Subaru Legacy/Outback Wagons Maintenance & Repair
12829313334170
    70 ft-lbs is definitely within the stock torque range for those lugs.
    -juice
    tfoshbonetfoshbone Member Posts: 18
    What are the tell tail signs of hg failure (before it's too late) ?? if there any other than oil in water or water in oil or white clouds trailing you thanks T
    leo2633leo2633 Member Posts: 589
    The torque range for the lug nuts on the Outback and Forester is 58-72 ft. lbs., as per the owner's manual.
    Len
    rob999rob999 Member Posts: 233
    IIRC, readers here have reported HG failure from the coolant jacket outward, meaning you might not see coolant in the oil and vice versa. Watch for coolant puddles under engine, high temp on guage and strong, hot coolant smell when walking around car.
    Drive up on ramps and climb under. Check the bottom of the block for oil stains near the gaskets. Also check the front and rear of the block.
    The good news is if you have less than 60k miles, it's covered under warranty. If you have more than 60k, and they haven't failed already, they probably never will.
    Plus, you can change the seals when you do the timing belt. You usually get a one year warranty on service work, so again you're covered a little longer.
    -juice
    otis123otis123 Member Posts: 439
    AC smells a little funky/musty/dry leafy when first started, but then goes away after a couple minutes. Any way to spray Lysol or something else somewhere to freshen it up? Other suggestions?
    Ralph
    Haven't tried it myself, but I heard you can spary Lysol at the intake point under the wipers.
    Also, change your interior air filter if you haven't done so in the last year.
    -juice
    zman3zman3 Member Posts: 857
    I thought someone else recommended running the fan with the A/C off for a minute or so after you stop to clear out any moisture. I have been known to be wrong however.
    beach2beach2 Member Posts: 6
    idahodoug and all, thanks for the advice on how to remedy the wet floors of my outback wagon. i have an appointment at the dealer to have them check it out. in the mean time, i got underneath and did notice the black plastic plugs but was hesitant to pop them out for fear of breaking them. when i pull gently on the plastic rocker panel though, LOTS of water starts pouring out. i'm sure what idahodoug described is exactly what is happening with my wagon. my one question is this; should i be worried about premature rusting because that water has been trapped in there for lord knows how long?
    Try dropping some baking powder in there, just like you do in the fridge.
    -mike
    Do they all have interior air filters? If so where are they? Thanks. T
    Behind or under the glove box. It was optional, so you may or may not have it. The installer was *supposed* to put a sticker on your door jamb with the date of the last filter change, but may have forgotten.
    -juice
    larryinohiolarryinohio Member Posts: 2
    I've had trouble with the engine starting, especially after a wet spell. Sometimes can take up to ten minutes to start and will smell like turpentine once it does start. All of this continues to happen after a major 120,000 service costing way too much! Also the engine wants to speed up and slow down with the RPM jumping all over the place, This can happen sitting still or driving. even more disturbing, sometimes when driving it seems to want to stick in third gear (this car is an automatic). I've had no luck with any of the subaru people so thought I'd post this and see what the "real minds" think. This is our fourth subaru in the last twenty years and never had any of these problems. But this is the first automatic. Thanks, Larry
    nygregnygreg Member Posts: 1,936
    What did they do during that service? Sounds strange that it began after they worked on it. I wonder if they didn't connect one of the spark plug wires or broke one. What kind of plugs did they use? Maybe a vacuum leak or the air filter canister was not installed properly when they changed the air filter.
    Greg
    mjansen1mjansen1 Member Posts: 46
    After sitting about 20 min. with the AC on in 85 degree weather, my 2000 Outback was "sluggish". At first I was turning and I thought something was up with the AWD but then when driving straight, it tried to stall on me. Any comments? Thanks
    grahampetersgrahampeters Member Posts: 1,786
    G'day
    The Engine Management Unit is adaptive, modifying its fuel and spark maping depending on the use of the vehicle recently. This is measured over about twnety minutes with greatest weighting toward most recent behaviour.
