Some of you posted that you talked to your regional rep, and had the problem resolved. How do I go about doing this? I really want a different alternator in this car. I don't want to have to change my battery yearly, and the fact that the car isn't working properly really bothers me. Any insight would be greatly appreciated.
2> Write or call Hyundai Customer Customer Care (The contact address and phone number are in your "Hyundai {whatever year} Owner's Handbook & Warranty Information" pamphlet.) to set up the meeting yourself. Expect the meeting to be at their convenience, not yours, since the reps like to schedule them with dealers to allow a number of issues to be dealt with every once or twice a month for efficiency.
Did anyone change the transm. fluid and filter on a 2002 Sonata GLS? My car dealer is about 30 miles away and I would like to do the job my self.
This is my first foreign car. I have been doing my own maintenance (on American cars) for 30 years.
Your input would be greatly appreciated!
Jim
The following week I had to take it in as the belt was squeaking, and they adjusted the belt, gave it an alignment and said all was well.
The following week, I had to have it towed in as the knocking noise from the engine scared me half to death, I didn't know what was wrong. They said they needed to replace the belt as adjusting it hadn't fixed the problem. Driving it home after this it seemed to have regained some of it's pep and the air conditioner ran cooler.
Has anyone else experienced any of these problem? Isn't it unusual for a belt to be bad at only 300 miles?
I need to take it in again this week in order to have the gas gauge fixed as it still never goes all the way to full. It goes to 7/8 if you fill it and then within 50 or so miles it is down to 1/4 of a tank. They told me to bring it in at at a 1/4 of a tank, and I asked which 1/4 the real one, or the one it says, as I wouldn't know when it is really at 1/4.
Is anyone having any of these problems?
I plan to follow your advice in a few months.
The socket size for the drain plug is 15/16 of an inch (or 24mm). I used the 15/16 because that is what I have available. If you are willing to buy it it costs around $4.00
Many thanks again.
Take good care!
Elantra Owners: Problems & Solutions.
If you're still having the light come on, take your car to a different Hyundai dealer. Any Hyundai tech worth his salt would know to hook up the diagnostics scan tool and read the malfunction code(s) that are stored from an initial "Check Engine" light event to have a reference from which to further diagnose the problem(s). The onboard diagnostic code generators common to all current cars are a great idea, but it still takes good ol' fashioned sleuthing skill to come up with the final diagnosis.
If your complaint currently is the fluctuating HVAC blower speed, you may or may not really have a problem. Some fluctuation is to be expected in heavy stop-and-go traffic with the blower on high and the air conditioning operating. These are high electrical load devices and can tax both battery and alternator at crawl speeds. However, if the starter motor sounds like it's laboring to start the engine, you may have an undercharged or defective battery. If the battery is undercharged, there could be numerous causes including poorly tightened cables at the battery, the alternator, and/or the starter motor. But, it could also be more complicated including a faulty alternator, or even the starter motor - which would put higher demand on the battery to crank the engine at startup. All of these devices CAN be tested on the car, and Hyundai's shop manual details the individual procedures how to do it. Doesn't sound like your dealer's electrical tech(?) wants to bother which is why I initially advised seeking out another Hyundai dealer for help.
And, if there's a constant under-voltage in the electrical system, THAT could also be responsible for (wait for it) a "Check Engine" light event in some cases.
Any suggestions?
The issue with the gas gauge turned out to be the sending unit. The gauge would read 7/8 when full and then drop down quickly, it would show empty when it really had over 1/2 a tank left. They assure me that my gas mileage will improve since this fix. I was getting 17 mpg. then and about 18 mpg now. They also told me it needs to be broke in before the gas mileage gets better.
Since these issues, the dealership has replaced a "dryer" for the air conditioner which was recalled.
Now I have to take it in for the door handle. The inside door handle on the drivers side has started to peel apart. I noticed it when I cut my fingers on something sharp when opening the door. Apparently the door handles are made of plastic and have a coating of metal or thin heavy plastic to make it look like metal. Whatever it is, it is very sharp and sliced my fingers when I opened the door. When I looked at the handle I could see that it is white plastic underneath this chrome coating which is peeling off.
These may be nice cars and I certainly hope so, I'm going to be driving and paying for it for a very long time.
I bought it brand new in June of 2002 and have put about 32K miles on it since then. No major complaints, but one annoyance I was wondering if anyone had any insight on.
I received a recall this past Spring that had to do with an O2 sensor and the need for it to be re wired. I had this work done, and about 3 months later (This past June), my Check Engine light came on. It was quickly fixed by the dealer and the service tech mentioned something about the original re wiring job being incorrect.
About 2 weeks ago, the check engine came on again. As a side note, this happened 1 day after having the car at the dealer for its 30,000 mile service (Had it done at about 29,500, if that info helps). Upon taking it to the dealer, I had expressed my concern about this happening multiple times. He mentioned the fact that the car has 4 O2 sensors and I'm curious if they're malfuntioning one by one, or if there's something going on with the O2s that I'm not aware of?
Anyone else had this experience? If so, was it resolved?
Also had one other small problem. The last time I rotated my tires, the person doing said that he couldn't, because on the right front wheel, one of the nuts was on in such a manner that the lug etiher was already, or was about to snap. I took it to a tire specialist, who had to break the lug off and replace it. He mentioned that this was a common problem with Hyundias. Anyone else experienced it?
