My jeep when turning into parking spaces or any other sharp turn the front wheels act as if they are locked up. I can hear a grinding noise and the wheels hop it is worse on hot summer days. Any insight into this problem would be greatly helpful.
I would try to tighten the belt. It may not be tight enough. I had a similar problem after changing my power steering pump. I was positive that it was tight enough but was releaved to easily fix the problem. Good luck.
I can't believe there is a message board for this stuff....who woulda thought? But I'm glad there is. My 93 GCL, which has had many, many issues in the past, :lemon: and currently has many other issues...is now leaking transmission fluid like there is no tomorrow. Most days there is a 3'x3' section of fluid on the driveway at home or work after it has sat all day...however, it seems to have an endless supply of fluid. Owners manual states it has a 10qt. capacity....I have only had to add 1 qt. in the weeks it's been leaking..it's started as a very slow leak about 2 months ago. I took it to Bob Sumerel last Friday, hoping it would just be a seal or something around $300 or less.... they told me the transfer case and the transmission seals were leaking. To repair the seals the whole tranny would have to be pulled and with the amount of labor I may as well have the tranny rebuilt. $2500-3500 for everything. This poor girl has 200K miles on her already.. Not to mention I owe money on the beast.. I am taking it to another shop wednesday for a 2nd opinion. Everyone thinks it should/could be done cheaper. I have no idea. It already has many other issues that need addressed that I just can't afford to deal with. :sick: So if this issue is gonna really run more than say $600.....I'm gonna have to sell it and cut my losses, as much as I don't want to. Does that quote sound high for a rebuilt transmission? Are the seals really that difficult to get to? I get crazy price ranges from talking to all kinds of people...need some input. Thanks so much!
Thanks. Any other ideas what it could be if that doesnt check out. I'll mention that to my dad tomorrow. Its just driving me crazy. I love the car. But the screech. Hopefully that'll fix it. Thanks again
def. buy a jeep, we own 3...98 5.9 limited, 99 limited GC, and a 95 cherokee every jeep is over 130,000 mi and are still perfect ........cant be happier with the power and comfort. we also own our own garage and obviously if they were a trouble some car we wouldnt run them
I called Chrysler and received a Ref#. I asked to speak with the District Manager and they said that my dealer needs to contact Chrysler and they would have to arrange a meeting with the Service Rep. I am now currently waiting to hear from the Service Rep. I have had the vehicle to the dealer 3 times and will file for the Mass Lemon Law soon. If anyone is experiencing the same bucking and stumbling problems with their Hemi powered Grand Cherokees please complain to their dealers. Possibly a class action law suit is in order if the problem is not addressed.
My 2001 4.6L is having the exact same idle issue. The dealership (that I sincerely trust) told me that there was excessive carbon built up on the fuel injectors. They can clean them for $189. I have not had this done yet, but am instead going to try the fuel cleaner additive.
Ok, so what does cause the honk and vibration from the steering wheel when turning right at low speed? My '97 GC has suffered all the same problems as you guys, only we don't have garages to rip us off here and so do all our own maint. I've adjusted the steering gear and changed the fluid - no improvement - thinking to change the gear ($$$!!!) unless there's a quick fix anyone can recommend. The brake rotors will last longer if you keep the caliper pins lubed and don't let the tyre shop monkeys over tighten wheel nuts (use a wrench not air ratchet) - sounds strange but seems to work! The trannies seem to get replaced a lot. I've just worked on mine (42RE) due to slippage. There's not much to the job if you've the basic mech skills, but the quality of the tranny components is not the best. The rear clutch discs wear out quickly if you don't change the fluid regularly (20,000 kms). Rear differential noises will improve if you put in the synthetic lube and additive. Drill an access hole and fit a plastic hose to the air-con drain so it flows out to the wheel well and stop water draining into the frame and passenger side. This car has cost me way too much in spares.....but I still love it. This forum is great, best wishes and Go USA!
