Can anyone suggest a less expensive alternate route?
I am not comfortable with just one set of keys for any vehicle.
And the rear window getting stuck. I swear this happened to me as well, but I finally got it to go up and figured it was user error as it had never happened before and hasn't happened since, but seeing others on this forum mention it convinces me it's a real problem.
An outstanding Sequoia by the way, that takes the place of two (2) cars for family trips. Talk about economy !!
Sorry to take so long to get back with you. I hope you have already solved your problem, but if not here goes.
You will need to go back inside of the rear hatch , sorry about that. Find the attachment point of the cable, it may have come loose. If it is tight in its hold down you can tweak the attachment point just a little and hold down by bending it away from the latch assembly. What you are doing has the same effect as shortening the cable.
Good Luck.
John
For the 2001-2002 sequoia, the key has a electronic CHIP different from 2003-2004, the remote is also different. both are cheaper than the 2003/2004. Blank key around $15-$20, remote is about the same price. The programming are little bit different. Both procedures are also available on this forum as well. Good luck!
alignment has been done by toyota
balance has been done by toyota
I saw a post on here suggesting the following alignment specs for an older sequoia:
camber: +0.25 degrees
caster: +2.75 degrees (4WD) or +3.00 degrees (2WD)
total toe: +0.08 degrees
do these specs hold true for the '05 model as well
When I took out the sensors from the wheel hubs, I noticed that there was an accumulation of rusted metal flakes built up on the magnets of the sensors. I cleaned the metal flakes off of the tips and reinstalled them. I had to reset the computer by disconnecting the negative terminal of battery. After I did thise, the VSC trac light stayed off.
To me this seems to be a maintenance item as I expect that the rusted metal flakes will accumulate to some critical mass over time such that it'll trigger the VSC traction light to come on.
Before you take it to a dealer, you might try cleaning off the megnetic tips of the sensors and see if it solves the problem for you.
Oh my gosh... :mad:
Could any one tell me what you have paid for your 30K service? If possible would you please also tell me what are the line items that you have done for the 30K service?
If I like to cherry pick the "must-have" items, what would those be?
Thanks for your help!
The service manager listened to my argument and said he would speak with the Toyota factory rep. I received a telephone call from the dealership that Toyota would repair the VSC computer for free. I am a loyal Toyota owner and the only other one I would consider would be Lexus.
Kudos to Toyota and my dealer for doing the right thing and fixing my VSC computer problem. Do I think the VSC computer will fail again? I don't think so because I heard from other Sequoia owners that the VSC computer was updated for later models.
I think the Sequoias are a fantastic vehicle and I will keep my Sequoia. I am a traffic officer and have investigated thousands of real world crashes. I picked the Sequoia because in my opinion it's one of the safest and probably the most reliable SUV on the road.
By the way, there's a website that sells computer parts to all makes of vehicles. See http://www.ecudirect.com/index.asp
The service center tells me that I should pay ~$310 , just to flush the engine and fuel system. They will also charge me the other regular 30K services for about $410.
Do I need to do this kind of service? any recommendation?
Any ideas on what could of triggered it. I pulled up to a stop sign went to pull out and no power to the power train, yikes. The engine runs fine, all the gauges read normal, no leaks, no runs, no errors. It just won't go. Now someone said pulling the neg cable from the battery will reset it. Turning it off and back on did not.
Unfortunately it is with the dealer and you know what that means, hmmmm, what is the most expensive thing possible - gee, that's exactly what your problem is. We'll have to rebuild your entire truck for a paultry $60K.
So any ideas are welcome on what I can test before relinguishing to the dealer.
My Sequoia had 107,000 when this happened to me. Only I was going 70 mph on an interstate when the car decided to put on the brakes and cut power to the engine. It was diagnosed by the dealer as a YAW rate sensor and a Steering angle sensor. We traded it in. Good Luck
Mine turned out to be the skid control ECU, according to the dealer. The part was $1800, with a couple hours labor to install. No recurring problems after a week...time will tell, though.
