My 95 aurora has hot and cold AC. Driver side blows hot, passenger side is cold.
Whats up with that? Any one out there had this happen to them? What did you do? :confuse:
If you run w/low refrigerant for too long - poof! The undersized A/C compressor dies.
Welcome to a $1200 repair!
--Robert
Thanks, David
Deb :surprise:
Henri
i bought my 99 aurora (92k mi) last year and love driving it-when it drives. i last year had the gm dealership change the plugs and they told me i needed to replace the plug wires @ $350, so i put it off. two weeks ago, the water pump gave out so i took it to a local garage and had them replace it as well as new champion dbl platinum plugs. upon getting the car back, headlights flicker when the car is off, and the parking lights stay on. the chime intemittently goes off as if the headlamps were manually turned on and the car is off/door open. the gas gauge when driving sometimes will register a full tank then drop back a few seconds later to the correct level. the car itself will not start unless jumped, regardless of whether or not i have jump started the car and immediately turned it off or if i have driven 100 mi and turned it off for 10 min. last night driving home (100 mi commute) got real light headed, and rolled up windows, only to smell a real funky sulphury smell, pulled over and pulled up the back seat and the underside of the back seat was very hot and there was a very strange noise coming from either the battery (i am pretty sure) or one of the fuse boxes next to it. I already took it once to the same garage that replaced the pump, they worked on it all day and were on the phone with chevy specialists, and then returned the car to me and said they didn't have a clue. the only other clues are that the other car must be revving in order for mine to jump, there is the tell-tale whine from the alternator via the sound system, and if i do drive for 10/20 mi, turn it off to gas and try to restart in 1-2 min it will turn over and eventually start, but it takes it 30-60 seconds of holding the key in the start position. any ideas? battery? alternator? plug wires? short? the green eye on the battery is bright green, and the info center while driving says the battery is charging to 14.2-14.8 volts. i really can't afford to take it to the dealer for "exploratory surgery" but can afford to get it fixed if at least someone might have an idea what is wrong. if not, i am trading/selling it in the next couple of days. thanks guys
I am having some difficulty following all of the issues you brought up. But, here are some suggestions:
1) Have the shop re-replace your spark plugs. Northstars work great with AC Delco plugs, not so with anyone else's. I'm not sure if this is your starter problem or not.
2) The "headlights flashing" problem is too much grease on your multifunction (turn signal, cruise control, headlight flash) switch. There's a procedure posted here on how to remove and clean this switch... do a search. I think the procedure is documented on howardm/dred98's Aurora page...
3) Is your battery hooked up to the vent tubes? If not, that could be a big problem... you could be getting explosive battery exhaust gases in your car. Not good!
4) Regarding your starting problem... does the car crank? Or does it just sit there with the key turned? Lights on/power good? If it's cranking but not starting, your Fuel Pressure Regulator needs to be changed. About a $50 part, use only the AC Delco, have them do it when they are putting the correct spark plugs in your car. If the car's not cranking, it could be a Security/PASS-KEY issue. Buy some contact cleaner spray and clean your key. Also used compressed air to clean out the ignition area. If you have a second key, try that. If your lights are flashing constantly, it could be this is killing your battery. It did mine. Still got the original in your car? If so, it may be time to change it. Again, use only the AC Delco unit (don't think anyone else makes a compatible battery).
5) Gas gauge... that's your sending unit. These do go bad over time. Mine will intermittently do the opposite, show no fuel at startup, only to jump back up when I start to drive (usually notice this right after gassing up). I use the Driver Info Center and don't look at the gauge that much, but again, in my case, it's right 98+% of the time.
Any other concerns, please post (and use returns to establish paragraphs). Let us know how the repairs proceed.
Hope this helps,
--Robert
If i decide to go ahead with the repair are there other things I should do as preventative while at the same time? I'm only adding a quart of oil even 1k or so which seems reasonable - runs pretty ok and I've just dropped $400 or so on the tie rods and a few hundred on the ignition switch.
What should I expect to face with head gasket replacement?
tx
thx for your answer-i was in a hurry and not thinking about pesky things like paragraphs haha but you are definately right.
i will try the things you suggested. a couple of notes though-
1. the car dos not crank at all. the response i get when turning either of the two keys is the same-nothing.
2. the car other than the water pump was fine/no problems whatsoever electrically or starting or anything until i got it back from the garage that switched the plugs to the champion double platinums and the water pump.
