Chevy Silverado/GMC Sierra's w 8100/Allison
The '00 model year was just reversed. I guess GM had some '00 CD units miss-identified as Cassette units in the wrong ben and obviously QA DOSEN'T check out the sound system for function.
75v
Above is a better place for the CD
- Tim
But in case not.
I liked the Tread better on the A/T's. Not noisy at all.
Coop tires have Excellent reputation here in the Mwest (Smaller companys have to have good product or can't compete with GY's GR's Mich's etc.) but if you don't have any need for the tread go with what you like better.
Sorry if I steped in here where not wanted!!!
75v
The weatherman says it should be in the 80's out here in 'SHAKE & BAKE' this weekend.
-Eric
Im new to edmunds(and using a computer). Just got a build date from the dealer of 9 april.Was told should arrive end of April.
MC 2500 4x4 ad 8.1 allison. Is there a way I can keep track of where the truck is?. I placed the order 11/18/00
Thanks, dinoserria
Just got back after driving from California to Washington putting about 1000 miles on the truck.
I experienced a real loud clunk while decelerating and later another one while I was accelerating not to be confused with the normal clunking going into first gear. These two clunks happened on different days and the last one was one the way back home.
Got about as far as Bend, Oregon on the way back when after a very heavy clunk the gears froze up in 1st or 2nd gear and wouldn't change up. About the same time the check engine service light came on.
I pulled off the road and checked the trans. oil etc. and let it cool off a bit then tried driving it again. Drove ok this time but I went to a GMC dealer in Bend where after a 4 hour wait they reset the codes for the Check Engine light and re-adjusted some switch in the transmission that they said was out of adjustment.
Stayed over night in Bend and next morning soon after driving the truck the check engine light came on again. Decided to drive back to California and will take it in to my dealer tomorrow. Drove ok on the way back.
Unfortunately none of the transmission techs. have any experience with the Allison trans so I don't have very high expectations that it will get fixed properly the first time.
Would be interested to know if anyone else has experienced a similar problem.
Watching for your update on what's going on.
Have 1000 mi 50/50 in town/hwy on 8.1/3.73/alli/4x4/sb so far with no problem at this time.
75v
cowboyjohn
Quick note to woolyback. Wooly, sorry to here you're having problems. Please keep us posted on your progress. Best regards and good luck.
Any mileage figures yet while towing? Did any of you consider this problem of a large engine with a 26 gal tank and want to comment on it? The LB has a bit more capacity, but it IS long with the Ext cab. I'm tempted to buy a diesel just for the mileage range, but it is very expensive. Thanks.
I have a question about the Firestone tires on the truck, the door sticker says to pressure them 50lbs for the front and 80 for the rear. Is this normal and does anyone have any comments or recommendations about what pressure to run them when not towing.
On tire pressures, I run 50 front and 50 rear when not towing, and when towing and/or loaded, I up the rear appropriately (up to 80 in some cases). Seems to be working well so far.
Draw a line across the tread with a piece of chalk. Drive down the road a mile or two. Look at the chalk wear. Adjust tire pressure so chalk wears uniformly with the load that you are most interested in....
- Tim
FOR WHAT IT'S WORTH ----
Couple ways to add extra fuel tank depending upon you perference and accepted risk factor.
1) -- Some have simply had a rectangular tank fabricated to the gal. size space they thought they could do without , bolted it in the front of the bed and gravity feed it (with an inline solenoid valve_to open/shut from inside the cab) to the fuel return line to the standard 26gal tank.
I have a Reese Kwik-Slide 5th wheel hitch and would kinda like to keep the rest of the SB bed available for other stuff plus like having the extra fuel down between the frame.
2) -- I've measured the spare tire space under the frame and believe a rectangular tank (don't have exact dim. with me at work) approx 31"x19"x8.5" what ever the dim. is -- it calculated out to about 27 gal.
Additionally if I remove the spare tire cable lift device a smaller rectangular shape could be welded on top of the lower section to fit up into that area to make an over all capacity around 40 to 45 gal. An inline electric fuel pump could be used for transfering the fuel to the return line of the standard 26gal tank. The filler neck could be positioned behind the license plate (as the bumber already has a large enough rectangular opening behind the license plate) which could be mounted on a fold down bracket like my (hate to tell my age) 1960 chev. impala had!!!
Think I'm going the second route as to keep the fuel in the frame area. I don't like carrying the spare tire their anyway because the wheel just turns to rust over time and I only carry it when on trips anyway. Haven't had a flat in 20 years.
75v
Picked up the truck today at the dealers but I'm no further forward as far as finding out why the service engine light came on. Techs. couldn't make the light come on again to trouble-shoot it. So there is an open work order on it and if the light comes on again I'm to take it in. Lot of good that will do me if I'm off in the boonies somewhere with my trailer. I'll keep you all posted if something worthwhile happens.
