The only thing that I usually have to do is to adjust the temperature setting depending on the season. In the winter, since I'm usually wearing heavier clothing if not a coat, I find that 64-66 is plenty warm. In the summer, I usually leave it at 74 or a little higher.
You will also find that you have to play around with the temp control on the center dash outlet to get the right temperature for the air that is blowing more or less directly on you. I'm not sure why BMW's system requires this exactly; my Audi had no such control, and in general I think that my A4's climate control worked better than on my 325i.
Neither system should have any effect on tire selection.
2.) Detroit gets some snow so if it was me I'd invest in winter tires.
One of the great things about BMW climate control systems, is that it can satisfy your practical side. I have a big practical side, and I turn the snowflake on and off and usually shut down the climate system before I turn the car off.
You are lucky. I've know people in the past who have abused their Hondas and they lasted to 150K. Only thing is these people had to add oil every 500 miles.
I am having a problem with the chrome trim around my windows. It's all gray and speckled (no rust or pitting) and the chrome cleaner/polish I bought at the auto store isn't doing anything. Any ideas? Can it be saved (I would love product recommendations0? Is it ruined? If so, since the car is barely over two years old, should I complain to my dealer?
Guess I'll try the dealer. Somehow, I don't think they'll be replacing it for free!!
Thanks, everyone, for your help. I've become obsessed with this!!
Is it worth it, or should I just buy a mityvac, and change the oil (and other two filters) myself??
Then, I'm thinking I could bring the car in (to a private shop) and just get the tranny and differential fluid change and get a 30minute inspection.
Thoughts?
I like the idea of giving the car the once over every 4-5 years. It's a maintenance investment rather than getting a new one. I also want to keep this car for 10 years and hand it in relatively good maintenance shape at 100-120k miles to a now teen age son when he GRADUATES from college and starts his career.
What is practical about turning the climate system off before you turn the car off and then, presumably, turning it back on the next time you start the car? Seems like it's more practical to set it and leave it. Maybe instead of "practical" you meant "control freak".
Anything else I should look out for / think of?
What about spark plugs-- can these go 100K miles or should I look to swap them out?
I'm assuming that the water pump and hoses can wait until 100K miles (I live in northern California, so the weather is not extreme).
I'm going to my room now...
Even though it was 88 degrees outside, the car still managed a max 148 SAE HP/ 149 SAE TQ. That equals about 175 hp / 176 tq at the crank. Also notice the midrange HP/TQ increase (blue line vs. red line) after I installed the Eurosport (Conforti) chip - approximately 14 HP and TQ max at the crank.
It was a fun morning, I recommend it to any enthusiast.
The spark plugs might last till 100,000K miles but it's a stretch. I replaced them at 60K miles. An added benefit is that you'll get a good idea for the health of the engine.
I replaced the water pump at 76K miles. I am glad I did it - it had 1/4 inch of corrosion built up on it. This may depend on the climate that you live in (I am in Boston).
You also mentioned that you've done most, if not all, of this yourself... do you think a novice can do it as well? (air filter and microfilter-- no problem, oil change w/ mityvac should be easy enough; but the other fluid changes and visual inspections may be beyond me...?).
I have a 03, 325i with 20K and miles on it that i bought a couple weeks ago. I noticed in the last few days that there is a very mild vibration at the steering wheel when I cruise at high speeds (read +75mph). This does not happen always though, and sometimes even at speeds in excess of 85mph, it seems to be fine.
Also, I notice that there is a mild vibration of the steering when I brake while driving at high speeds.
Is this something that people have encountered and if so, is it something serious? Should I get the car checked at the dealership since it is covered under warranty?
Thanks a lot in advance,
ddas
I have far less than average skills and was able to do it by myself. It's a dirty job, though; less so if someone is helping you.
I know that's probably not what you wanted to hear..sorry
try E46fanatics or google it. Hope that helps..good luck
Well, I suspect that this is common. If you think about it: changing the oil every 3000 to 5000 miles would prevent you from burning through a quart if it takes the engine 9500 miles to do it.
In other words, I wouldn't worry about it. Just take it in and have them top it off at no cost to you. Hope this helps.
P.S.: While you're there, tell the service manager that your service advisor is a pr*ck.
I realize BMW has a kit for doing this but I'd rather not put $300 worth of materials into a car I will be gladly giving back to BMW in less than 10 months.
I'm thinking of getting a unit I can swap to my next car (assuming it doesn't come pre-configured with satellite radio - at this time the 06 miata doesn't have sat listed for example).
Any suggestions...thanks
The models that have tilt reverse functionality only come with an additional package denomitated: "Primium Package", it includes more gizmos too.
Email me and I'll direct you to a good site.
giovanni3
http://www.caranddriver.com/article.asp?section_id=27&article_id=8794&page_number=1
"The best solution to the sludge problem seems to be the oil sensors that have been used for years on all BMWs, along with more than 90 percent of GM vehicles. These devices are not really "sensors" that somehow analyze oil quality; they are software programs that record cold starts, oil temperature, and a count of cylinder firings. The systems then infer the oil's condition based on its measured "experience." They can call for oil changes in fewer than 5000 miles and more than 10,000 miles, depending on driving conditions."
Best Regards,
Shipo
Not that I'm looking to buy one, but I see (in general) that asking prices for used M3s are on the high side. The only ones that are under $20K have tons of miles or an automatic.
2001 Prelude Type SH, 2022 Highlander XLE AWD, 2022 Wrangler Sahara 4Xe, 2023 Toyota Tacoma SR 4WD
Another one at a local used import dealer.. same year.. 89K miles for the same price...
If it is a decent... fairly low mile coupe with manual.... and it is $17K or less, it will sell very fast... They are out there, you just have to jump on them..
Not a very cheap or reliable car to own, IMO... But, very desirable...
regards,
kyfdx
I have a 01 330i SP/PP. I purchased this vehicle used about two months ago and since then have been trying to pinpoint a location in the backseat of the vehicle where a rattle is coming from. I had thought it might have been the back seats or cushions, so I’ve taken the back seat apart and found everything secure and sound (as well as $4.00!). Now I am wondering if it might be the ‘third-eye’ taillight in the rear window. The trim is secure, however when I tap the trim with my fingers it makes a rattle sound. I took the trim down and did not see anything loose. The pilar trim pieces (with the reading lamps) make the same sound, however I don't know how to remove them.
Anyone have any suggestions of other locations in the rear of the vehicle I might be able to check for rattles? I can’t seam to find this one and it’s riving me nuts! :confuse:
The rattle only sounds when I go over a ‘rippled' or a very bad bumpy road. “We have bad roads here in Seattle”.
The rattle sounds rather like as if you rapidly tap your finger nail to your desktop. Thanks to all in advance for any suggestions!
Ximloe
