Toyota Tundra Accessories and Modifications
farmguy2001
Member Posts: 5
I am trying to find a source for getting a quad cab Tundra 4X4 modified to add a camper-type shell to bed that is tied together with cab so there is internal access between cab and bed. The goal is to get a hybrid vehicle with interior similar to Sequoia SUV but with utility of the pickup bed of the Tundra.
- Paul
They stick out of each side, fairly noticeable, especially when clean.
A mid range sound. I don't know the actual number (i.e. 40's, 70's). Not obnoxious, but they sound healthy.
I think they mean more to people that really know cars than to me. I'm just learning and am enjoying this expensive, creative process.
I don't have keyless entry but that comes with the security system. You get two remotes. I purchased my truck through an auto broker and got the one that had most of the options I wanted. It came from our local Toyota dealer. I get a better deal from the broker. Just bought my wife a 2002 RAV4 from the same broker. Originally I was going to have the dealer put the security system and the tow hitch on. The broker made it part of the deal and I was going to get both items at dealer cost. The night before I got the truck I found I could get the security system and install it myself and a tow hitch is much cheaper from many other places that a Toyota dealer. Nixed these two items from my order and my monthly payment went down $16 a month. One thing to note. Your truck must have power door locks in order to be able to use the security system. If you look on a window sticker the RS3200 security system is $499. I think $199 and a little bit of labor on my part is a good deal. The kit comes with instructions and everything is plug in. No soldering and hopefully no drilling. The kit even includes tie wraps.
Wasn't sure if your taco was the same; sounds like not, but just wanted to mention that cause you might get off cheaper!
Thanks for any help offered.
96, 2wd, std cab, 2.4L, 4 cyl., manual tranny
and somehow magically very fast.
I want to make it faster
Really, I'd just like to get a clearer understanding of these things. People speak of them on this board from the position of knowledge, so I have yet to put it all together.
Thank you,
Alex
http://www.howstuffworks.com/turbo.htm
You can add an s/c or turbo to your truck, but not sure if anyone sells a bolt on kit for your make. You may need to custom fabricate the mounting brackets, plumbing, etc. That would be $$$.
Thank you,
Yosmany
How can I disable my headlights that are always on. Would like them to be turned off when hunrting, etc.
My rig does not have the limited slip rear-end which came out on the 2002. Can I retrofit this as a option for my truck, Is it worth it?
Dick
www.tundrasolutions.com
There's a forum for both Tacos and Tundra's, but mainly for Tundras. You'll have to register on the site to become a "registered" member which will give you access to the forums. To access the archived "how to" section, you'll have to be a club (paid) member. But asking questions and browsing the open forum is free; you may find answers to your questions that way.
This is an offroad club, you can ask about lift kits and all other info.
In short:
Cornbred spacer lift (one of TTORA members, he makes his own lift kits): by far the cheapest, 1-3" of lift, front only. He can sell you an AAL (add-a-leaf) for the rear with shocks for nearly store price.
RevTek lift: 2-3" I think. Expensive.
Rancho lift: 4" lift....it's expensive, but it's better than CB lift, for example.
Trailmaster lift: 6" lift kit, the most expensive kit.
Those are suspension lifts.
For body lifts, you can get a Performance Accessories kit for $150.
You need 3" suspension lift to clear 32x11.5 tires, and 6" of lift to clear 33s: by that I mean that you will be able to run around without rubbing (even with 6" your 33s may rub some) on the street and offroad.
As far as charger goes: $2.5K for the standard V6 TRD charger that'll give you 265 hp. You can ask about various other performance mods like headers on the board.
Also, Should I make any additional adjustments beyond the supercharger, such as an exhuast or is it ok to just add and the supercharger and leave it alone at 265 hp?
Thanks a lot!
1. AAL.
2. New shackles.
3. New leafpacks (like Old Man Emu ones).
As far as charger goes, I think it's 265hp with just the charger. If you want to be sure, check www.tacomaterritory.com and ask in our forums. I don't remember whether 265hp is just the charger, or the charger with headers/exaust.