My '93 Grand Cherokee keyless entry and cabin lights failed at the same time. The interior lights stay on all the time, and the remote entry never works. Along with the remote entry, the security system is never enabled. This all happened at the same time. All I have been able to do is remove the cabin light fuse to keep the battery from running down. I hope it is just a door open/close sensor. :confuse:
My 2000 GC Limited with the 10 CD changer has been doing the same thing. Sometimes I can get 3 or 4 of the 10 to play, (not the same ones each time) and sometimes none at all. I tried cleaning the laser with a laser CD cleaner disk and finally got the CD disk to play but no improvement. I tried an air duster (blowing compressed air into the cavity) but that didn't help either. I even tried buying a new magazine from a dealer (around $50 !) but that didn't improve things either. Any other suggestions out there? It seems to make no difference whether the CDs are home-burned or purchased. Sometimes they play, sometimes they don't. Doesn't make any difference whether the car is moving or not.
I have a 97 GCL and I just got an estimate for what sounds like the same problem. My estimate was only $400! So I feel better about that and am going to bring it in tomorrow to get the work done. I'll have to send an update!
I am at this point in the process. I brought it back many, many, many times. It still bucks...etc. I am to meet with the District Rep. Tuesday, June 21. I have made up my mind I will go to a Lawyer unless this guy fixes this Jeep. I am not going to even listen to any excuses, or denials. If they can't fix it. That means they did not give me an acceptable product for my money, so my lawyer will do what he can. I am asking you jeephemi, would there be away to get everyone with the problem together? I see alot of people on forums, complaining about it.
Jeephemi, Our stuttering, bucking and hesitations, are not the same problem as some of the others. Our transmission is different, we have the 545rfe not the one with water in it(nag1). Our problem must be way deeper 'cause they won't even turn a nut or bolt to try and fix it! The 2005 Jeep hemi problem does not have a TSB. I wish it did. I just want to make that clear. But I am still totally, upset. I have no words to describe how upset...Like no sleep..upset..like my wife don't want to hear about it anymore upset......day after day.
The only problem I am having so far is that I get a squeeking noise when I turn my wheels all the way to either side and I am averaging only about 11 to 13 mpg in mixed city / freeway driving. I have also noticed that my transmission likes to stay in a low gear. Does anyone have any advice on these issues?
I am replying to my own post, but I made some progress with the keyless entry that does not work, the security system that does not engage, and the interior lights that stay on all the time. Last night I was poking around the relays and found that if I removed the Illuminated Entry relay (90% sure correct) the dome lights turned off when I shut the door. The relay didn't seem to be bad, so I after staring at a "few" wiring diagrams I think the problem is at the Security System Module which, as far as I can tell, is located somewhere in the car.
Has anyone looked at the compressor to find out if it is spinning too tight? If so the extra load could make even a new belt slip to the point of a squeal. Just a thought
I had the same problem. I did have cv joints replaced, but I found the locking up while turning was only fixed by replacing the front brakes. I did this myself for about 15 bucks and it imediately made the car more nimble in tight spots. I have a '94 JGC Laredo. Somehow when the Brakes get warn the tend to get into a bind. It wouldnt hurt to replace the rotors either while your at it.
I have the same problem with my 1997 Jeep Grand Cherokee - did anyone ever reply to your posting? I'm wondering if it is a big issue that needs to be fixed.
HI - I'm having the same problem. 97 JGC and fan stopped working - works when directly wired to battery - all fuse's are OK - don't know where to go from here. I've also heard that it might be some sort of module or relay - but where is it?
Hey man, I have a 99 JGC and had the exact same problem, but with the drivers side. This problem was always intermittent, but now it's only warm air and doesn't change. The only way to fix the problem would be to take your dash apart and get to the heater assembly. The problem is that your blend door is stuck in one position. You can get the error codes by doing the following: Turn your key to the on position and hold down the A/C and Circulate buttons at the same time. Then turn one of your temp dials clockwise. This will make the display flash some codes. I think mine showed 19, 42 and 52. I found these codes in the Haynes manual. The codes read something like Door travel is too small. 50% or the dealer cost will be for the labour to take apart your dash. The other is for a new assembly. If you or a friend are mechanically inclined just get to the door and find out what's causing it to get stuck. I'm working on mine this weekend and I'll let you know.
jkram, I think you have a good idea about getting people with the problem together. I am now waiting for the Service rep to return a call to the dealership. I was told she is on vacation for 2 weeks. I drove a new Hemi last week and it did not drive nearly as bad as mine. The stumble was very, very slight. I think with a few miles on it the stumble will get worse. I have a fear that the problem may be with the cylinder deactivation. This could be very costly for Chrysler and I think they don't want to admit it at this point in time. Let me know if there is a secure way for me to contact you, we need to talk.
