipment that I don't have.
Let me forewarn you though that Mitsu trannys are sensitive to the type of fluid used. I'm friends with my local dealer's service foreman. He said Mitsu will refuse to honor the powertrain warranty on the tranny should it fail due to using dextron fluid. Most quick lube joints use dextron, which is a thicker fluid then the SP3 that Mitsu uses. He said some trannys will operate ok on it and others failed after 10k. One guy was forced to go after super lube to get the tranny replaced because Mitsu wouldn't honor the warranty due to not using the proper fluid. With that in mind, I would either have the tranny serviced at the dealer or buy the fluid at a Mitsu dealer, make sure the shop uses that fluid, and keep the receipt. If you do go to the dealer, just specify you want the tranny service and that's it. You don't have to do the "30k package".
check with your dealer and also visit mitsucars.com
one dealer here has an 03 VR-X with 4k miles on it......if you would settle for lightly used its a great deal right now but no rebates. price is still cheaper than new. VR-X is sport version of Diamante.
Basically figure 9-10 grand off list for new Diamante if you have loyalty.
An XG is based on the Diamante anyways although in some ways has surpassed the Diamante. Either car is a nice car. XG is more traditional luxury cues.
You have an OZ, right? I tested a manual OZ on Saturday and really liked it for the 12k price it was selling at. New.No ABS on it tho.
What is your thought on this deal: I called a dealer who is 85 miles away. I spoke directly with the sales manager and he realized he would only have one shot at selling me a car. He has 1 03 D left, a black LS with gray interior but no traction control/heated seats (I would love to have the heated seats ), which I think is exactly what I'm looking for. The manager said he would give $1500 off sticker right off the bat plus the 7k in rebates. He gave a ballpark of 6-7k for my Lancer, which is ludicrous. I wouldn't take anything less then 8k. So, here's the lowdown: 27,500 for the D - 8k for lancer * .06 sales tax = 20677 + 16049 (payoff on Lancer, dont ask) - 7k = 29700 roughly. I might try to get him to drop down 1k or so, but it might be difficult. I know the deal is absolutely crazy, but what do you think? Is it possible to get the price of the D down any further and keep the tradein where its at? The thing that attracts me most about this deal, is even with all my negative equity I won't have to finance more then 100% of the car's worth, which should help me get a good interest rate. My Lancer's interest rate is 9.9 and I already planned on trying to trade it in a year from now which would put me still about the same negative equity but without the huge owner loyalty rebates.
I feel I'm at a disadvantage since its the only D he has left that I could use the nice big rebate on and he knows that. But I also know the D has been on his lot 3-5 months and Mitsu sales are hurting. So help me out....have I lost my mind??
Used rental return D's are in big abundance here, which is why I've had 2 of them.
As pleasant as a Diamante is I would have major issues paying over 20 for a new one. And your negative equity would leave you stuck way behind on the D. After 6 months you would owe 28 but the car wholesale would be worth 15.
In your scenario a lease may work better for you.
Get a Ralliart instead....LOL.
Have you been satisfied with the build quality of your 2 d's? Any interior finish issues or rattles? Engine smooth and quiet and how is the highway ride? How is the fuel economy? This car would mostly be driven in the city, so 19-21 mpg would be nice.
The climate control is a little undersized as far as how much heat it can put out in -10 weather and the window glass seems thin. I've had some loose rear weatherstripping, no big deal. Got that fixed. My ES seats I find a little uncomfortable sometimes. The LS and VRX seats are better. The v6 can be coarse sounding at idle or under accelration but doesn't vibrate much. It becomes much smoother at certain rpms and certainly way better than say, a GM 3800. I have gotten 20-27 mpg routinely and about 24 on average in heavy traffic. I never have to worry about these cars. You drive em, it runs. Its an easy car to own. It just goes about its business. Like my Prizm (corolla) did. Its like you never have to worry about it. A totally trustworthy car.
that said, I know there are sedan that are more enjoyable. The 2003 Maxima and current Mazda 6 are better choices as far as total refinement. The new Galant may even be more pleasurable.
But I think the Diamante is a great classy alternative to a Taurus, mostly all GM sedans, etc. A lot of folks who like the blandness of the Accord and Camry would like the simialr demeanor of the Diamante.
If you buy it at the right price its a really good car. If I had more money I would buy something nicer, sure.....but they feel well built and they are quiet and composed cars that give the impression that you got more than what you paid for. Even if they are dated and not best in class. There are no real glaring flaws or signs of cheapness.
Do you still have payments on the Lancer? If so for how many years?