What really would have been interesting is if you had disconnected the battery cable for a while. Wish I had known to try that with mine first, before I took it in. I have heard reports on another forum of that working just fine (!!!???)
Don't know anything to tell you, except ask the dealer if he thinks Toyota could help defray the cost of the part, if it turns out to be expensive, like mine.
I used a scan tool to check for codes but there is no fault code returned. the VSC, TRAC and Check light is still on. Any ideas
Drive on ..........
Also anyone have trouble with the rear window not going down?
Regarding the tires,
- tires are rotated every 5k miles
- all scheduled maintenance performed
- 35k miles on vehicle
- tires kept inflated properly (the uneven wear is not 'cupping')
- I have never hit anything major in the vehicle
- noticed outer edge wear with 25k on it
- I don't think alignment should be an issue with 20k miles from normal driving.
- had alignment done at 30K
- No improvement whatsoever. I think it actually got worse
I have also seen posts on this or other discussion forums noting similar problems. Whenever I see a new Sequoia parked ('05 or newer), I have a look at the tires. Given I do not know the mileage on them, most of the ones I have seen have outer edge tire wear issues. I have talked to a number of different service people at Toyota Dealerships in Atlanta and they have denied it is an issue in most cases.
I think it is an issue with the vehicle. I have gone switched Toyota Dealers (Service person noted she sees this frequently) so I will see if they can get this resolved. My tires are about bald on the outside edge but probably 25K of life remaining on the rest of the tire. Not looking forward to the $800 bill for new Michelins.
Regarding the rear window, I just kept messing with the switch and the rear window worked again. I have not had problems since.
I would definitely be interested in others experiencing these issues.
Regarding alignment specs, one of our blog colleagues had what I believe was revised specs about a year ago. I could not find it back. At 77K I have had no outer wear issues. First set went 50K. I run a minimum of 36 psi. More at the rear when loaded. This is a 2002 Lmt 2x4 rather than the 4x4.
Had the factory upgrades to front suspension, ball joints etc. the brake upgrade, replacement of the solenoid for the rear window under warranty. The last time the window stopped going up or down, the service manager correctly said the brushes on the electric motor will hang up. If you can tap the motor (which I did) it will often go back to work. It did. This can happen more often if the window is not lowered or raised very often (my case). Basically I seldom lower the rear window, which avoids the issue of not being able to raise it.
The rear latch outer handle just broke and was replaced at the dealer (out of warranty). I was aware of the latch handle being plastic and weak, however it was my grasp of the handle without unlocking the rear hatch that snapped it off. Otherwise no mechanical issues.
Agreed on the slight bump or movement after stopping. With the microchip controling so much of todays vehicle's operation, it does not surprise me that there are occasional changes in idle, shift points etc. at unexpected times.
As you know to minimize warping of the brake rotor's, it is a good idea to allow the vehicle to move forward slightly after stopping to not hot spot the rotor's. Typically not a big deal around town but in hot weather with agressive braking (mountains) and then stopping at a light with the brakes held firmly in one spot, warping can occur. The first thing to check if pulsating of brakes (warping) is felt is to have the lug nuts appropriately torqued in the correct rotation to determine if that is an issue, before the rotor's are turned, (shaved).
Enjoy and travel safely.
1. Bright indicator does not work-- been happening for about 3 years.
2. Gas empty indicator will mysteriously go on-- even when the tank is full. Seems to be a random occurence. Been happening since 2002.
3. Dome lights some time come on when turning right-- last six months.
4. Recently, the door ajar light comes on randomly and the dome lights come on simultaneously.
In the last couple of weeks, these weird events have been draining the battery and we have to jump start it. Been to the dealer twice and the car is there again. First they said bad connections that were cleaned, second they said bad battery, now they seem to be at a loss. Anybody have a clue?
Lets not forget the Traction Control problem!
