The radio on Christine was replaced early on because it was defective. I did have the "upgraded" Infinity stereo that originally started out as 320 watts. Somewhere along the way, DC said it was 360 watts.
Anyway, never had a problem with the CD player. The only problem was that if I turned it up too loud, the driver's door/speaker would vibrate. As for the sound, it was okay, but not what I expected for an "upgraded" system. I still say that the best system I ever had was in my 1994 Infiniti J-30. It was a BOSE! Before that radio, I never really knew what a GOOD stereo sounded like. Of course, BOSE designs the stereo according to the manufacturer's specs and the car's interior. The BOSE in my Acura CL-S is NOTHING like the Infiniti J-30 BOSE, but better then the Infinity in Christine.
fastdriver
Help would be appreciated otherwise here comes 5* will try to get them to replace under warranty since it appears to me the problem is an assembly problem at the factory.
P.S. The HID lights are totally cool!!!!!!!!!!
If that is the case it is only 3 bolts and two plugs to swap out and defiantly worth the trouble.
My 01 LHS had the AC amp in it. I bought an AB amp from an 01 300M. Figured I would have to listen to both for a while to notice the difference, boy was I wrong. I put in a cd and adjusted the volume and eq to the best max level with the old amp then switched amps the difference was amazing. It seems to have twice the power. I now wonder if the AC amps are for the standard system and the are just using them up in the premium systems because of an impeding change to the stereo in the new models figuring most people , like myself, don't know bean about stereo systems. If you still have your 01 I would defiantly check this out and do the swap the leasing company will never catch on.
Many happy miles in your new ride :>)
Reinstall them with the screwdriver. There is no need to put them on as tight as the factory.
I agree an easy-out should probably get the stripped ones out. If you are real desperate, take some channel locks and grab onto the side of the head and twist. Maybe you'll get it out. Try the easy-out first though.
Hope this helps.
I've been on a crusade replacing the so called "Infinity" speakers that came from the factory. So far I've replaced the rear deck and lower door speakers with REAL Infinity speakers which has yielded a major improvement. Yesterday I replaced the wing speakers with a pair of Kicker R25 tweeters I got from Glennbp and that was worth the effort. The sound from the factory speakers was scratchy, harsh, and lacking detail.
Next I'll replace the rear door speakers with another pair of Kicker's now that I've worked out a screw in mounting method for them. I'm not sure what I'm going to do with the center dash speaker but I'll figure out something.
The Infinity AB amp won't win you any stereo competitions but with good quality speakers attached, it can generate pretty repectible sound at an annoyingly loud level - according to my wife.
Did you mean Motortrend instead of R&T? If it was R&T what month and page???
Does anyone know why this happened? I heard that the front speakers had some sort of crossovers to split the bass and tweeters. Was that the problem? I'd still like to change the front door speakers, but not if I have to rewire everything.
BTW, my car is a 1999.
-vman
here are some reasonably priced good speakers for the doors.
http://www.crutchfield.com/cgi-bin/S-lBtyKGrREX3/ProdView.asp?s=0&c=10&g=52000&I=023PCXT652&o=m&a=0
1. The door speakers signal is strictly low frequency, there are no highs being fed to the lower speaker. When I first installed the new speakers I wired in the crossover they provided to split the low and high signals. No highs were present. I ended up splicing into the wire for the wing speakers to get the highs for the coax tweeter on the lower door speaker.
2. If I hooked the wires up directly to the low side of the Infinity Kappa's, the bass was weak, but if I inserted the crossover they provided and hooked up to the low side of the crossover the bass came back.
If the Jensen's had a built in crossover I'd guess their crossover settings were a poor match to what the amp was putting out. That was the reason I stuck with Infinity speakers. I figured their attitude about crossover points would be reflected in their retail speakers and they'd work best with that amp.
As for the side airbags...I wouldn't sweat it. A lack of them wouldn't have kept me from buying Big Red if she didn't have them. However, it sounds like you're having a little buyer's remourse. You're probably over-analizing things. Think of it this way... if you take the Special back are you going to regret it 30 days from now? Want to trade it for a really nice red '01?
videoman----do those tips shine like a mirror or are they like a satin finish?
I personally like Pioneer, and am strongly considering the TS-C1653 or TS-C604. The former is current, the latter an out of manufacture model, but both regularly available on ebay for about $100-120 shipped.
do the factory 6x9 have a tweeter in them or are they just for bass? Did you replace the factory front tweeters?
Re: the corner speakers. I wonder why they keep cheapening them. If you look at at 99/00 they are a nice gray metal grill with Infinity label. Then the 01's went to a cheap looking plastic with a small circular grill. I wonder if the grill from a 99/00 would fit.
Someone asked if the stainless are shiney -- yes they have a mirror like finish. Pretty similar to chrome. I keep Zaino on them just to keep it that way.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1848658798
I have a feeling this guy doesn't know which end is up (or used for what for that matter). He's got three wheels listed - razorstars on the car pic, the 16" sebring/concorde wheels on the top pic and the 01/02 wheels on the bottom :-D
yes
no
jab02lhs:I thought about switching amps, but I'm concerned about warranty coverage on my new and old cars should the amp fail. The amps would not match the year of the cars and could cause warranty problems. Maybe I'll just watch for an amp on ebay.