I am having a problem with my 05 hemi grand cherokee. The dealer installed the wrong type oil, much heavier than the required 5w-20. My lifters are now very noisy. Has anyone used anything other 5w-20 in their hemi Jeep without problems? Will a simple oil and filter change quiet the engine back down? Does anyone know why the multi displacement will not work with anything other than 5w-20(per the owners manual)?
2005 Laredo with the 4.7 and 545 xmission with the 35 mph stumble problem when in higher gear. Downshift and it runs fine. Can make it fail by driving 35-40 mph in a high gear and starting up a hill. Can feel it normally up to about 60mph missing and stumbling occasionally. Will be the 3rd visit next week at the dealer's. 6k miles.
I looked at your profile and your contact info is private. My last post was moderated out because I did not follow the forum rules, my fault. I don't want to get thrown off, because it is important we let others see what is going on with our Jeeps. sincerly, jkram
OK I took my glove box out and found the Actuator (electric motor) that moves the blend door. I unscrewed the Actuator and I can manually turn the door and change the temp. The motor is seized so the door is stuck on cold air. This motor controls the temp for the Driver and middle vents. If it's the passenger side with the problem it will be more difficult to get to the motor as it is located on the side closer to the engine. Your local Jeep dealer will be able to show you the parts diagram. Just tell them you need a price on some A/C Heater parts, but don't know the name and you think it's a blend door actuator. They printed out a diagram to show me the parts and the ridiculous price. Best bet is to go to an Auto Wrecker. Dealer is $160 CDN for Actuator. If it's the temp control unit it's $650 CDN.
I got a 98 JGC. I recently started noticing water builing up under my clear passenger floor mats. It's the a/c drain that's clogged. In detail where did you drill the hole for the plug? Do you have any pictures you could send?? Thanks for any help.
Sorry, do not have any pictures even if I could figure out how to post them. On the passenger side firewall directly under the dash assembly is where it is located. Pull back the carpet (you may have to remove some of the plastic footwell trim on the right) and you will see it high in the center of the passenger footwell. In my 97 JGC it is a round black plastic piece with a y shaped plastic at the top. I drilled the hole in the center of the round piece. This will give you a clear view out the front of the forward facing drain tube and also give you access straight up to clear the tube coming from the condenser. I found a bit of debris in this area although so far I still am getting drainage in to the footwell. I am going to try drilling another hole up higher in the condenser area to see if there is more that I can clear out. I will post any major successes or disasters!
I had the same problem w/40k on our 99 Jeep Grand Cherokee 4.0L-The dealer replaced the cooling fan for $400+ and 6mths later same problem. I replaced the cooling fan relay behind and under the right front headlight assembly-still no fix. We were getting nervous at stop lights and drive thru restaurants. I heard through the grape vine at the dealer that the fan harness plugs were shorting out and I purchased two bullet connectors-cut out the plug and VOILA!! no more problems.Now we can sit still @ lights and drive thru restaurants and run the A/C full blast. Hope this works-unplug your harness look into both sides for signs of a shortage.
I had a simaliar problem but the whole left side of my GJC stopped working I took it to the dealer and he stated the jeep has 3 internal control computers the one in my left door was frozen. It was $368 for a new computer and $60 to possibly unfreeze it
I'm having the same problem with my 03 GC Ltd. It just started a few weeks ago. I have had one mechanic drive the vehicle and he is checking the Tech Service Bulletins (TSB's) now. He said that these models have a hydraulically driven fan motor that share fluid with the power steering pump. There are some potential area's in that setup that could cause the problem. Mine whines more when turning left than right, but occasionally when turning right I feel a slight "roughness" or vibration in the steering wheel also. I can tolerate the noise but want to know if I have an impending power steering pump failure or something serious like that. I have not noticed any problems with it overheating, in fact I have been impressed with how cool it has been running in June Mississippi weather! Hope this helps, I'll try to remember to post the solution when we find it.
Again, I am replying to my own message, but if anyone else has the same problem, here is what happened.
Simple, the Keyless Entry Module blew up. The Keyless Entry is a circuit board located in the overhead console/dome light. When it blew up it sent a signal to the Interior Light Module (located in glove box panel) telling it that the 'Unlock' button was constantly being pushed, so the lights were always on.
You know how you hit the unlock button and the dome light comes on.
