dealer would not/could not fix it (it pulled)
no adjustment on front except toe in
(no camber caster adjustment) I went
to a private mechanic that ground a slot in the strut to give more adjustment.
The recall number is 2002088 and involves a safety defect that requires replacement of Control Arms.
Too bad they didn't cover paint and a dozen other defects too.
I have an 01 Max GXE auto with about 17k miles on it. My steering wheel has just started to shake at low to moderate speeds, but it shakes with or without me applying the brakes so I don't think it's the rotors. I assume this to be an alignment issue. I'm going to rotate the tires and see if that makes a difference. Is there something I'm missing here?
Leon
Any input on these subjects?
As for the transmission, I'm still trying to figure out why he didn't ask me these maintenance questions when I first arrived 2 days ago for my oil change.
My car has always run so smooth, I hate to have someone do things to my car that are just not necessary.
Thanks again, I needed all the advise I could get. Maybe they think "blondes" don't visit Townhall...Ha!
A good synthetic keeps varnish and oxidation of the fluid to a minimum even if you decided not to use the synthetic and used regular tranny fluid than a annual drain and refill would keep the tranny nice and healthy. I concur with gentlemen who recommended that the fluid radiator fluid does'nt need changing until 5yr or 60,000 miles yet thereafter every 30,000 miles or 2yrs is recommended then to you can uses havoline 5yr 150,000 miles yet I would prefer to split the mileage in half or better yet not execeed 60,000 and if mileage was reached use a 4yr or 5yr time frame to change coolant, one does not have to use a flush to change radiator fluid a drain along with a water hose for a 10min in the radiator would work better yet fill with distilled water only and and run car with high heat for 20min drain and refill half and half distilled water and antifreeze (remember only distilled water)
When I start the Engine, I see "Check Engine" symbol on the Meter Controls. Is it a Problem??
How can I avoid this problem??
How many more miles can we depend on this Car?
http://vbxmaxima.8m.com/ecu.html
http://vbxmaxima.8m.com/ecudecoder.html
They tell you how to retrieve the "check engine" code yourself, how to figure out what they mean, and how to reset the light.
In my case, I have a recurring intermittent speedometer problem that keeps setting off the light. I've had the speed sensor replaced twice, and it still goes off, so we suspect it is the speedometer itself. I don't particularly want to spend the $400 or so to get it fixed right now, and I'm 95% certain that it's not affecting anything else, so I've just been living with it.
I've also read that O2 (oxygen) sensors are common problems with Maximas that cause the light to go on.
Good luck!
During acceleration I'm noticing significant knocking and pinging. I use only premium gasoline and have tried other brands without any success.
I returned from the dealer today from a service appointment. The mechanic drove the car and said he could not hear the pinging. He also commented that he performed a diagnostic test, which indicated the car had never mis-fired and also stated that my car had the updated ignition coils.
I asked that service manager ride with me so that he could hear the noise first hand. During the test drive he was able to hear the pinging and commented that it was a "normal gas ping"
I was told that if there was nothing showing up in the diagnostic test as abnormal, that there was nothing that needed to be fixed.
I'd hate to hear what a "ABnormal gas ping" sounds like!! I'd appreciate any comments or feedback from anyone with similar issues.
The Service Bulletin states that 2000 & 2001 Maximas built before 3/16/2001 exhibiting "knock detonation" (pinging) should have the ignition coils replaced.
This also applies to vehicles that may NOT identify the error (DTC P 1320 Ignition Signal Primary) in the diagnostic test. The Service Bulletin still recommends the changing of the ignition coils. There are additional details in the bulletin.
I guess I'll be making yet another trip to the service department, or better yet, a different dealer..
The manual (for my 2k2) does say the following about pinging (in section 9 under "Octane rating tips"):
"However, now and then you may notice light spark knock for a short time while accelerating or driving up hills. This is no cause for concern, because you get the greatest fuel benefit when there is light spark knock for a short time under heavy engine load."
I wonder what classifies as "light spark knock"...
Last Wednesday it was knocking really bad when accelerating from 2500 rpm in 2nd or 4th gear, but has since stopped. In my experience, I've found the problem comes and goes. Sometimes changing gas brands fixes it. I think sometimes gas stations get bad gas or regular gets put in the premium pump.
My 2000 Maxima SE (40,000 mi) has recently started to stall out, even after warming the engine up a bit. Anyone have any idea what the problem could be? Thank you in advance for any help you can give!
I bought the car with 17K and now has 26k the clutch whins when you take off most of the time then goes away. The dealer stated that this is a known issue with the Maxima and there is nothing wrong. Has anyone had this problem?????
I have Nissan looking into it......but where that leads i can only guess.
Is there anything I can do to fix this short of tearing the dash apart and replacing it? Any way to grease it, maybe?
-Charlie
Try that specific direction with your Nissan dealer and see where you end up.
away. It almost sounds like a valve tap ! It only does this maybe once every
2 - 3 weeks. It doesn't matter if the car has sat overnight or for 3 days.
Btw, I have a ' 00 & a ' 02 and they both do this on ocasion. Very disconcerting !
Any ideas ?
cars I've ever owned , including Nissans have ever done this. I have a '92
Nissan P'up. It doesn't do it. I had a '94 Altima , it didn't do it. I had an '86 Max.,
it didn't do it ( VG 30 ). All with the same maintenance practices. The problem seems
to be with the VQ's. Again , not a big deal but disconcerting none the less.
Btw, did you know that the '02-'03 Max's use the smaller SENTRA oil filter
compared to the '00-'01's .Doesn't make sense to me. Bigger engine
smaller filter !! ?? Is it the Nissan "Bean counters"? Dunno !
if you have an automatic then...not sure.
Switched to non Nissan filters - never a repeat of the clatter since.
Are ' PureOne' and 'STP' filters any good ? What filter would you
recommend based on what you've read in these forums ?
Interestingly enough, I read somewhere here at Edmunds on one of
these boards that the ' 02-' 03 Maximas use the smaller Sentra
filters to enable the oil pressure to come up faster. I can't possibly see
how because the Sentra filter is the same diameter as the regular
Maxima filter and is shorter by ONLY 1/2 inch. I'd hate to stray from
Nissan filters but I will if I must.
I switched to Purolater.
Try it and see.
You know it when you hear it, normally after the clutch is warm (stop and go traffic) and when you are riding the clutch like in your driveway or starting up a steep hill.
Seeya
Now there's a possibility some wiring is not making contact properly - you seem to have eliminated any defects in the components (unless one of these that was replaced was defective, possibly the starter), but then again, I'm not a mechanic.
Dinu
Did anyone else have this problem and is there a way to fix it?
How do you reset average mpg. on the trip computer?
