We just took delivery of our Freelander HSE last weekend as a replacement for my wife's Saab. Although it is her truck, I can't wait to get that thing muddy
For the record, we have no issues with our steptronic tranny. I *think* we may have a bit of a hard shift from 2 to 3, but it is so subtle and non-bothersome that I don't plan to do anything about it unless it gets worse.
And also, this only occurs under the following conditions:
1) it is in regular D mode (doesn't happen in Sport or steptronic mode)
2) the throttle is only very lightly pressed; when accelerating normally it doesn't occur, only when you really baby the throttle.
I'm keeping watch, though
Not sure what's up with your Centre, but I would ask them to get the vehicle from another dealer's stock. Most will do trades to get the Freelander you want; although you will usually get the best deal buying one off the lot (even though you'll sometimes have to buy options you don't want, sometimes they're practially free).
I'm sure I'm not alone in this quandary. If anyone could share their decision points that helped them get past this uncertainty, I would appreciate it.
1. For any of you that have experienced the blown fuse on the driver's window, what has the dealer said with regard to a long-term fix?
2. Has anyone with the Harmon Kardon stereo replaced the stock head unit? Anything tricky about this?
Thanks, Steve
brandon
Steve
Chicago Sun - Times
Steve
But what really concerns me is the sluggish acceleration everyone is mentioning. How is it to drive in traffic and to pass on highways really?
Steve
1) the handling is very well done.
2) the interior fit and finish? What fit and finish!
3) the ergonomics? the pictograms for switches?
4) the engine and acceleration were better than reviews lead you to believe but you have to keep stirring the engine to get much motion.
5) interior space is at a premium. At 5'11'' my head rubbed against the headliner the entire trip.
What a worthless review. I guess like most national newspapers, I shouldn't expect a "hard" review. That may jeopardize the advertising revenue they receive from LRNA. Thank God for Edmunds.
(thanks for reading).
Steve
Sales of the Freelander have been less than expected, but have been picking up.
cheers.
Well, the Freelander has been the best selling SUV in Europe since it came out, so I'm not sure I'd characterize it as a misstep.
pluskin: Apples and Oranges my friend
"2002 Land Rover Freelander:
Front into flat barrier $932 / Rear into flat barrier $2,723 /Front into angle barrier $719 / Rear into pole $2,096 / Total damage 4 tests $6,470 / Average damage per test $1,618 / Bumper rating: Poor."
"The Freelander has a flimsy rear bumper bar and no foam at all to absorb crash energy. In both rear tests at 5 mph, the rear door was damaged beyond repair. Replacement of the door and glass, which shattered, cost more than $1,000. The electric motor that operates the rear window also had to be replaced ($337 for the part alone), and fender damage had to be repaired after the rear-into-flat-barrier test. Total damage exceeded $2,000 after each of the rear tests, flat-barrier and pole.".................
Luckily the new CRV makes these numbers look good.
Steve
"The CR-V's performance was even worse. It sustained more than $2,500 damage in each of the two rear impacts." and "Overall, the CR-V sustained about $6,600 damage in the Institute's four bumper tests, nearly double the total damage sustained by a 1998 CR-V in the same tests. "When Honda redesigned the CR-V, the manufacturer obviously didn't care about the bumpers. The result is that CR-V owners can expect a lot of costly damage, even in minor bumps," Lund says."
What this statement means is that because the new CRV tested worse with more expensive damage, the numbers for the Freelander, though very high, were not the worst. And being facetious; "look good"
My friendly local dealer told me that the kit's have been discontinued, but their components are available separately. The web site confirms this as they are no longer posted.
The brake and directional lights are mounted very low, in the rear bumper. There are running lights and backup lights mounted higher on the body, where you would expect to find the brake/tail lights.
The ultra-low positioning of the brake lights in particular meant that I almost never noticed them. After several near-misses I had to change lanes just to get out from behind the thing, because I really felt like I could rear-end him.
It seems bizarre to put running/backup lights in a prominent location where you would look for brake lights, and in turn bury those lights so low that they are impossible to see in bumper to bumper traffic. I'm amazed there is no federal regulation dictating brake light placement. In any event, the Freelander is downright dangerous to other traffic under such conditions. Beware.
Edmunds is reporting a possible two-door Freelander is in the works but the image shown is of a two-door English model which I can't see them bringing here (it is not particularly elegant).
Much thanks.
I must confess: my first thought was "Lucas electricals" and how I figured it was a malfunction... ;-)
Thanks for the response and the information.
Do you have a source for the information you posted which suggests that Land Rover "is bringing in the 3 door model for 2004?" I believe the Edmunds report suggests something may arrive in 2003. I am trying to assess what new plans, if any, that the company has to modify the Freelander for 2003.
