Good Luck!
:shades:
Disconnecting the battery does work but only if the problem has been fixed. Otherwise, what ever is causing that check engine light to shine will continue to do so.
After an extensive diagnosis, the Nissan dealer service rep said that the problem is that my main electrical harness had been cut and that my ECM needed to be replaced. Now prior to this current problem, my car was running fine. :P
So I'm thinking that one of the mechanics previous to the dealer cut the harness because my car probably would not run with the cut harness, right? Anyhow, I need to know my options because my dealer said that the ECM unit is $880 and the harness is $1,800, plus another few senors and with labor, my total cost would be $3,900, which I definately don't have.
What options do I have? Can I buy the ECM and harness somewhere else and have an Electrical mechanic put it in? Is this a difficult job to do? Please help! Any advice would be so appreciated! By the way, for reference, I live in Temple City, CA. Thanks so much for your help!!!
Oh, by the way. I was told that the Nissan Maxima does not need a transmission flush.... ever. Is this true???
Here's the links:
http://www.nissanhelp.com/Ownership/Bulletins/Nissan/2005/NTB05-021.htm
http://www.nissanhelp.com/Ownership/Bulletins/Nissan/2005/NTB05-095.htm
With the transmission flush, I would go ahead and get it done if you've never flushed the transmission in your Maxima. The manual doesn't state when to flush your transmission but most people recommend getting it done every 20- 30,000 miles.
'17 Chevy Volt Premiere
I am the original owner of a silver 2003 max SE with 43k miles on it now. To date, zero mechanical problems. Only major expense was I did replace the [non-permissible content removed] OEM Potenza tires at 34k with Yokohamas. I have numerous (minor) interior squeaks/rattles that go away when i turn up the excellent standard stereo. Price you mention is halfway between kbb retail value of 16.4k and private party value of 14.6k Good luck; FWIW, i would check the front brake pads for wear too.
During the last 1 month, the car stopped twice while driving or waiting in the traffic.
In the first occasion, the ABS light first got turned on. I turned off the car, and after a while, when I started it, I saw the ABS light going on again. Then after driving for about 15 minutes, I suddenly felt that the car did not have any driving power and I saw the airbag light got on. So, I pulled on the side of the road. Then I waited for about 15 minutes and then tried starting the car, it drove fine. I took to dealer next day and they said battery voltage was low. And they charged it and the ABS light was turned off. The dealer said, the car was otherwise in good shape and no repair is needed.
After about 15 days in the second occasion: after driving for about 20 minutes, I had to stop in long traffic in downtown and the car died again. I waited half an hour on the side of the road and the car started again. But, within 10 miles, the car again died while waiting in another traffic light. Interesting is that all the 4 lights could be turned on. But, the car would not start even after waiting for 30 min - when I tried to star it, all the dashboard lights would come on. Then I tried a jump start and the car ran fine and it is still running without any issue and I could not reproduce the failure again.
Next day, I checked battery/alternator at Autozone and they said charging system is fine. I also had a code check and that was clean too.
Then, I took my car again to the same dealer shop (no jump start was needed) and for the last 6 days it was at dealer shop; they drove it for more than 40 minutes for 2 days and could not figure out what is going on.
Service manager said, I could take the car back and if it dies next time, we can toe it there.
So, I really need the help from here as I dont want to get stranded in the middle of road.
Thanks for reading (the posting got long - I wanted to give as detail info as possible).
Ataur.
tia!
2004 Maxima Owners Manual
Make sure there's no frame damage. On a car that old, frame damage might be grounds for calling it totalled. Happened to me with my Stanza a long time ago.
We just changed the muffler on our 2000 Maxima GLE. Over the years, we've done just about everything - changed ignition coils, oxygen sensor, etc. All said and done, it's been a great car for us and we're hoping to get 200,000 miles out of it. It's just south of 100,000 now.
With regular maintenance and fixing problems as they come up, we haven't really had any major issues.