Blonda:I'm going to see how much it is to buy the emblems, or if unavaiable separately, buy the "grilles" with emblems.
MRL - Unless you can get the dealer to swap the amp, then you'll either have lousy sound or you'll have to buy another which won't be covered either. If you do swap and there is a problem, sure you won't have the orig amp, but the orig sucks anyway Honestly I don't think they'd notice and/or care. It's a chrysler stereo, the mechanic will get paid...
My question is, for those of us going to Detroit then Brampton Canada for the plant tour, what exactly do we need to get into Canada? Is a drivers license enough or do we need a passport, birth certificate, etc.?
What do we say the reason is when we're crossing the border? I was denied access once by telling the truth.
-vman
Who knows? Maybe the 300M was becoming too much of a contender to some of the Mercedes products so they cheapened it a little.
Who knows? Maybe since the 300M will soon be replaced with the 300N, they figured they'd save some bucks for it's development.
Who knows? Maybe I'm just crazy and don't have a clue as to what I'm talking about. Well, that I do know.
-vman
Side air bags--Would not, and will not, make any difference to this buyer on a future car. If they come with the car fine, but I would evaluate the head room and how much it takes up, and it could actually lead to a no-sale if its a problem. Also, remember that these side bags have been iffy. Caddy had a problem with them on the first year Catera when they were putting a lot of sales-pitch pressure on with TV ads that Zig, etc., and it killed the first year sales when they had to stop production and get the problem solved. Also, Hyundai has been recalling Sonatas this year because of a problem with the bag sensor allegedly causing the bag to go off at the wrong time. Two of my friends got recall notices on their 2002's. So, I don't think not having them would impact most buyers on a sale.
The Street Rods National meet ended here this weekend. Went up on Saturday, and as usual it was awesome. About 5 out of every 7 cars were for sale. Unfortuantely, the heat was incredible. 96 degrees with 50% humidity by noon. AS a result, I spent a lot of time inside the A/C Convention center looking at the vendor offerings. Wish I listened to my dad when I was young and learned more about the inner working of cars. Best deal I saw was a guy trying to sell a 37 Jag convertible for $9.5K. Said he needed the money for college tuition for one of his kids. Nice car but I saw a similar one last year at the Dream Cruise for $11K that was in better shape. Maybe a kit, I don't know. The zip-in sidecurtain windows didn't appeal to me either. Highest priced rod I saw was $70K for the standard looking Ford remake. Problem was, many of these cars were great looking, but they were essentially the same rendition except for paint/upholstery color, and it was hard to distinguish what made one better than another. Would have been hard for me to pick a best of show. Short block Chevy and Corvette engines were the most common non-EOM power plants. A great way to spend a day if the heat stroke potential wasn't so high.
Now things have changed a bit since 9/11, but in the past, all you needed to cross the border was a drivers license. Nothing more required. Now, if you are concerned bring a Passport, you will never need more than that anywhere you go. If you don't have a passport, I would strongly suggest getting one just because it's only a couple bucks and it's very useful to have But if you don't a drivers license and birth cert. would be fine, though the bc on it's own is a worthless id as there is no pic on it.
Also, as to why you are going? Just say pleasure - that's why you are going. Don't give too much info - the border guards really don't care
Canada/US relations are good, so going back and forth is not a problem. Same with Mexico - last time I was down near the border in AZ I just walked across - no one even said anything.
btw - Some things to keep in mind - they will search I believe about 1 in 10 or 20 cars somewhat randomly. If they search you, don't worry about it unless you are bringing something back over the border you didn't declare
Recommend you not bring alcohol, fireworks, controlled substances (except perscription meds) or firearms across the border - can cause problems.
Taxes!!! - Save your receipts!! There are two taxes in Canada (GMT and something else, Otto can you help me here One of them is refundable when you come back across the border (if you want). It's about 7% of what you spend. You fill out a form and they will send you the money back since it's for Canadian citizens, not US.
The Cdn dollar has just taken another dump this morning, so bring your money and exchange at a bank NOT a store or you will be ripped off. If you are looking at buying anything for your M in the next while, check out the prices in Cdn dollars and do the math, you will probably save a bundle, plus you get your tax back.
When crossing the border put that smile on your face and enjoy your trip, I wish I could be there to take the tour but it is just to far for me. Have fun and I hope I have answered your questions.
Another interesting thing on the drives down there is all the crosses on the side of the road where people have been killed in accidents. There's a lot and it really makes you think and be grateful you don't have to live with those conditions every day.
The end of this month I travel to Costa Rica. They have the 2nd highest accident death rate in the WORLD. I have no intention of driving anywhere, but the biggest risk to my safety I think will be the 2 hour ride from the airport to the hotel and back.