3. since the headlights are flickering and there is a loud random clicking noise in the dash that seems to coincide with the headlamps flickering i am wondering if it is an issue with a switch or relay maybe in the dash. could that be the source of the power drain from the battery when the car is not running?
4. i pulled the back seat up again and found the tube leading from the battery was not inserted into the place where it leads to the outside of the car. while that does not fix the starnge clicking and popping noise coming from the battery it definately fixes the odor (:
5. since the other car has to be revving in order to start my car, and the radio when shut off produces a whine through the speakers in sync with my engine while it is running, i am wondering if either a) the alternator is part of the problem or b) i have messed up the alternator by having jumped it a hunded times.
again all these issues just started when i got the car back from the garage. could it be that the process of replacing a water pump something is disconnected that might now be shorted out? or could it be that perhaps (since i was already told that they desperately needed replaced) that the plug wiring is shorting out something somewhere and that is causing the power drain? thanks everyone for you help-these definately are great cars and i will be thrilled to get mine back to flying down the highways of southern indiana! haha
As sinatra2 said, the cause of the lights flashing/relay clicking IS the multifunction switch.
http://www.howardm.net/dred98/switchfix.php is the URL you need to visit. Do that, let the battery charge up, take your car in to get the plugs and wires replaced with the right parts, and THEN let us know if the starting problem is still occurring. As sinatra2 said, it's possible that the drain from the flashing lights has killed your battery. This happened to mine.
Regarding the whine from the radio, I suspect interference from the plug wires. Again, have those re-replaced and see if the radio problem continues to occur.
Hope this helps,
--Robert
A great resource on the NorthStar engines (including the Aurora V-8) can be found here:
http://www.babcox.com/editorial/us/us100232.htm
Particularly, this section:
"If you have to pull a cylinder head on a 1993-'99 4.0L or 4.6L Northstar V8 to replace a gasket or do a valve job, do not reuse the old 11mm head bolts. Also, GM has revised the head bolt torque values and tightening procedure as follows:
In sequence, torque all bolts to 30 ft.-lbs.
In sequence, rotate all bolts an additional 70°.
In sequence, rotate all bolts an additional 60°.
In sequence, rotate all bolts another 60°.
Torque the front three M6 head bolts to 106 in.-lbs.
Because the Northstar V8s are aluminum, thread damage is not unusual. GM's recommended thread repair kit is J42385-500 for main and head bolts, and J42385-2000 for other fasteners."
Hope this helps,
--Robert
Sorry I couldn't be more specific (I'd check my Aurora but it's in storage until October :-(
--Robert
Lets see - can you describe the noise a little better?
I had what I think may be a similar sounding problem with my 97 a few years ago. As I would accelerate while getting on the highway (slight right turn) I would get a noise and a feel at the same time, like something was rubbing, almost grinding; not all that loud though. It turned out to be the left side tranny mount (you can see it through the driver's front wheel opening). This problem is kinda' coming back now but I know it is because I need a rear tranny mount.
Is this the sound/feel you have too?
they think though that the alt and battery will fix everything-we shall see i guess.
--Robert
a quick check for the fuel pressure regulator which is locacted on the fuel rail under the silver engine cover is to unplug the vacuum hose and if fuel comes out you need to replace...........
Joe in Phoenix
Best Regards
Regarding tranny fluid flushes/maintenance, if this is your problem, your not changing the fluid out probably didn't have any input as to why this happened. Nevertheless, my car, at 95k miles (bought it 4 years ago with 27k) has had the tranny fluid flushed 3x - before I bought it, around 51k miles, and again right at 95k before I stored the car (I drive a GTO for 6-7 months in the summer, then the Aurora during the winter months here in Wisconsin). You'll never see the tranny fluid drop below 100 to 99%, but that doesn't mean you shouldn't change it periodically (as well as the trans filter) - if there's metal in there, or the fluid is shot, you will shorten the life of your tranny by not performing this regular maintenance.
Ditto things like plugs and wires, and coolant flushes. People hear "100 k miles" and then wonder why their car is missing when they only have 75-80k miles on it. Or their coolant tank is filled with goo. Not to put money into the dealer's pocket, but sometimes these things need to be changed (I've had 2 coolant flushes as well, and the plugs and wires changed at 80k - made a huge difference). I see so many people with bad plugs/wires posting here... if only they tested the wires, or pulled a plug and looked at how bad it was, they'd know...
--Robert
maintenance stickler on all of his vehicles
Hope this info helps,
Jim
so one more time THX HAMMEN2
5.0v with load.