    If the car has been idling for a sustained period, it has likely leaned out. To correct this, accelerate hard through the gears. This modifies ECU mapping rapidly.
    Cheers
    Graham
    wmiller4wmiller4 Member Posts: 97
    Do this at your own risk but, it absolutely works at getting rid of the AC smell! Turn on AC, fan on high, open car windows, and ensure the AC recirc button is not on. Spray Lysol in the fresh air intake right under the driver windshield wiper.
    I did this to my wife's Honda Accord and it worked! The one draw back is the over powering smell of Lysol. It does go away after awhile. Plus the Lysol kills the bacteria and mold causing the smelly problem.
    To help keep the smell from returning too quickly,remember to shut off the AC a few minutes before you reach your destination leaving your fan on high to "dry" the moisture in the AC system.
    junkherjunkher Member Posts: 27
    We have had a similar problem with our "Park-It-Outback". My wife and I have come up with this cheery name 'cause both of us hate to drive it because it is so god awfull noisy. I think the only quiet thing is the quartz clock. ANYWAY -
    This bouncing rpm thing was tracked down to a computer problem.
    Ours not only reved up and down by itself but would literally take off by itself. If you did not have your foot on the brake, LOOK OUT!
    Well, According to Subaru, the FUEL TRIM sensor ( one for high trim, one for low) has been out of whack on my particular vehicle. It SHOULD turn on the engine light I am told, but for some reason does not. When the low trim is out of adjustment, it screws up the fuel injection giving to little fuel. The computer senses a dying motor and tries to correct by giving it more fuel, whalla- takes off rapidly by itself! Scary as hell when it does it too! It is very likely a similar problem where the computer keeps manipulating the fuel injection.
    Didn't you post the same "problem" and found solution about 1.5 months ago??
    francophilefrancophile Member Posts: 667
    nygreg, are you thinking that someone with a moniker of "junkher" might be here trolling for arguments? Gee whiz, maybe so :-)
    When I read stuff like that, especially stuff like the bit about the car "taking off by itself", I figure this is someone who either knows absolutely NOTHING about driving a car or else someone who is trying to set up a lame-brained lawsuit and is fishing for stories to feed their lawyer. In any case it is not someone whose words carry any weight with me.
    rgds,
    -wdb
    sorry folks, dont be turds...
    I did not post it here, I DID post it elsewhere. Take a pill and mellow out - I am not looking for going after a lawsuit . In case you didnt notice, this IS a Q/A section.
    Am I a SUB lover, ( not in the least, I hate ours - no secrets here ). Is this a necessary function to LIKE the vehicle that you are talking about?
    I am GLAD you like your car.... Buy more of them!
    Others may actually be helped by the solution the mechanics found wrong with my car and the fuel/computer problem with unsteady RPM's. The mechanics at the dealership did an absolutely fantastic job in locating a difficult problem to find. MOST mechanics think in the ( No engine light - No problem ) realm. This was NOT the case with my local Subaru dealer. They appear to be a great crew...... They spent the time and actually found the problem. It is not the way of most dealerships.
    Before the car would barely pull its own weight. It now flies up mtn roads with no problem.
       Kudos to good mechanics!
    For those with car computer brains, WHY or HOW does one computer differ from another in its programming from the factory - Is it faulty sensor information?
    babaorileybabaoriley Member Posts: 74
    WARNING, long post:
    After 44K miles, my OB has a problem. During a drive yesterday, it would hesitate and shudder under hard acceleration. Light to moderate acceleration and all other conditions were normal. Later in the drive, at a stop (idle speed) for more than fifteen seconds there would be a buck or two, followed by a rough start. Everything would smooth out very shortly followed by normal engine response, except under hard acceleration. My fuel level was low and I suspected bad gas, so I filled up with 76 regular, making sure the gas cap was on tight. The rest of the trip exhibited the same conditions.