The car is beautiful! I'm so glad I got the old BMW style front end treatment and the black helps the chrome stand out and looks real classy. It rides like a dream and the power is great (a little slow off the line, but I think thats because the accelerator pedal has more travel then my other car; dig a little deeper and the engine has a sweet growl and the car hauls butt). I can't get over how well it smothers bumps. Handling is better then I expected considering the soft ride, but lean is noticeable when any sudden steering changes are made. Fit and finish was good, except for the glovebox (it's crooked and sagging some on the left side). The car feels and sounds as tight as a drum; I hope it stays that way. Brakes feel a little soft, but I'm sure that will improve after they break in some. The tranny adapted to my style quickly; it shifts very smoothly and downshifts pretty quick. The driver's seat is taking some getting used to. I'm still trying to find the sweet spot. The passenger seat feels better to me and the rear seat is downright sofa comfy. The Lexus-like "luminance" gauges are so cool; the red laser needles turn on before the actual gauges light up. The gauges definitely add a touch of luxury car flair. The leather smells, looks, and feels nice and I love the gathered look on the door panels. The Infiniti sound system is excellent! Parking the car is taking some getting used to; I'm not used to such a long car so I keep parking it crooked. Best of all, my friends loved the car and were gushing about how nice it was. That made me beam with pride (what can I say, I want people to like my ride). Even though I know the Diamante isn't a high status car, it still makes me feel like I'm in one.
My list of disappointments is small and pointed directly at Mitsu's cost cutting: I wish all the power window switches were lit like on my former 93 D. The lack of standard heated side mirrors and side impact airbags is ridiculous in this class of car. The rearview mirror should be electrochromic. The interior door handles would look better if they were chrome. The stereo should look different then the one on the lowly Lancer. Lastly, the interior is a bit dark in the middle since it lacks a center dome light (they should at least put a bulb in the center of the front dome light instead of just having the map lights that point at the seats). Other then these minor quibbles, I like the car a lot. If it upholds the Mitsu quality that I have come to expect, it should stay reliable for many years to come.
Question for you: Do you find the horn wimpy sounding? There appears to be 2 separate horns, but only one is used for the regular horn whereas both are used for the alarm. Is there anyway to make both horns work or have you added a dual note horn system to replace the single high note one? Also, where the heck is the actual horn? The alarm horn is on the left fender in plain view but the other one sounds like its buried somewhere on the right fender. My Lancer had 2 loud horns so I need to do something about the cheap sounding horn!
Ingtonge did you ever come across any performance parts for your Lancer, if I consider buying an 03 leftover OZ I would want to add some cheap hp to it. I'd also like to know if ABS can be added to a non ABS car at the dealer.........
The wing on the VRX is a bit much, yes.....
i think the VRX has an automanual shifter.....does the LS have one?
There are performance parts available for the Lancer; interest grew substantially after the EVO was released. The amount of power you can add is limited though (about 10-15 hp is available), unless you are willing to move into turbocharging. Most of the performance parts are geared towards handling and brakes.
Do you know any good places to buy Mitsu accessories (like mudguards etc) for the D at a discount price?
your OZ was an automatic! want a stick!
I haven't come across any D accesories on the net, although i have spent a lot of time looking at web pages for the Diamante / Magna that are in Austrailia where the car is made and is more popular. type Mitsubishi Magna in google and see what you find. There are a zillion versions of the Diamante down there. Go to the Mitsubishi Austrailia website too, they might have some info.
considering the frameless glass I am amazed at how quiet the windows are. Since my W/S was fixxed in the rear, NO noise anymore from the doors. Dealer should be able to take care of it.
Maybe Mr. Vivona can offer some advice here. He is the 'expert' source for all things Diamante and is very experienced with them.
An interesting observation: a relay under the driver's side of the dash goes berserk when my cell phone rings. I had the phone sitting in the bin under the stereo. I thought I remember someone else mentioning this odd occurence. Why would a cell phone cause a relay to click on and off rapidly? I also have heard some loud valve tapping in the first few seconds of a cold start. Anyone else encountered this? I know its not really harmful to the car, but I'm just wondering if anyone has had this and fixed it by using a thicker oil.
Other then these issues, the car has been doing good. It has over 600 miles already and fuel economy for the first 2 tanks was 19-20 mpg. Not bad considering the engine is far from broken in.
the tranny will become more aggressive over time. ours kicks down RIGHT NOW. didn't use too.
A leak around the door can be caused by a door misalignment, a window misalignment, a delta misalignment, or an improperly seated weatherstrip. The service manual gives specific alignment instructions for the fit of the door, the glass, and the delta piece that holds the tweeter. If any of these pieces are not adjusted to spec, you can have a wind leak. In a minor case, a quick fix is to insert a small piece of peel-and-stick weatherstrip under the regular weatherstrip to bulge it out just a bit to improve the seal. Hopefully, the new weatherstrip will solve your problem. But if it doesn't, you will have to check the alignments.