The door handles are plastic with a three-layer metal coating - nickel is bonded directly to the plastic, then copper, and finally aluminum, for final appearance, are successively electroplated to the nickel base. Copper is used because it has a much stronger affinity for nickel than aluminum does, but has a very strong affinity for aluminum, too. Done right, this technique is very durable, but if the plastic was not properly prepped squeaky clean prior to the base nickel overlay, the overlay (and successive metal electroplatings) won't remain bonded to the plastic. Hopefully your experience was a fluke and neither the replacement handles nor any of the remaining original handles will suffer the same defect. But DO keep the service receipt for the warranty replacement so that if there's further metal plating peeling, you'll have proof that it happened previously.
My experience with check engine lights is they are emissions related. Something must have tripped the computer when I excelerated. Since the car runs okay I will give it 50 miles to reset. If it does not reset I will take it to the dealer for repair.
I am a little concerned about whats going on. I called the dealer today and will be taking it in on Wednesday morning.
The dealership did a pretty good job. It was fixed within 1 hour and the gave a free car wash coupon and a complimentary newspaper. Not many dealerships do that. Even ones that sell much more expensive cars.
What I'm more concerned about from the symptoms you described is COOLANT getting into the oil. If you have a blown head or intake manifold gasket, water could be drawn into the intake manifold and enter one or more combustion chambers. (Bad News) It would be unnoticeable with the engine running since the vaporized moisture would mostly exit through the exhaust, with some blowby accumulating in the sump. (Bad News, too, but not immediately catastrophic*) But, once shut down, residual liquid would condense in one or more cylinders and would then act as a hydro-lock when you tried to restart.
*Coolant is not a good lubricant and will eventually cause main and rod bearing failure if present in the sump and being constantly replenished because of a leaking gasket. If your radiator coolant level is decreasing, and/or you got a milky, mayonnaise consistency glop on the underside of your oil fill cap, you got problems. Problems that are Hyundai's problems if your car is still under warranty and if you've followed your owner's manual's maintenance schedule religiously. Even if things seem OK, I'd suggest you submit an oil sample for analysis at your next change. An analysis will unequivocally indicate the presence or absence of water and antifreeze in the used oil. Well worth the $20.00 cost if it saves your engine or puts the kabosh on stupid dealer tricks. You can get a free sample submission kit by request from:
Blackstone Laboratories
4929 South Lafayette Street
Fort Wayne, IN 46806-2211
The kit allows legally mailing the sample for analysis. Their turn-around time is 48 hours from receipt and they email the results and forward a hard copy via snail mail.
(By the way, I'm not an employee, dealer, or stockholder for/of Blackstone, but I have used their services during the break-in period of my '03 Sonata.)
My sticker price was $18,900.. or very close to $19,000.
I think Sonata is a great car.
If you want a bit firm ride, have your tire pressure at 33 psi or 35psi. I think the mfg recommendation is 30psi, but it's way~~ too~~ soft.
I'm also a little concerned about my transmission shifting pattern. It seems to really wind out when I am going up a hill before it will finally shift. BTW, this is a 2004 Sonata GLS V6 with about 500 miles on it
Your transmission shift patterns are also set by the ECM. Not only that, but the ECM uses adaptive learning algorithms to tailor the shift patterns and shift quality according to -your- driving style. Pulling a hill would logically result in delayed upshifts since the engine's under higher load.
From the descriptions you provided, it sounds to me like your new car is behaving normally. I drive a 2003 Sonata with the 2.7 liter V-6, too, and it mimics the behavior you've noted. These "Delta" engines have proved reliable if not temperamental exotic powerhouses. At 500 miles your engine and transmission are by no means fully broken-in and won't be until after 20,000 miles. Most will have ocurred by around 10,000 - 12,000 miles, though. If you plan to keep your Sonata long term, then, with 500 miles on the engine, I'd suggest an early oil and filter change, by the way. The owner's manual does not advise it, but most break-in wear occurs during the first 500 miles and there are factory leftovers that are better elliminated than trusted to the oil filter for the duration of a normal oil change interval. Subsequent break-in occurs at a much slower pace. Your second oil and filter change should then be performed at the mileage advised in your owner's manual according to severity of service. Hyundai DOES recommend in the owner's manual to maintain speed no higher than 55 mph during the first 1,200 miles and alter the speed frequently to help seat the piston rings. (I suspect these days I'm about the only driver who bothers to follow THAT advice, though, but I firmly believe it pays off in lower fuel and oil consumption during the engine's service life, and also results in longer service. 300,000+ miles is not at all unreasonable to expect if the engine is maintained properly even when conventional motor oils of the minimal specified quality are used. I've settled in with Chevron Supreme "ISOSYN" 10W-30. Pennzoil with "PureBase", Mobil Drive Clean, and Castrol GTX are also excellent choices and are generally more widely available than the Chevron oil. All are "conventional" motor oils and all are purported to include molybdenum as an extreme pressure/anti-wear additive as well as zinc dialkyldithiophosphate [ZDDP] used in the same capacity.) Best of luck with your new car!
I have taken it well above the 55 mph range though, but never for more than a few minutes. I'm on my third tank of gas, and checking my mileage on my last fill up, I was getting right about 16 mpg. Hopefully it will get better
Has anyone out there experienced this problem? If you have did you solve the problem and what was the solution?
Any assistance would be greatly appreciated.
Yes I thought that it might be the torque converter. However, the slight change you mention is noticeable when negotiating hills. But the buck I am experiencing is much more abrupt, and it has only happened on straight flat highway? The engine RPM does stay steady when this happens. I have not changed the factory transmission fluid either. I read somewhere that a faulty O2 sensor or mass flow sensor could cause this symptom. Any ideas?