    On my return trip, all seemed normal for about forty miles, then I decided to test the hard acceleration starting from about 30 MPH on an uphill after a toll plaza, and the shuddering and bucking came back bad and the Check Engine light came on and stayed on.
    I drove it the remaining 30 miles home, following the handbooks' suggestions of not driving hard, towing, etc. and took it to the dealer this morning. Before I took it I checked the air filter and all fluid levels. Everything was OK.
    Anyone have any suggestions as to what this may be before the dealer calls back? The first thing the dealer asked was if I wanted the 45K service done, when I declined he stated he may not be able to get to my car today because I don't have an app't. I dislike this treatment, but need to know what's wrong with my OB.
    TIA, Brett
    Typically, when someone has a problem they stay focused on discussing the problem. When that person starts with calling it a "Park-it-Outback" and goes on how they hate the car, well, you start to get suspicious. Your e-mail reads almost, if not exactly, as your earlier one. The problem was solved and I thought it was good input for all of us to learn from. I appreciated that. As I read it now, you were responding to another post. So now that you've been driving it for a while, how do you like it?
    Greg
    Sounds very similar to what happened to my '00 Legacy at similar mileage. It would come and go at first, but it got worse over time. The dealer wound up replacing the plug wires, coil, and one fuel injector, to the tune of $455.
    rgds,
    -wdb
    canyuntrashcanyuntrash Member Posts: 7
    I'm new here, so pardon any repeats on my part... haven't had time to explore all the messages.
    My 02 Bean has been great, 'cept for a recurring problem with the brakes wearing fast and rotor warp. Dealer has me thinking it's my "driving habits" and says I need to go with after market "racing" (guessing slotted/drilled) rotors. They replaced pads and turned rotors at about 17K saying Subaru "allows" one fix like this under warranty. But, at 31K, they replaced the pads and turned the rotors without my even my asking. Now, at 35K, the shimmy returns....
    So wassup? Are the stock rotors junk? Is the dealer giving me a story? I've heard other owners getting new rotors under warranty.... any comments?
    Wind noise: this is a classic. First problem was my door panel kept coming loose at the bottom edge and the rubber seal would hang out. After three trips to the dealer ( the first two they just pounded the panel back on and said I shut the door too hard) they finally ordered a new panel. Unfortunately, it didn't match the Bean interior, but the wrench and I used the new rubber and clips on my old panel. Viola! never had floppy panel problem again.
    But... then a nice wind hiss developed near the front of driver's window near the mirror post. Again, after more than 4 visits, they finally replaced the upper rubber seal. That problem is gone, but now a new wind noise is coming from just below where my left shoulder is. ARRRGH!
    Again... wassup wit dis s---? Think mebbe the door is warped? Anyone else experience this rig-a-ma-role?
    This is my third Subie, but I'm losing my patience.
    The only thing that keeps me hanging on was getting to sneak preview the 05 OB totally redesigned body and interior style... yes, I got to touch it and sit in it too. Very sweet! Needless to say, if the dealer and SoA treat me right, I'll be doin the trade-in as soon as it comes out.
    jlemolejlemole Member Posts: 345
    Warped rotors have been a hot topic here lately. I think the general consensus is that the OEM rotors are not that great (my rotors are now showing signs of warping at 21k). Since you've had them turned twice and you are still under 36k, I would insist that they replace the rotors under warranty. I also think you should try another dealer if your current one's answer is to replace them with expensive aftermarket racing rotors.
    If you must replace them on your own dime, I don't think you need slotted or drilled rotors. There are very good basic rotors (i.e., Brembo). They're more money that OEM, but not nearly as expensive as slotted or drilled.
    Always make sure that tire lugs are hand-torqued to approx 72 ft-lbs to avoid one possible cause of rotor warpage.
    Good luck and let us know how you make out.