As to the glass thickness, the front glass is 5mm which is thicker than the usual 4mm. I recall reading an Infinity ad bragging about their 5mm glass thickness and measured my Diamante to find the same thickness.
Mr. Vivona
At 35,000 miles one of the front tires finally was worn enough to justify my changing the set out. I did some research and both Consumer Reports and the user reviews on Tire Rack led me to the Bridgestone Turanza LS-H. I have been very happy with Turanzas in the past and have always figured that I would replace the Goodyear Eagles with them. But, I found the best price for a set of four Turanza LS-Hs would cost me a total price of $575. Actually, the Turanza was in second place in the Consumer Reports test. First place was the Falken ZE-512, a tire I had never heard of.
I was surprised to find that a set of Falkens would only cost a total of $299, with a tire cost at 50% of the Turanzas. I checked some web forums and found a lot of happy Falken ZE-512 owners. So I have taken a chance and had them put on my Diamante. They are smooth and quiet and handle well. They have better grip under acceleration than the Goodyears did when new. And they don't vibrate.
So, time will tell if the Falcon ZE-512 is a good choice for the Diamante. I will keep you posted.
By the way, despite my specific instructions to hand torque the lug nuts, I checked immediately afterwards and found the lug nuts to be torqued all different, some at 30ft lbs and most over 160 ft lbs. Had I not checked, I would experience brake pulsation in 3,000 miles. This is a battle I will never win with mechanics. Even with hand tools, they seem to think overtightening is good, or just don't know how to properly use a torque wrench. They also left all tires at 40psi (required for balancing) and scratched my rims by using a standard tire mounting machine instead of a touchless mounter. Thank goodness I only have to replace tires only once or twice in the life of the car. I do my own rotations.
My wife is about 3 years away from tire replacement on her 2002 Diamante. Her Goodyears appear to be starting the bad wear pattern, a problem mentioned by most of the reviewers on Tire Rack. 60% of those reviewers said they would not buy the Goodyear Eagle tires again. I agree.
I would be interested in hearing what other replacement tires are being used on Diamantes, particularly the second generation (97+) models.
Mr. Vivona
Thanks a lot in advance.
04 Galant vs. Diamante, pros and cons? I see the 04 Galant moves out and has nice room.
The car's ride on the highway is good too, almost serene. When doing 70, it feels like u are only doing 50. I do feel a little front end float over certain dips, but not as bad as the land yachts of yore. The one thing I do notice is the structure doesn't feel as drum tight as most cars today, but thats to be expected of a platform introduced 7 years ago. Anyone even seen a strut tower brace for this car?? I think it would help quite a bit.
My car now has over 1500 miles (that's right, 1500 in 2 weeks!). I was surprised to get a call on Monday letting me know the special order parts were in. It only took 5 days, which includes a Sunday and Xmas. I have to wait till they get their alignment machine fixed so I can get all the issues fixed at one time though.
Oh yea, I forgot to mention the rivalry between a friend and I. He always has to buy a new car whenever I do; he trys to outdo me. When I bought my 03 Tiburon GT, he bought an 03 Elantra GT 2 weeks later and now that I bought the Diamante, he went and bought an 04 Endeavor a week later! GGrrrrr.....Drives me crazy that I have the newest car for all of 1 week or so. I must admit though, the Endeavor is a very nice machine. It has the solid structure I wish my car had. But at least I have him beat in luxury
I've had vibration in the front end since I installed new tires recently. Reading other Edmunds notes, it appears that the torqe specs may be a bit particular. My car used to have one of the softest front ends that I've ever driven. Maybe I'll see those days again.
I have yet to find a mechanic that knows how to properly use a torque wrench or torque stick (an extension used with an air impact wrench). Case in point, I recently put new tires on the 1999 and demanded hand tools and torqueing. They didn't even have a torque wrench and used hand tools to "guess" at the torque. Immediately after leaving the tire store I pulled off in a parking lot to check (and reset) the torque. I found the torque to vary from 30 to over 150 ft lbs. If I hadn't redone the torques to 80 ft lbs, I would have had brake pulsation within 3,000 to 5,000 miles (three times a year, you say?).
You can get torque wrenches at any auto parts store, Home Depot, Lowes and Sears. I like the Sears "digital" torque wrenches. They are much easier to set and they click when you reach the set torque. A good one is the one at http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&- vertical=TOOL&pid=00944597000
If you want to save money, get the $20 beam type at http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&- vertical=TOOL&pid=00944642000&tab=specs#tablink
In any event you want a range up to at least 150 ft lbs which will cover 90% of the bolts on a car. Yes, ANY bolt on a car should be set to the correct torque and service manuals provide torque information.
Mr. Vivona
