Subaru Impreza WRX
-Brian
Did you forward the link to SoA? I'm sure they'll see it anyway.
-Dennis
I did a rough estimate, and the wing probably produces about 65# of downforce at 80mph, 102# at 100mph, and 228# at 150mph. These are all optimistic numbers, assuming the wing has a lift coefficient (CL) of 0.8 and is in clean flow at each speed. I eyeballed the wing to have about 5 sq. ft. of planform area. You can scale my downforce numbers directly with area and CL, if different input parameters are desired.
Whether or not these downforce numbers make a difference or the wing is really required is a question best left to the engineers at Subaru, pending further information.
Craig
I don't get the big deal, my biggest concern would be a demand for it so immense that it would get stolen.
-juice
Sometimes they're very slow to make changes, but they do listen.
The WRX and STi are perfect examples. Also, some of the options on the 04 WRX (moonroof, all weather package) are the result of people making their voice heard IMHO.
-Dennis
-juice
Later...AH
Craig
and, having someone steal it, without removing it in a nice way, is just one of the concerns that I have. I'm leaning regular WRX right now, but if I get the STi, I may buy an additional trunk and just replace it.
In truth, it looks much better to me in person than in pictures, but I still don't need the extra attention.
Considering lift force, I can give you the link to the numbers which are pretty reliable. No downforce, by the way, it is still a lift force, but it is not very high.
You do not need to read these funny characters, just check out the pictures. Top is Evo VII with wing set to minimum angle of attack (Cd==0.39), in the middle is Evo VII with wing set to maximum angle of attack (Cd=0.40), and on the bottom is STi which has non-adjustable wing (Cd=0.38). Forces in Newtons. Test speed is 144 km per hour.
Also, the data is for 2002 STi, which has slightly smaller wing, then current model.
Skyline has underbody panels, which almost fully cover front and rear parts of underbody.
This picture shows the air flow near the wing: Air flow
To moderator: I had to post the picture, because I had to change its size, the original is too big and looks bad. It was taken from russian car magazine "Auto Review".
So the Evo wing, set at the max AOA, is worth another 146N of downforce at 144 km/h (~90 mph) compared to the min AOA setting. What's neat is that you can see how it translates into lift on the front wheels. Imagine if this was a FWD car -- you'd be unloading the fronts (=drive traction) just to keep the rears planted, which seems unproductive to me.
I'd be real curious to see numbers without any spoiler, just so we can conclude how beneficial the spoiler is, period. And since these appear to be aero loads only, it would be neat to factor in the weight of the car. I guess if we knew the curb weight and the F/R weight distribution, we could figure that out.
Craig
I thought this may be a good place to ask -- do any of you feel that superchargers / turbochargers ... installed by someone who knows the car and the system ... results in significantly higher maintenance? Compromises reliability?
Thanks for all opinions.
JW
Prodrive's experience with Subaru's goes back to when Subaru used a Legacy in the WRC. :-)
It's too bad that Prodrive's PP won't be factory backed like it is in the UK. :-(
-Dennis
I was under the impression that the WRX had 100" spacing for the holes. Because of this I am assuming the two cars are incompatible, but am hoping they are compatible.
Also, note that it's described as "5x100" because there are 5 lugs. Some wheels have only 4.
Best place to sell is NASIOC because for the most part it's only going to be the correct offset for other Subies.
-juice
I will look in to NASIOC for selling the wheels when I am ready.
- Thanks Juice.
-juice
I knew I loved this board!!
Yes, quite a few changes. Here's a link to the press release from SOA (pics included).
http://impreza.subaru.com/microsites/impreza/news/news_main.jsp
-Ian
Dropping the car down 1-3" would be a better way to make the car more aero/less lift than the wing in the rear IMHO.
-mike
and, try putting the car in first before going to reverse.
I've never heard of windows fogging up because they missed a step in the manufacturing process. Are you talking about interior or exterior fogging?
The vibrating could be a loose exhaust shield, or maybe a pebble is wedged in there.
You should definitely NOT be getting pinging. Possibly you have the wrong octane or you just got a tank of bad gas.
Make sure your air lever is on fresh air (from outside) instead of recirculate.
-Dennis
Often when wheels make noise it's because the brake discs gather a little bit of rust overnight. Some cars are very susceptible to this, some almost never get it.
Reverse gear engagement is an issue for lots of cars, probably not for any luxury cars or Hondas. I've driven lots of MT cars short distances (lots of road-tests while working for my father's shop) and most of them, new or old, had a unique feel/action when going into reverse that I had to be careful of. Shortly after my brother-in-law took delivery of an SLK he asked me if he should be worried that reverse is sometimes tough to engage (I told him to mention it at next service and, if the mechanics didn't find anything wrong, not to worry about it. If the M-B guys are okay with it, I am too)
Window glass: the best thing to do for these is clean them within an inch of their life. Any kind of residue on them will make them very susceptible to fogging and streaking. When I'm cleaning my windows I always start with a mild ammonia solution (wearing gloves and using a garbage bag to protect all fabric/etc) to cut through that buildup, then dry with clean cloth, then clean with spray cleaner. When they're really clean they will stay clear much longer and morning fog/dew will clear out much faster. I live in NJ and my windows build up road haze etc so fast that after just a month or so they look streaky even with full defrost blowing. Cleaning them in my regular fashion eliminates that completely, until the stuff builds up again.
DjB
* the vibrating is probably a loose heat shield. If you have ramps try to see if you can find the source.
* the brakes might have surface rust, no biggie. The bearings on the new Imprezas are supposed to be more robust than before, so I doubt that.
* try engaging first gear, then reverse. They're next to each other on the gear box so it'll be easier.
* the windows may be fogging up due to outgassing. Seems odd given the miles, but it should stay clean after a few cleanings
Hope this is helpful.
-juice
Aside from what's already posted, what's your shift points? Could be shifting too soon?
As bluesubie mentioned, keep your air lever in "outside" not "recirc" even when defrosting.
Yes the car's still a blast! Good luck.
If it's a loose heat shield, the sound may change depending on whether the exhaust is cold or warm. Can you pin this down in more detail?
"next after leaving the car parked for a day I noticed that the wheels will make some noise for the first mile(My WRX is wearing P1's)sounds like either the brakes or bearings are rubbing"
If it's a quiet rubbing, I am guessing your rotors got a film of rust on them, which is very common (especially if it rains, is humid, or if you park the car for an extended period of time). Since the brake pads are always in contact with the discs, you will hear a rubbing sound. Should go away after you hit the brakes a few times. In fact, you should be able to isolate whether or not the noise is coming from the brakes by applying the brakes and seeing if/how the noise changes.
"Getting the car into reverse takes a couple of try's"
My WRX is the same way, as was my Prelude and my Civic before that. Most cars do not have a synchro on reverse, so it can be harder to get into (even though you're not moving). What always works for me is to put the shifter back in neutral, let out the clutch, and try again.
"and after shifting from 3rd to 4th I can hear the valves pinging as I give it gas(sounds like a tired 4 banger going up a steep hill sound)."
This is definitely not good. Are you using 92+ octane gas?
"I have also noticed that the windows seem to have missed something in the manuf. process as the windows fog up real quick"
Very typical for a new car, the plastics outgas and really cloud up the windows, in turn making them very susceptible to fogging. This reaches a maximum some time after the car is new, and then goes away over a period of years. Some cars are worse than others.
Craig
Mark
Craig
TWRX
You must have heard about the cat changes on nasioc. :-)
-Dennis