    Jon
    02 OBW
    I just re-read your post. You can't tell us you got to sit in the 05 Outback without giving us some details! Give us the goods.
    I have a MY '00 Legacy GT and I like to drive around corners in a spirited manner, which is to say that I use the brakes harder than maybe most people. However I also know how to use brakes without abusing them. My opinion is that the stock Legacy rotors are really only okay for casual use and will warp prematurely with spirited use or misuse. I have had the rotors cut twice, once at 27K miles and again at 52K miles. Considering the way I drive and how I use the brakes I do not consider this to be excessive, however it is perhaps a bit disappointing.
    The first time they were cut was under warranty, and the dealer cut all 4 rotors.
    The second time was during front brake pad replacement; the rotors had actually been warped for some time but not so badly that I felt the need to cut them before the brake replacement. If I had still been under warranty I would have tried to get Subaru to cough up a new set of rotors.
    When the time comes for new rotors I will replace them with something like Brembos. I will probably just get regular smooth finish, although I might get slotted rotors because they are supposed to provide more immediate stopping power in wet conditions. I will not get drilled rotors; from what I have read and learned those are for racing and provide virtually no benefit under normal use.
    rgds,
    -wdb
    vetmatsvetmats Member Posts: 71
    I had the same problem at around 63,000. I had my car into the dealer twice, the first time they couldn't find anything wrong, the second time they replaced one fuel injector. Then, the car started stuttering and losing power on a road trip. I ended up having to get the car towed to the nearest Subaru Dealer. That dealer found out that I hadn't changed my fuel filter in a long time. The crud in the fuel filter had gotten loose and ended up in the fuel injectors. I had to get all four fuel injectors replaced.
    After my experience, I would recommend that you ask the dealer to check your fuel filter, if it hasn't been changed in a while. The dealer said I should get it replaced every 15K from now on.
    If the fuel filter is not changed regularly, eventually it may clog with material, which means that not enough fuel will be able to pass through it. What will happen is that the engine will starve for fuel, which may manifest itself as stuttering, among other things. What will NOT happen is that the filter will suddenly allow a bunch of junk through. Old fuel filters do NOT suddenly fail to filter the fuel.
    rgds,
    -wdb
    with Franco.
    Greg
    Nothing but gas will get through the filter...
    LLBean - front rotors turned at 10k and front rotors and front pads replaced at 22K. Still fine at 44K - either original rotors were defective (according to dealer) or the alloys were torqued too high at factory. Will never know...
    Check out those Forester crash stats released today (6/17/03) at the Insurance Institute site - blew away the competition! Can't wait for the 2005 Outback with curtain bags!!!! How about knee bags, too, Subaru??!!
    Ralph
    declansdaddeclansdad Member Posts: 120
    I had this same problem with my wife's '96 Integra. The dealer tore the car apart but could not find anything wrong. They couldn't even pull up any codes--they chalked it up to a bad batch of gasoline. I was very skeptical to believe their explanation; but since then, I've not had the problem return.
    Maybe try adding some octane boost and fill up at a different gas station next time. Hope this helps and good luck.
    Michael
    Wind noise -
    If you look at the passenger door how it closes, you will notice the glass does not strike as high on the window seal as it does on the drivers side. Try this - Hold the door latch open on the passenger side and close the door several times and watch how the window hits the door seal near the top
    ( latch side ). Repeat this on the drivers side and compare how it seats. You will undoubtably notice they are NOT the same. I looked through the lot locally and found every window on the drivers side -Outback ( Beans too ) are not aligned correctly on the drivers door. Once the window is aligned correctly on the track - whalla - noise dissapears and the door closes correctly. ( The window hits to high from the factory - on the latch side-top corner - ).
    I have heard of others placing rubber tubing under the door seal. Adding tubing under the seal is not necessary once the window is placed in the window track correctly.
    As I have come to find out, these cars are not exactly "free from wind noise" even when you fix the window correctly.
