The 5th time, the light was on when they diagnosed it and problems were identified. As identified by ray h71, part of the problem was the vapor recovery charcoal cannister. There also seemed to be a sensor error for the gas tank and they replaced several hoses, etc. They called Hyundai on this issue and were told that this problem had been found on other Hyundais, but not on the Sonata.
Anyway, they had the car for 2 days waiting for a part and provided them with a rental car until it was fixed -- and this was not the dealership we bought the car from! I was impressed...and they said to bring back the service survey that will be sent to my stepson and they will give him a free tank of gas and a car wash!
Even though Hyundai is one of the few car companies that is increasing sales in this economic environment, they continue to cater to the customer to win their loyalty...
Just put on a new set of tires (42,933 miles). Went with set of Continental ContiTouringContact CH95s, 205/60R15 91H. Provide better handling and steering response than the original Michelin Energy MXV4s, and a lot less expensive--almost half as expensive at only $65/tire.
They also just replaced the rear brake pads and turned the rear rotors.
She is under full factory warranty until 2006 (6yr/72K), as I opted for an additional 1yr/12k bumper-to-bumper warranty under the horsepower rating compensation program.
All I've had to do is replace the windshield wipers (40K), replace cabin pollen filter (21K & 40K), replace engine air filter (39K), replaced one burned out front headlight at 20K and another at 30K, flushed coolant (30K), rotated tires (6 times), and LOF (8 times).
Had the airbag recall done at 34K. The MAF recall at 21K. Front brake rotors resurfaced under warranty (28K).
My sales and service experiences have always been positive. (This dealer also sells Cadillacs.)
All things considered, a GREAT CAR!
I'm curious...how did you get the rotors resurfaced under warranty? They are listed as a wear item. My dealer has consistently charged me for anything regarding the brakes.
Also, thanks for the tip on the Continentals...my wife loves the Michelins but I might run the CH95s by her.
The Continentals seemed like the best all around choice. If they are good enough for BMW as OE tires, then they should be OK for my Hyundai. (Too bad Hyundai has never made a Sport Package for the V6. Things like LSD, bigger tires, more aggressive suspension, etc.)
You should look over the November 2002 issue of CR. Has a good discussion on both winter and M&S tires. That is where I saw the comments about the Continental ContiTouringContact as well as their reasonable price.
By the way --
RE: timing belts and water pumps - replaced my belt at 96000; the mechanic said it looked fine, although I know it was risky waiting that long. Had the serpentine and a/c belt replaced then, too, but not the water pump. The $160 for a dealer's part was too much money at the time.
RE: tires - being more interested with increasing the comfort of the ride than the ability to turn corners, at 60000 miles I replaced the 205-60-15 Michelins with 195-65-15 Goodyear Regatta 2's. Those, along with new front struts, gave a noticably quieter and less harsh ride. And they have been great in the winter - in MO we get enough snow to be concerned, but not enough for snom tires. I hear the Yokohama Avid and Avid T's are good, too, but I got a great deal on the Goodyear's.
RE: squeaky brakes - this is a continual problem. Ended up with a set of pads (from what parts house I don't remember) that had a metal clip attached on the back of both the inner and outer pads. This did the trick. I think you can put a metal shim in there, too, as an alternate fix. The brake "goop" they sell you in the tiny tube for $1 doesn't seem to help much. Cleaning the rotor with some isopropyl alcohol seems to be a good idea, too.
Help me with the a/c belt squeak, please -- my wife is really getting tired of this! Thanks!!!
*If it's a serpentine belt, make absolutely certain that ALL the ribs fit into the pulleys' matching grooves. It's very easy to have the belt "hang" out of either side on one or more pulleys. That'll ruin a belt sure as shootin'.
**A spring loaded idler pulley is not adjustable. It can be "detensioned" at belt-change time by prying between two bosses against the spring force to allow the pulley to be moved sufficiently to remove the old belt and install a new belt. If the spring loses tension over time, the spring-loaded pulley bracket, or the whole assembly will need to be replaced.
Hyundai should offer the Sonata in a GT version. This car would be a blast with a 6-speed stick, 17” wheels, dual exhaust, sport suspension, etc.
So how can I tell?
I have the package with the sunroof and abs, but nowhere on the Hyunda website do I see a package that cotains keyless entry. Ofcourse Im looking at the 2003 models
I'll talk to my slick salesman tomorrow.
Thanks for the help!