Ok, so now what? How long should these HUGE batteries last? How can I tell if it is the original battery? What do I replace it with, another Delco? How much are those? Thanks guys!!
paul
If the battery is original, you got your money's worth. My original battery carried a catalog number of 681. The replacement was 76-84.
The original battery in my '97 (Sept, 1996 build) died in November 2001. At that time I could not find any replacement other than ACDelco because of the venting provisions. Five to six years is about the most you can expect, even given the benign environment under the rear seat.
You are right about the size -- at 55 pounds, it is the heaviest car battery sold by ACDelco. It is the same size as the battery in my 1970 4-4-2.
Some people have reported success using gelled electrolyte replacements (I do not remember the brand name). I think there may be some (minor) issues with cable connections. Also, these gel batteries may be lower CCA rating than the original (970 amps).
I paid $110+tax at an ACDelco distributor; I think list was $130 to $140. I installed it myself.
Hope this helps.
Les
It is very common for Northstar engines to exhibit high oil consumption. Google "Northstar oil consumption" and you will get plenty of hits. One of the suspected reasons for the high oil consumption is aggressive honing of the cylinder bores during manufacture.
My factory service manual states that "normal" consumption is up to 2 quarts in 2000 miles. Your experience of 4 liters in 5000km exceeds this figure. My '97 uses about 1 qt per 1300 miles. It has been fairly consistent from 37,000 miles on the odometer when I bought the car to now (122,000 miles). I maintain the oil level at 1/2 qt below full on the dipstick (reading that dipstick is another story). Evidence is that the Aurora Classic dipsticks are not calibrated correctly and that full on the dipstick is actually overfilling the oil pan, contributing to excess consumption.
GM does have a service bulletin describing a very complicated cure(?). I think most of us have decided to live with the problem. It's much cheaper to buy the extra oil (even synthetic) than to maybe fix the problem. I had been very concerned that the condition would worsen with miles and my Classic would turn into a mosquito fogger, but so far that does not seem to be the case. Knock on wood.
Hope this helps.
Les
This was an $1800 repair, which required the engine and tranny to be dropped, the block split and re-sealed. Very common failure on Northstars... was supposed to be fixed by the '98 model year, but my early-build '98 had this issue regardless. Thank goodness for my extended warranty :-)
--Robert
--Robert
happy he owns a '98 :-)
FYI,
--Robert
I have a 96 Aurora, which was "given" to me by my Mom (I'm 38, but hey....gotta love those moms). The car has 95,000 miles and was bought new by my parents. Of course it was given to me in immaculate condition. Well, needless to say, as soon as I get it...
1. Driver's side window no longer works---I am guessing it's the window lift motor. This came on gradually...slow operation, then it finally died. If this sounds familiar to anyone, let me know if I'm on the right track. I can replace this myself, as I am pretty handy. I haven't pulled the door yet, so maybe it's just a loose connection.
2. This next problem is just plain weird. My Bose radio has been fantastic, until today. I no longer have any SOUND ! Everything that I can see on the faceplate of the radio seems fine. I can scan channels, switch from radio to CD, etc.. just no sound. I have fooled with all the knobs to see if I'm just a dummy, but still nothing. Someone help please... (and no, I'm not blonde...).
3. I too have the whine....I read that many of you do.
4. Radiator problems, problems, problems. My mom had this inspected over and over, they claim there is no leak. Well, yes there is. I have to add coolant once a week. There is corrosion on the left side of the radiator. But the service guys say no leak. Anyone had similar problems?
Whew...sorry this is so long. I am hoping that other owners can give me some guidance. Thank you all so much!
If you don't have the service manuals, http://www.alldatadiy.com is a web site that you can subscribe to that has online manuals, TSB's, et. al.
Hope this helps,
--Robert
1) Probably is the window regulator. I've seen them go on other GM cars of this vintage, not had this experience with my Aurora. I was having issues with windows not going down when the master (driver's side door) switch was used, but the actual individual window switches worked. Had to have the quad switch on the door replaced.
2) I would pull the head unit and re-seat the connections... also double-check the subwoofer/bass shelf in the back.
3) whine? What whine? I'm pretty familiar with common Aurora problems, but I've not heard of any whining issues.
4) Sure you don't have a head gasket problem? If you're not seeing leaks under the car, then the coolant has to be going somewhere. Green or orange/red (Dexcool) coolant? I would have the system flushed and switch to DexCool. Not to say I haven't heard of problems wih the plastic radiators on the Classics...
--Robert
