FYI: It is smart to check your oil frequently, because some manufacturers tell you right in your manual that your car can actually consume up to a quart of oil a month. Most cars do not typically burn that much oil, but it is possible.
Wondering what I might be able to get for it. Hoping around $6000. Any opinions???
Thanks!!
Also, for what it's worth, the best performing cars - Porsche, BMW, etc. - all have a good amount of brake dust that goes along with their exceptional performance. If the pads are so hard or of a composition that doesn't generate brake dust, they are either $8,000 ceramic brakes or soemthing that doesn't perform very well. My TL 6-speed that came with standard Brembo brakes has twice as much dust as our MDX and stops twice as well. A very acceptable trade off, IMO. So if washing your wheels is an unacceptable chore, you might want to consider a Camry. Or a 911GT2 with ceramic brakes for a bit more money.
Any help would be greatly appreciated! With the exception of not being able to enjoy this feature I love this car! Well except for the picky nav system
How many were produced and in what color combinations?
I like this package, what was the package called and did it have a package ID # in the VIN or Monronie's sticker?
Kirk
I find it useless for a family car not to have folding seats but each person is entitled to their own opinion
Could you let me know a few things about your 2002 GLE??
1. Do you use premium fuel and if not how does it run on Regular 87
2. Do you know what you get for gas mileage
3. Have you had and significant mechanical issues?? If so, what?
4. Would you recommend this car
Thanks for any help you might offer me.
Dennis
I tried from the driver door, and from the each individual door. Nothing seems to function. I checked the fusible link compartment under the hood. I found the bank of fusible links and fuses that say "pwr window" in the layout diagram. It is a 40A fusible link, but the copper link appears to be intact.
Now I am left with the front passenger power window stuck in the half-way open position. What must I check to diagnose this problem?
The location of your nearest Nissan dealer...
I locked car, put key in ignition 6 times until hazards flash, then turn key to ACC like instructed.
But when I press any key on either fob....hazards don't flash as they should when activating a FOB.
Is there maybe a fuse blown or a wireless receiver for the fobs has an issue ?
Any ideas ?
First they told me i had to purchase a nissan battery - then i would need my
Dashboard replaced and a new sunroof motor and switches and they would have to
Keep my car for almost 6 months before they could find a gas gauge/odometer
Suitable for my car. This all because my battery was failing and I was driving when it happened. Drove right into Sears - and replaced the battery with the top of their line. Little did I know that the sunroof, systems indicators, gas gauge to mention a few things - all stopped working. What did they say... "you needed to purchase a Nissan Battery".. my response - Nissan does not make batteries, and I was on the road when this happened and this is general maintenance of my vehicle. Then they said to bring it in - the first thing they told me was it was "out of warranty" - any excuse - then they said the whole dashboard has to come out and be replaced...
If you look on the internet - there are thousands of people that are suffering from the same problem - Nissan needs a recall - mind you - all because the battery was replaced... well Nissan - you need a recall - because everyone replaces their own battery - recall all the years that cause problems with battery removal -
Then the dealership called me one day to offer me a $9.98 oil change. After it was done - they charged me more than $35.00 - they knew I was there for the special oil change - and what the Manager said - when I checked the amount on my bill was "well, you were supposed to tell your service man why you were here, and what we offered. Remember - I walked into service and they knew I was expected and for what - they are liars and cheats. When I called back the manager - he told me he would give me a $30 credit on my account. Now, they will not even return my calls.
not even for parts information.
No I would never go back here again - never buy a Nissan again (I've had 5 Nissans, 3 Maxima's) and I will tell everyone one I know to go down the block to Bill Tyson Automotive in Royal Palm Beach instead. 561-753-6122 - they will help you and they are honest people.
> bill tyson automotive - undid the damage in just a few moments - and i now
Have a great place to go for my 2007 nissan maxima se -
> and
> i can trust them too.
> thanks guys - your the best!!!!
sounds like a lot of mis-information.....obviously u had more wrong than just a battery. but the part with the sunroof probably lost its memory...all u have to do is hold the button closed for 5 -10seconds and it will reset itself. losing the odometer after a battery replaced sounds more like a fuse or ur just promoting this automotive business you put down. sorry u had a bad experience....hopefully u found someone to tell u the truth.
sounds like the remotes ur programming are inoperable or the battery in them is dead. when u open then up to replace the battery, check for water damage or green corrosion. before trying again. procedure: get in car and lock car, insert key in and out till flashers flash, once they flash take keyless entry remote and press lock on remote(it should flash on ur cluster if it see it), then manually unlock the door from the main switch on the door, open the door then close the door then lock to close the process. then try ur remote. This is only for older model vechile...newer one u will need consult scan tool to program. hope this helps!