Thanks for the info on the tires. Best mileage I got on my trip was 13mpg solo running around 65mph.
To (n75v111) regarding the extra fuel tank modification how do you get around the emissions requirements or do you not have to worry about smogging where you are.
EITHER ---
1) Don't worry about what vents to atmosphere from the Aux Tank. The Aux. has to be vented to avoid pressure build-up so people here just have used a vented cap.
Note that this does not functionally change the pressurization of the standard fuel system because the shut-off valve is nomally closed except for the gravity transfer time (approx. 30min/1/2tank). The standard fuel system pressure apparently is quite low because the gravity transfer is sufficient for the transfer.
2) One could determine the standard fuel system vent configuration and just connect a vent line from the Aux. Tank to the standard system to avoid vent to atmosphere --- I THINK!!!
75v
I am being told 3/26/01 or later. Does anyone have any knowledge regarding this transport snafu. Thanks.
Just fininished making cardboard Template to mark exact drill points thru the floor and bolt in Reese 15K that I converted over to the Kwik Slide - Nice conversion if you don't already have it.
Will allow the 'Pull' position to be 43" from back window glass centered over axel which allows for a 61 degree angle turn. Slide goes back 10" to allow full 90 degree turn.
Questions??
75v
A query for our host or others: I can't help but notice the huge difference in price for the Allison option on this site (MSRP-$2295, Invoice-$1973) when compared to others ($1200 and 1032 respectively). I've priced this option with dealers three times in the last ten days and all reflect the lower price. What up? Does Edmunds know something the dealers don't, or am I just a babe in the woods? Thanks.
Dave
in an LT..you have paid for the auto tranny...and it's $1200 extra....
in an LS....it's $2400....due to a manual being standard
- Tim
No, the price quoted on this site is for a 2001 Cheverolet Silverado, 2500HD, 4dr Extended Cab LT, 4WD LB w/Onstar.
Very peculiarsome.
- Dave
The $2300 price tag is for an allison in a Chevrolet, the $1200 price is for an Allison in a GMC. The base price of the Chevy is significantly lower than the base price of the GMC. Overall most Chevy options are higher than GMC options.
We Just picked up 1 of 3 8100/Allisons (Chevy) on 3/24. Two more (GMC 2500HD and 3500 SLT's) are being built this week. Been waiting on them since 9/21/00
- Tim
-Josh
It sounds a little high, We just took delivery of a 3500, LS, 4x4, loaded with all the goodies available to the LS, less the snow plow springs and toneau cover.
$32,678 (33,592 w/ttl)
We have a GMC SLT 3500, 4x4 8100/Allison, Leather, 1SD, and all other options available less snow plow, and toneau cover for $35,093 ($36266 w/ttl)
Thanks, Nelson
Thanks for the input. I 'specd out the truck at edmunds(helpful site) and it showed dealer invoice as $33,800. So invoice and tax($1,276) comes out to $35,076. So I guess I'm getting the truck for $709 over invoice. I think I can live with that.
-Josh
- Tim
GM accepts orders. It's been about 6wks. Is this typical?
8.1 alli 4x4 LT SB & most of the options.
Hang in there guys - Usually it's better to wait and get exactly what options you want than taking something the dealer has on the lot.
5th whl position--
Was kinda waiting to see if anyone else would give you their view on the 5th wh loc.
1) Recommendation from reese is around 2" in front of the axel But -------
with the SB that gets a little tough with the standard (non-slider) hitch. You have to move behind the axel about 4" to get close to 75 degree turn.
I know several that have done that and have no problem with control and get along just fine (one even with 98 chev. 1/2 ton and 28ft unit)-- You just have to watch it if you get tight parking etc.
Just finished making all the frame to axel measuremets --
With the Reese slider (Reese has a slider conversion for the standard 'A' frame 15K model)-if you locate the front 'L' brackets 'rear edge' flush with outer welded frame member 'rear edge' (easily seen behind the wheel and slightly forward)and match the 'L' bracket front centered sloted hole to the rails #1 row (the rows are numbered 1 & 2 in the front rail and 3 & 4 in the rear rail in Reese IM) outer square hole, that will position the front rail such that the Hitch Pin in the 'Towing' position with be 15/16 behind the Axel. Moving it more forward than that will most likely require droping the fuel tank to allow drilling the hole and to get at the 'L' bracket mounting bolts.
Will drill the holes and install mine this weekend -- Pull older 32' Hitchhiker.
75v
..high pressure oil...and firmer shifts (I know you didn't mention) are just typical of any car until it's warmed up.
- Tim
cowboyjohn