It was also telling the Security Alarm Module (also in glove box) the doors were unlocked (constantly), so the security was never armed, even when you hit the electronic door lock.
When I removed the cajun style (blackened) Keyless entry module, everything returned back to normal. Now all I have to do is see if I can get the dealer to get me a new one.
I hope this helps you guys. My first thought is power steering belts. During humid times (or very cold temps) you'll notice squeals around every parking lot. That's pretty normal. Some tricks are to never turn the wheel all the way until it stops and to not turn the wheel while the car is not moving. If you have already checked the belt and it is not noticably loose these tricks should help. If you know it is not the belt then I do not have any suggestions, except that I am pretty sure the steering pump cannot squeal on its own.
Oh man exactly same with the "roughness" too. I can feel it on my right arm from the armrest (the CD container). I don't turn the wheel all the way though..
My son drives a 98 jeep grand cherokee ltd. . For the last 6 months on occasion, the power options will act up and do strange things. then all will be ok again for a while. Also on two occasions the jeep will not start . We have taken it to a dealer and they cannot find the problem. Then next thing you know it starts ok. Any similiar experiences /fixes?? thanks
I have a 93 JGC laredo and had the exact problem. After 1200 $ and changing many sensors ( which did not fix the problem), I realised IT WAS THE CAP ON THE HT COIL COMMING LOOSE DUE TO HEAT EXPANSION (THE HT COIL SITS ON THE SIDE OF THE ENGINE, REMEMBER). ALL I DID WAS USE A TIE WRAP AND BELT BOTH CAPS ON THE HT COIL TOGETHER. ALSO CHK THE engine is not heating beyond 110 deg C. DONT SPEND ANY MONEY ON ANYTHING ELSE.
Hi, This is a simple problem which I solved by changing the HT coil and TIE wrapping both caps of the HT coil. This is what fixed my issue after changing a bunch of sensors @ 1200 $.
Presently I am dealing with the Death Wobble. SUDA
this is exactly what ours is doing. it used to stall at stop signs and lights, but after the crank shaft positioning sensor and cam shaft sensor were replaced, it stopped. but now it still stalls while driving down the interstate. the only thing that hasn't been replaced at this point (it's been going on a year) is the computer. i'll buy one if that will fix it, but trying to chase down the source of the stalling has cost a fortune. it's a 97 grand cherokee. after it the engine cuts out we'll coast to the side of the highway and usually the engine will come back to life.
we've blown out 2 mufflers from backfiring. now, we just tolerate the noise because it isn't worth replacing the muffler anymore. it backfires every time at least once or twice. mechanic said replacing the cam shaft pos. sensor should have fixed it, but it hasn't.
we're to the point where we're ready to ditch it or hang ourselves. can anyone please help?
I have had this vehicle for 7+ years and have had to replace the ignition coil on a regular basis. It started out every 6-8 months and has gotten worse. Changed two today! My wife can even do it now. We carry at least one spare at all times. It was running real bad at 1900- 2100 rpms. Changed wires, distributor, plugs, etc and thought I had it. Wrong! This is a 5.2 liter and a snapon scanner shows no codes but a big analyzer indicates low spark from the coil. I have had numerous suggestions, anybody got an idea?
I'm having a similar problem- did you ever get it resolved? I've had mine to the dealer three times now- they keep replacing the bulbs, but the same problem occurs- when the headlights and running lights are on, the running lights and brake lights don't light when the brake is applied
I have the same front end problem on a 95' Cherokee, my neighbor seems to think it's the universal joints in front. Not so sure about that. Have you found out what your problem is yet? My guess is that we both have Chrysler products.
Hi, My 1997 Grand Cherokee,4.0 auto transmission is having problems between shifts. Sometimes it drives normal and then sometimes it's as if it's in neutral. The vehicle must be brought to a complete stop turned off and then start over until the next time which might be 5 minutes. Anyone have any ideas? Thanks jk56
:confuse:
I am experiencing the same problem on a 94 JGC 4X4 Lim with 160K on it?
:confuse:
Mac
sincerly, jkram
Good luck man. Hope this helps.
SUDA
spark plugs, spark plug wires, rotor, distributor cap, ignition coil, fuel pump, fuel filter, map sensor, distributor (which included the cam shaft sensor), catalytic converter and muffler (twice), crank shaft sensor, ignition coal again.
this is in reference to my previous message, #1427