I live in the DEEP South, and with Summer comming-on, I want to get a solar film on the windows soon. My question, does the chance of the service department not returning the door assembly to it's "original" factory condition or causing some other damage (seen or otherwise) during the window replacement, outweigh a scratch-free window? Should I report it to the dealership even if I don't have it replaced? Not a huge problem, but would appreciate some opinions.
Yes I know it is old & new sonatas seem all anyone is talking about, but I just wanted a reliable, comfy run around to get me to & from work..have I found one?
i cant see how you guys (& girls) put so many miles on a car ..you could not do that in the UK !
I checked out the service history today & at 28K (1998) it had a new engine as there was knocking on the old one, so now there is only 36k on the new engine, anyone elses have this problem ...did the new engine have any later faults ?
Also am I the only Englishman in here ?
Bottom line: the glass should not be scratched and it should be fixed, imho.
The first is additional strength. ("Stressed" material is stronger.) The former method results in stress formed at the surface because it's cooled more rapidly than the interior of the glass. The latter method results in stress, again at the surface, due to "loading" of various ions several microns into the surface of the glass matrix.
Secondly is that, should the tempered glass be struck and break, it'll do so in a controlled manner: litle average 3/8" sized chunks instead of nasty shards. The problem with that 2" scratch is that area is no longer properly tempered since the surface integrity is now compromized. With the tempering stress compromized, the entire window could theoretically decide to give way unexpectedly. And if it does, it may or may not result in some undesirable shards in the process. The dealer will probably call a professional glass installer out to do the work. So, I doubt you have anything to worry about regarding leakage or mechanical problems. These guys know what they're doing and it isn't really rocket science anyway. (And as JK posted, if any troubles develop, it'll be the dealer's obligation to have them rectified. Just keep your repair invoice.)
Wiggler, this may be a waste of bandwidth, but, have you ever had the transmission fluid changed? If you do a lot of stop-and-go driving, that's hard on the fluid. At 30,000+ miles, I'd consider it due. (ANY make automatic transmission) Since the transmission appears to shift OK once wamred up, you may be getting some varnish build-up sticking in the valve(s) associated with the 2-3 upshift when cold. Another thing you might consider is reprogramming the shift quality. These trannies are totally under computerized electronic control, and the control module has an "adaptive learning" mode. To reset, drive the car about 20 miles to bring the tranny up to operating temperature. (VERY important) Write down your radio presets, and disconnect the ground lead from the battery for at least 30 seconds. After you re-attach and tighten the ground cable, drive your car in city traffic over predominently level terrain for about half an hour. It'll probably shift somewhat harshly initially since the transmission control module needs to re-learn your driving habits from scratch. During this time avoid jack-rabbit starts. The transmission control module will continue to fine-tune its shift quality over the next several days. Once your driving style is learned, the control module will automatically compensate from then on for normal transmission clutch plate and brake wear to maintain the memorized shift quality. Don't forget to reprogram your radio's presets since they were erased when you disconnected the battery. If this exercise does not result in any improvement, then there still may not really be a malfunction. (I'm still coming back to the normal shift quality once warmed up.) As I mentioned initially, if you're still on the factory fill fluid, it would be a good idea to consider a drain and refill. Make sure you use the type of ATF Hyundai recommends or its later replacement (SP-III) since the newest stuff is backward compatible with pre-2003 trannies. One of SP-III's improvements is better low temperature performance. Most (all?) Asian car manufacturers no longer recommend Dexron specification ATFs, so don't let an independent transmission shop try to con you into accepting it. If you do the work yourself, I found that my local Kia* dealer sells an SP-III ATF about $1.00/qt cheaper than my Hyundai dealer. These boxes take about 8 quarts. There's no replaceable filter on these boxes, by the way - only a screen that can only be accessed upon complete disassembly. The drain plug is a large hex bolt and soft metal washer on the bottom of the tranny towards the passenger side of the car. If you do replace or have the ATF replaced, that might be a good time to follow up with the reprogramming sequence I outlined.
*Kia Optimas are bolt-for-bolt identical to the Hyundai Sonata. The only differences are cosmetic - fenders, hood and rear deck lid, grill, bumpers, and interior appointments. When shopping replacement wear and tear items, always check both sources if there's a Kia dealer within a reasonable driving distance.
I bought mine last December and in February had the dealer install leather - a purely self-indulgent lust I've had for some time. The seats are firm, but I don't find them any more so than those of the '96 Accord I previously owned. As for too low, are you aware that the height can be adjusted - both the rear and front of the front seat cushion? I've got mine adjusted as low at both points as I can, and I still feel it's a bit -high-. (Or else the top of the windshield is too low - I often find myself ducking at intersections so I can see when the light turns green. Grrr!) I hasten to point out that I'm 6'11", and long on torso, so the genes I inherited may be part of my problem.