    Thanks for all the replies.
    I did change the fuel filter at 30K, but it is almost 15K more and will probably change again.
    I originally thought bad gas and filled up (added 12 gallons) of Union 76 during the trip. I was then going to add dry fuel, octane boost and reset the ECU to see if the hard acceleration stuttering went away after I got home, but when the CE light came on and stayed on, my wife got paranoid and so I took it to the dealer more for her benefit.
    I'm still awaiting their diagnosis.
    -Brett
    outbikeoutbike Member Posts: 6
    Hello All -
    Need some quick advice - went to a Valvoline Quick change to get the oil changed in my 96OB w/ 2.5L AT. They claimed to have filled it w/ 4.5qts, however, when I check the oil, the line is well above the full mark (in fact, I have a hard time discerning where the fill line is). Be assured that I have checked the level after letting the car sit overnight on a level surface. My question is this: should I be concerned about potential engine damage if the engine is over filled by .2-.3qt? Should I return to Valvoline and have them drain and refill the engine. I have 117K on the car and I need it go at least another 83K more (hopefully). Appreciate your input and thoughts!
    Outbike
    Why would an old fuel filter still not allow junk through it? My problem manifested itself over 2 months, so it didn't really happen all of a sudden, just got gradually worse.
    Maybe the dealer did screw me. Unfortunately, my car was stuck at an out-of-town dealer, and I didn't have much choice.
    Maybe someone here could have a better suggestion for the cause of the problems that my outback had.
    1. It started last December, with a check engine light. Took the car to a dealer, code was "Misfire on Cylinder 4". Dealer couldn't find problem, reset code.
    2. Again in January. Check Engine light came on, car ran a little rough. Took it to the same dealer. Same code. This time, replaced fuel injector on Cylinder 4.
    3. Road trip in February. Car gradually started stuttering worse and worse, losing power gradually as well. Got the car towed to the closest (a different) dealer. This dealer claimed that all four fuel injectors were clogged and that they needed to be replaced along with my fuel filter. He took out a couple of the injectors, knocked them upside down on the counter, and showed me the junk that came out.
    My car has ran fine since this last dealer trip. Seeing how all four injectors were clogged, I assumed that the main problem was that I had waited too long to replace my fuel filter.
    Does anyone else have another explanation for this problem? Or some sort of preventative maintenance to prevent this from happening again?
    fibber2fibber2 Member Posts: 3,786
    1) >>The dealer wound up replacing the plug wires, coil, and one fuel injector, to the tune of $455.>>
    An '00 OB with moderate mileage should still be covered by the EPA warranty. Poor driveability is often accompanied by an increase in emissions. Items like plugs and filters are owners responsibility. But you should be able to make a good case for a CEL caused by early failure of wires, coil & a single defective injector.
    2) <<Fuel filters don't fail.>>
    True - usually they clog and restrict. But there are documented cases of filter blowout. One of the car magazines discussed this some years back. Tiny metal particles can enter the tank when you fuel up, usually from scraping between the pump nozzle and the 'unleaded restrictor' at your fill port. Ever notice how damaged those nozzles look? As the filter clogs back pressure rises, forcing those metal particles against the cellulose filter medium, eventually puncturing it. The raised pressure at the small breakthru bursts the dam, letting all of the junk thru at once. Remedy: Care when fueling, and change the filter occasionally!
    Steve
    jasong2jasong2 Member Posts: 18
    My wife has a 2000 Outback. For the past 1-2 months, she has been having problems with it stalling and idling/driving roughly and the "Check Engine" light comes on.
