Toyota Camry Maintenance
Hello;
I have a 95 camry v6le which is coming up on a 60k
mile service. Its not under warranty anymore. So does it make
any sense to take it to the Toyota dealer for 60k miles
service? Dealer quoted about 1500$ (in California).
Is it really that high?
I am thinking of getting a quote from Jiffy lube,
Pepboys etc...? any advice on who is better?
So far i 'diligently' took this car to dealer for
every service/maintenance. No mechanical or any other
problems so far.
thanx a great deal for your advice.
regards
Steve
problems so far.
regards
Steve
http://www.toyotapart.com/ and ordered all of the parts from them, genuine Toyota at wholesale prices. Local mechanic I use put them on at about a $500 savings over what the dealer wanted for labor only. No other maintenance is required at 60,000 and do not let the dealer or anyone else talk you into it. I have 128,000 on my 92 Camry V6 SE (same engine as you have) At 120,000 I did the same thing and added the water pump replaced. For belts etc, I would really try to use genuine Toyota parts, my experience is that there really is a difference especially in brake pads. Timing belt at dealer here is $180 (parts & labor) add two more belts ($50) plugs $60-70 + labor) transmission service $30, you can do the air filter yourself.
If your motive, with all this frustrated bad mouthing about Toyota, is simply to make them look bad, you have taken the wrong road.
Unfortunately (for you at least), you've accomplished nothing in that regard. The finger of suspicion points toward you, not poor old Toyota.
You have yet to learn that in situations like yours (real or otherwise--and in this case, otherwise), the first casualty is most often the truth!
Take some advice---give it up!
I found a Goodyear hose from Autozone to be the same length as OE, but the Gates hoses and NAPA hoses were about 1/2 inch shorter on each end, but still fit on , I did not use them.
I'm a little new to the problem of the sludge, however, I know my sister had a problem with oil pressure on her camry (4 cyl) and I told her it looked like a sending unit or bypass problem. My mechanic was out of town for the holidays so she took it to the Toyota garage. They told her it was sludge and charged her close to $700. She then drove back to her house (approx 200 mi) and she had the same problems. Her maechanic replaced the sending unit and the problem disappeared. Just recently my wife has had friends who have been told by Toyota that they need the sludge removed from their engines. Seems to be a pattern.
I would NOT take your Toyota to one of the "mass merchants" you mentioned!!
1500.00 sounds way too high, I would check other Toyota dealerships.
You might also look for a quality independant that specializes in Toyotas.
armtdm's advise about buying your own discount parts and then bringing them to a shop to have them installed is a bad idea.
Most shops would either refuse the work or charge you additionsl labor to make up for the profit they didn't make on the parts. Not a good way to establish a relationship with a shop.
Kind of like bringing your own ham and eggs into a restaurant, and asking them to make your breakfast!
My dealer said he will provide warranties on
the parts that I get, IF they are genuine toyota
parts.
So I can purchase parts at toyotapart.com and
then get the work done at a dealer.
I am not sure, if the dealer will honor the
guarntee, he just told me that he would, so....
If you diligently' took your car to dealer for
every service/maintenance and no mechanical or any other problems so far,I think 1500$ is high.
How much have you ever paid for maintenance(7500miles,15000mies,...30000miles...)? If you have changed anything, it might cost 1500$.
They would consider a person like that to be the ultimate cheapskate since they typically depend on making a profit on both the parts as well as the labor.
But...if your guy doesn't care, go for it!
Air filter (can do yourself), fuel filter, drain and refill transmission fluid, maybe coolant if it does not have the long life from the factory stuff in it!. Nothing else at 30,000. Plugs are at 60,000, belts and timing belt at 60,000, Check you manual and go with that.
Honda says 90K for their 2.2L 4 cylinder. Why can't I extend the belt change to 90K? Is it the belt that can't take it, or Toyota says replace it at 60K to make $ more often.
If the belt breaks, the pistons won't hit the valve as it is the case with Mazda MPV 3.0L V-6 or Chrysler Neon 2.0L engine.
the water pump and all pulleys,and the spark plugs
(it's much easier to change belt with plugs out)
maybe the above writer meant $2000,I don't
think there is even a ma and pa shop that
would attempt that job for $200.
