I just got a 01 Maxima GLE equipped with the Bose 7 speaker package. I am wondering if I can hook up a regular amp with Infiniti sub to the system. I have heard rumors about ohms or frequency being different. Does anyone know anything about this, or how to do it?
Thanks in advance,
Todd In Folsom CA
Any ideas????
Ash
i pulled over to check the brake fluids which was fine...but noticed that the entire rear driverside was HOT... the wheel was hot to the touch... while the other 3 wheels were cool to the touch... i called Geico for a tow truck but in the mean time, i pumped the petal a few more times, and it seemed like the pressure was okay again.... i decided to take it slow and drove off.... i took a few stops to make sure it wasn't overheating... and paid attention to my brake petal.. which seemed to work again... and my wheel returned to normal temp... my next step is to completely change the rear caliper... if you have a 2000 or 2001, i would pay attention to the brakes..seems like its the one weak point on this car... brakes are scary when it doesn't work right................
Other than that and a bad O2 sensor, the car has been fine.
Coincidentally, the 4th generation Maxima (1995-1999) was the last made in Japan. Although my 1995 certainly doesn't have the bells and whistles of my 2004 TL, I think its build quality is nearly as good. Which is to say two rungs up from the current Maxima.
I am a "diehard" 1995 Maxima fan. But after owning a 2002 Honda S2000, 2004 Acura TL and 2005 Acura MDX, I don't think I'll return to the Nissan (or Infiniti) camp. Relatively speaking, I think Nissan/Infiniti have slipped in quality. They are still far superior to anything made in the US, but I would have put the quality of my 1995 up against anything comparable in the world, including the old TL, Accord, Camry, Avalon, etc.
'17 Chevy Volt Premiere
I'm considering the purchase of a new Maxima and had some questions for present owners:
1. How does the ride of the SE compare to the SL? Is the SE much firmer?
2. Does the car develop any annoying rattles or buzzes in the cabin after a few thousand miles?
3. How would you compare the quality of the Bose audio system to other high end audio systems in competing cars such as the Acura TL?
4. How would you rate the Navigation system? How does it compare to systems from other automotive manufacturers, such as Acura?
5. What has been your experience with dealer service quality?
6. Are you overall satisfied with your Maxima and would you buy it again?
Thanks very much.
SL versus SE debate. I bought two SE's. I like the "rougher ride" and stiffer handling of the SE versus the softer setup in the SL. Drive both cars, there really is a difference in ride and some road noise. SL tires are 55's with 17 inch rims and the SE's are 45's with 18 inch rims. As for me, I liked the SE over the SL, to each their own they say. Also, I hate fake woodgrain, like the brushed metal look of the SE better and the little lip spoiler at the back.
I have a 99 Max with 95k. I just failed Ma emissions testing with three error codes. I looked the code descriptions up and wondering if anyone might have an idea of what I might be looking at. I knew I might have a problem before with my service engine soon light coming on.
p0450 - EVAP system pressure sensor or circute failure
p1444 EVAP canister purge volume control valve or circuit fault
p1446 - EVAP canister vent control valve closed.
email me.. i got the installation procedures for you.. email address is my username on here... and add @gmail.com
The GLE comes with the standard speaker package, which is just ok. Does anybody know of a speaker upgrade package for the 01 Max?
Thanks....
If they are pritty close I can buy the kit and get it fitted and extra fibre glass added to it to fit snug but if the two models are totaly different then I'm back to square one.
So if anyone could send me photos of their 95, pictures of the front back and side or give me an idea that would be great.