    We have had a lot of rain, so I tried dry gas. That seemed to work for a few days and the "check engine" light went off. Problem started again, so I tried fuel injector cleaner. Again, problem went away for about 4-5 days. Now the problem is back and seems to coincide with rainy weather. Is there a connection? What else could it be? We did just have a tune-up and 36K maintenance performed in April. Thank you! - Jason
    Did the dry gas / injector cleaner fix the problem, or did sunshine??? Rainy weather can affect a few systems that may be related to your problems:
    1) Electrical leakages. This is often seen on the high voltage ignition side of the system, but could also be an issue on the 12v side as well. Leakage on HV typically reduces spark output, but could also cause 'crosstalk' where the wires meet at the coil (mounted on top near the air filter). These do not use a mechanical distributor, so you can eliminate that. On the 12v side, leakages can attenuate or slow signals that are collected and fed to the ECU. For instance, replacing the distributor is a crank and cam optical sensor. A reduced or delayed signal could change spark timing. It get worse, becaused the poorly burned fuel will be detected by the O2 sensor, which then begins to fiddle with the mixture. A bad cycle is set up.
    Cool/rainy weather could be promoting tank condensation, which the gas dryer could be fixing. Cool, moist air burns a bit differently, requiring a slightly modified mixture. It is always possible that the O2 sensor might not be responding properly and is 'skewed' more often on damp days.
    Hope these help..
    Steve
    originalbitmanoriginalbitman Member Posts: 920
    Outbike - I would be concerned. Had the same problem after an oil change at the dealer. Took it back and service manager confirmed it was overfilled. Mehcanic (tech?) was POed and reluctantly drained it to the correct level. Bottom line: should be drained off. I would do it myself if I were you.
    bit
    G'day
    Not good news really. It has an immediate effect in performance drop and fuel economy loss - about 15% when it happened to me. Drove me to change dealers
    I gather it can also have long term impact if not corrected although I think it would need to be a really big overfill to do this.
    Cheers
    Graham
    jfljfl Member Posts: 1,396
    A Fumoto valve would make it really easy to drain out a bit of oil to adjust the level. It also makes oil changes a breeze.
    Jim
    Recently, I've been noticing a definite ticking (or tapping?) noise from the engine of my 02 Outback wagon (2.5l; 21k miles). It gets faster when I accelerate, but at idle it's not a constant ticking. Rather you'll hear three ticks, then a delay, then three ticks, delay, etc. Funny thing is that it's not always there either. It seems to occur on warm days, or when I've been making repeated short trips, turning the car on and off, etc. It doesn't seem to be there in the morning, or if the motor is cold when started. Can anyone venture a diagnosis?
    Jon
    Definitely get it drained. Even more importantly, make SURE they drained the oil from the ENGINE. I've heard tales about techs at oil change centers draining the transmission oil instead of the engine oil, then adding new oil to the engine -- the result being 2x the oil in the engine and NO oil in the tranny!
    Good luck,
    -wdb
    IIRC, the oil capacity is 4.6 quarts on the 2.5 engine.
    The last few times I've changed my oil and filter I've paid keen attention to not putting in too much oil, even using a measuring cup to dole out the final 0.6 quart after putting in the first 4 quarts straight from the bottles. The last time I even measured out only about 0.3 quart.
    However, despite my precautions the oil dipstick reads high, indicating an overfill. WHat gives? Does anyone have a similar experience?
    Oil change on the 2.5L requires 4.2 quarts. On my OB, when I add this amount and check it on a level surface the dip stick reads right on.
    Greg
    amsbearamsbear Member Posts: 147
    My owners manual for my 98 OBW Ltd states:
    2.5L = 4.7 U.S. Quarts
    2.2L = 4.2 U.S. Quarts
    Alan
    hypovhypov Member Posts: 3,068
    2.5l DOHC = 4.7 US qt.
    2.5l SOHC = 4.2 US qt.
    Rob-
    If you have a SOHC then you're 0.4 US qt over.
    -Dave
    4.2 quarts it is! I just re-checked the owners manual on my.subaru.com
    For the life of me I don't know where I got that 4.6 number I've been using. Thank goodness I've not had any side issues - at least that I know of! Thanks again.