Oilcan2, where do you live that they charge $2000 to replace a timing belt?!
I have the v-6 4 cam 1MZ-FE.This engine is the
v-6 used in camrys from 94 to 98.the 93 has the
3vzfe and 92 shows 2 v-6 engines,the 2vzfe and
the 3zvfe,the 1 mz-fe is the aluminum block
engine.I'll call a local dealer and get a price
on a 98 camry v-6 belt replacement and post it.
Sorry about the mix up.
http://www.gates.com/pdf/tbelt.pdf
I will stick with 60K if the engine is interference type, and will stretch it to 75 to 90K if it is not.
Good help and hints in this site.
Make sure you know what model engine, and date of mfg. you have then check with the mfg of you car for, hopefully, reliable information.
Ask toyota directly, most service reps at dealers have too many models, years and are probably too wet behind the ears to know their timing belts from their chains or even what an interference engine is!!!!!
So, you decide to save money by stretching the 60K interval to 90,000.
At 83,000 miles on a dark rainy night while merging onto a crowded freeway, the belt decides to let go?
Ah...but think of the money you "saved"!
I'll take my chances on belt replacement. I'm not going to get one until the car reaches a minimum of 80,000 miles.
Our Camry V6 is not neglected or abused. It sits inside a cozy garage out of the sun and bitter cold. Certainly, in 1996, they had enough technological know-how to make a timing belt that would last greater than 60,000 miles.?
I think 60,000 miles is too early. I don't know anyone personally who has had timing belt problems. I have asked around, with other owners, and they are going further than 60K...in some instances over 100K! It must be rare...
But I realize that others don't feel this way. That is ok. I won't call them fools. They are cautious and they want peace of mind. Nothing wrong with that. Just like those who change their oil every 3,000 mi....
But please folks, don't have any nightmares of merging into the crowded freeways...and your timing belt breaks... There are far more important issues to be concerned about during those occasions!
Years ago, Honda required 60,000 mile timing belt changes. Along the way, they improved the quality of the belts and the intervals changed from 60,000 to 90,000. After 1997, it's 105,000.
Now, don't you think Toyota suggests 60K for a good REASON ? I'm surprised they haven't matched Honda in this regard.
But, you can go ahead and take your chances. I just hope it's you driving when it snaps and not your wife or daughter.
Sounds like false economy to me!
If I screw up, then I'll let ya'll know! Promise.
If nothing happens and the belt gives service to 80,000 miles, then you'll hear about that too !......
We are talking $200 bucks here, not $2,000. Not worth the worry or hassle just DO IT!
I asked the mechanic about the condition of the original belt. He stated that it looked "ok", but that it was a "good idea" to have gone ahead and had it replaced.
My plan calls for a 80,000 mile belt replacement in my '96 LE V6...thanks for the advice though.
I also had some other belts and hoses replaced at the same time... It was a fine little sedan.
We could do the Wilcox Timing Belt Test !
Drive it until it snaps! Hell, we could take bets!
The thing is, it probably WILL go the 80,000 miles. The 60K reccomendation I'm sure was set to allow leeway.
Another thing to think about is oil contamination.
Sometimes the front seal will start to leak and the oil will get on and ruin the timing belt.
I think that's another reason for the 60K reccomendation. You never know.
dave
I don't understand why didn't Toyota leave slight room under the filter so I can slide a piece of cardboard to deflect the draining oil. The hole in the engine mount bracket is worthless. The oil gets on the oil pan, and runs down on part of the exhaust.
On my second oil change, I let the oil drain from drain hole longer, and used one of those oil absorbent rags, it did better than the first oil change, but it still got some on the pan and exhaust. Not a big deal, I just wonder if someone has better method.
Really really do work if you change your oil often!
Saw something similar once and it scared me.
I had one years ago on my '77 Chevy Impala. Loved it! Thought Fumoto had gone out of business.
Isell, according to the website, the valve projects out only 1/2 inch compared to the original drain plug.
On my Chevy small block, the angle of the fumoto valve was such that it didn't hang down closer to the ground.
It really depends on the location of the drain plug and the shape of the oil pan.
