The first oil change is at 20K miles. The car uses synthetic oil. There is no reason to change the oil sooner. In fact, all you really need to do is change the oil at 20K miles. If you take the car in, they'll check the fluids, and charge you $740. Why not learn to do it yourself?
The brakes last a long time on the Cayenne, something on the order of 35K to 40K miles, on par with any car. The real expense comes from replacing the tires at 20K-25K mile intervals. You can do better if you don't run the 20" tires. Other than that, if you can afford the gas, the Cayenne shouldn't break your wallet to run.
CL 63 AMG boasts the most powerful naturally aspirated V8 engine in the world.???
I dont know much in details about car engine, can any1 tell me whats the difference between the naturally aspired and the twin turbo??? i know the twin turbo engines are fast but what else is the difference, i wanna to know in detail.
I want to know everything abt it how does it feel while driving whats the power difference whatever info u guys got....... all kinds of info will be appreciated
Actually, I have some first hand experience with that one - If you buy any of the v8 Cayennes, then brakes are not an issue - if you buy the v6, then the suspension and brake parts are all from the Touareg, and they have major problems with early wear.
The rotors and pads on the v6 are all wrong for a vehicle this size.
Porsche Cayenne S Transsyberia Chews Up Punishing Route
<img src="http://a332.g.akamai.net/f/332/936/12h/www.edmunds.com//media/il/news/2007/0416/porsche.transsyberia2.500.jpg
I do not know about the 2008...but your dealer would have the final say/answer. I would ask them.
2004 Cayenne now has 40035 miles on it....doing nicely.
Yes...expect wear on the tires...since these sport utes stop on a dime...thus there is increased tire wear. I sometimes use the gears to slow the car down...
2021 Toyota Venza Limited Hybrid, 2022 Ram 2500 Laramie 6.4 Hemi, 2007 Mazda MX-5 Miata PRHT
Chevy used the Cheyenne name on some trim lines on some trucks plus they have a concept truck by that name.
I am just under 60K miles now, bought an extended warranty out to 100K.
(2). Will people suffer on the back seats?
(3). Do people feel the driver seat comfortable at all?
1 - 70 is barely breaking a sweat for this vehicle and the RPM's are so low at that speed it is very quite. It's well insulated as well so wind noise is not an issue. The only noise you may get is from a set of performance tires near the end of their life.
2 - Back seats are good for 2. Anyone in the middle would suffer with the large drive shaft tunnel.
3 - I find the drive seat to be great. Firm but good and with lumbar adjustment it's great on the back.
JR
We had a baby in the back seat, he slpet the entire way...
The driver's seat is awesome. Good support and the lumbar support is nice, too.
All in all, one of the best "road trip" cars we've ever owned.
I know Porsche-lovers like the Porsche engine vrrrrring. But I doubted it would be enjoyable for family rides. Based on you guys experience, I think I should not worry about it. I will go for a test drive for Cayenne and trying to persuade my wife to OK a Cayenne instead of X5, together with my little boy who is a Porsche lover for some reason.
I also have a 2005 Cayenne S...I went from 20 inch to 22 inches. As, you suspected it has improved the ride (smoother), handling and stability.
You might want to put gyf's response in context. He's in Hawaii and, according to a post in May, 2007, had just got the 12,000 mile service on his 2005 Cayenne (<6,000 miles/ year?).
I started an Edmunds forum titled "Are larger wheels/tires a waste of money". Obviously, the answer is highly subjective, but the question came up when a friend of mine bought a 2007 E350 w/ Sport package and we did the calculations on his expected tire replacement costs over a projected 6-7 year/100k mile life of the car. It essentially went from $2,000 with the standard 17" wheels and rotateable V rated tires to $8,000+ with the 18" wheels and staggered size W rated tires. Considerably more than the additonal gas he would have spent, had he gone from the E350 to the E550.
I haven't spent much seat time in the Cayenne S but, from my experiences, it already handles as good as or better than just about any SUV out there on the standard 19" wheels. I would simply advise that, before you jump up to 20/22" wheels and tires, you make sure you do the full cost benefit analysis. Including the higher frequency of tire replacement (softer compound, lower profile tires).
And also consider that, if you don't happen to live in Hawaii or a similar climate, most "W" or "Y" compound tires will become harder in lower temperatures and will severely adversely affect your traction in snow or even cold rain. Not to mention, give you a rougher ride, NOT a smoother one. That has been my unfortunate experience with my Acura TL 6-speed with the "summer tire" package.
I have a 911S, so I do appreciate handling and performance. We may also be trading our MDX for a 2008 Cayenne this fall. But as good as the Cayenne is, I won't forget which one is the sports car.
I own a Cayenne and ordered it with the factory 19's and bought a set of 17's 'take-off's' for the winter.
I can say the difference in handling with the 19's is noticable over the 17's, but even with the 17's the Cayenne is a great handler given the size and weight. I just put a new set of 19's on and it's not cheap but not over the top either. However, the Cayenne has a limited range of Porsche N-spec tires that are OK to use on the Cayenne so the choices are limited. I went with Pirelli's for mine.
I can't imagine the ride getting better with shorter side-walls on tires up to 22', in fact, I would expect it to degrade with perhaps minor handling improvements.
One thing I can say for sure is that the Cayenne is hyper-sensitive to any imbalance in the wheels. Anyone buying tires for this should look for a shop with a Hunter Road-Force balance machine or they may be un-happy with the results no matter the tire size.
Anyway, I find the 19's a good compromise between handling, cost and performance and having my 17's for the NY winters allows me to use the Cayenne year round.
JR
SUVs and Smart Shopper
Any views on this color? Do you think it would re-sell well?
Try going on line...several available there...
1. Are there any recurring issues with this vehicle that I should know?
2. Does stability control, Electronic brakeforce disribution and 4 channel brakes come standard (I have the preferred package).
3. Does the warranty cover wear & tear items or just the traditional bumper-to-bumper mechanical failures? I have the extended certifed pre-owned warranty.
4. What maintenance is really required and how often should I expect to change the brakes/tires? Additionally, why $200 for an oil change?
That's it for now. Any help I can get here is greatly appreciated. BTW, germancarsforums.com isn't really that good. Edmunds forums are very good and I owned several Acura's where acurazine was very good as well. Can anyone recommend a good Porsche forum other than edmunds?
yes....i am around,,,,but due to work, home , family, etc....i am here less....
all is well with my cayenne....
I also got the 100K warranty.
one quick suggestion.....You can get cheap , inexpensive tires from internet , either on ebay or craigslist... for your cayennes.
There is a set of 19" wheels and tires for only $300 in dublin, CA.
I am sure happy that we only need oil changes every 15,000 miles....
take care...and see you around....
2- they should be in your owners manual. Some cars have different options than others. I am not sure about cayenne base.
3- warranty does NOT cover wear and tear items.
4- Engine should run with no problems , just simply follow maintenance schedule. You do not need a $200 oil change...
I buy my oil at Autozone or costco, and go to the local oil changer...whom I know well and they change out everything for me..... I go to my trusted mechanic for some routine checks....and back to dealership for major checks....
Dows anyone know what can be used cheaply & easily to increase HP on the 06 Cayenne Base?
Live in England...... Many Thanks
Also want to install ipod & bluetooth....any suggestions ??
Tnx-u
