You have a 10/100,000 warranty... and let Hyundai worry about the volume of polymers.
Any ways, the owners manual indicates that 87 octaine gas or higher should be used. Since 87 is the lowest grade available in my area, and also the least expensive, would you mind commenting about the gas octaine that you are using, and your experiences with it. Thanks in advance for any of your comments.
So what was the final price before Tax & License?
I appreciate your reply and it tracks with what my Hyundai service manager suggested shortly after I bought the car in Dec. The service manager said that his techs use 10w30 even on the new Sonata's despite the factory recommendation. Back then I thought the dealership might be using a one size fits all approach so I decided to follow the manufacturers recommendation of 5w20 when I did my first oil change. However, after reading your very persuasive post, I will probably switch to 10w30 year round. Thanks again.
According to Hyundai, the financing and $1000 deal ends this month, and my dealer didn't know what they will be offering in May. As we all know, one usually has a better chance of getting a good deal close to the end of a month.
BTW, my purchase was done in Eastern PA.
And thanks for the response regarding the fuel grade.
My car was doing pretty good until about two/three weeks ago when engine check light came up for no apparent reason. I simply took battery negative terminal out for two minutes, and put it back. The check engine light CEL was gone. But I noticed car was not starting in first self as it use to be for last four and a half years. I also noticed a surge sometimes if car starts after cranking few times. I suspected the fuel filter was not properly working, but after changing fuel filter, its still the same. I discovered a new way though to start in first self (crank), i.e., turn the ignition on and wait for two or three seconds until a continuous voice (probably fuel pump working) stop, and a click could be heard. Then turning the self key will start the car in first try. I still have to understand why surge happens, i.e., the engine rpm suddenly jumps to 1.7 or so.
Soh
The cabin air filter is behind the glove compartment bin. You'll need to remove the glove bin for access - a tricky procedure to dislodge the nylon chord that limits how far down the bin "falls" when opened. Once the bin is completely off, the filter, itself, is behind an access panel cover at the front of the A/C evaporator-heater core case. When you remove the panel cover, the cabin filter comes out with it. You then remove the panel cover from the old filter and install it on the new one. Slide the filter into its slot in the case and latch the panel cover, replace the bin, re-attach the travel limit chord, and you're good to go. Unless you enjoy solving puzzles, this chore might be better left to a service tech who's familiar with the procedure. (I made four abortive attempts before I finally figured it out when I installed a cabin filter in my cabin-filterless '03 Sonata GL.)
I read somewhere on here that you can have the dealer activate Speed Sensitive Locks. Is this true? I have an '06 LX.
Eric
msg :mad:
Hyundai WebTech
For those who aren't familiar with Hyundai WebTech, registration is free and the site's an invaluable resource for TSBs and shop manual text and diagrams across Hyundai's entire U.S. model lineup. Good stuff!
Thank You!
We're not? I've mentioned specific brands many times in my posts - such as Purolator, Prestone, TropArtic, Castrol, etc. I use a product manufactured by leather producer, "Eagle Ottawa" - who supplies leather to all three U.S. automakers, DaimlerChrysler, Ford, and General Motors in addition to BMW and Daimler-Benz in Germany, Ford-owned British Leyland in Great Britain, and Toyota in Japan, among others. Eagle Ottawa's leather care product is called, "Tanner's Preserve Leather Conditioning Cream", though it can be hard to find. It's surprisingly inexpensive, too. There's always the relatively pricey, well thought-of "Zymol" line of leather care products, too.
Thank You
Car has 44000 on it at this time. What are the suggested/needed things to be done now that it has more miles? Tranny? Spark plugs? Flushes?
Thanks in advance.
I just noticed today, my 6th day with my Limited, a small scratch on the hood up by the wipers. Hopefully it's just the clear coat but we'll see. Does anyone recommend any of those 'scratch removing' creams?
Still looking for comments on my previous post concerning what I should be looking at with an 04 with 43,000 miles as far as maintenance.
Would love to get a Fram Purolator or K&N part number. WIXfilters has it as part # 57061.