I do agree that when I have my arms comfortable, it seems I have insufficient leg room. I've compromised in my preferred arm and legroom settings long enough that I'm no longer bothered by it, though. My suspicion is that Hyundai's designers are engineering the ergonomics more in line with the average home market physique and letting the rest of the world tough it out. To some degree I had the same complaint with my Accord, too. I see Honda now has a tilt AND telescoping steering wheel for the '03 Accords. A telescoping steering wheel on the Sonatas would defintely help in my opinion. (I presume you ARE aware that the Sonata DOES have a tilting steering wheel, aren't you? Adjusting that has helped some on my car.)
I find the ride quality of my car is mostly comfortable, but small SHARP jolts seem to come through rougher than on my former Accord. Seems to me that Hyundai could soften the shocks' compression settings for the first 1/2" of travel without unduly compromising the handling qualities.
As for the audio system, I've read auto enthusiast magazine reports on test Sonatas that cover the gamut - from complaints about the "tinny" sound quality that you suggest, to accolades about "the surprisingly robust bass and sweet highs" of the stock sound system. My experience favors the latter description, but, my music tastes run from classical to new age played at moderate levels. I wonder if someone who rented the car you drove had run the system full tilt on some bass heavy hip-hop and damaged the speakers. From what I can see in the trunk of the magnet structures on the rear deck's 6x9s, these are not premium high-power capable speakers. Someone else on this forum replaced all four OEM speakers with some premium Sony units and now he's ecstatic with the sound quality. For what it's worth, I babied mine during break-in (Hyundai calls for reduced speeds for a full 1,200 miles!), and it seems to have paid off. At just under 6,000 miles, I'm getting 25+ mpg in the city and 32+ mpg on the highway. This is within 1 mpg of my Accord in the city and identical on the highway, and my Accord only had the 4 cylinder engine.
Let us know what you finally buy and give us a review. The fact that you'd at least considered a Sonata makes you welcome here anytime!
Mocky, your best bet is to log on to the Kelley Blue Book site. You can feed your car's particulars in and choose trade-in value or sell-it-yourself-to-a-private-party value and get a dollar estimate according to your location and the car's general condition. Be forewarned that piling up 23,000 miles per year will cost you. When my '96 Accord got totaled last November, I used that web site just for reference. When my insurance company finally called with a settlement offer they were under the Kelley valuation by about $125.00. I wasn't disappointed in the offer, but offhandedly mentioned what Kelley came up with. The adjuster matched it before I could say anything else. I decided not to argue with her...
When you are comparing mpg between the Sonata and Tiburon, don't forget that you have engines producing different horsepower levels. The 2.7 Sonata has 170 hp and the 2.7 Tiburon has 181.
I don't know if they are different engines or the same engine tuned differently, but this will definitely impact on mpg, especially in city driving...
Ray_h71: My Tiburon only has 670 miles so I know it has quite a ways to go before it fully breaks in. I was rather surprised by my 2nd tank of gas because my 00 Accent got as low as 24 mpg one time during its break-in even though it has a much smaller 4 cylinder. If my Accent and your Sonata are any indication, my Tib's fuel economy may end up impressing me a lot by the 10k mark. By the way, the Tib weighs 200 pounds less than the Sonata and is a little more aerodynamic, so that might help. But as you said, the Tib begs to be driven hard....:)
Hahahaha. There are other c class board besides edmunds and people complain about it's lack of power or off-the-line punch. I myself is very disappointed when I drove one, it is lethargic from a dead stop. Sure you can speed once on the highway but the driving fun around town is zero. I would speculate that the sonata will have a better pick up from dead stop and when merging as commented by many owners.
1. Engine displacement, the bigger the displacement the more torque it has at lower rpm needed for off the line acceleration.
2. FWD v/s RWD, rear wheel drive has to overcome rotational inertia of the propeller shaft, plus the 90 degrees redirection of power from longitudinal to tranverse at the axle is less effcicient compared to parallel transfer of power in FWD.
3.Electronics, the more electronics involved (drive by wire) the more time is needed for the computer to think before it executes the fuel delivery (you got it, more delay in engine response). Many complained of disconnected throttle feel of the c240.
I have yet to test drive a sonata but the seating position and range of adjustibility is excellent. If it has a telescopic steering wheel, it can match the driving position of the c class. I read from many reviews that it transmits sharp road bumps like expansion joints but not as harsh as the accord.