Also engine upgrades (I want to install a turbo or in general give her more grunt) the guy localy in my home town said I would have to replace the entire motor and tansmission. Does anyone else out there say other wise or point me in the right direction.. or is he right in whitch case dame!! thanks hope to here from fellow Maxima lovers soon
As far as giving it more grunt, perhaps you should try to find a 1995+ to trade up to. Mine (with 153,000 miles) would have only been worth about $4,500 on a trade in, which is why we decided to keep it. It looks very good and runs like new. It "only" had 190 horsepower, but thanks to 205 ft lbs of torque and a relatively light 3,000 lb curb weight, it is nearly as quick as my 2004 Acura TL 6-speed with 270 horsepower (and 3,450 lbs).
bingman,
600 bucks to replace the rear caliper on your 2001 max? holy smokes! did you get both sides replaced? with 2 new calipers and new pads?? labor must cost alot.... i just bought a new caliper the other day and plan on installing it with new pads on both sides one of these weekends....
they are SOLID cars..but have crampped rear seating...
I always thought they looked good though..like many Jags are something...
Meanwhile, someone might come along who knows from what you've said here.
ECU/PCM Computer injection motor
Factory #: A18-A45E97 (2Z08) Model: EB
Nissan Part #: 23710-97E10 (according to VIN)
My car is a 24 valve Maxima from 1994. (VE engine)
If anybody could tell me where to get this, how much, etc....it would be greatly appreciated.
First off, I was replacing a '97 Dodge Intrepid. And my key decision criteria in '05 was not disimilar from '97. As a 48 year-old family man with two (now teenage) sons, and someone who purchases cars and plans to keep for many years, I decided I still wanted and needed a family sedan and valued most (not in any particular order): Reliability and safety (VDC important), family size (rear seat room, trunk), looks / sportiness, and initial cost ($30K or under). The Maxima met all these criteria and more. I didn't choose the following cars because of the following reasons:
TOYOTA AVALON: Even more back seat room than the Maxima and as reliable, but didn't like looks, drives like a livingroom, is marketed as basically "an old(er) man's car," and cost thousands more comparably equipped.
ACURA TL: Colleague at work bought one in February, have driven in it a number of times since. Great car. But Consumer Reports (CR) lists reliability as only average (Maxima is very good, a shade under excellent), TL more expensive, smaller back seat and trunk, back seat doesn't fold down.
VOLKSWAGEN PASSAT: Average reliability at BEST. Whole Volkswagen line not good reliability per CR. Otherwise, I thought an excellent car from a feature / function standpoint. But fairly bland looks.
NISSAN ALTIMA: Reliability average. No VDC. Didn't like looks as much as Maxima. But was less expensive with many similar traits, i.e. rear seat room.
TOYOTA CAMRY: Excellent reliability and car, size of rear seat and trunk, comporable cost, maybe even a bit less. But find the looks very bland, just simply did not want the car so many others on the road drive.
HONDA ACCORD: Similar to Camry analysis above, although no VDC option and reliability above average, not excellent. A bit sportier handling and looks than the Camry, but still neither as good as the Maxima. No heated outside mirrors, smaller trunk as well.
Did for a short time look at some small SUV's, but decided another family sedan was best for me. However, if I had bought one, the Honda CRV would have been my clear-cut choice over the Ford Escape, Subaru Forester or Toyota RAV-4, based mostly on excellent reliability, much bigger back seat (leg room) than anything else (even mid-size SUV's), great feature in that the rear seats recline up to 45 degrees, cargo space, transmission, gas mileage and VDC.
One last item: I bought my Maxima in Spirited Bronze with Cafe Latte (camel) leather interior. Love the bronze / pewter color to begin with, let alone its uniqueness. Liked this exterior / interior color comibination better than any available in the six other cars listed above.
To each his own, but hope others find this helpful!
with this money at any level you should be able to buy 3 way 6*9's for the back, 16cm 3way with splits for the front, a verying quality cd player head unit, one to two amps too power the sucker, and one to two subs to give the bass.. my idea make sure you shop around
JA
I have a 2001 Maxima SE with about 39k miles on it. Everything has been good so far until a few days ago when I left for a vacation and when I come back after a month, the moment I hit the brakes, I get a pulsating feeling, the steering wheel is all shaking up so I take it to the dealer and he says, I need to get my rotors resurfaced and replace the brake pads. I dont want to resurface the rotors and instead replace them and the pads - what should I be buying? (both rotors and pads) - I am a novice so pardon me if this looks like a lame question.