Also, I'd like to add the fender flares that are on the 4wd models. I asked one dealer, and he thought that they wouldn't fit a 2wd truck. Anyone tried this?
Dan
As for the fender flares, the sheet-metal for the 4WD models is different to accomidate the larger wheels and tires than the 2WD models excluding the pre-runner. Fender flares for the 4wd model will not fit correctly on the 2wd model. However, similarly, there are alot of aftermarket catalogs available that you should be able to find fender flares for your 2wd truck.
Extang, SportsMaster(one I have), should all work for you.
Shell would be nice if you can get it on nice and tight, and in fact it'll provide much-needed weight in the bed to level the truck. If you can get it water-tight to the bed, it's good.
You will notice a huge difference.
Just buy or borrow a long wrench, take the tension off, remove the old belt, and put the new one on. Simple.
I would recommend a goodyear gatorback belt (ask your part store guy) since they are said to be quieter and long lasting.
B
Once I figured out how to take the dash apart, it was a simple "plug & play" installation. It sounds good, works great, and looks like a factory installed option. A nice, inexpensive upgrade that will pay for itself in resale value.
If anyone out there is interested in the installation details, I could elaborate.
-james
If you're like me, you like to: (1) get in your truck, (2) start the engine, (3) put on your seatbelt (while the engine gets its oil up to pressure & circulating), then (4) drive off. The problem is that the "idiot-chime" will be reminding you to fasten your seatbelt in between (3) and (4).
For those people who don't need to be reminded, there is an easy solution. Beneath the drivers seat there is a 2-wire connector. Disconnect it and, voila!!... no more seatbelt warning chime. The chime will still remind you if your lights are on or key is in the ignition.
Warning - possible connection between that wire and the airbag system... I don't think so, but use at your own risk.
-james
Wondering if you could describe how you got the dash apart to replace the radio. We now have a spare stereo/cd from an '02 Highlander that looks like it will fit but I don't know how to take the dash apart. The truck is a '99 Prerunner but I'd bet its similar to your '96 LX. Any info you could pass on would be appreciated.
The center dash unit (on my truck) is held in place at 6 points: two screws in the center (behind the climate control panel), two "pop-out" fasteners on top, and two "hook tabs" on the bottom.
1) remove the knobs from the heater controls (put in a safe place).
2) My truck has slide-type heater controls. Yours may be rotary, so this might be slightly different. Using a small, flat-blade screw driver or pocket knife, carefully pry up the climate control cover panel. 2 screws should be revealed. Remove and lay aside.
3) pry the right top corner of the center assembly out. It should pop loose. (I actually removed the glove box and pushed it loose from behind, but that is unnecessary). Pull the other top corner loose.
4) if you have in-dash cupholders, pull them out to the extended position, then tip the entire assembly forward and lift up. There may be electrical connections tying the unit to the dash. Disconnect (squeeze-pull) and lay aside.
5) remove the 4 screws retaining the radio unit. I don't recall if the are Phillips or hex-head (maybe 8mm). Slide the unit out and unplug the 2 multi-connectors and antenna lead. The antenna is a tight fit, but it pulls out. Twist as you pull - may help.
In my installation, the mounting brackets on the replacement radio didn't fit. I removed the brackets from the old radio and they fit PERFECTLY on the new one. Plug in the connectors, test the radio (make sure it works properly), and screw everything back together.
Good Luck !!! Let me know how it works out.
-james
Thanks again for the dash removal instructions. They were right on - at least as far we got. Once we found the screws we decided it would be worth measuring before going any further(should have started with that anyway). Turns out the Highlander head unit (radio, cd and cassetter) is about 3/4" too wide. But, it we find something that will fit at least we know to get into the dash now. Thanks again!
MSRP 22015...option package 2979 ..Total
$25,504...Invoice with option total $22,703...True market value on Edmunds is $23,435. Right now with 2000 rebate...should I minus $2000 of $25,504 or minus $23,435???
PLEASE give me some advice. Very appreciate it.
How much should I offer ?
