Oil Filters, whose is best, and Why?
It kind of makes you wonder who made it for them.
--- Bror Jace
Any experience this issue with other filters or go beyond 6 months with a filter. I recenly went 12 months on a fitler, analysis fine but the filter is a vertical mount! Drain back immaterial.
about $5
Chris
"but the dealer said not to use synthetic because it is a waste of money"....cracks me up. Ask to see his high school diploma first. Probably can't
A few years back I worked P/T at a Wal*Mart auto center. Most of the people their were compitent (me too), but quite a few were idiots! Many times they would use the wrong filter, and three cars got new engines (that I know of) becuase of it. A lot of cars rolled out of there with no lubed chassis, and the same filter it came with. They used Fram filters which are among the worst. They're own brand (Super Tech) is a better filter!
I thought about going to synthetic and changing it once a year. I usually drive my car at least 10 miles each way. I am not sure how the warrantee would be going only once a year though. 6 months might be safer bet.
Reasons for the low mileage is because I ride a motorcycle when the weather permits. This is ranges from once a week average during the winter months to near daily during the summer. So during the summer the car sits around alot.
I have changed my oil in other cars in 4 month intervals. Sometimes with as little as 1,500 miles. Always used conventional oil and even with only 1,500 miles in 4 months the oil has a strong smell of gas and the car runs a little smoother when changed. Maybe the synthetic would offer better protection for my type of low mileage driving conditions.
Chris
I've owned a lot of cars thru the years where the manufacturer promotes their own OEM brand, but this is the first I've ever seen one give specific warnings to watch for with other brands. There is no further explanation in the manual about the Ford design specifications that prevent engine start-up noise.
Maybe Ford reads Edmunds oil filter post.
Almost all filters meet or exceed OEM specs
Also, they are laid back on the rules about visitors in the shop area, and I am allowed to hang around and watch while the guy does the work.
That last part is very important to me. I don't trust anyone to do my oil changes if I can't personally supervise the job.
They give this deal on any make of car, and it is not just for people who have bought their vehicles there. What a great deal, huh?
tom
looked good otherwise. good price too
It also gives efficiencies at 98%(single pass) and 99%(multi-pass).
Also interesting is that it now contains"special synthetic fiber-enhanced filter media".
It also is a dead on look-alike to an ACDelco I got at Autozone.Looks like a good filter.
Wal-Mart housebrand oil is Quaker State. I probably shouldn't have anything to do with a company that is associated with Fram and various types of snake oil, but my only rule of thumb is to avoid Fram oil filters at any cost.
Also, Champion Labs does an excellent job in constructing filters.
tom
Looked pretty good. Every component was of really good quality and the filter cartridge inside took up a great deal of the internal volume. The spring was an impressive coiled piece and I kept it. Now I have to find soime way to use it.
Anyway, I was impressed with this filter overall and a little relieved since I bought a number of these based on reputation. >;^)
--- Bror Jace
I was very surprised when I saw the specs for this paper. It was much heavier than the typical medium for auto oil. The combination of the heavier weight and the synthetic fiber content makes this a real nice sheet of paper for such a low priced filter.
tom
armtdm, the spring as in the can towards the top of the filter and the diaphragm was attached to the base. Oh, and that base was as solid as any I've ever seen. I tried sawing right above the place wherethe canister joins the plate and after having got 1/4" through and saw nothing but steel, I gave up and had to saw further up the filter's side to get through.
--- Bror Jace
Here's my search when I looked for an oil filter for our 2k Villager Sport. The Puro-Prem number was L14612 (2yrs ago). First time I saw it I said no way to that short can. I emailed Purolator if I could use the old Pathfinder filter L1620 (a longer can). I was told that the new filter in that application (3.3-v6) was the short L14612. Now, they have it revised to an L14610 (of which I haven't seen yet).
I have been using the longer AC-Delco PF2057, and will switch to the Bosch-3323 in my next dump (as it's more available). It appears to me they at first went to the short filter for the 3.3-v6 off-road (Xterra/Pathy) application, which is not a ground clearance issue with a Villager/Quest minivan. Thus applying an across-the-board inventory for the NIssan 3.3-v6. Besides, the original (Motorcraft/Nissan numbers?) filter on the van then was a longer one. That clearly tells me the short filter has but one only benefit - ground clearance.
By the way, how much is the Supertech?
2. Cardboard endcaps.
3. Cheap anti-drainback valve
4. Cheap plastic bypass valve.
I'm sure there are other shortcomings.
